Audi Q5 2012 - Angle Steering Coding
dpasquazzo
Bahrain
C?ID=324791
Dears,
I replaced the faulty angle steering and would like your support to code the new one. already installed, the functions such as shifting and sound are not working.
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372LI8000YT
   Coding: 0000FF
   Shop #: WSC 06335 000 00000
   VCID: 44C4A221C7443C66F5-8010
                    Fault Status: 00100011
                    Reset counter: 205
                    Mileage: 64499 km
                    Date: 2018.06.12
                    Time: 01:24:55
                    (no units): 40.0
                    Text: 288390091138FB1202
                    Ign. Timing: 618.0 °ATDC
                        8
                    Reset counter: 206
                    Mileage: 64499 km
                    Date: 2018.08.26
                    Time: 18:30:10
                    Reset counter: 205
                    Mileage: 64499 km
                    Date: 2018.08.26
                    Time: 18:34:32
                    Fault Status: 00101101
                    Fault Frequency: 30
                    Reset counter: 206
                    Mileage: 64498 km
                    Date: 2018.09.01
                    Time: 00:58:03
   Coding: 0000FF
01426 - Controls in Steering Wheel (E221)
                    Reset counter: 190
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:04:27
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 190
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:04:27
                    (no units): 40.0
                        8
                    Text: 3B8AFF5F1281062413
                    Knock Sensor: 24.225 V
                    Absolute Pres.: 31.0 mbar
                    Mileage: 51150 km
Sunday,22,September,2019,15:59:44:57315
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4505.4
VIN: WA1CFCFP7DA018393   License Plate: Q5-2012-NEWSTEERIMG2
Mileage: 68090km-42309mi   Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 20 2E 3C 42 44 46 47 52 53 56
          5C 62 6D 72 77
VIN: WA1CFCFP7DA018393   Mileage: 68090km-42309miles
5C-Lane Maintain. -- Status: Cannot be reached 1100
Address 01: Engine (J623-CNCD)       Labels:. 06L-907-115-V1.clb
   Part No SW: 8R2 907 115     HW: 8K0 906 264
   Component: 2.0l R4 TFSI  H09 0008
   Revision: --H09---
   Coding: 2A2A0032244601022000
   Shop #: WSC 06208 123 12345
   ASAM Dataset: EV_ECM20TFS0218R2907115 001009
   ROD: N/A
   VCID: 73A631FDDA6ACBD794-8026
No ASAM data for: "EV_ECM20TFS0218R2907115" (AU48)
17169 - ROD - Unknown Error Code
          - 00 [167]
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:45
15101 - ROD - Unknown Error Code
          - 00 [039]
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:55
16774 - ROD - Unknown Error Code
          - 00 [039]
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:45
14882 - ROD - Unknown Error Code
          - 00 [047]
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:45
15093 - ROD - Unknown Error Code
          - 00 [039]
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:55
Readiness: 1110 0001
   Part No SW: 8R1 927 158 H    HW: 0BK 927 156 AM
   Component: 0BK 20TFSIRdW H16 1003
   Revision: --H16---
   ASAM Dataset: EV_TCMAL551211 002020
   VCID: 43C6A13DCA4A3B57C4-8016
No ASAM data for: "EV_TCMAL551211" (AU48)
Unable to open the following:
IV_EV_PDK2ZFPO623_F4,IV_EV_TCMAL551211_002_AU48_D3,IV_EV_TCMAL551211_002_AU48_M12
Internal ROD error:
EV_TCMAL551211_002_AU48.rod:XPL
Address 03: ABS Brakes        Labels:
   VCID: 55E26F65ACDEB5E79A-FFFE
   Part No SW: 8K0 907 064 GR    HW: 8K0 907 064 FR
   Component: BCM2 2.0      H11 0621
   Coding: 05A54040000000000000
   VCID: 06407829B1F8CE7FA3-8052
   Subsystem 1 - Part No SW: 8K0 959 754 A    HW: 8K0 959 754 A
   Serial number: 0812000152087013
   Part No SW: 8K1 820 043 S    HW: 8K1 820 043 S
   Revision: C0000000    Serial number: 01100920122613
   Coding: 642122C000
   VCID: 383CC6D18B8C688F61-806C
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:47
   Part No SW: 8K0 907 063 DG    HW: 8K0 907 063 DG
   Revision: 07016001    Serial number: 00000477634601
   Coding: 260000108074AFC00081400000001D0D0F1C470826090201000008004401030100000024000000
   VCID: 77BE05EDC612A7F7A8-8022
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 120831  H11 0050
   Serial number: 90243014120816101616
   Coding: 01DD13
   Subsystem 2 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
   Component: E1 - LDS  H07 0090
   Serial number: 00000000000705090497
   Subsystem 3 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 31680946000000000001
02988 - Left-Hand/Right-Hand Traffic Switchover Active
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:41
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:42
01229 - A/C Humidity Sensor (G260)
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:42
03679 - Switch for Night-Vision System
                    Fault Status: 01101000
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:58:42
03735 - Switch for Head-Up Display
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:58:42
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Serial number: 003JPD91SZEI
   Coding: 30463431313030303030554A304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 48DCB611F36C180F11-801C
   Serial number: 6334MSME7453761AG
   Serial number: 6344MSME474145504
   Serial number: 6352QSME7D214F4CZ
   Serial number: 6362QSME04214054+
   Serial number: 63732SME3427473E0
   Serial number: 63832SME1B27570E4
Internal ROD error:
EV_AirbaAU10SMEAU416.rod:MWB,EV_AirbaAU10SMEAU416.rod:XPL
9439771 - ROD - Unknown Error Code
          - 00 [137]
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:45
   Component: Lenks.Modul   H05 0005
   Revision: --------    Serial number: 90372SA80000V
   VCID: 44C4A221C7443C6FFD-8010
                    Fault Status: 01100101
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:41
                    (no units): 44.0
                    Text: 2C86FFFFFFFF00C0FF
                    Speed: 65025.0 km/h
                    Raw, Index/Key Err.: 255 255 000
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:42
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 930 Q    HW: 8R0 920 930 Q
   Component: KOMBIINSTR.   H35 0553
   Revision: 00000000    Serial number: RF935TC9D
   Coding: 53C6220046010008010000
   VCID: 42C8A439DD50325FCF-8016
02797 - Control Module for Directional Stabilization Assistance (J759)
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:42
01319 - Control Module for Distance Control (J428)
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:42
   Part No SW: 8R0 907 468 G    HW: 8R0 907 468 B
   Component: GW-BEM 6CAN   H11 0051
   Revision: 1X090024    Serial number: 2441X1280880E4
   Coding: 80CF07FF00
   VCID: 43C6A13DC24A3B57C4-8016
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790059699
   Serial number: 12249003521021200181
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:42
                    Bin. Bits:    11111
                    Voltage: 13.80 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
   Part No SW: 8K0 857 511 C    HW: 8K0 857 511 A
   Component: FLA           H04 0003
   Revision: AA001002
   Coding: 02012064747464545425363E
   VCID: 312AFBF568F6B9C726-8064
03455 - Function Restriction due to Faults in Other Modules
                    Reset counter: 98
                    Mileage: 65506 km
                    Date: 2019.06.26
                    Time: 22:05:18
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785     HW: 8T0 035 785
   Component: SG ext.Player H08 0210
   Revision: 00000000
   Coding: 020202
   VCID: 78BC06D1CB0CA88FA1-802C
   Part No SW: 8T0 907 566 A    HW: 8T0 907 566
