A6 C6 4F 2006 Australia
I removed rear seat base cushion to access fuel pump connections under seat to replace fuel lines.
On reinstalling seat cushion I now have the Air Bag light on with the following VCDS Fault Coding
Monday,16,September,2019,13:09:12:28258
VCDS Version: Release 19.6.1 (x64) Running on Windows 10 x64
Address 15: Airbags Labels: 4F0-910-655-8R.CLB
Control Module Part Number: 4F0 910 655 E HW: 4F0 959 655 B
Component and/or Version: 4F AIRBAG AUDI8RH29 0280
Software Coding: 0013382
Work Shop Code: WSC 02325 785 00200
VCID: 290FFC4915FFC46FBD7-807C
01220 - Rear Side Airbag Igniter; Passenger Side (N202)
002 - Lower Limit Exceeded - MIL ON
I have not been able to reset the fault code using VCDS.
There are two airbag sensor/switches at the rear base of the seat and I believe it to be the left one on a right hand drive vehicle.
Both appear in good condition however the left one moves more on its mounting frame.
Has anyone else had a similar issue after removing the rear seat.
A Google search has not really identified any cause or solution.
Vehicle scan Below
Vehicle scan Below
Monday,16,September,2019,09:40:34:28258
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ4F07N011459 License Plate:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 56
61 62 72 76 77
VIN: WAUZZZ4F07N011459 Mileage: 139020km-86383miles
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F1 910 559 R HW: 4F1 907 559 D
Component: 3.2l V6 FSI 0020
Revision: --H19--- Serial number:
Coding: 01050003190F0120
Shop #: WSC 02325 785 00200
VCID: 3A2D3305E0597FF7C4D-806E
012425 - Signal Line for Fuel Pump Electronics
P3089 - 007 - Electrical Malfunction - Intermittent
Reset counter: 38
Mileage: 139001 km
Mass Air / Rev.: 0.0 mg/str
Temperature: 43.5°C
Engine Off
Pressure: 0.7 bar
Part No SW: 4F2 910 156 G HW: 09L 927 156 C
Component: AG6 09L 3.2 FSI RdW 0010
Revision: --H01--- Serial number: 4190458
Coding: 0000001
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0060
Coding: 0020895
VCID: 6695B775C4612B17505-8032
Component: FBSAUDIC6 ELV H31 0210
Revision: 27120501 Serial number: 10601000446366
Coding: 0000023
Shop #: WSC 02323 785 00200
VCID: 6393AE6137535E3FB7B-8036
Subsystem 1 - Part No: 4F0 910 131 C
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Subsystem 3 - Part No: 4F0 910 220 F
Component: FBSAUDIC6 IDG H01 0060
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 731 D HW: 4E0 035 729
Component: Interfacebox H43 2830
Revision: 00000000 Serial number: 350ET067690907
Shop #: WSC 02335 785 00200
VCID: 2313EE6177D31E3FF7B-8076
Component: Bedienteil MMIC6H02 0060
Subsystem 2 - Serial number: 00000000429279
Subsystem 3 - Serial number: 0130.05.060000000100010553ÿ
Subsystem 4 - Serial number: 010553ÿ
Part No SW: 4F0 910 043 HW: 4F2 820 043 M
Component: KLIMABETAETIGUNGH20 0170
Revision: 00000030 Serial number: 00000030129589
Coding: 0533574
VCID: 5BE396810F2366FFFFB-800E
Part No SW: 4F0 910 279 L HW: 4F0 907 279 B
Component: ILM Fahrer H17 0240
Coding: 0000101
VCID: 323D1B25382987B70CD-8066
Subsystem 1 - Part No: 4F2 910 113 A
Component: Wischer AudiC6 H04 0190
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH12 0090
Coding: 00146221
Shop #: WSC 02335
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8127872
VCID: 1C61D59D4AAD21C7361-8048
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4F AIRBAG AUDI8RH29 0280
Revision: 08H29000 Serial number: 0037LD0EZU5%
Coding: 0013382
Subsystem 1 - Serial number: 6332CSME0F4D196BK
Subsystem 2 - Serial number: 6342CSME0F4D1942A
Subsystem 3 - Serial number: 6352QSME1002503B%
Subsystem 4 - Serial number: 6362QSME100936614
Subsystem 5 - Serial number: 63734SME105A3831W
Subsystem 6 - Serial number: 63834SME0E6E03095
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90026061510265
Coding: 0102141
Component: Lenkradmodul H07 0090
Part No SW: 4F0 910 900 C HW: 4F0 920 901 B
Component: KOMBIINSTR. M73 H12 0070
Revision: 00100000 Serial number: 58T149X56
Coding: 2049743
Shop #: WSC 07484 002 1048576
VCID: 2019E16D66C50527EA9-8074
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 130080660380B7
Coding: ECFE53C41B3104
Shop #: WSC 22050 822 66649
VCID: 270BFA7103EBF21FAB3-8072
Part No SW: 4E0 910 888 J HW: 4E0 919 887 D
Component: MNS ECE H47 1040
Revision: 00000000 Serial number: 364EP067560605
VCID: 35372039C947908F29F-8060
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00000000 Serial number: X•d
Coding: 0016922
Shop #: WSC 02327 785 00200
VCID: 2C01055D1A0DD147461-8078
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01014147500000
Coding: 0263565
Shop #: WSC 20110 822 84911
VCID: 2E050F552C11A357685-807A
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 G HW: 4F0 035 223
Component: Amp.-ASK H10 0350
Revision: 43S00001 Serial number: 00606060289420
Coding: 0000007
VCID: 221DEB6568C91737FCD-8076
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000245085
Coding: 0001014
VCID: 5EE59F951C3173D7985-800A
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00000000 Serial number: &Pe
Coding: 0016922
Part No SW: 4F0 910 801 B HW: 4F0 907 801 A
Component: EPB CB4C0060 H04 0060
Revision: --H04---
Coding: 0005021
Shop #: WSC 02324 785 00200
VCID: 1F1BE2915BBB3ADFD33-804A
Part No SW: 4E0 910 541 M HW: 4F0 035 541 E
Component: TUNER EU/US/RDW H42 0570
Revision: 00000000 Serial number: 352ES067653932
Coding: 0000001
VCID: 2A0D034510F9CF77B4D-807E
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000046577
Component: von VA0 2606021515
Coding: 344630393135313035442056413032363036303231353135
Shop #: WSC 00000 384 00290
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0016386
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0016386
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 E HW: 4F0 919 283 E
Component: Parkhilfe 8-Kan H12 0030
Revision: 00H12000 Serial number: 11820615200508
Coding: 0201006
VCID: 2615F77504E1EB17905-8072
Part No SW: 4E0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H13 0700
Revision: 00000000 Serial number: 00000007542638
Coding: 0010990
End----(Elapsed Time: 02:21, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
