2009 R32 - high fuel trim on bank 1
cas
Middle East
C?ID=343324
Hello all,
I have a 2009 R32 on which I've been trying to track down a high partial fuel trim on Bank 1. It varies from around +12 to +19 at the worst.
Bank 2 sits steady around +7.
Idle fuel trims for both banks around +0.2
It's had:
  • New fuel filter
  • New fuel pumps (both)
  • New CTS
  • New MAF
  • New plugs
  • New pre-cat O2 sensors
  • Transposed the coil packs between bank 1 / bank 2
I'm running out of ideas... Possibly a false lean from an exhaust gasket leaking under load, or maybe a bad injector?
There aren't any vacuum leaks and the idle trims suggest that to be the case too.
If any one has any ideas about how to narrow this down further I would be most grateful.
Cheers!
Friday,08,November,2019,19:09:26:09551
VCDS Version: 19.6.2.0  HEX-V2 CB: 0.4508.4
VIN: WVWPM51K99W138436   License Plate:
Mileage: 173670km-107913mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 62 72 76
VIN: WVWPM51K99W138436   Mileage: 173670km-107913miles
Address 01: Engine        Labels: 022-906-032-BDB.lbl
   Part No SW: 022 906 032 KJ    HW: 022 906 032 GP
   Component: R32-DQ-EU2      G   0696
   Revision: 1QH02---    Serial number: VWX7Z0H83NQ7UC
   Coding: 0000178
   Shop #: WSC 00000 000 08192
   VCID: 5DE79A6DE133DA1F821-8008
Readiness: 0100 1101
   Part No SW: 02E 300 011 CP    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     431 1812
   Revision: 04843012    Serial number: 00000804301651
   VCID: 5F9BA065EB3FC80F90D-800A
   Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 143B800D09250002280F01E7901F0041B500
   Shop #: WSC 32782 001 1048576
   VCID: 005983193A0157F7C97-8054
   Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: 6D87CAAD1193AA9F121-8038
01810 - Actuating Motor for Temperature Flap; Right (V159)
00716 - Air recirculation Flap Positioning Motor (V113)
   Revision: 00H54000    Serial number: 00000008917194
   Coding: E68F8B27000415004714000014000000000900005C000100000000000000
   VCID: 33331CD537373C6F045-8066
   Component: Wischer 011008 021  0501
   Coding: 00038805
   Shop #: WSC 01357
   Component: RLS     061008 054  0402
   Coding: 00207789
   Shop #: WSC 01357
   Component: 5F AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0C3GV9
   Coding: 0013638
   VCID: 6C81C7A92A89A39705F-8038
   Subsystem 1 - Serial number: 6332MSME4116165A5
   Subsystem 2 - Serial number: 6342MSME4162585FI
   Subsystem 3 - Serial number: 6352QSME380A352CK
   Subsystem 4 - Serial number: 6362QSME700C4F34N
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Component: J0527           051 0101
   Coding: 0012122
   VCID: 78A9EBF96ED11F37F17-802C
   Part No SW: 1K6 920 874 B    HW: 1K6 920 874 B
   Component: KOMBIINSTRUMENT VDD 2416
   Revision: V0002000    Serial number: VWX7Z0H83NQ7UC
   Coding: 0007107
   Shop #: WSC 32785 001 104857
   VCID: 323D19D1C82D35670F3-8066
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 260908F1001064
   Coding: ED837F0E0002020002
   VCID: 353722CD3943225F2A1-8060
01304 - Radio
                    Fault Frequency: 20
                    Reset counter: 50
                    Mileage: 173572 km
                    Time: 22:29:20
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 L
   Component: Haldex 4Motion      0116
   Coding: 0000001
   VCID: 363525C12445294723B-8062
   Component: IMMO            VDD 2416
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Component: Tuer-SG         006 1219
   Coding: 0000182
   VCID: 392F2EFD155BC63FCE9-806C
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.141 H08 1901
   Coding: 809002005103087F2D0484057008CFC6E0FC00
   VCID: 03538C1527174CEFD45-8056
   Subsystem 2 - Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Subsystem 3 - Part No: 1K0 951 178 A
   Component: Innenraumueberw.003 0203
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Coding: 0000438
   VCID: 3A2D31F1105DCD27C73-806E
   Part No: 1T0 907 357
   Coding: 0000004
   VCID: 74B1DFC972B97B57DDF-8020
Address 56: Radio
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1302
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   VCID: 38292BF92E51DF37317-806C
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0000144
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 22 Einparkhilfe     0101
   VCID: 2D070AADD1136A9F521-8078
End----------(Elapsed Time: 01:15, VBatt start/end: 11.9V/12.0V)-----------
Did you crimp off N80 and all intake hoses to isolate?