   Component: SWA Master    H17 0040
   Serial number: 0182361570
   Coding: 010211
   Shop #: WSC 61135 001 1048576
   ROD: EV_LaneChangAssis_VN75.rod
   VCID: 3E30D0C9A1A856BFAB-806A
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 A    HW: 8T0 907 568
   Component: SWA Slave  H17 0040
   Serial number: 0182024992
   Coding: 010211
IV_EV_LaneChangAssis_AU21_A6,IV_EV_LaneChangAssis_AU21_M20
Internal ROD error:
EV_LaneChangAssis_VN75.rod:FFMUX,EV_LaneChangAssis_VN75.rod:XPL
262148 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:43
337166 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:43
730117 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:43
   Part No SW: 8K0 959 793 P    HW: 8K0 959 793 P
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000038882996
   Coding: 011D12205C00440004
   VCID: 4DD28705140EFD2722-8018
   Part No SW: 8R0 909 144 Q    HW: 8R0 909 144 L
   Component: RCevo         H54 0702
   Revision: 00000002    Serial number: 0000033813
   Coding: 100000010001
   Shop #: WSC 06192 123 12345
   ASAM Dataset: EV_RCEPSAU48X 104002
   ROD: EV_RCEPSAU48X_104.rod
   VCID: 46C0B829F9780E7FE3-8012
IV_EV_RCEPS_104_M11
Internal ROD error:
EV_RCEPSAU48X_104.rod:FFMUX,EV_RCEPSAU48X_104.rod:XPL
4205828 - ROD - Unknown Error Code
          - 00 [137]
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:43
5258753 - ROD - Unknown Error Code
          - 00 [137]
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:43
4215041 - ROD - Unknown Error Code
          - 00 [137]
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:43
   Revision: 00002001    Serial number: 0183439451
   Coding: 01000E2020B93095853005368004000F
   Component: J245EE20SKB13  H03 0220
   Component: J394EE20SKB13  H03 0220
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8R0 035 223 G    HW: 8R0 035 223 E
   Component: DSP STD       H11 0460
   Revision: 00000000    Serial number: 00000000000001
   Coding: 0203010102
   VCID: 302CFEF163FCB0CF29-8064
   Part No SW: 8K0 959 792 P    HW: 8K0 959 792 P
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000038521013
   VCID: 4CD48A01EF14F42F35-8018
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 00000001179229
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 383CC6D1838C688F61-806C
IV_EV_ParkiBrake_AU48_A3,IV_EV_ParkiBrake_AU48_M16,IV_EV_ParkiBrake_AU48_S5
Internal ROD error:
IV_EV_BY62XParkiBrake_F9.ROD:FFMUX
917760 - ROD - Unknown Error Code
          - 00 [137]
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:43
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8R1 035 195 F    HW: 8R1 035 195 F
   Component: Symphony3     H08 0460
   Revision: 00000001    Serial number: AUZ5Z4L1563535
   Coding: 0402008201058500135B770800
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:43
                    Bin. Bits: 00100000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00001010
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
00468 - CD-ROM Drive (R92)
                    Fault Status: 01100011
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:52
Address 5C: Lane Maintain.
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000038945703
   Coding: 010C12204000240004
   VCID: 46C0B829F1780E7FE3-8012
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B36D9DDBABA43978C-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H52 0330
   Serial number: 8R0827852B
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000038945934
   Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005581898
   Coding: 0010390
   VCID: 3D32D7C564AE4DA7B2-8068
End----------(Elapsed Time: 01:55, VBatt start/end: 13.9V/13.9V)-----------
I took before this
Friday,21,December,2018,20:17:20:57315
VCDS Version: 17.8.1.0 (x64)  HEX-NET CB: 0.4436.4
Data version: 20171130 DS276.6
VIN: WA1CFCFP7DA018393   License Plate: Q5QQ5
Mileage: 64510km-40084mi   Repair Order: 111
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 2E 3C 42 44 46 47 52 53
          56 5C 62 6D 72 77
VIN: WA1CFCFP7DA018393   Mileage: 64510km-40084miles
13-Auto Dist. Reg -- Status: Cannot be reached 1100
   Revision: --H09---
   Shop #: WSC 06208 000 00000
   ROD: EV_ECM20TFS021_AU48.rod
   VCID: 73A631FDDA6ACBDE9C-8026
17178 - Databus
          U1123 00 [047] - Received Error Message
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:09:40
                    Engine speed: 797.25 /min
                    Normed load value: 13.7 %
                    Coolant temperature: 93 °C
                    Intake air temperature: 66 °C
                    Voltage terminal 30: 14.062 V
                    Drivetrain coordinator: ACC fault status-ACC: Not active: although TSK passive
                    Drivetrain coordinator: ACC fault status-Start and stop request: Set at stopping speed
                    Drivetrain coordinator: ACC fault status-Bit 2: Not transmitted simultaneously
                    Drivetrain coordinator: ACC fault status-Bit 3: Does not reactivate after DTC-induced shutdown
                    Drivetrain coordinator: ACC fault status-Bit 4: Not active when limiter active
                    Drivetrain coordinator: ACC fault status-Bit 5: Transmits no undefined signals
                    Drivetrain coordinator: ACC fault status-Bit 6: Not active when main switch off
                    Drivetrain coordinator: ACC fault status-Bit 7: Not active when driver braking
                    Drivetrain coordinator: ACC fault status-Bit 8: Not active during the EPB emer. braking
                    Drivetrain coordinator: brake fault status-ESP: no error
                    Drivetrain coordinator: brake fault status-Deceleration controller: Available
                    Drivetrain coordinator: brake fault status-TSK/ESP handshake: no error
                    Drivetrain coordinator: brake fault status-Bit 1: no error
                    Drivetrain coordinator: brake fault status-Bit 3: Not malfunction due to inaccurate engine torque
                    Drivetrain coordinator: brake fault status-Bit 4: No indication of TSK message consistency error
                    Drivetrain coordinator: brake fault status-Bit 6: Automatic engagement OK
                    Drivetrain coordinator: brake fault status: 4
                    Drivetrain coordinator: brake function status-Parking Brake: not active
                    Drivetrain coordinator: brake function status-ACC: Not braking
                    Drivetrain coordinator: brake function status-ESP: Not invoking TSK braking
                    Drivetrain coordinator: brake function status-Driver: Not braking
                    Drivetrain coordinator: brake function status-Hill descent control: passive
                    Drivetrain coordinator: brake function status-ASR: no intervention
                    Drivetrain coordinator: brake function status-MSR: no intervention
                    Drivetrain coordinator: brake function status-ADS: no intervention
                    Drivetrain coordinator: brake function status-ABS: no intervention
                    Drivetrain coordinator: brake function status-EDL: no intervention
                    Drivetrain coordinator: brake function status-ASP: no intervention
                    Drivetrain coordinator: brake function status-AWV2: No warning pressure
                    Drivetrain coordinator: brake function status-Bit 4: no intervention
                    Drivetrain coordinator: brake function status-Bit 11: not passively cycled
                    Drivetrain coordinator: brake function status-Bit 12: not passively cycled
                    Drivetrain coordinator: brake function status-Bit 13: standstill detected
15101 - MAP/MAF <-> Throttle Position Correlation
