Trouble purge 7r golf cooling system
vario
France
C?ID=351985
Hello To start sorry for the spelling I'm french
So here I have a problem I have in my possession a golf 7r 2017 I have to perform a bleed coolant is impossible to find the procedure on VCDS if someone can help me
thank you in advance
Mari
C?ID=150535
Maybe I'm wrong, but if you want to get the air put of the cooling-system, just fill the cooling tank and run the motor without putting the lid on the cooling tank. Air can escape and you can keep coolant on level. I have seen that doing to my car several times!
vario
France
C?ID=351985
Yes, but it is not good for the circuit I have a friend who can do it but he uses ODIS so I think it is possible to do it with VCDS
Mari
C?ID=150535
... when they did it to my car, a computer was connected, so they probably used ODIS also (not sure, didn't look at the computer screen at that time)...
obdauto
France
C?ID=274086
with Basic settings IDE05231 we can"t arrive to make bleed air from coolant
is there a solution ?
 Vendredi,04,Janvier,2019,10:23:42:22998
VCDS -- Logiciel d'Èmulation de VAG/VAS sous Windows 7 x64
Version VCDS: FRM 18.9.0.2  HEX-V2 CB: 0.4436.4
Version donnÈes: 20180927 DS296.0
www.rosstech.fr
VIN: WVWZZZAUZJW110929   Plaque d'immat.: FA414FA
KilomÈtrage: 33000   Ordre rÈparation::
Type chassis: AU-VW37 (3Q0)
Scanner: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 39 3C 42 44
          47 4B 52 5F A5 A9 D6 D7
01-Moteur -- Etat: DÈfaut 0010
02-Boite auto -- Etat: OK 0000
03-Freins ABS -- Etat: OK 0000
05-Autor. dÈmarrage -- Etat: OK 0000
08-Climatronic -- Etat: DÈfaut 0010
09-Centrale Elec. -- Etat: DÈfaut 0010
10-Assistance stationnt -- Etat: OK 0000
13-RÈgulation dist. -- Etat: OK 0000
14-Amortisseurs -- Etat: OK 0000
15-Airbags -- Etat: OK 0000
16-Volant multifonct. -- Etat: OK 0000
17-Instruments -- Etat: OK 0000
19-Gateway CAN -- Etat: OK 0000
22-Transm. intÈgrale -- Etat: OK 0000
29-Feu gauche -- Etat: OK 0000
2B-Verr. Col. Direct. -- Etat: OK 0000
39-Feu droit -- Etat: OK 0000
3C-Chgt de file -- Etat: OK 0000
42-Porte conducteur -- Etat: OK 0000
44-Direction assistÈe -- Etat: OK 0000
47-Sonorisation -- Etat: OK 0000
4B-Module Multifonc. -- Etat: OK 0000
52-Porte passager -- Etat: OK 0000
5F-Electr. d'informat. -- Etat: OK 0000
A5-Capt Av. Assist. Cond. -- Etat: OK 0000
A9-Son portÈ par structure -- Etat: OK 0000
D6-Ctrl feu gauche 2 -- Etat: OK 0000
D7-Ctrl feu droit 2 -- Etat: OK 0000
Adresse 01: Moteur (J623-DJHA)       Labels:. 06K-907-425-V1.clb
   No. piËce Log: 8V0 906 259 J    Mat: 06K 907 425 B
   PiËce: 2.0l R4 TFSI  H13 0003
   RÈvision: --H13---
   Codage: 092500122466050B3004
   No. Atelier: WSC 01357 011 00200
   Jeu de donnÈes ASAM: EV_ECM20TFS0208V0906259J 001005
   ROD: EV_ECM20TFS0208V0906259J_VW37.rod
   VCID: 47CB59014F28695F1FF-8012
2 Codes dÈfaut trouvÈs:
21388 - Soupape de volet de gaz d¥Èchappement 1 (N321) Rupture
          P3019 00 [047] - -
          ConfirmÈ - TestÈ depuis R‡Z mÈmoire
             Capture:
                    Etat du dÈfaut: 00000001
                    PrioritÈ du dÈfaut: 2
                    FrÈquence du dÈfaut: 1
                    KilomÈtrage: 33868 km
                    Date: 2018.12.28
                    Temps: 19:58:14
