JETTA 2.0 TSI 200HP - TURN OFF TRACTION CONTROL
andre.bernardo
Brazil
C?ID=374585
Hello!
I need to turn off Jetta's traction control.
Would it be possible through VCDS?
AUTOSCAN:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 4F 52 56 62 72
77
VIN: 3VWLN61K2BM056858 Mileage: 83230km-51716miles
Thanks.
You've posted only the CAN Gateway installation list, what we need is the full unedited Auto-Scan - see my signature for a link to a How-To.
** edit ** Looks like Mike@Gendan and I posted simultaneously :cool:
andre.bernardo
Brazil
C?ID=374585
          77
Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
   Part No SW: 06J 906 027 AP    HW: 06J 907 309 A
   Component: MED17.5.2        04 8417
   Revision: P3H06---    Serial number:
   Coding: 0403000C1C070160
   Shop #: WSC 00066 000 00000
   VCID: 79BAFB0B302DB087DE-802C
053271 - Please Check Fault Codes in Control Module for ABS Brakes
               U1017 - 015 -  - Intermittent
                    Fault Status: 00101111
                    Mileage: 83207 km
                    Date: 2019.09.05
                    Time: 17:02:52
                    RPM: 1982 /min
                    Load: 21.2 %
                    Speed: 16.0 km/h
                    Temperature: 87.0°C
                    Temperature: 57.0°C
                    Absolute Pres.: 940.0 mbar
                    Voltage: 13.589 V
   Part No SW: 02E 300 054 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2608
   Revision: 05351112    Serial number: 00001010220263
   Shop #: WSC 02069 000 90108
   VCID: 200CF66FF337014FB9-8074
18255 - Please check DTC Memory of ABS Controller
            P1847 - 000 -  - Intermittent
                    Fault Frequency: 255
                    Reset counter: 1
                    Mileage: 83207 km
                    Date: 2019.09.05
                    Time: 17:02:53
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Revision: 00H31001
   Coding: A43B600D09270000251306E990210041210000
   VCID: 76A0F037C133DFFFB3-8022
03409 - Rolling Mode recognized
                    Reset counter: 232
                    Mileage: 83207 km
                    Date: 2019.09.05
                    Time: 15:44:19
                    Count: 14
                    Count: 4096
                    Count: 396
                    Count: 43264
                    Count: 257
                    Count: 65024
01169 - Door Contact Switch Driver Side (F2)
                    Reset counter: 232
                    Mileage: 83213 km
                    Date: 2019.09.05
                    Time: 17:07:42
                    Count: 7
                    Count: 2
                    Count: 20992
                    Count: 147
                    Count: 48385
                    Count: 254
                    Fault Status: 00100011
                    Reset counter: 192
                    Mileage: 83207 km
                    Date: 2019.09.05
                    Time: 17:02:52
                    Count: 320
                    Count: 2
                    Count: 4608
                    Count: 83
                    Count: 48897
                    Count: 254
                    Reset counter: 192
                    Mileage: 83207 km
                    Date: 2019.09.05
                    Time: 17:02:52
                    Count: 320
                    Count: 2
                    Count: 4608
                    Count: 67
                    Count: 48897
                    Count: 254
   Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000000002
   Shop #: WSC 00066 000 00146
   VCID: 6E90D857B163E73F7B-803A
   Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
   Component: BCM PQ35 M    011 0045
   Revision: BC011001
   Coding: 08000A2A802DE3C040080080140081240371008850A08D605C8000000040
   VCID: 3B362103BA9142978C-806E
   Component: RLS 231210 05  54  0403
   Coding: 03302D
   Subsystem 2 - Part No: 1K8 951 171
                    Fault Status: 00101010
                    Reset counter: 196
                    Mileage: 81672 km
                    Date: 2019.07.24
                    Time: 13:58:38
                        Term 15 On
                    Voltage: 13.50 V
                    Reset counter: 232
                    Mileage: 75544 km
                    Date: 2018.09.16
                    Time: 19:35:34
                        Term 15 On
                    Voltage: 14.25 V
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 5C6 919 475     HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H10 0005
   Revision: --------    Serial number: 84091034001092
   Coding: 108101
   ASAM Dataset: EV_EPHVA18VW3610000 001003
   ROD: EV_EPHVA18VW3610000.rod
   VCID: 71AAC32BA05DF8C766-8024
   Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
   Component: AirbagVW10    012 0612
   Serial number: 003G6D03GMC5
   Coding: 00003142
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 32280C2765DB83DF5F-8066
   Serial number: 3572MSME54292359ZZZW
   Serial number: 3582MSME3D322359ZZZY
   Subsystem 3 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3516KSME7510130DZZZJ
   Serial number: 3526KSME5D1B130DZZZ.
