Coding out faulty sensor
Viking
C?ID=151455
I have an intermittent fault occurring on the oil thermal sensor in my Yeti. It's probably the sensor itself, but as a temporary measure is it possible to simply code out the sensor to stop the bloody warning light flashing up every few miles when it decided it wants to?
Wednesday,09,October,2019,18:45:44:61903
VCDS Version: 19.6.1.0 (x64)  HEX-V2 CB: 0.4505.4
VIN: TMBMD75L2G*******   License Plate: YETI
Mileage: 111980km-69581mi   Repair Order:
Chassis Type: 5L-SK35 (7N0)
Scan: 01 03 05 08 09 10 15 16 17 19 22 25 2B 42 44 46 52 55 5F 61
          62 72
VIN: TMBMD75L2G*******   Mileage: 111980km-69581miles
Address 01: Engine (J623-CUUB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 J    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 1186
   Revision: 8AH20---
   Coding: 01190012042701091000
   Shop #: WSC 33361 790 00999
   ASAM Dataset: EV_ECM20TDI01104L906016J 001003
   ROD: EV_ECM20TDI01104L906016F_001.rod
   VCID: 303A1AB3CAAC4F777A9-8064
   Part No SW: 1K0 907 379 CB    HW: 1K0 907 379 CB
   Component: ESP MK60EC1   H46 0174
   Revision: 00H46001
   Coding: 933F400E09240103C90E02EB9020809AA1000021
   VCID: 74B2D6A37EB43357DE1-8020
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0370993080
   Coding: 030C0C
   VCID: 372821AF2FC2984F3B3-8062
   Part No SW: 3T0 907 044 CJ    HW: 3T0 907 044 CJ
   Component: Climatronic   H19 0709
   Revision: 00001009
   Coding: 0010000003
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 7CA2FE8356647B17961-8028
9472881 - Motor for Fresh Air / Recirculated Air Flap
          B108B 71 [008] - Actuator stuck
                    Reset counter: 155
                    Mileage: 105409 km
                    Date: 2019.07.22
                    Time: 10:11:48
9472882 - Motor for Fresh Air / Recirculated Air Flap
          B108B 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 211
                    Mileage: 105310 km
                    Date: 2019.07.21
                    Time: 16:42:37
9476885 - Position Sensor for Fresh/Recirculated Flap Motor
          B109B 15 [008] - Open or Short to Plus
                    Reset counter: 142
                    Mileage: 110233 km
                    Date: 2019.09.24
                    Time: 14:42:43
   Part No SW: 1K0 937 087 AR    HW: 1K0 937 087 AR
   Component: BCM PQ35  H   112 0903
   Revision: AC112903
   Coding: 4E000ABCE01BF1C0440800C0110089E44B7100AE666D87F08081C704A041
   Shop #: WSC 73430 790 00063
   VCID: 015C8F77310616FFC57-8054
   Subsystem 1 - Part No: 5L2 955 119 B  Labels: 1KX-955-119.CLB
   Component: SK356  26  0610
   Coding: 00F7B5
   Component: RLS 150915 05  54  0403
   Coding: 062BED
Address 10: Park/Steer Assist (J446)       Labels:| 5J0-919-475.clb
   Part No SW: 5J0 919 475 C    HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0011
   Revision: --H11---    Serial number: 32961525500848
   Coding: 108007
   ASAM Dataset: EV_EPHVA14SKxxx0000 002001
   ROD: EV_EPHVA14SKxxx0000_002.rod
   VCID: 35342BA735CE6A5F29F-8060
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    014 0613
   Serial number: 003G5RAV523G
   Coding: 00004E42
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 313C1FB7C1A6467F757-8064
   Serial number: 3572MSME65011E53ZZZS
   Serial number: 3582MSME4F642C54ZZZ3
   Serial number: 3516KSME2C064939ZZZY
   Serial number: 3526KSME6A094939ZZZ/
   Part No SW: 5K0 953 521 DT    HW: 5K0 953 569 AH
   Component: LENKS.MODUL   016 0162
   Revision: FF010042    Serial number: 20150904300396
   Coding: 1002140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 015C8F77318616FFC57-8054
   Subsystem 1 - Part No SW: 5E0 919 719 L    HW: 5E0 919 719 L
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000B0968110915
   Coding: 820000
   Part No SW: 5L0 920 940 T    HW: 5L0 920 940 T
   Component: KOMBI         H03 1007
   Coding: 420E210100
   ROD: EV_Kombi_UDS_VDD_RM09_005_SK26.rod
   VCID: 3D2433870DFEB21FE1F-8068
9453842 - Oil Level Thermal Sensor
          B1041 35 [009] - Signal high time > maximum
                    Reset counter: 115
                    Mileage: 111987 km
                    Date: 2019.10.09
                    Time: 18:41:23
   Part No SW: 7N0 907 530 BE    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1673
   Revision:   H58       Serial number: 170915F1003184
   Coding: 356323
   Shop #: WSC 30504 002 1048576
   Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7531
   Serial number: HA1-00029.07.15
   Coding: 0301
   Shop #: WSC 73430 790 00999
   VCID: 52FE703BA4605D672CD-8006
   Component: IMMO          H03 1007
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8EC8DB2CF0F5A774D-803E
   Revision: 00000000    Serial number: 15000193421008