                    RÈgime moteur: 0.00 /min
                    Valeur de charge normÈe: 0.0 %
                    Vitesse du vÈhicule: 0 km/h
                    TempÈrature du liquide de refroidissem.: 86 ∞C
                    TempÈrature air d'admission: 47 ∞C
                    Pression de l'air ambiant: 1020 mbar
                    Tension borne 30: 12.304 V
                    Compteur de dÈsapprentissage selon OBD: 40
                    Moteur: Ètat de fonctionnement: ES
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 103 kPa
                    Tension sonde l.: banc 1: sonde 1 (sonde lambda large bande): 1.968 V
                    FAC_TPS_1_SAE: 16.015625 %
                    FUP_H_SAE: 9700.0 kPa
21399 - Soupape de volet de gaz d¥Èchappement 2 (N322) Rupture
          P3023 00 [047] - -
             Capture:
                    Date: 2018.12.28
                    Temps: 19:58:14
                    T_AST_SAE: 0 s
Tests passÈs: 0000 0000
Adresse 02: Boite auto (J743)       Labels:. 0BH-927-711.clb
   No. piËce Log: 0GC 300 012 A    Mat: 0GC 927 711 G
   PiËce: GSG DQ381     H06 1401
   RÈvision: 00H06V07
   Codage: 0014
   No. Atelier: WSC 00000 000 00000
   Jeu de donnÈes ASAM: EV_TCMDQ381061 001
   ROD: EV_TCMDQ381061.rod
   VCID: 211FE799814C776FB1B-8074
Aucun code dÈfaut trouvÈ.
Adresse 03: Freins ABS (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   No. piËce Log: 5Q0 614 517 CF    Mat: 5Q0 614 517 AD
   PiËce: ESC           H25 0513
   RÈvision: 00000000    No. de sÈrie: 62787000001019
   Codage: 01FA6BA15421216C4780070240CC6980D62A84E2E0029677384250F8C2A8430000000012121212B835351919323200
   Jeu de donnÈes ASAM: EV_Brake1UDSContiMK100IPB 036010
   VCID: 77ABE9C17F48D9DFAFF-8022
Adresse 05: Autor. dÈmarrage (J518)       Labels:| 5Q0-959-435.clb
   No. piËce Log: 5Q0 959 435 C    Mat: 5Q0 959 435
   PiËce: VWKESSYMQB    021 0803
   RÈvision: 00021000    No. de sÈrie: 0457671186
   Codage: 032C0C
   Jeu de donnÈes ASAM: EV_KessyHellaMQBAB 002020
   VCID: 3C2136ED06EE3A8782D-8068
Adresse 08: Climatronic (J255)       Labels:| 5G0-907-044.clb
   No. piËce Log: 5G0 907 044 CF    Mat: 5G0 907 044 CF
   PiËce: Climatronic   H04 1801
   RÈvision: 00001K08
   Codage: 0002001420011001110500000010102A
   Jeu de donnÈes ASAM: EV_ACClimaBHBVW37X 006145
   VCID: 6D87CBA90D14630F453-8038
   Calculateur de soufflante d'air frais (avant):
   Transmetteur de pression/de tempÈrature de fluide frigorigËne:
   Capteur de qualitÈ d'air:
1 Code dÈfaut trouvÈ:
262914 - Pression fluide frigorigËne
          B10AB F0 [009] - Trop basse
             Capture:
                    Compteur de RAZ: 193
                    KilomÈtrage: 33893 km
                    Date: 2018.12.29
                    Temps: 15:28:58
                    TempÈrature extÈrieure: 12.0 ∞C
                    RÈgime moteur: 1500 /min
                    Courant du compresseur: valeur effective: 0.000 A
                    TempÈrature en aval de l'Èvaporateur: 14.3 ∞C
                    Temps de fonctionnement syst.-DurÈe de fonctionnement du moteur: 5 s
                    Temps de fonctionnement syst.-Borne 15 ON: 5 s
Adresse 09: Centrale Elec. (J519)       Labels:. 5Q0-937-08X-V2.clb
