Octavia Long coding help
NWT
C?ID=22843
Hi Guys
Have a 2016 Skoda Octavia 1.6tdi here. Customer had another car with faulty fuel gauge in the cluster and tried to swap clusters over to confirm problem was in the cluster.
So now as usual ABS coding lost on both cars.
Can anyone please help with possible coding for ABS.
thanks
uesday,16,July,2019,13:57:21:30982
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: TMBKG7NE4G0160555   License Plate: GC65NNU
Mileage: 121203km-75312mi   Repair Order:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 20 42 44 52 5F
VIN: TMBKG7NE4G0160555   Mileage: 121203km-75312miles
Address 01: Engine (2D2D2-CXXB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 056 CL    HW: 04L 907 445 B
   Component: R4 1.6l TDI   H06 2506
   Revision: 22004001
   Coding: 01114012432519090000
   Shop #: WSC 63751 002 1048576
   ASAM Dataset: EV_ECM16TDI03004L906056CL 002006
   ROD: EV_ECM16TDI03004L906056_002_VW37.rod
   VCID: 79BAE047F8A05487DE-802C
25126 - Databus
          U1123 00 [035] - Received Error Message
                    Mileage: 121203 km
                    Date: 2019.07.16
                    Time: 13:34:53
                    Coolant temperature: 52 °C
                    Intake air temperature: 50 °C
                    Voltage terminal 30: 12.234 V
                    CAN status - engine control module: 0
                    Cruise Control System (CCS): status: main switch off
Readiness: N/A
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 63385000002760
   Shop #: WSC 73430 031 00063
   ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
   VCID: 4BD66A8FE2BC16173C-801E
8 Faults Found:
0195 - Control module not coded
          U1013 00 [137] - -
          [ECU marked as Not Configured because vehicle ID is invalid]
                    Reset counter: 9
                    Date: 2019.07.16
                    Time: 13:34:52
0212 - Longitudinal Acceleration Sensor
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 9
                    Date: 2019.07.16
                    Time: 13:34:52
0270 - Lateral Acceleration Sensor
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 9
                    Date: 2019.07.16
                    Time: 13:34:52
0279 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 9
                    Date: 2019.07.16
                    Time: 13:34:52
0295 - Steering angle sensor
                    Reset counter: 9
                    Date: 2019.07.16
                    Time: 13:34:52
8278 - Control Module Incorrectly Coded
          U1014 00 [137] - -
          [FCAN: Mismatch between bytecoding and Lenkerposition signal]
                    Reset counter: 9
                    Date: 2019.07.16
                    Time: 13:34:52
8306 - Databus
          U1122 00 [137] - Implausible Message
          [FCAN: Unplausible VIN number]
                    Reset counter: 9
                    Mileage: 121203 km
                    Date: 2019.07.16
                    Time: 13:34:57
8308 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
                    Reset counter: 9
                    Date: 2019.07.16
                    Time: 13:34:52
   Part No SW: 5E0 907 044 Q    HW: 5E0 907 044 Q
   Component: Climatronic   H04 1002
   Revision: 00001K07
   Coding: 02110104002100011005000000101000
   VCID: 3326126F9A4C6ED754-8066
   Air quality sensor:
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 86580812152840
   Coding: 0F000942424702FB07A04082B10C07280000000000000000000000000000
   Shop #: WSC 73430 790 00063
   ROD: EV_BCMBOSCH_015.rod
   VCID: 034682AF8A6C1E5784-8056
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 150925  041 0570
   Serial number:         151027060949
   Coding: 065DDD
   Component: RLHS  037 0059
   Serial number: S4Y15M12D16H07M00S33
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY152570EGW
   Component: Sirene, DWA  005 0312
   Serial number: 00000000000033863520
   Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0054
   Revision: --------    Serial number: 39291534201177
   Coding: 0001050001
   ASAM Dataset: EV_EPHVA14AU3700000 002024
   VCID: 3C343953B712A1AF85-8068
13637426 - Databus
                    Reset counter: 9
                    Mileage: 121203 km
                    Date: 2019.07.16
                    Time: 13:34:51
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V1.clb
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 23111503213186
   Coding: 00000200FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   VCID: 3A383F4BBD269F9F97-806E
1071 - Databus
          [FAULT_CIS_AXV_INVALID]
                    Reset counter: 9
                    Mileage: 121203 km
                    Date: 2019.07.16
