Audi A8L ACC issue - 00234 Misadjusted
W12BTW
C?ID=357694
Hi guys,
my ACC stopped working a week ago. Just stopped working and pulling the following error. Tried to clear the error but still coming on. I did also check the measuring blocks and this is what is recorded. It comes up with Error code on Group 1 ?
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4E0 910 561 F HW: 4E0 907 561 F
Component: ABSTANDSREGELUNGH03 0020
Coding: 0041251
Shop #: WSC 02313 785 00200
VCID: 2517F333A9EB2BBFCDB-8070
00234 - Sensor for Automatic Distance Regulation Misadjusted
000 - - - Intermittent - MIL ON
Fault Status: 10110000
Reset counter: 90
Mileage: 178716 km
Date: 2019.03.30
Time: 13:17:00
Temperature: 35.0°C
Voltage: 11.39 V
Bin. Bits: 00100000
Have you inspected the sensor to check if it shows any signs of having gotten whacked or being loose in its mount?
W12BTW
C?ID=357694
Hi,
thans for the reply. It Looks perfect and clean no visual damages or movement.
W12BTW
C?ID=357694
Hi all,
just for all which might have the same issue. It just needed re-calibration which you can do if you have VCDS.
Just curious:
What procedure did you use with VCDS?
Did you set up the proper targets?
W12BTW
C?ID=357694
Hi,
i have Hex V2. I did looked into other posts and information from other forums.
I did use the basic settings option and selected the group 001,002,003 and pressed the on/off/next button 2 times. Which did fix the issue.
Newtonzsul
Brazil
Hi,
Hi Sr. How did you do that exactly? " I did use the basic settings...". I dont get that. If possible, please, tell me step to step, cuz thats my first experience with my Hex V2. Thanks a lot!
Flaps_84
Norway
C?ID=394321
Here's the step-by-step in deep detail. I'm finishing up my calibration after a rock got caught up behind the radar and the steel bracket which over time made the one upper left adjusting screw to get lose from the plastic nut/keeper. I've ordered an repair kit of the three screws including the plastic nut/keepers and then re-calibrated as told in the article linked down bellow. In my case I only have one radar sensor at the front right side, but the procedure are identical except you will have different "bank numbers". Do some measurements and write down distance between the steel bracket and the radar sensor; the length of each of the three screws before any ajustments is made so it's easy to go back if something get worse. Between every small adjustments, take ta car for a spin and drive some miles. Then go back in your garage and read the new missalignment and check if your value of missalignment are moving up or down, then adjust again accordingly to the new value. You have to repeat this proccess over and over until you get as close to 0 degree as posible. Keep in mind that you have to reset/basic settings for every drive after every read outs to make the "brain" calculate new missalignment. In my case it was the bank 001, 002, 003, 004. The bank 004 is the hard master reset you have to do when all the others are back to 0.000 degrees which automatically happen when you push the basic settings ON then OFF for each bank 001, 002, 003. If you only do a reset of bank 001, 002, 003 and 004 without doing any adjustment to the radar, then the fault is only temporarily fixed until the "brain" calculate the missalignment beeing too big and then lock out the ACC telling "ACC not available". In order to do the basic settings you will need to enter the "Security Access code", which are: 91153.
Best regards,
Eirik Larsson
Hi, glad to see you had Success! I noticed your VCDS release is 18.9.1 ; the latest version is available 21.3.0 !
Flaps_84
Norway
C?ID=394321
Where did you see it's telling 18.9.1?
I've updated both the VCDS cable and PC software two weeks ago last time I was home from sea (my work).
Post #1 screen shot ; the top header line
Flaps_84
Norway
C?ID=394321
Ohhh, that's not me.
I just updated this thread to my experience 😁