          P0068 00 [039] - -
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:09:50
                    Engine speed: 799.50 /min
                    Normed load value: 13.3 %
                    Coolant temperature: 94 °C
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 8 s
                    MAP_MES_SAE: 51 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.963 V
                    FAC_TPS_1_SAE: 10.156250 %
                    FAC_LAM_LIM[1]: -0.777 %
16774 - Implausible Data Received from ABS Control Module
          U0415 00 [039] - -
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:09:40
                    Engine speed: 798.00 /min
                    Voltage terminal 30: 14.042 V
                    ECU_STATE: SYN_ENG_IGK_ON
                    TOIL: 86 °C
                    Time since engine start: 331.2 s
                    T_ES: 0 min
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: operated
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: operated
                    Cruise control switch actuation-Large increment: not activated
                    STATE_ERR_ABC_PRED: 18
16775 - Implausible Data Received from Steering Column Control Module
          U0429 00 [039] - -
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:09:40
                    TOIL: 86 °C
                    T_ES: 0 min
                    STATE_ERR_ABC_PRED: 0
14882 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [047] - -
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:09:41
                    Engine speed: 800.75 /min
                    TOIL: 86 °C
                    Time since engine start: 331.7 s
                    T_ES: 0 min
15093 - Leak in Air Intake System
          P2279 00 [039] - -
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:09:50
                    Engine speed: 795.50 /min
                    Voltage terminal 30: 14.082 V
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 8 s
                    MAP_MES_SAE: 51 kPa
                    FUP_H_SAE: 16250.0 kPa
   Revision: --H16---
   VCID: 43C6A13DCA4A3B5ECC-8016
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 C    HW: 8R0 907 379 C
   Component: ESP8 quattro  H06 0230
   Coding: 025500
   VCID: 40CCAE31D35C2046D1-8014
   VCID: 06407829B1F8CE76AB-8052
   Coding: 642122C000
   VCID: 383CC6D18B8C688669-806C
00457 - Control Module for Network (J519)
                    Reset counter: 190
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:05:32
   VCID: 77BE05EDC612A7FEA0-8022
   Coding: 01DD13
                    Reset counter: 191
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:06:45
                    Reset counter: 191
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:06:45
            000 -  -
                    Reset counter: 191
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:06:45
                    Fault Status: 01101101
                    Reset counter: 191
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:06:50
                    Reset counter: 191
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:07:45
                    Reset counter: 191
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:07:45
Address 13: Auto Dist. Reg
Address 15: Airbags (J234)       Labels:| 8R0-959-655.clb
   VCID: 48DCB611F36C180619-801C
          B1006 1B [137] - Resistance Too High
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:08:59
9442075 - Driver's Belt Force Limiter Igniter
          B1013 1B [137] - Resistance Too High
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:08:59
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [137] - Resistance Too High
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:08:59
   Coding: 0000FF
                    Reset counter: 190
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:04:27
            014 - Defective
                    Reset counter: 190
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:04:27
                    (no units): 40.0
                        8
                    Mileage: 51150 km
   VCID: 42C8A439DD503256C7-8016
                    Reset counter: 190
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:04:28
                    Reset counter: 190
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:04:28
   Coding: 80CF07FF00
   VCID: 43C6A13DC24A3B5ECC-8016
                    Reset counter: 191
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:09:57
                    Bin. Bits:    11111
                    Voltage: 14.00 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 191
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:09:57
                    Bin. Bits:    11111
                    Voltage: 14.00 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
   Revision: AA001002
   VCID: 312AFBF568F6B9CE2E-8064
            000 -  -
                    Reset counter: 183
                    Mileage: 64498 km
                    Date: 2018.10.07
                    Time: 05:31:43
   Revision: 00000000
   Coding: 020202
   VCID: 78BC06D1CB0CA886A9-802C
   Coding: 010211
   VCID: 3E30D0C9A1A856B6A3-806A
   Coding: 010211
262148 - Databus
                    Reset counter: 190
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:04:28
337166 - Databus
                    Reset counter: 190
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:04:28
730117 - Control Module 2 for Lane-Change Assist
          C1115 F0 [009] - Automatic Calibration Not Possible
                    Reset counter: 190
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:04:28
   VCID: 4DD28705140EFD2E2A-8018
   Shop #: WSC 06192 000 00000
   VCID: 46C0B829F9780E76EB-8012
4215044 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 191
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:10:18
5258753 - Steering End Stops Not Learned
          U4E6650 F0 [137] - -
                    Reset counter: 191
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:10:18
4208000 - Steering Angle Sensor
          U8F2251 F1 [137] - Synchronization Failed
                    Reset counter: 191
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:10:18
   Coding: 0203010102
   VCID: 302CFEF163FCB0C621-8064
   VCID: 4CD48A01EF14F4263D-8018
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 383CC6D1838C688669-806C
917760 - Longitudinal Acceleration
          C10B1 29 [137] - Signal Implausible
                    Reset counter: 190
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:04:29
                    Voltage terminal 30: 13.2 V
                    Internal Fault ID: 163
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
   Component: Display
            000 -  -
                    Reset counter: 190
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:04:29
                    Bin. Bits: 00100000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00001010
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Reset counter: 190
                    Mileage: 64517 km
                    Date: 2018.10.17
                    Time: 03:04:37
   VCID: 46C0B829F1780E76EB-8012
   VCID: 3B36D9DDBABA439E84-806E
   Coding: 0010390
   VCID: 3D32D7C564AE4DAEBA-8068
End----------(Elapsed Time: 01:54, VBatt start/end: 13.9V/13.8V)-----------
Maybe it help to see what new codes shall I enter ?
Regards,
myounus
Northwest UK
C?ID=321059
Please can you clear all DTC's and run another scan. Thanks
dpasquazzo
Bahrain
C?ID=324791
here the latest:
Thursday,26,September,2019,16:37:59:57315
          5C 62 6D 72 77
VIN: WA1CFCFP7DA018393   Mileage: 68170km-42358miles
20-High Beam Assist. -- Status: Malfunction 0010
   Revision: --H09---
8 Faults Found:
15077 - Idle Control System RPM
          P0507 00 [237] - Higher than Expected.