                    Time: 13:34:51
                    Control Module temperature: 27 °C
                    Voltage terminal 15: 12.0 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 9
                    Mileage: 121203 km
                    Date: 2019.07.16
                    Time: 13:34:51
1059 - Databus
          [FAULT_CIS_ESP_FAIL]
                    Reset counter: 9
                    Mileage: 121203 km
                    Date: 2019.07.16
                    Time: 13:34:51
1078 - Databus
          [FAULT_CIS_SAS_INIT]
                    Reset counter: 9
                    Mileage: 121203 km
                    Date: 2019.07.16
                    Time: 13:34:51
   Part No SW: 3Q0 959 655 AS    HW: 3Q0 959 655 AS
   Component: Airbag VW20   013 0200
   Revision: --------    Serial number: 003SQPRGC5S+
   Coding: 98CCC000000000005C5400CC008800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 0F6EBE9FD6246A3710-805A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 612 15
   Serial number: 3576U000000B3089B71F
   Subsystem 2 - Part No SW: -----------    HW: 454 000 512 15
   Serial number: 3586U0000003D795871J
   Subsystem 3 - Part No SW: -----------    HW: 454 802 511 15
   Serial number: 3516REC4FF808000000W
   Subsystem 4 - Part No SW: -----------    HW: 454 800 212 15
   Serial number: 3526R8A014E090000003
   Subsystem 5 - Part No SW: -----------    HW: 454 801 410 15
   Serial number: 3556VF222D1080000007
          B13BC F2 [137] - No function
                    Mileage: 121203 km
                    Date: 2019.07.16
                    Time: 13:34:51
   Part No SW: 5Q0 953 521 M    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20151210500480
   Coding: 1400
   ROD: EV_SMLSVALEOMQB.rod
   Part No SW: 5E0 920 951 B    HW: 5E0 920 951 B
   Component: KOMBI         324 6422
   Coding: 27A40A002180A60001886A011000000000000000
   VCID: 2600FB3B599E0B7FC3-8072
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 9
                    Mileage: 121203 km
                    Date: 2019.07.16
                    Time: 13:34:51
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1244
   Revision: --------    Serial number: 0004245273
   Coding: 030100045F087300EB000248080F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000D0387271115
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185704001512132637
Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
   Part No SW: 5G0 857 511 D    HW: 5G0 857 511
   Component: FLA           H04 0002
   Revision: AA001001
   Coding: 01028F6B76765D525220343E01
   ASAM Dataset: EV_HighBeamAssisAU37X 001009
   ROD: EV_HighBeamAssisAU37X.rod
   VCID: 2B160A0F427C36171C-807E
   Component: TSG FS        010 0031
   Serial number: 0000178773848
   Coding: 00150020D001040000001100
   VCID: 47DE56BFFED4F27718-8012
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000008319031
   Coding: 1D0200
   Component: EPS_MQB_ZFLS  125 1063
   Coding: 8103
   VCID: 44C441B3CFE2D96FFD-8010
15873 - Steering angle sensor
                    Reset counter: 9
                    Mileage: 121203 km
                    Date: 2019.07.16
                    Time: 13:34:51
                    Motor status: 00
                    Supply voltage: 11.75 V
                    Temperature: 27.0 °C
                    KFC: 3E
                    KFA: 00 01
                    Environmental conditions: 5F
                    uioUdNotFilt_xdu16: 11.91 V
                    uAdSensI_SwitchedKl30_xdu16: 11.91 V
   Component: TSG BFS       010 0031
   Serial number: 0000178897502
   VCID: 46C05BBBF9DEEB7FE3-8012
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000008353717
   Coding: 050200
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 874 A    HW: 5Q0 035 874 A
   Component: MU-S-ND-ER    H24 0245
   Serial number: SKZAZ2R8132372
   Coding: 03730201FF00000011111201008800002F0200C601200100C6
   ROD: EV_MUStd4CTSAT_VW41.rod
   VCID: 3228176B655667DF5F-8066
   Subsystem 1 - Part No SW: 5E0 919 605 J    HW: 5E0 919 605 J
   Component: ABT_Std-2_Nav  H41 1028
   Serial number: SKZ8Z9RBT01AZF
          U1111 00 [009] - -
                    Reset counter: 9
                    Mileage: 121203 km
                    Date: 2019.07.16
                    Time: 13:34:54
                    Voltage terminal 30: 11.9 V
                    BAP-BAP_Function_ID: 02
7206 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 9
                    Mileage: 121203 km
                    Date: 2019.07.16
                    Time: 13:34:54
End----------(Elapsed Time: 01:38, VBatt start/end: 12.1V/12.0V)-----------
NWT
C?ID=22843
Hi Peter
We only got car after dash had already been swapped.