Have you done a leak down test of injectors plus look at plug's burn patterns?
dieseldub
Gresham, OR
C?ID=28764
Strange that your autoscan shows no codes in the engine computer despite the obvious out of range fuel trim you have going on.
O2 sensor lean code the only fault it sets?
Does it ever set a fuel pressure code? Most of these direct injected gas engines have a control module for the fuel pump to control in-tank pump output via PWM to better dial in pressure and volumes required for the precise operation that direct injection requires.
Not at all unusual for the fuel pump control module to flake out and no longer adequately control the in-tank pump (even a new pump).
A lot of the fuel filters on these cars also have a built in pressure regulator and return. But there are several different ones with different pressures. You have to make doubly sure you get the right filter rated at the correct pressure spec.
Reactions: cas
Do I have to say it because I'm going to?
FOD and purported by whoever?
Reactions: cas
cas
Middle East
C?ID=343324
Many thanks for the replies everyone :)
Is the exhaust leak free a the flexi joints? What fuel are you using?
As best as I can tell, the flexi pipes aren't leaking. Took a look when the exhaust was off to replace the prop shaft
Using 98 or 95, depending on what is available. It doesn't appear to make any difference.
Capped off the EVAP (also had a new solenoid) to check, and the exhaust flapper. All new lines for the intake manifold changeover plumbing. No signs of leaks anywhere else, plus the idle fuel trims seem OK.
Not done a leakdown yet... need to find somewhere suitable around these parts. When I pulled the plugs there was nothing untowards there.
When the fuel pump gave up, I was getting error codes. Since replacing the pumps, there haven't been any codes but I have been keeping an eye on the fuel trims.
From what I saw, it only flags up if fuel trim maxs out (+25% in my case). It hasn't done that since I swapped the pumps (new, genuine ones).
I replaced the fuel filter with a new, genuine filter, 4 bar if I recall correctly.
I've never seen a fuel pressure code, but I will look into the fuel pump control module as I hadn't considered that before. Thank you
I hope it isn't FOD, at least in the context I understand it!
Has the car been chip-tuned?
Not to my knowledge, but I guess we never really know what previous owners have done to vehicles
NZDubNurd
New Zealand
C?ID=230482
Bare in mind, everybody: this car is EU2 emissions regs. I can't recall the exact differences, but it's possibly only 2 lambdas and a simplified set of codes etc?
Most people on here are going to be dealing with EU4 versions of this car/drive train, only a few markets got EU2.
This motor isn't direct injected - though even VW relased official documented discussing it's direct injection :facepalm: It's caused quite some confusion at times!
A VERY common issue for this, usually IS leaking flexies - they are a concertina design, and it's hard to spot the crack, which open or close depending on engine movement. I'd certainly concentrate some time there, possibly with somebody applying some back pressure to the exhaust outlets (There isn't a lot of restriction in the R32 system)
cas
Middle East
C?ID=343324
That's very useful, thank you very much. Will try to get it up and take a second look.
