Relative compression test, make the car crank but not start
TregR5
New Member
Norway
hexa193-00c6ea-3db555-bd85c3-tqiahh-5e69
I have a 2005 Touareg with R5 engine and I want to perform a relative compression test. Therefore I need to make the car crank but not start. Is it possible to do something in VCDS to prohibit the car from starting?
TregR5
New Member
Norway
Oh hello, sorry, was maybe a little fast posting my question without any introduction. A little info about me: I have cars and motorbikes as a hobby and are interested in car/motorcycle diagnostics. I have now put my VCDS serial number, in my profile. I dont need to scan my car, but are interested if VCDS are able to prohibit my car from starting when cranking it. Do you know if it is possible and if so, what the procedure is? I am going to take a relative compression test with my oscilloscope so therefore i need to crank for some seconds. Thanks.
Viking
C?ID=151455
The requirement for an autoscan is so that people know what hardware and such related stuff your particular car has. One answer for one person may not be relevant to another person with a similar car.
TregR5
New Member
Norway
Thanks for the information. I will do the auto scan tomorrow and post the result.
DGMotors
C?ID=57532
Unplug crank/cam sensors or unplug the PD injector loom where it goes into the cylinder head - it will throw fault codes but you have VCDS to remove them after.
TregR5
New Member
Norway
I got a bit delayed with the job but now I have performed it.
I did unplug the PD injector loom and was then able to crank for as long as needed, thank you! The concern I have is a P0304 fault code which was the initial reason I wanted to perform a relative compression test. Is this cylinder no.4 or is it cylinder no.4 in the firing sequence (which is cylinder no.5)? Does anyone have an idea what might set this fault code? The results from the relative compression test seems ok, but I have not performed it a lot of times. I notice that the engine starts vibrating, which off course seems natural since one of the cylinders does not fire properly, when the fault code is set. It seems that this happens when engine are "semi warm", not at cold state and not at fully warm state. Attached is the report from the auto-scan.
Sunday,12,May,2019,16:26:23:46421
VCDS Version: 18.9.1.0 (x64)
VIN: WVGZZZ7LZ5D001609   License Plate:
Mileage: 196740km-122248mi   Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZZZ7LZ5D001609   Mileage: 196740km-122248miles
   Part No SW: 070 997 016 E    HW: 028 101 125 8
   Component: R5 2,5L EDC G001AG  9769
   Revision: 12345678    Serial number: VWZ3Z0D1205352
   Coding: 0011175
   Shop #: WSC 31414 000 00000
   VCID: 1C37968EDC1E92AA21-515E
16502 - Engine Coolant Temp. Sensor (G62)
            P0118 - 000 - Signal too High - Intermittent
                    RPM: 1554 /min
                    Torque: 202.5 Nm
                    Speed: 44.0 km/h
                    Load: 31.0 %
                    Voltage: 14.36 V
                    Bin. Bits: 00001000
                    Temperature: 47.7°C
                    Temperature: 36.9°C
16688 - Cylinder 4
            P0304 - 000 - Misfire Detected
                    RPM: 756 /min
                    Torque: 102.5 Nm
                    Load: 0.0 %
                    Voltage: 13.91 V
                    Inj. Quantity: 2.96 mg/str
                    Temperature: 51.3°C
                    (no units): 0.0
Readiness: 0 0 0 X 1
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No: 09D 927 750 BP
   Component: AL 750 6A           0560
   Coding: 0004136
   VCID: 7DF1BB0A27443BA2B6-515E
   Part No SW: 3D0 909 135 J    HW: 5WK 470 21
   Component:    Kessy            6400
   Coding: 0000232
   VCID: 2C57464E8CBE622A51-515E
   Subsystem 1 - Part No: 4E0 905 852 D
   Component: ELV                 1834
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 H
   Component: CLIMAtronic R/L   X 3716