                    Mileage: 68100 km
                    Date: 2019.09.22
                    Time: 16:05:43
                    Engine speed: 953.25 /min
                    Normed load value: 11.0 %
                    Coolant temperature: 91 °C
                    Intake air temperature: 81 °C
                    Voltage terminal 30: 14.160 V
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 3021 s
                    MAP_MES_SAE: 41 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.007 V
                    FUP_H_SAE: 7720.0 kPa
17169 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [175] - -
                    Fault Frequency: 13
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:45
                    Engine speed: 792.25 /min
                    Intake air temperature: 72 °C
                    ACC variants (coding): ACC
                    CCS Switch: no operating unit
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Control component verified: No
                    ACC variants: ACC
          P0068 00 [237] - -
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:55
                    Engine speed: 909.75 /min
                    Normed load value: 16.9 %
                    Vehicle speed: 7 km/h
                    Coolant temperature: 46 °C
                    Intake air temperature: 42 °C
                    Voltage terminal 30: 13.281 V
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 33 s
                    MAP_MES_SAE: 51 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.026 V
                    FAC_TPS_1_SAE: 11.718750 %
                    FAC_LAM_LIM[1]: -2.661 %
          U0415 00 [047] - -
                    Fault Frequency: 13
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:45
                    Engine speed: 804.75 /min
                    TOIL: 103 °C
                    Time since engine start: 949.2 s
                    T_ES: 0 min
          U0235 00 [047] - -
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:45
                    Engine speed: 797.00 /min
                    TOIL: 103 °C
                    Time since engine start: 949.6 s
                    T_ES: 0 min
14900 - Steering Effort Control Module
          U0130 00 [047] - No Communications
                    Fault Frequency: 9
                    Mileage: 68100 km
                    Date: 2019.09.22
                    Time: 16:06:26
                    Engine speed: 1267.00 /min
                    Normed load value: 17.6 %
                    Coolant temperature: 95 °C
                    Intake air temperature: 82 °C
                    Voltage terminal 30: 12.128 V
                    TOIL: 105 °C
                    Time since engine start: 0.6 s
                    T_ES: 0 min
15100 - MAP/MAF <-> Throttle Position Correlation
          P0068 00 [104] - -
                    Mileage: 68102 km
                    Date: 2019.09.22
                    Time: 16:28:39
                    Engine speed: 777.50 /min
                    Intake air temperature: 80 °C
                    Voltage terminal 30: 13.105 V
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 11 s
                    MAP_MES_SAE: 52 kPa
                    FAC_TPS_1_SAE: 10.546875 %
                    FUP_H_SAE: 10480.0 kPa
          P2279 00 [109] - -
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:55
                    Engine speed: 795.75 /min
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 8 s
                    MAP_MES_SAE: 51 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.012 V
                    FUP_H_SAE: 10990.0 kPa
Readiness: 0110 0001
   Revision: --H16---
   Coding: 027500
   Shop #: WSC 06335 123 12345
   VCID: 40CCAE31D35C204FD9-8014
8 Faults Found:
00494 - ESP-Sensor Unit (G419); Incorrect Component
                    Reset counter: 139
                    Mileage: 68100 km
                    Date: 2019.09.22
                    Time: 16:06:25
                    Hex Value: 0x00C0
                    Hex Value: 0x0782
                    Hex Value: 0x0005
                    Hex Value: 0xBE97
                    Hex Value: 0x00FF
                    Reset counter: 139
                    Mileage: 68100 km
                    Date: 2019.09.22
                    Time: 16:06:25
                    Hex Value: 0x00C0
                    Hex Value: 0x0782
                    Hex Value: 0x0028
                    Hex Value: 0x2A97
                    Hex Value: 0x00FF
                    Reset counter: 139
                    Mileage: 68100 km
                    Date: 2019.09.22
                    Time: 16:06:26
                    Hex Value: 0x00C0
                    Hex Value: 0x0782
                    Hex Value: 0x0016
                    Hex Value: 0x0396
                    Hex Value: 0x00FF
03110 - Active Steering Control Module (J792)
                    Reset counter: 139
                    Mileage: 68100 km
                    Date: 2019.09.22
                    Time: 16:06:26
                    Hex Value: 0x00C0
                    Hex Value: 0x0782
                    Hex Value: 0x000C
                    Hex Value: 0x8596
                    Hex Value: 0x00FF
03033 - ESP Sensor Unit 2 (G536)
                    Reset counter: 139
                    Mileage: 68100 km
                    Date: 2019.09.22
                    Time: 16:06:26
                    Hex Value: 0x00C0
                    Hex Value: 0x4282
                    Hex Value: 0x0023
                    Hex Value: 0xB897
                    Hex Value: 0x00FF
                    Reset counter: 139
                    Mileage: 68100 km
                    Date: 2019.09.22
                    Time: 16:06:26
                    Hex Value: 0x00C0
                    Hex Value: 0x4282
                    Hex Value: 0x0008
                    Hex Value: 0xB497
                    Hex Value: 0x00FF
                    Reset counter: 139
                    Mileage: 68100 km
                    Date: 2019.09.22
                    Time: 16:06:26
                    Hex Value: 0x00C0
                    Hex Value: 0x4282
                    Hex Value: 0x003E
                    Hex Value: 0x0597
                    Hex Value: 0x00FF
01119 - Gear Recognition Signal
                    Reset counter: 179
                    Mileage: 68105 km
                    Date: 2019.09.23
                    Time: 05:48:16
                    Hex Value: 0xA300
                    Hex Value: 0x4206
                    Hex Value: 0x100B
                    Hex Value: 0x27AE
                    Hex Value: 0x00FF
03286 - Sensor for Contact with Door Handle; Front Right
                    Reset counter: 135
                    Mileage: 68102 km
                    Date: 2019.09.22
                    Time: 16:28:23
   Coding: 642122C000
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:47
03220 - Stop Valve for Coolant for Climatronic (N422)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 135
                    Mileage: 68102 km
                    Date: 2019.09.22
                    Time: 16:28:08
   Coding: 01DD13
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:41
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:42
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:42
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:58:42
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:58:42
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:45
12660736 - Steering Effort Control Module
          U0130 00 [009] - No Communications
          [Active Steering Control Unit no communication]
                    Reset counter: 135
                    Mileage: 68100 km
                    Date: 2019.09.22
                    Time: 16:06:26
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:41
                    (no units): 44.0
                    Speed: 65025.0 km/h
                    Fault Frequency: 22
                    Reset counter: 0
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:42
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:42
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:42
   Coding: 80CF07FF00
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:42
                    Bin. Bits:    11111
                    Voltage: 13.80 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
   Revision: AA001002
                    Reset counter: 98
                    Mileage: 65506 km
                    Date: 2019.06.26
                    Time: 22:05:18
   Revision: 00000000
   Coding: 020202
   Coding: 010211
   Coding: 010211
262148 - Databus
          [Rain/light-sensor - no signal/no communication]
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:43
337166 - Databus
          [Braking ECU - readout error memory]
                    Fault Frequency: 13
                    Reset counter: 139
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:43
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:43
4205828 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Fault Frequency: 13
                    Reset counter: 139
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:43
                    Write only channel
          C10AC F0 [137] - Unknown Error Elaboration
          [Lenkungsendanschläge nicht angelernt]
                    Fault Frequency: 37
                    Reset counter: 139
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:43
                    Write only channel
4215041 - Control Module
          C109F 00 [137] - Incorrect Version Installed
          [Fehler bei Codierung Dynamik-Lenkung]
                    Fault Frequency: 13
                    Reset counter: 139
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:43
                    Write only channel
   Coding: 0203010102
          [FC_G_SENSOR_CALIBRATION_OOR]
                    Fault Frequency: 24
                    Reset counter: 139
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:43
                    Voltage terminal 30: 14.0 V
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
   Component: Display
                    Reset counter: 139
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:43
                    Bin. Bits: 00100000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00001010
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Reset counter: 135
                    Mileage: 68097 km
                    Date: 2019.09.22
                    Time: 15:57:52
   Coding: 0010390
End----------(Elapsed Time: 01:54, VBatt start/end: 11.7V/12.0V)-----------
dpasquazzo
Bahrain
C?ID=324791
I reset all codes once more :
Thursday,26,September,2019,16:45:45:57315
          5C 62 6D 72 77
   Revision: --H09---
          P1647 00 [167] - -
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:58
                    Engine speed: 0.00 /min
                    Coolant temperature: 34 °C
                    Intake air temperature: 38 °C
                    Voltage terminal 30: 12.148 V
                    ACC variants: ACC
          U0415 00 [039] - -
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:58
                    Coolant temperature: 35 °C
                    Engine: operating status: ES
                    ECU_STATE: ENG_STOP
                    TOIL: 33 °C
                    Time since engine start: 0.0 s
                    T_ES: 2188 min
          U0235 00 [039] - -
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:58
                    Voltage terminal 30: 12.167 V
                    ECU_STATE: ENG_STOP
                    TOIL: 33 °C
                    T_ES: 2188 min
   Revision: --H16---
   Coding: 027500
   Coding: 642122C000
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:54
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:59
   Coding: 01DD13
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:54
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:54
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:54
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:43:54
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:43:54
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:58
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:54
                    (no units): 44.0
                    Speed: 65025.0 km/h
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:54
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:55
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:55
   Coding: 80CF07FF00
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:55
                    Bin. Bits:    10111
                    Voltage: 12.10 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
   Revision: AA001002
                    Reset counter: 98
                    Mileage: 65506 km
                    Date: 2019.06.26
                    Time: 22:05:18
   Revision: 00000000
   Coding: 020202
   Coding: 010211
   Coding: 010211
262148 - Databus
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:56
337166 - Databus
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:56
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:56
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:55
                    Write only channel
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:55
                    Write only channel
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:55
                    Write only channel
   Coding: 0203010102
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:56
                    Voltage terminal 30: 12.1 V
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
   Component: Display
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:42:56
                    Bin. Bits: 00100000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00001010
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:43:04
   Coding: 0010390
End----------(Elapsed Time: 01:45, VBatt start/end: 12.1V/12.1V)-----------
dpasquazzo
Bahrain
C?ID=324791
any update on the coding for the steering angle ?