Stupid BUB
Vehicle Identification No. WVWPM51K99W138436
Model golf r32
GOLF
Date of production 24.10.2008
Model year 2009
Sales type 1K14X7
Engine Code BUB
Transmission Code KQA
Emission standard 0GV Emission standard EU2
(critical vapor pressure)
Reactions: cas
Dunwood
CA, USA
C?ID=370890
DIY here, thought:
Your vehicle is 173KM or 108K miles. I'm assuming the motor mounts are worn or have been replaced? Or you just stomp on it alot?
Letting them go too long? Maybe damaged flexi-joints? Or maybe they were replaced and but one of the flexi-joints got buggered during installation?
At idle, the flexi-joints (or some other item) is fine. Mid to higher RPM, motor starts moving around due to marginal mounts and then something starts leaking, maybe the flexi-joints?
Air is added pre-Cat via cracked flexi (or other), and frt O2 sensor sends lean condition info to ECU thus added fuel due to fake lean condition. One flexi joint is good, the other bad?
Explains normal op @ idle. Your parts cannon might be out of ammo.....?
cas
Middle East
C?ID=343324
DIY here, thought:
Thanks for the reply. Yes, I agree that's possible. Engine mounts have all been done reasonably recently.
Re: parts cannon - they weren't all done for the fuel trim! I was just trying to give some recent history for the vehicle ;)
cas
Middle East
C?ID=343324
I decided to revisit old ground today.
Simultaneously capped off, at the intake manifold:
  • Exhaust flapper
  • EVAP
  • Intake changeover
  • Brake booster
  • Noise pipe / resonator
And there was no change on the fuel trims which suggests the vacuum system is fine. That makes sense to me, because the issue is a partial fuel trim (not idle), and it is only affecting one bank.
Which doesn't really get me much further. Still need to look for exhaust leaks giving a false lean, or something along the lines of a bad injector.
cas
Middle East
C?ID=343324
Spark Plug analysis would show this too no?
There was nothing untowards to my (untrained) eye when I pulled them. A touch rich across the board would be my assessment... will take another look when I get the chance.
Thinking about the flexi pipes leaking underload, I remembered why I initially discounted that - the flexi pipes are downstream of the precat sensors, so I don't think a leak there would be able to introduce a false lean?
Zenerdiode
Newcastle, England
C?ID=24330
Very good to question it; but because of the pulsed nature of exhaust gasses, combined with the high and low frequency/speed pressure waves, negative pressures (relative to atmospheric) are indeed created in the system. These can 'suck' oxygen-rich fresh air in and up to the sensor. :)
cas
Middle East
C?ID=343324
Thank you for that, very informative. I never thought of it that way, but it makes sense
cas
Middle East
C?ID=343324
I know you are not agreeing with flex pipe leaking. Been there!
Read this on a R32 flex pipe causing problems with 02 signal.
https://forums.ross-tech.com/showthread.php?10315-B1S1-no-activity-thinking-bad-ECU
Good Luck
Just read through your thread. It is certainly making me lean (pardon the pun) that way. Particularly as I very recently noticed 033 trims zero'ing out like you mention in your OP.
The flex pipes look a little easier to get to on the MkV than you describe about the MkIV. I'm guessing my MkV options are (1) drop the downpipes and cut out/replace the flex pipes, or (2) replace the entire downpipes and cats.
Is that about the measure of it? If so, I'll need to weigh up the chances of a good repair versus splashing out on some aftermarket downpipes with high flow cats.
vwtech
Verified Coal Cracker
Wilkes-Barre, PA
C?ID=7573
If that's a question I don't understand?
Does MKV have SAI with a Kombi valve you can hold open while jumping SAI pump? Then block tail pipes and feel around flex joints?
If O2 zero out then I say same problem. Glad it's got you thinking about flex pipes. Kicked my A$$ for sure figuring it out.
The cats were separate from the down pipe with flex joints on MKIV so I got the whole dealer down pipe no cats.
If cats are part of pipe with flex joints I would think about welding new flex joints? Just get a real good type!!!! That's easier said then done...
Good Luck
Reactions: cas
