2013 Audi A1 DSG gearbox fault
Kam
United Kingdom
C?ID=41543
Audi A1 2013 Model
Hi I have a Audi A3 and have an issue with the Gearbox 7 speed DSG.
The gearbox itself has a mechanical breakdown and hence the selector lever is stuck. The TCM mechatronic unit seems fine.
However I am looking at replacing the Gearbox, which comes complete with new TCM/mechatronics unit, the question is does this vehicle need any security login or dealer level online coding? This is because I believe that the VIN and the possibility of Immobiliser information is stored in the TCM.
Auto scan Attached below
Wednesday,20,November,2019,14:49:19:32967
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 19.6.2.0 HEX-NET CB: 0.4508.4
VIN: WAUZZZ8X4DB082602 License Plate: KU13 MMO
Mileage: 109340km-67940mi Repair Order:
Chassis Type: 8X-AU21 (8U0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 62 72
VIN: WAUZZZ8X4DB082602 Mileage: 109340km-67940miles
Address 01: Engine (J623-CAXA) Labels:. 03C-906-016-CAX2.clb
Part No SW: 03C 906 016 DM HW: 03C 906 016 BG
Component: 1.4l R4/4V TS H11 7526
Revision: LEH11--- Serial number:
Coding: 00250032002401000000
Shop #: WSC 57361 001 1048576
ASAM Dataset: EV_ECM14TFS01103C906016DM 001009
ROD: EV_ECM14TFS01103C906016DM.rod
VCID: ED9241E83C11B927FC-80B8
Readiness: 1110 0101
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 060 E HW: 0AM 927 769 D
Component: GSG DSG AG7 431 5220
Revision: 00043014 Serial number: CU501301245247
Shop #: WSC 61773 001 1048576
VCID: AC148CEC0E8B702FAB-5160
001836 - Gear 1
P072C - 000 - Not Selectable - Intermittent
Mileage: 109340 km
Date: 2019.11.20
Time: 14:44:02
005949 - Position Sensor 4 for Gear Selector
P173D - 000 - Implausible Signal - Intermittent
Mileage: 109340 km
Date: 2019.11.20
Time: 14:44:24
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6R0 907 379 BR HW: 6R0 907 379 BA
Component: ESP9.0i front H02 0003
Serial number: --------------
Coding: 33DF488B432B02C2CC1A1269C25340951104
Shop #: WSC 00046 412 00000
ASAM Dataset: EV_Brake1ESP90iBOSCH 003031
ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
VCID: 8F6E3B6056DD2B37AE-80DA
Address 08: Auto HVAC Labels: None
Part No SW: 8X0 820 045 A HW: 8X0 820 045 A
Component: J255 Klima Manuell 0150
Revision: 0000708S Serial number: 03030018068685
Shop #: WSC 00046 000 00000
VCID: B424948CD7BB28EFF3-80E0
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 K HW: 8X0 907 063 K
Component: BCM PQ35 M 111 0715
Revision: AH111715
Coding: 0E000A2CA805F1C0201841E00100015443FB6C0A00EF4922DC0087830041
VCID: C4C4C44C471B986F43-8090
Subsystem 1 - Part No SW: 8U0 955 559 A HW: 8U0 955 559 A Labels: 8U0-955-559.CLB
Component: G397_RLS H06 0002
Serial number: 20106850
Coding: 02005D
Subsystem 2 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0020
02740 - Bulb for Tail Light 2; Left
Fault Status: 00101010
Reset counter: 225
Mileage: 109340 km
Date: 2019.11.20
Time: 14:37:33
Voltage: 14.40 V
Term 50 On
Address 10: Park/Steer Assist (J446) Labels:| 8X0-919-475.clb
Part No SW: 8X0 919 475 M HW: 8X0 919 475
Component: PARKHILFE 4K H03 0051
Revision: 11001001 Serial number: 37061302301775
Coding: 000101
ASAM Dataset: EV_EPHVA14AU21X0000 002005
ROD: EV_EPHVA14AU21X0000_002.rod
VCID: D0ECF81C8B6374CFF7-8084
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8X0 959 655 B HW: 8X0 959 655 B
Component: Airbag10.41 H05 0009
Revision: -------- Serial number: 003KZ0040WRZ
Coding: 30323236303230303138554A305238583053
ASAM Dataset: EV_Airba1041BPAAU210 001018
ROD: EV_Airba1041BPAAU210.rod
VCID: C9DAD57868394507B0-809C
Serial number: 3554VRB40044UOUE99PO
Serial number: 3575HRB405T1SJR2B9KF
Serial number: 3585HRB405L1SJR2BPUY