Regards
dpasquazzo
Bahrain
C?ID=324791
ok I did the procedure successfully.. still incorrect modult coding is there>
I open the long coding :
rear wiper [ok]
board computer installer [ok]
bit 2-3 Adaptive Cruise control ACC [0C I ticked the last one but in fact I am not sure]
bit 4-5 Multi function steering [MFL 30 I ticked the last option but in fact I am not sure]
bit 7 Lane change assiste, the mirror do have that option so I ticked it]
TOTAL 0000BF
now I need my workshop code ? importer value as well..
can you please help with this ?
dpasquazzo
Bahrain
C?ID=324791
here the lastest reset
Tuesday,01,October,2019,17:48:38:57315
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4505.4
          5C 62 6D 72 77
VIN: WA1CFCFP7DA018393   Mileage: 68240km-42402miles
   Revision: --H09---
   VCID: 73A631FDDA6ACBD7AA-8026
9 Faults Found:
          P1647 00 [175] - -
                    Fault Frequency: 13
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:47:38
                    Intake air temperature: 39 °C
                    ACC variants: ACC
          P0068 00 [237] - -
                    Mileage: 68188 km
                    Date: 2019.09.30
                    Time: 16:54:43
                    Normed load value: 15.3 %
                    Coolant temperature: 83 °C
                    Intake air temperature: 76 °C
                    Voltage terminal 30: 13.242 V
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 26 s
                    MAP_MES_SAE: 55 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.987 V
                    FAC_TPS_1_SAE: 11.328125 %
                    FAC_LAM_LIM[1]: 3.259 %
          U0415 00 [047] - -
                    Fault Frequency: 14
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:47:38
                    ECU_STATE: ENG_STOP
                    TOIL: 33 °C
                    T_ES: 2193 min
          U0429 00 [038] - -
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:16:43
                    Engine speed: 802.25 /min
                    Normed load value: 14.1 %
                    Intake air temperature: 88 °C
                    Voltage terminal 30: 13.789 V
                    TOIL: 105 °C
                    Time since engine start: 854.6 s
                    T_ES: 0 min
          U0235 00 [047] - -
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:47:38
                    ECU_STATE: ENG_STOP
                    TOIL: 33 °C
                    T_ES: 2193 min
                    Mileage: 68173 km
                    Date: 2019.09.30
                    Time: 15:24:55
                    Engine speed: 1433.00 /min
                    Coolant temperature: 33 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 11.699 V
                    TOIL: 33 °C
                    Time since engine start: 0.7 s
                    T_ES: 2193 min
15316 - MAP/MAF <-> Throttle Position Correlation
          P0068 00 [039] - -
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:02:38
                    Engine speed: 774.25 /min
                    Normed load value: 12.9 %
                    Coolant temperature: 84 °C
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 8 s
                    MAP_MES_SAE: 49 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.002 V
                    FAC_LAM_LIM[1]: 0.002 %
          P0068 00 [096] - -
                    Mileage: 68173 km
                    Date: 2019.09.30
                    Time: 15:25:49
                    Engine speed: 931.75 /min
                    Normed load value: 17.3 %
                    Vehicle speed: 10 km/h
                    Coolant temperature: 54 °C
                    Intake air temperature: 44 °C
                    Voltage terminal 30: 13.085 V
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 24 s
                    MAP_MES_SAE: 52 kPa
                    FAC_TPS_1_SAE: 12.109375 %
                    FUP_H_SAE: 11390.0 kPa
          P2279 00 [109] - -
                    Mileage: 68173 km
                    Date: 2019.09.30
                    Time: 15:25:49
                    Engine speed: 1219.00 /min
                    Normed load value: 16.1 %
                    Vehicle speed: 21 km/h
                    Coolant temperature: 64 °C
                    Voltage terminal 30: 13.476 V
                    Engine: operating status: PL
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 52 s
                    MAP_MES_SAE: 47 kPa
                    FAC_TPS_1_SAE: 12.890625 %
                    FUP_H_SAE: 8640.0 kPa
Readiness: 0010 0001
   Revision: --H16---
   VCID: 43C6A13DCA4A3B57FA-8016
   Coding: 027500
   VCID: 40CCAE31D35C204FE7-8014
8 Faults Found:
01486 - System Function Test Activated
                    Reset counter: 142
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:14:32
                    Hex Value: 0x0000
                    Hex Value: 0x4782
                    Hex Value: 0x0015
                    Hex Value: 0x31AD
                    Hex Value: 0x00FF
                    Fault Status: 00100101
                    Reset counter: 182
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:14:32
                    Hex Value: 0x0000
                    Hex Value: 0x4782
                    Hex Value: 0x0028
                    Hex Value: 0x2AAD
                    Hex Value: 0x00FF
                    Reset counter: 142
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:14:32
                    Hex Value: 0x0000
                    Hex Value: 0x4782
                    Hex Value: 0x0005
                    Hex Value: 0xBEAD
                    Hex Value: 0x00FF
                    Reset counter: 142
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:14:32
                    Hex Value: 0x0000
                    Hex Value: 0x4782
                    Hex Value: 0x0016
                    Hex Value: 0x03AD
                    Hex Value: 0x00FF
                    Reset counter: 142
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:14:32
                    Hex Value: 0x0000
                    Hex Value: 0x4782
                    Hex Value: 0x000C
                    Hex Value: 0x85AD
                    Hex Value: 0x00FF
                    Reset counter: 142
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:14:32
                    Hex Value: 0x0000
                    Hex Value: 0x4782
                    Hex Value: 0x0023
                    Hex Value: 0xB8AD
                    Hex Value: 0x00FF
                    Reset counter: 142
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:14:32
                    Hex Value: 0x0000
                    Hex Value: 0x4782
                    Hex Value: 0x003E
                    Hex Value: 0x05AD
                    Hex Value: 0x00FF
                    Reset counter: 182
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:14:32
                    Hex Value: 0x0000
                    Hex Value: 0x4782
                    Hex Value: 0x0028
                    Hex Value: 0x2AAD
                    Hex Value: 0x00FF
   VCID: 06407829B1F8CE7F9D-8052
                    Reset counter: 140
                    Mileage: 68198 km
                    Date: 2019.09.30
                    Time: 17:15:53
   Coding: 642122C000
   VCID: 383CC6D18B8C688F5F-806C
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:47:33
                    Reset counter: 140
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:47:38
   VCID: 77BE05EDC612A7F796-8022
   Coding: 01DD13
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:47:33
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:47:33
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:47:33
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:48:33
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:48:33
   VCID: 48DCB611F36C180F2F-801C
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:47:38
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.30
                    Time: 15:24:55
   VCID: 44C4A221C7443C6FC3-8010
                    Reset counter: 142
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:18:03
   VCID: 42C8A439DD50325FF1-8016
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:47:34
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:47:35
   Coding: 80CF07FF00
   VCID: 43C6A13DC24A3B57FA-8016
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:47:34
                    Bin. Bits:    10111
                    Voltage: 12.10 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
   Revision: AA001002
   VCID: 312AFBF568F6B9C718-8064
                    Reset counter: 142
                    Mileage: 65506 km
                    Date: 2019.06.26
                    Time: 22:05:18
   Revision: 00000000
   Coding: 020202
   VCID: 78BC06D1CB0CA88F9F-802C
   Coding: 010211
   VCID: 3E30D0C9A1A856BF95-806A
   Coding: 010211
262148 - Databus
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:47:36
337166 - Databus
                    Fault Frequency: 14
                    Reset counter: 142
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:47:36
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:47:36
   VCID: 4DD28705140EFD271C-8018
   VCID: 46C0B829F9780E7FDD-8012
          U1113 00 [008] - -
          [Fehlerwert "Lenkradwinkel"]
                    Reset counter: 182
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:16:43
                    Write only channel
          B1168 54 [008] - Missing Calibration / Basic Setting
                    Fault Frequency: 14
                    Reset counter: 182
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:47:35
                    Write only channel
                    Fault Frequency: 44
                    Reset counter: 142
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:47:35
                    Write only channel
                    Fault Frequency: 13
                    Reset counter: 142
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:47:35
                    Write only channel
   Coding: 0203010102
   VCID: 302CFEF163FCB0CF17-8064
   VCID: 4CD48A01EF14F42F0B-8018
   VCID: 383CC6D1838C688F5F-806C
                    Fault Frequency: 32
                    Reset counter: 142
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:47:36
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
   Component: Display
                    Fault Frequency: 11
                    Reset counter: 142
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:47:36
                    Bin. Bits: 00100000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00001010
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Reset counter: 139
                    Mileage: 68173 km
                    Date: 2019.09.26
                    Time: 16:47:44
   VCID: 46C0B829F1780E7FDD-8012
   VCID: 3B36D9DDBABA4397B2-806E
   Coding: 0010390
   VCID: 3D32D7C564AE4DA78C-8068
End----------(Elapsed Time: 01:48, VBatt start/end: 13.8V/13.8V)-----------
myounus
Northwest UK
C?ID=321059
You'll need to go into the gateway 19 and remove the ticks from the modules that the car does not have. 3C is lane change, 13 is ACC. Look at the steering wheel to see if it has controls on it.