DrPeter
16.4905° S, 151.7375° W
Hi Peter
- Sorry to hear that, the coding is vehicle specific and it does not look like we have any details about this controller's coding. It looks like the vehicle will need to be coded with an online connection to the manufacture with the factory (ODIS) scan tool using the Software-Version-Management (SVM) test plan.
drpeter
ps... Would anyone else have an Auto-Scan??? :)
NWT
C?ID=22843
Ok, thanks anyway Peter. Thanks for the info.
NWT
C?ID=22843
Thanks soo much Boki Ar. Car did accept coding but does have a few communication errors in other modules, and still fault stored for coding. No coding helper at all to try and correct vehicle specs. Still managed to adapt most sensors as well except steering angle sensor. Will take car out later and try that again.
Saturday,20,July,2019,08:51:39:30982
VIN: TMBKG7NE4G0160555   License Plate: 20.7.19
   Revision: 22004001
25126 - Databus
                    Mileage: 121203 km
                    Date: 2019.07.20
                    Time: 08:45:08
                    Engine speed: 845.00 /min
                    Normed load value: 38.4 %
                    Coolant temperature: 17 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 14.953 V
Readiness: N/A
   Coding: 1C0762911426096C007C060541C8243846289000608224F200400070C002
                    Reset counter: 9
                    Date: 2019.07.20
                    Time: 08:45:07
          U1014 00 [137] - -
                    Reset counter: 9
                    Date: 2019.07.20
                    Time: 08:45:07
8299 - Databus
          [FCAN: Anhaenger_01_alt veraltet bit is set]
                    Reset counter: 9
                    Date: 2019.07.20
                    Time: 08:45:07
16412 - Display for Tire Pressure Monitoring
                    Reset counter: 9
                    Mileage: 121203 km
                    Date: 2019.07.20
                    Time: 08:45:16
16413 - Display for Tire Pressure Monitoring
                    Reset counter: 9
                    Mileage: 121203 km
                    Date: 2019.07.20
                    Time: 08:45:16
   Revision: 00001K07
   Air quality sensor:
   Coding: 065DDD
   Coding: 00885D
   Coding: 0001050001
13637426 - Databus
                    Reset counter: 9
                    Mileage: 121203 km
                    Date: 2019.07.20
                    Time: 08:45:06
1071 - Databus
                    Reset counter: 49
                    Mileage: 121203 km
                    Date: 2019.07.20
                    Time: 08:45:06
                    Control Module temperature: 21 °C
                    Voltage terminal 15: 14.8 V
1058 - Databus
                    Reset counter: 9
                    Mileage: 121203 km
                    Date: 2019.07.20
                    Time: 08:45:09
                    Voltage terminal 15: 14.6 V
1059 - Databus
                    Reset counter: 9
                    Mileage: 121203 km
                    Date: 2019.07.20
                    Time: 08:45:06
1078 - Databus
                    Reset counter: 9
                    Mileage: 121203 km
                    Date: 2019.07.20
                    Time: 08:45:06
          B13BC F2 [008] - No function
                    Mileage: 121203 km
                    Date: 2019.07.20
                    Time: 08:45:06
   Coding: 1400
   Revision: AA001001
   Coding: 1D0200
   Coding: 8103
19204 - Databus
          [ESP_02 Botschaft - SNA_Check]
                    Reset counter: 49
                    Mileage: 121203 km
                    Date: 2019.07.20
                    Time: 08:45:06
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 14.50 V
                    Temperature: 24.0 °C
                    KFC: 4B
                    KFA: 00 04
                    Environmental conditions: 25
                    uioUdNotFilt_xdu16: 14.72 V
                    uAdSensI_SwitchedKl30_xdu16: 14.71 V
                    Reset counter: 9
                    Mileage: 121203 km
                    Date: 2019.07.20
                    Time: 08:45:06
                    Motor status: 01
                    KFC: 3E
                    KFA: 00 01
                    uioUdNotFilt_xdu16: 14.42 V
                    uAdSensI_SwitchedKl30_xdu16: 14.41 V
   Coding: 050200
End----(Elapsed Time: 01:38, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
