In my golf V+ 1.4tfsi i found this problem :
Tuesday,29,January,2019,12:55:29:44995
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4436.4
VIN: WVWZZZ1KZBW565250 License Plate:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZBW565250 Mileage: 116980km-72688miles
Address 01: Engine (CAV) Labels: 03C-906-027-CAV.clb
Part No SW: 03C 906 027 BA HW: 03C 907 309 B
Component: MED17.5.5 G 5860
Revision: LAH16--- Serial number:
Coding: 0000077
VCID: 619CAC6A9D43563FF13-8034
P0300 - 000 -
Mileage: 116988 km
Date: 2013.06.21
Time: 01:09:24
RPM: 2143 /min
Load: 13.7 %
Temperature: 87.0°C
Temperature: 32.0°C
Absolute Pres.: 930.0 mbar
Voltage: 13.970 V
000770 - Cylinder 2
P0302 - 000 - Misfire Detected
Mileage: 116988 km
Date: 2013.06.21
Time: 01:09:24
RPM: 2143 /min
Load: 13.7 %
Temperature: 87.0°C
Temperature: 32.0°C
Voltage: 13.970 V
000772 - Cylinder 4
P0304 - 000 - Misfire Detected
Mileage: 116988 km
Date: 2013.06.21
Time: 01:09:27
RPM: 2192 /min
Load: 14.1 %
Temperature: 87.0°C
Temperature: 31.0°C
Voltage: 13.843 V
004874 - Cylinder Disabling
P130A - 000 - - MIL ON
Fault Status: 11100000
Mileage: 116988 km
Date: 2013.06.21
Time: 01:09:32
RPM: 2193 /min
Load: 15.3 %
Temperature: 87.0°C
Temperature: 30.0°C
Voltage: 13.843 V
Readiness: 1110 0101
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 050 F HW: 0AM 927 769 D
Component: GSG DSG AG7 403 2321
Revision: 00040034 Serial number: CU501102075952
VCID: 2C020D5EAA01CB57125-8078
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 243B600D212800FF240D06E984190040310800
VCID: 76B6EF3628CDC187B41-8022
Part No SW: 5K0 907 044 DT HW: 5K0 907 044 DT
Component: Climatronic H17 1010
Revision: 00003001
Coding: 0000000002
VCID: 005A89EE7A89FF379ED-8054
Address 09: Cent. Elect.
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 5K0 919 475 E HW: 5K0 919 475 E
Component: PARKHILFE 8K H01 0012
Revision: -------- Serial number: 12501102702391
Coding: 108102
VCID: 382A210E625977F766D-806C
Part No SW: 5C0 959 655 C HW: 5C0 959 655 C
Component: AirbagVW10 013 0613
Serial number: 003G6R01BVY0
Coding: 00003831
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 323E132684A59DA7589-8066
Subsystem 1 - Part No SW: 5M0 955 557 HW: 5M0 955 557
Serial number: 3572MSME3464335BZZZW
Subsystem 2 - Part No SW: 5M0 955 557 HW: 5M0 955 557
Serial number: 3582MSME2405655BZZZW
Serial number: 3511HSME382D2626ZZZN
Serial number: 3521HSME08682626ZZZK
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Revision: -------- Serial number: 90422KB600024
Coding: 1892140000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76B6EF36284DC187B41-8022
Component: E221__MFL-TK6 H06 0022
Serial number: 40000000000000270163
Coding: E30000
Part No SW: 5M0 920 871 HW: 5M0 920 871
Component: KOMBI H20 0420
Coding: 170B00
VCID: 6D84C05A5D1B025F45B-8038
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 110211F1001834
Coding: 359002
VCID: 303A192E8A29AFB72ED-8064
Component: IMMO H20 0420
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8ECB466CF51567209-803E
Part No SW: 5K0 959 701 G HW: 5K0 959 701 G
Component: Tuer-SG 009 2101
Coding: 0000180
VCID: 36362F36644D8187741-8062
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
VCID: 3432153E723193974A5-8060
Address 46: Central Conv.
Part No SW: 5K0 959 702 G HW: 5K0 959 702 G
Coding: 0000436
VCID: 372822326347788F6F7-8062
Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 01000000 Serial number: VWZ1Z2L0311567
Coding: 0500040004
VCID: 6B80CE42638F0C6F5BF-803E
03138 - Input AUX IN
Reset counter: 21
Mileage: 116896 km
Date: 2013.06.16
Time: 22:50:31
Part No SW: 5K0 959 703 E HW: 5K0 959 703 E
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 01357 011 1012552
Part No SW: 5K0 959 704 E HW: 5K0 959 704 E
Coding: 0000144
End----------(Elapsed Time: 00:56, VBatt start/end: 13.8V/13.8V)-----------