dpasquazzo
Bahrain
C?ID=324791
OLD POST on same issue
old coding as per this post is 0000FF
could you please advise if I should use the old coding of this newly suggested (using longcoding help)???
myounus
Northwest UK
C?ID=321059
You don't need to use long coding. In the 'installation list' option you can see which modules are ticked and remove those ticks.
Module 19 CAN Gateway
dpasquazzo
Bahrain
C?ID=324791
I don't really understand the next step now..
I need to tick all the boxes in the long coding ? select all the relevant options ?
then I have a number 0000BF
and I will enter this code with the workshop number and Importer ?? can I be any values ??
press DO IT
and it should be good ?
Now why the coding is not the same as when the car had the faulty part on it (same part number) it was 0000FF
how come it changed to 0000BF ?
Regards
Per your email, I agree with the suggestion to correct the CAN Gateway Installation List. Modules that aren't installed should not be enabled in address 19 because it will cause conflicts.
https://www.ross-tech.com/vcds/tour/installation-list.php
Next, the earlier scan had 8K0 953 568 M coded to Coding: 0000FF
Sunday,26,August,2018,18:32:31:57315
Coding: 0000FF​
If you haven't done so already, code the replacement 16 module to that value with the non-zero suggested WSC/Importer/Equipment numbers of 12345 123 12345 followed by Do it. If those are rejected, you can use numbers such as 54321 321 54321 instead. The exact WSC/Imp/Equip numbers don't' matter as long as the coding is correct.
dpasquazzo
Bahrain
C?ID=324791
Coding: 0000FF​
step by step.. lots of errors but not I got back the control from steering but I lost the gearbox, it is not changing by itself ,-(
Wednesday,02,October,2019,20:46:09:57315
          62 6D 72 77
VIN: WA1CFCFP7DA018393   Mileage: 68290km-42433miles
20-High Beam Assist. -- Status: Not registered 0011
44-Steering Assist -- Status: Not registered 0011
   Revision: --H09---
10 Faults Found:
17178 - Databus
          U1123 00 [040] - Received Error Message
                    Mileage: 68253 km
                    Date: 2019.10.01
                    Time: 21:16:44
                    Engine speed: 1122.75 /min
                    Normed load value: 24.7 %
                    Coolant temperature: 59 °C
                    Intake air temperature: 57 °C
                    Voltage terminal 30: 11.718 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
          P0507 00 [096] - Higher than Expected.
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 18:11:34
                    Engine speed: 893.50 /min
                    Normed load value: 12.2 %
                    Coolant temperature: 99 °C
                    Intake air temperature: 70 °C
                    Voltage terminal 30: 14.101 V
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 802 s
                    MAP_MES_SAE: 44 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.978 V
                    FUP_H_SAE: 8650.0 kPa
18876 - Cruise Control Switch (E45)
          P0568 00 [039] - Implausible Signal
                    Mileage: 68291 km
                    Date: 2019.10.02
                    Time: 20:41:23
                    Engine speed: 801.50 /min
                    Coolant temperature: 96 °C
                    Intake air temperature: 74 °C
                    Voltage terminal 30: 13.964 V
                    CCS Switch: ACC operating unit
                    ACC variants: ACC
          P1647 00 [175] - -
                    Fault Frequency: 9
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:46
                    Engine speed: 804.50 /min
                    Coolant temperature: 92 °C
                    Intake air temperature: 90 °C
                    Voltage terminal 30: 13.945 V
                    ACC variants: ACC
          P0068 00 [172] - -
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:56
                    Voltage terminal 30: 13.925 V
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 8 s
                    MAP_MES_SAE: 51 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.943 V
                    FAC_LAM_LIM[1]: 1.305 %
          U0415 00 [047] - -
                    Fault Frequency: 9
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:46
                    Engine speed: 798.25 /min
                    Voltage terminal 30: 13.906 V
                    TOIL: 105 °C
                    Time since engine start: 3378.1 s
                    T_ES: 0 min
          U0235 00 [047] - -
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:46
                    Engine speed: 816.75 /min
                    TOIL: 105 °C
                    Time since engine start: 3378.5 s
                    T_ES: 0 min
                    Mileage: 68260 km
                    Date: 2019.10.02
                    Time: 05:32:33
                    Coolant temperature: 68 °C
                    Intake air temperature: 40 °C
                    Voltage terminal 30: 12.207 V
                    ECU_STATE: ENG_STOP
                    TOIL: 38 °C
                    T_ES: 0 min
          P0068 00 [039] - -
                    Mileage: 68261 km
                    Date: 2019.10.02
                    Time: 05:39:24
                    Engine speed: 830.00 /min
                    Coolant temperature: 52 °C
                    Intake air temperature: 49 °C
                    Voltage terminal 30: 13.203 V
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 12 s
                    MAP_MES_SAE: 44 kPa
                    FUP_H_SAE: 11440.0 kPa
          P2279 00 [047] - -
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:56
                    Engine speed: 791.00 /min
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 8 s
                    MAP_MES_SAE: 51 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.948 V
                    FUP_H_SAE: 11640.0 kPa
   Revision: --H16---
   Coding: 027500
8 Faults Found:
                    Fault Frequency: 8
                    Reset counter: 145
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:47
                    Hex Value: 0x0000
                    Hex Value: 0x4382
                    Hex Value: 0x0008
                    Hex Value: 0xB4AD
                    Hex Value: 0x00FF
                    Reset counter: 145
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 18:44:13
                    Hex Value: 0x0000
                    Hex Value: 0x0280
                    Hex Value: 0x0015
                    Hex Value: 0x319B
                    Hex Value: 0x00FF
                    Reset counter: 145
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 18:44:13
                    Hex Value: 0x0000
                    Hex Value: 0x0280
                    Hex Value: 0x0005
                    Hex Value: 0xBE9B
                    Hex Value: 0x00FF
                    Reset counter: 145
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 18:44:13
                    Hex Value: 0x0000
                    Hex Value: 0x0280
                    Hex Value: 0x0016
                    Hex Value: 0x039B
                    Hex Value: 0x00FF
                    Reset counter: 145
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 18:44:13
                    Hex Value: 0x0000
                    Hex Value: 0x0280
                    Hex Value: 0x0023
                    Hex Value: 0xB89B
                    Hex Value: 0x00FF
                    Reset counter: 145
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 18:44:19
                    Hex Value: 0x00C0
                    Hex Value: 0x0702
                    Hex Value: 0x003E
                    Hex Value: 0x0596
                    Hex Value: 0x00FF
                    Reset counter: 145
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 18:44:19
                    Hex Value: 0x00C0
                    Hex Value: 0x0702
                    Hex Value: 0x000C
                    Hex Value: 0x8596
                    Hex Value: 0x00FF
                    Reset counter: 185
                    Mileage: 68246 km
                    Date: 2019.10.01
                    Time: 18:47:40
                    Hex Value: 0x6600
                    Hex Value: 0x4306
                    Hex Value: 0x100B
                    Hex Value: 0x27AB
                    Hex Value: 0x00FF
                    Reset counter: 143
                    Mileage: 68260 km
                    Date: 2019.10.01
                    Time: 21:30:13
   Coding: 642122C000
                    Reset counter: 142
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:42
                    Reset counter: 142
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:47
   Coding: 01DD13
                    Reset counter: 142
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:41