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Component: LENKS.MODUL   009 0136
   Revision: FF010039    Serial number: 20101130301752
   Coding: 089A140000
   Shop #: WSC 00066 000 00195
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 76A0F037C933DFFFB3-8022
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H06 0010
   Coding: 830000
   Part No SW: 5C6 920 870     HW: 5C6 920 870
   Coding: 171B00
   VCID: 689CAE4F9387390F31-803C
   Part No SW: 7N0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H35 0614
   Revision:   H35       Serial number: 04011101200539
   Coding: 351002
   VCID: 312A032B68DDB8C726-8064
   VCID: 6A98D4478D8B0B1F27-803E
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Component: SG EXT.PLAYER H13 0111
   Revision: A1001003    Serial number: 7668787325
   VCID: 271EED735619F677F8-8072
   Part No SW: 3C0 959 701 C    HW: 3C0 959 793 A
   Component: TUER-SG FT    002 0337
   Revision: 12101005    Serial number: 0001704151
   Coding: 0010B7
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_DCU42BroseDriveSide A03004
   ROD: EV_DCU42BroseDriveSide_VW36.rod
   VCID: 281CEE4F5307F90FF1-807C
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 1409
   Serial number: 00000005325465
   Coding: 000090
67334 - Locking Module for Central Locking
          B122F 29 [008] - Signal Implausible
                    Reset counter: 232
                    Mileage: 59272 km
                    Date: 2022.10.13
                    Time: 18:49:59
          B11EE 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 232
                    Mileage: 83079 km
                    Date: 2019.09.05
                    Time: 11:29:11
131585 - Motor for Rear Window Regulator
          B11EE 01 [008] - Electrical Failure
                    Reset counter: 232
                    Mileage: 83079 km
                    Date: 2019.09.05
                    Time: 11:29:11
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   VCID: 312A032BA8DDB8C726-8064
01316 - ABS Control Module
                    Fault Status: 00101101
                    Reset counter: 232
                    Mileage: 83228 km
                    Date: 2019.09.05
                    Time: 17:28:42
                    Voltage: 13.25 V
                        DU
                    Temperature: 56.0°C
                    RPM: 1216 /min
                    Speed: 17.0 km/h
                    Speed: 17.0 km/h
   Component: EZE_2         H35 0614
   Coding: 01030100
   VCID: 6FAEC553BE69EE3770-803A
   Subsystem 1 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.019  H08 0006
   Serial number:     WRH0000Z1MS
   Coding: 180000
   Part No SW: 3C0 959 702 C    HW: 3C0 959 792 A
   Component: TUER-SG BT    002 0337
   Revision: 14101005    Serial number: 0001800312
   Coding: 0010B6
   ASAM Dataset: EV_DCU52BrosePasseSide A03004
   ROD: EV_DCU52BrosePasseSide_VW32.rod
   VCID: 291AEB4B480DC007EE-807C
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  006 1409
   Serial number: 00000005379871
   Coding: 000090
   Part No SW: 5K0 035 190     HW: 5K0 035 190
   Component: Radio RCD510  041 0167
   Revision: 00000001    Serial number: VWZ1Z3K3573441
   Coding: 0100041004
   VCID: 6288BC677DBB535FEF-8036
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668878450
   Coding: 0A00000000010100
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
9457425 - Left audio channel for speech/telephone
          B104F 11 [001] - Short to GND
9457169 - Right audio channel for speech/telephone
          B104E 11 [001] - Short to GND
End----------(Elapsed Time: 01:36, VBatt start/end: 12.1V/12.1V)-----------