   Coding: 0000030
   VCID: 3561632A5FF423E23E-5140
02193 - Supply Voltage for Regulator for Fresh Air Blower
            010 - Open or Short to Plus
00353 - Function Return Message from Fresh Air Blower Regulator
                    Voltage: 14.40 V
                    Voltage: 11.83 V
                    Voltage: 0.00 V
                    Voltage: 14.00 V
            014 - Defective
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 K
   Component:                     2703
   Coding: 0103677
   Shop #: WSC 00795 218 05193
   VCID: 44870EEE042E8A6AB9-515E
            000 -  -
Address 15: Airbags        Labels: 3D0-909-601.lbl
   Part No: 3D0 909 601 E
   Component: 0B Airbag 8.4E+ H10 0951
   Coding: 0012354
   VCID: 2541B36AEF5453628E-5140
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 D
   Component: Lenksäulenmodul     3301
   Coding: 0000031
   VCID: 408F02FE1036964A9D-5140
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 880 M
   Component: KOMBIINSTRUMENT RB8 2935
   Coding: 0005111
   Shop #: WSC 00795 218 92423
   VCID: 418907FA1B3C9F4292-5140
Address 18: Aux. Heat        Labels: 7L6-819-008.clb
   Part No: 7L6 815 071 B
   Component: Standheizung  E1MAC 0235
   Coding: 0000000
   VCID: 3169573AAB9C0FC262-5140
   Part No: 6N0 909 901
   Component: Gateway K<>CAN      0101
   Coding: 0000006
   VCID: 70EF923E601646CA2D-5140
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0122
   VCID: 7F0D41022D4829B2A4-5140
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  0001
   Coding: 0000003
   VCID: 66C3F46652D2987A47-5140
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 F
   Component: LUFTFDR.-CDC- 3C3P1 3081
   Coding: 0015521
   VCID: 3663642642F228FA37-5140
   Part No: 7L0 959 760
   Component: Sitzverstellung     0702
   VCID: 77FDA922057811F2EC-5140
Address 37: Navigation        Labels: 7L6-919-887-CD.lbl
   Part No: 7L6 919 887 B
   Component:      Navigation     0629
   VCID: 458113EA0F14B362AE-5140
Address 39: Right Light        Labels: 3D0-909-158.lbl
   Part No: 3D0 909 158
   Component: EVG GDL+AutoLWR(r)  0001
   Coding: 0000003
   VCID: 67DDF96255D881727C-5140
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L0 959 933 G
   Component: 1N HSG              3213
   Coding: 0000065
   Shop #: WSC 00490 218 186825
   VCID: 408F02FE1036964A9D-4AE8
   Subsystem 1 - Part No: 7L0 959 701 A
   Subsystem 2 - Part No: 7L0 959 702 A
   Subsystem 3 - Part No: 7L0 959 703
   Subsystem 4 - Part No: 7L0 959 704
   Subsystem 5 - Part No: 7L0 907 719
   Component:    Neigungssensor   0020
   Subsystem 6 - Part No: 7L6 951 171
   Component: A  Innenraumsensor  0019
Address 56: Radio        Labels: 7L6-035-186-CD.lbl
   Part No: 7L6 035 186 A
   Component:        Radio        0629
   Coding: 0007447
00878 - Connection to Speaker Front Left
00881 - Connection to Speaker Rear Right
Address 68: Wiper Electr.        Labels: 7L0-955-119-V1.clb
   Part No: 7L0 955 119 F
   Component: Front Wiper         2416
   Coding: 0000004
   Shop #: WSC 31414 000 376832
   VCID: 377D692245F8D1F22C-515E
Address 76: Park Assist        Labels: None
   Part No: 7L0 919 283 E
   Component: 0E Einparkhilfe     0907
   VCID: 387F6A1E48E6DE8A25-515E
Address 77: Telephone        Labels: Redir Fail!
   Part No: 7L6 035 729 E
   Component: CIB PAH  HW 202 SW  0307
   Coding: 0000372
End-------------------------(Elapsed Time: 08:22)--------------------------
I would suggest fixing the G62 fault first and then see again whether the misfire is still present.
TregR5
New Member
Norway
I am working on the G62 now, the sensor seems to give a stable resistance and it is increasing with decreasing temperatur. Anyone know how likely it could it be that the sensor itself could be intermitently working? I am also very open for suggestions regarding the misfire since I suspect that these two faults codes are separate issues, even though I think it is a good idea to focus on the G62. Thank you.