                    Reset counter: 142
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:42
                    Reset counter: 142
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:42
                    Reset counter: 142
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:59:42
                    Reset counter: 142
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:59:42
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:46
                    Reset counter: 143
                    Mileage: 68260 km
                    Date: 2019.10.02
                    Time: 05:30:38
   Coding: 0000FF
                    Reset counter: 142
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:43
                    Reset counter: 142
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:43
   Coding: 80CF07FF00
                    Reset counter: 186
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:43
                    Bin. Bits:    11111
                    Voltage: 13.70 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 146
                    Mileage: 68291 km
                    Date: 2019.10.02
                    Time: 20:37:56
                    Bin. Bits:    11111
                    Voltage: 13.70 V
                    Count: 6
   Revision: AA001002
                    Reset counter: 142
                    Mileage: 65506 km
                    Date: 2019.06.26
                    Time: 22:05:18
   Revision: 00000000
   Coding: 020202
   Coding: 010211
   Coding: 010211
262148 - Databus
                    Reset counter: 142
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:44
337166 - Databus
                    Fault Frequency: 8
                    Reset counter: 145
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:44
                    Reset counter: 142
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:44
                    Fault Frequency: 21
                    Reset counter: 145
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:44
                    Write only channel
                    Fault Frequency: 8
                    Reset counter: 145
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:44
                    Write only channel
   Coding: 0203010102
                    Fault Frequency: 12
                    Reset counter: 145
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:44
                    Voltage terminal 30: 13.9 V
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
   Component: Display
                    Reset counter: 145
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:43
                    Bin. Bits: 00100000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00001010
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Reset counter: 142
                    Mileage: 68245 km
                    Date: 2019.10.01
                    Time: 17:58:52
   Coding: 0010390
End----------(Elapsed Time: 01:54, VBatt start/end: 13.8V/13.8V)-----------
There aren't any Transmission DTCs but the car is packed full of faults. The 1st thing I would correct is the removal of 20 and 44 from the Gateway [Installation List] :
44-Steering Assist -- Status: Not registered 0011​
After adding those back and using Save coding make sure to cycle the ignition and clear all fault codes in the vehicle.
Next, there are still numerous 03 and 44 DTCs that appear to be related to wrong coding or wrong control modules.
Were you ever able to get 03 to accept the factory coding of 2D554C per our earlier discussion?
Will 44 accept the coding values of 100000000001 or 100001000001 ? You have 44 coded for Dynamik-Lenkung (Dynamic Steering) which is not installed.
dpasquazzo
Bahrain
C?ID=324791
Got this SAFE stuff coming on now on the dashboard. no gages, overheading as fan control module goes on after 20 min drive..
          62 6D 72 77
VIN: WA1CFCFP7DA018393   Mileage: 68570km-42607miles
04-Steering Angle -- Status: Not registered 0001
15-Airbags -- Status: Not registered 0011
17-Instruments -- Status: Not registered 0011
20-High Beam Assist. -- Status: Not registered 0001
   Revision: --H09---
17178 - Databus
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:34:45
                    Coolant temperature: 70 °C
                    Voltage terminal 30: 12.031 V
          P0507 00 [039] - Higher than Expected.
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:35:49
                    Engine speed: 901.00 /min
                    Normed load value: 12.5 %
                    Coolant temperature: 82 °C
                    Intake air temperature: 69 °C
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 60 s
                    MAP_MES_SAE: 45 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FUP_H_SAE: 10440.0 kPa
          P0068 00 [039] - -
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:35:01
                    Engine speed: 880.50 /min
                    Coolant temperature: 71 °C
                    Voltage terminal 30: 13.378 V
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 12 s
                    MAP_MES_SAE: 44 kPa
                    FAC_LAM_LIM[1]: 0.841 %
          U0415 00 [039] - -
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:34:45
                    ECU_STATE: ENG_STOP
                    TOIL: 110 °C
                    T_ES: 63 min
          U0235 00 [047] - -
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:34:45
                    ECU_STATE: ENG_STOP
                    TOIL: 110 °C
                    T_ES: 63 min
          P2279 00 [039] - -
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:35:01
                    Voltage terminal 30: 13.398 V
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 12 s
                    MAP_MES_SAE: 44 kPa
                    FUP_H_SAE: 9980.0 kPa
   Revision: --H16---
   Coding: 027500
   Serial number: 0812000152086008
   Coding: 642122C000
                    Reset counter: 167
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:34:52
   Coding: 01DD13
                    Reset counter: 167
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:34:41
                    Reset counter: 167
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:34:41
                    Reset counter: 167
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:34:41
                    Reset counter: 167
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:35:45
                    Reset counter: 167
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:35:45
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:34:44
13697280 - Component Protection
          U1101 00 [137] - Active
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:34:43
   Coding: 0000FF
                    Reset counter: 167
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:35:42
                    Reset counter: 167
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:35:43
                    Reset counter: 167
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:35:43
   Coding: 80CF07FF00
                    Reset counter: 168
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:37:49
                    Bin. Bits:    11111
                    Voltage: 14.30 V
                    Count: 6
   Revision: AA001002
                    Reset counter: 163
                    Mileage: 65506 km
                    Date: 2019.06.26
                    Time: 22:05:18
   Revision: 00000000
   Coding: 020202
   Coding: 010211
   Coding: 010211
262148 - Databus
                    Reset counter: 167
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:34:43
337166 - Databus
                    Reset counter: 167
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:34:43
                    Reset counter: 167
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:34:43
                    Reset counter: 167
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:34:43
                    Write only channel
                    Reset counter: 167
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:34:43
                    Write only channel
   Coding: 0203010102
                    Reset counter: 167
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:34:44
                    Voltage terminal 30: 12.0 V
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
   Component: Display
                    Reset counter: 167
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:34:43
                    Bin. Bits: 00100000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00001010
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Reset counter: 167
                    Mileage: 68576 km
                    Date: 2019.12.21
                    Time: 15:34:51
   Coding: 0010390
End----------(Elapsed Time: 01:47, VBatt start/end: 14.4V/14.6V)-----------
dpasquazzo
Bahrain
C?ID=324791
Latest update..