   Coding: 4100000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   Part No SW: 7N0 959 793 J    HW: 7N0 959 793 G
   Component: TSG FA        H04 0561
   Revision:             Serial number: 0000165582676
   Coding: 01150220D001231003
   VCID: 49CC575749B61EBF5D7-801C
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 70     3501
   Revision: 00H22000
   VCID: 392C279715568E3FCD7-806C
   Part No SW: 7N0 959 792 J    HW: 7N0 959 792 G
   Component: TSG BF        H04 0561
   Revision:             Serial number: 0000167133767
   Coding: 01150020D001231003
   VCID: 48CA525352BCE7B7429-801C
   Component: AFS-ECU       H05 0111
   Coding: 03DE00003F000000
   Subsystem 1 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Part No SW: 5L0 035 200 C    HW: 5L0 035 200 C
   Component: MU-S-D-ER     H22 0245
   Serial number: SKZAZ2R8856584
   Coding: 03130600FF00000011111201008800002F0000C60120810000
   ROD: EV_MUStd4CTSAT_SK35.rod
   VCID: 1E66D40BA038C907D85-804A
   Component: Batt.regelung H58 1673
   Coding: 030F1873
   VCID: 71BCDFB701A6067F357-8024
   Component: J367-BDM  H07 0180
   Serial number: 42251412211491655569
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-795.clb
   Part No SW: 7N0 959 795 F    HW: 7N0 959 795 E
   Component: TSG HL        H04 0561
   Revision:             Serial number: 0000166784151
   Coding: 010000200001531004
   VCID: 47C8516F5FA2E8CF4B3-8012
Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-795.clb
   Component: TSG HR        H04 0561
   Revision:             Serial number: 0000166784145
End----------(Elapsed Time: 01:20, VBatt start/end: 12.1V/12.1V)-----------
Gone But Not Forgotten
That would be a possible defeat device and it wouldn't be a wise choice either.
dieseldub
Gresham, OR
C?ID=28764
Does your engine have an actual physical dipstick? If not, I would leave the level sensor coding alone so you can still at least get an idea of what the oil level is. Fairly certain coding out that sensor codes out the level sensor as well...
Viking
C?ID=151455
Yes it has a dipstick, and it gets checked regularly, at least every sunday evening and more often if the bonnet is up for screenwash etc. The warnings about not being a wise thing to do or whatever are my choice to make I guess, and I'm happy to take the decision if coding it out is actually possible until its oil change time and I can swap out the sensor.
Per my fuzzy recollection when playing games with a 2010 NAR GTI years ago.. that's an Adaptation channel. Perhaps?
[*IDE00492-MAS02013*] ESI: Coding of Service Interval Extension (SIE) - TOG
Oil level thermal sensor not connected to instrument cluster
Oil level thermal sensor connected to instrument cluster​
Tweaking that from off to ON in my GTI resulted in a cool new oil can on the MFA but I didn't install the sensor so that got disabled quickly.
In your case, it'll likely mask the bing bong celebration on startup however I suspect the oil change strategy won't be correct. OTOH, if this is a temporary solution and you are going to replace it and lose all of you oil, resulting in an oil change, I suppose resetting the SRI when the new sensor is fitted may resolve any long-term oil strategy concerns?
Also - please see this http://wiki.ross-tech.com/wiki/index.php/B1041
Since your Yeti is Mk6 based the Damaged TOG wiring doc may be applicable?
Viking
C?ID=151455
Many thanks Dana. Some work for this weekend I think.
Viking
C?ID=151455
Indeed, the adaption channel ESI: Coding of Service Interval Extension (SIE) - TOG has removed the infernal bong and flashing light.I'll have an investigation of the wiring issue this weekend, and maybe just plug the new sensor in first without draining the oil and replacing it. If the fault is fixed then swap the sensor, if the fault remains then investigate the wiring.
Viking
C?ID=151455
Curiously, since removing the thermal sensor from the instruments, the oil temperature readout in the MFD is now correct whereas before it was stuck on 79°c.
Neat. I'm ASSuming there isn't another oil temp input, and if so, I wonder if the cluster using using a filler value or default strategy? Similar to unplugging a MAF sensor and watching that MVB show "live" MAF data raise and lower as you rev the engine .. could the fallback/filler oil temp value may be ECT based in this case?
Viking
C?ID=151455
Afaik there's only the one thermal sensor. Maybe the instrument cluster is now not seeing a fault and the sensor is in fact working correctly. Or given that the fault has been there since I got the car some months ago, maybe someone played with the adaption settings and erroneously added the fault. I have a Tiguan with the same engine, I'll try and see the adaption values on that over the weekend.