Rear Impact Crash Sensor:
Serial number: 3515ZRB40124UIV8819V
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 501 D HW: 5K0 953 569 H
Component: LENKS.MODUL 016 0140
Revision: FF010017 Serial number: 20130121201509
Coding: 1994204000
VCID: BB36BFB032E5E79732-80EE
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb-SRI1
Part No SW: 8X0 920 980 F HW: 8X0 920 980 F
Component: KOMBI_MEDIUM H03 0252
Coding: 41CE00
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04396
VCID: C2C8C254550F965F71-8096
1048578 - No Basic Setting
B2010 00 [009] - -
[Steuergerät keine oder falsche Grundeinstellung / Adaption]
Reset counter: 183
Mileage: 109330 km
Date: 2019.11.16
Time: 10:11:20
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8U0 907 468 G HW: 8U0 907 468 G
Component: GAT 4CAN 1L M H13 0059
Revision: 1P100034 Serial number: 3441P131230608
Coding: FBCF1064000100010353
VCID: C6C0DE447127AA7F5D-8092
Subsystem 1 - Part No SW: 8K0 915 181 L HW: 8K0 915 181 L
Component: J367-BDM H08 0181
Serial number: 00000000002040896420
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 121126000000000000E8
Component: IMMO H03 0252
Coding: 000002
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 H HW: 8X0 959 793 H
Component: TSG FA H10 0415
Coding: 011802201C01000000
VCID: D2E8F2148D6F06DFC1-8086
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11251
Shop #: WSC 00046
VCID: B02C989C77A314CF97-80E4
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 H HW: 8X0 959 792 H
Component: TSG BF H10 0415
Coding: 011802201E01000000
VCID: D1EAFD1888697DC7F8-8084
Part No SW: 8X0 035 183 F HW: 8X0 035 183 D
Component: RMC Cnct H53 0801
Coding: 01010400000053070023020103010000010000
VCID: BA38BAB435DFDE9F29-80EE
Subsystem 1 - Part No SW: 8X0 919 603 A HW: 8X0 919 603 A
Component: DU6 Basic H43 0084
Serial number: 9462AP0D2626206
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 8X0 959 795 D HW: 8X0 959 795 D
Component: TSG HL H07 0415
Coding: 010002200001000000
VCID: D0ECF81C836374CFF7-8084
DrPeter
16.4905° S, 151.7375° W
Based on my research and as far as I can tell, when replacing the transmission and/or the J743-Mechatronics controller, there are only two things that need to be done and both can be done with VCDS:
- Coding
- Basic Settings
We have a page for the Basic Settings functions here:
7-Speed Direct Shift Gearbox (DSG/0AM) - Basic Settings
It would appear that some of these transmissions could have a P1701 - Transmission Control Unit: Locked fault code, but I do not believe this one will, I can not be 100% sure at this time.
Hope this helps,
drpeter
Kam
United Kingdom
C?ID=41543
Yes I have that fault on a 2015 golf where the customer has supplied a second hand gearbox and TCM. Hence I was asking regards this vehicle.
Golftwincharged
Guyana
C?ID=320847
No immo on this TCM 0AM927769D , all you need to do is carried out Basic settings , the 0CW (newer version 0AM) has IMMO locked to unit usually carrying HW number 0AM927769K OR 0AM927769G
Good luck.
Kam
United Kingdom
C?ID=41543
Hi so the customer has decided to have a used gearbox replacement (supplied by himself), should I use the TCM that came with the gearbox or put his original one on? Which is better option, It’s not an issue coding and carrying out basic settings for either one.
Golftwincharged
Guyana
C?ID=320847
you will need correct software version for the current car from original tcm, if you have that file and you can flash the replacement tcm, then go ahead, however you dont have that file use the old tcm to avoid software compatibility issues and carried out basic settings 060.
tip, you can read MVB 041 for auto trans and read the current software version for the tcm.