Angle Steering look fine now
Tuesday,04,October,2022,12:08:51:57315
VCDS Version: 22.9.0.0 (x64)  HEX-NET CB: 0.4623.4
VIN: WA1CFCFP7DA018393   License Plate: Q5_6
Mileage: 90930km-56501mi   Repair Order:
          62 6D 72 77
VIN: WA1CFCFP7DA018393   Mileage: 90930km-56501miles
09-Cent. Elect. -- Status: Not registered 0011
2E-Media Player 3 -- Status: Not registered 0001
3C-Lane Change -- Status: Not registered 0011
77-Telephone -- Status: Not registered 0001
   Revision: --H09---    CVN: 9345A5A8
   ROD: EV_ECM20TFS0218R2907115.rod
   VCID: 73A631FDDA6ACB154E-8026
   VINID: 9D10535935A01D44400480C90C75A58E29
17178 - Databus
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:33:30
                    Engine RPM: 1044.25 /min
                    Normed load value: 11.4 %
                    Coolant temperature: 103 癈
                    Intake air temperature: 81 癈
                    Voltage terminal 30: 14.453 V
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:33:52
                    Engine RPM: 1034.00 /min
                    Normed load value: 11.8 %
                    Coolant temperature: 99 癈
                    Intake air temperature: 82 癈
                    Voltage terminal 30: 14.492 V
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 20 s
                    MAP_MES_SAE: 43 kPa
                    FUP_H_SAE: 7950.0 kPa
          P0068 00 [039] - -
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:33:40
                    Engine RPM: 1021.75 /min
                    Normed load value: 10.6 %
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 8 s
                    MAP_MES_SAE: 41 kPa
                    FAC_LAM_LIM[1]: -1.329 %
          U0415 00 [039] - -
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:33:30
                    Engine RPM: 1041.25 /min
                    Voltage terminal 30: 14.472 V
                    TOIL: 111 癈
                    Time since engine start: 1057.5 s
                    T_ES: 0 min
                    Cruise control switch actuation-Main switch: Not operated
                    Cruise control switch actuation-Set: Not operated
                    Cruise control switch actuation-Resume: Not operated
                    Cruise control switch actuation-Accelerate: Not operated
                    Cruise control switch actuation-DELAY: Not operated
                    Cruise control switch actuation-Cancel: Not operated
                    Cruise control switch actuation-Limit button: Not operated
                    Cruise control switch actuation-Large increment: Not operated
          U0235 00 [047] - -
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:33:31
                    Voltage terminal 30: 14.433 V
                    TOIL: 111 癈
                    Time since engine start: 1058.0 s
                    T_ES: 0 min
          P2279 00 [039] - -
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:33:40
                    Engine RPM: 1028.50 /min
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 8 s
                    MAP_MES_SAE: 41 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.982 V
                    FUP_H_SAE: 7370.0 kPa
   Revision: --H16---    CVN: C29C02CD
   VCID: 43C6A13DCA4A3B951E-8016
   Part No SW: 8R0 907 379 H    HW: 8R0 907 379 H
   Component: ESP8 quattro  H06 0110
   Coding: 12DD18
   Shop #: WSC 06334 123 12345
   VCID: 45C2BF25CC7E05A530-8010
   Shop #: WSC 06335 000 00000
   VCID: 06407829B1F8CEBD79-8052
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Coding: 642122C000
   VCID: 383CC6D18B8C684DBB-806C
                    Reset counter: 68
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 12:00:29
   VCID: 77BE05EDC612A73572-8022
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 10464314
   Coding: 024D25
   Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
                    Reset counter: 68
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:28:21
                    Reset counter: 68
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:28:21
                    Reset counter: 68
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:29:21
                    Reset counter: 68
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:29:21
   VCID: 48DCB611F36C18CDCB-801C
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:28:25
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Coding: 0000FF
   VCID: 44C4A221C7443CAD27-8010
   Coding: 4FC6220047010708010000
   VCID: 42C8A439DD50329D15-8016
                    Reset counter: 68
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:28:22
                    Reset counter: 68
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:28:22
   Coding: 80CF07FF00
   VCID: 43C6A13DC24A3B951E-8016
8 Faults Found:
                    Reset counter: 108
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:28:22
                    Bin. Bits:    11111
                    Voltage: 14.40 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 108
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:28:22
                    Bin. Bits:    11111
                    Voltage: 14.40 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
01327 - Control Module for Parking Aid (J446)
                    Reset counter: 108
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:28:22
                    Bin. Bits:    11111
                    Voltage: 14.40 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 108
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:28:26
                    Bin. Bits:    11111
                    Voltage: 14.40 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
03408 - Control Module for A/C Compressor
                    Reset counter: 108
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:28:26
                    Bin. Bits:    11111
                    Voltage: 14.40 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 68
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:28:27
                    Bin. Bits:    11111
                    Voltage: 14.40 V
                    Count: 6
00830 - Convertible Top Control Module (J256)
                    Reset counter: 108
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:35:24
                    Bin. Bits:    11111
                    Voltage: 14.40 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
03713 - Control Module for HV Battery Management
                    Reset counter: 108
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:41:49
                    Bin. Bits:    11111
                    Voltage: 14.30 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
   Revision: AA001002
   VCID: 312AFBF568F6B905FC-8064
                    Reset counter: 62
                    Mileage: 85788 km
                    Date: 2022.02.14
                    Time: 18:39:37
   Revision: 00000000
   Coding: 020202
   VCID: 78BC06D1CB0CA84D7B-802C
   Coding: 010211
   VCID: 3E30D0C9A1A8567D71-806A
   Coding: 010211
337166 - Databus
                    Reset counter: 68
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:28:23
                    Reset counter: 68
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:28:23
   VCID: 4DD28705140EFDE5F8-8018
   VCID: 46C0B829F9780EBD39-8012
   Part No SW: 8K0 907 064 GR    HW: 8K0 907 064 FR
   Component: BCM2 2.0      H11 0621
   Coding: 0203010102
   VCID: 302CFEF163FCB00DF3-8064
   VCID: 4CD48A01EF14F4EDEF-8018
   Revision: --------    Serial number: 10000000167564
   VCID: 383CC6D1838C684DBB-806C
262656 - No Basic Setting
          B2010 00 [137] - -
          [FC_ASSEMBLY_CHECK_NOT_DONE]
                    Reset counter: 68
                    Mileage: 75503 km
                    Date: 2020.12.06
                    Time: 19:09:22
                    Voltage terminal 30: 14.6 V
                    Internal Fault ID: 67
                    Yellow warning lamp: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Reset counter: 68
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 12:03:39
                    Voltage terminal 30: 13.1 V
                    Function light in parking brake button: On
                    Red operating lamp: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Status ParkingBrake left: applied
                    Status ParkingBrake right: applied
   Component: Display
                    Reset counter: 68
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:28:23
                    Bin. Bits: 00100000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00001010
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
            003 - Mechanical Failure
                    Reset counter: 68
                    Mileage: 90938 km
                    Date: 2022.10.04
                    Time: 11:28:31
   VCID: 46C0B829F1780EBD39-8012
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   VCID: 3B36D9DDBABA435556-806E
   Coding: 0010390
   VCID: 3D32D7C564AE4D6568-8068
End----------(Elapsed Time: 01:48, VBatt start/end: 13.0V/14.2V)-----------