   No. piËce Log: 5Q0 937 084 CP    Mat: 5Q0 937 084 CF
   PiËce: BCM MQBAB M+  H36 0253
   No. de sÈrie: 01001728901984
   Codage: 000000000000000000000000000000000000000000000000000000000000
   Jeu de donnÈes ASAM: EV_BCMMQB 018001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 08499A3D02B6A627D65-805C
   Appareil de commande de moteur d'essuie-glace:
   Sous-systËme 1 - No. piËce Log: 5G1 955 119 A    Mat: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   PiËce: WWS    170926  043 0551
   No. de sÈrie:         171005094347
   Codage: 0E4DDD
   DÈtecteur de pluie et de luminositÈ:
   Sous-systËme 2 - No. piËce Log: 5Q0 955 547 B    Mat: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   PiËce: RLHS  047 0105
   No. de sÈrie: S5Y17M10D16H21M27S40
   Codage: 00A8DD
   Capteur d'alarme antivol:
   Sous-systËme 3 - No. piËce Log: 5Q0 951 172     Mat: 5Q0 951 172
   PiËce: Sensor, DWA  005 0316
   No. de sÈrie: 000000000ZY172450GJD
   Avert. d'alarme:
   Sous-systËme 4 - No. piËce Log: 5Q0 951 605 A    Mat: 5Q0 951 605 A
   PiËce: Sirene, DWA  005 0314
   No. de sÈrie: 00000000000039365950
   Calculateur d'ouverture/fermeture de toit coulissant:
   Sous-systËme 5 - No. piËce Log: 8V3 959 591 A    Mat: 8V3 959 591 A
   PiËce: J245 PS73.404  H04 0005
   No. de sÈrie: 0000FST001TNFJF00000
   Codage: 181801
204546 - ClÈ avec radiocommande 2
          B147A 18 [009] - Courant trop ÈlevÈ
             Capture:
                    PrioritÈ du dÈfaut: 4
                    Compteur de RAZ: 192
                    Date: 2018.12.28
                    Temps: 20:05:58
Adresse 10: Assistance stationnt (J446)       Labels:| 5Q0-919-294.clb
   No. piËce Log: 5QA 919 294 B    Mat: 5QA 919 294
   PiËce: PDC 8 KanalH07 0044
   No. de sÈrie: 000308418617287
   Codage: 0471155811
   Jeu de donnÈes ASAM: EV_EPHVA18AU3700000 009035
   VCID: 4BC3653153408D3F3B7-801E
Adresse 13: RÈgulation dist. (J428)       Labels:| 3Q0-907-572.clb
   No. piËce Log: 5Q0 907 572 J    Mat: 3QF 907 572
   PiËce: ACC BOSCH MQB H10 0654
   Codage: 330067C159FFC728949C810580400600000000000000000000
   Jeu de donnÈes ASAM: EV_ACCBOSCHVW416 002006
   VCID: 3E253CE510F22897AC9-806A
Adresse 14: Amortisseurs (J250)       Labels: 5Q0-907-376.clb
   No. piËce Log: 5Q0 907 376 B    Mat: 5Q0 907 376 A
   PiËce: DAEMPFUNGS-SG H17 0121
   No. de sÈrie: 19091741350624
   Jeu de donnÈes ASAM: EV_DRCONTITEMIC 001019
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 38292AFD32D616A7665-806C
Adresse 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   No. piËce Log: 5Q0 959 655 BH    Mat: 5Q0 959 655 BH
   PiËce: AirbagVW21    005 0336
   No. de sÈrie: 003VVR3GCHFQ
   Codage: 98CCC000000000005C0000CF000800000065
   Jeu de donnÈes ASAM: EV_AirbaVW20SMEVW37X 002158
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 074B99010FA8A95FDFF-8052
   Capteur de collision du sac gonflable latÈral: cÙtÈ conducteur:
   Sous-systËme 1 - No. piËce Log: -----------    Mat: 480 001 710 17
   PiËce: SideSensor_Df  001 0887
   No. de sÈrie: 3570000000044129982B
   Codage: 2D2D2D
   Capteur de collision de sac gonflable latÈral: cÙtÈ passager:
   Sous-systËme 2 - No. piËce Log: -----------    Mat: 480 001 710 17
   PiËce: SideSensor_Pf  001 0887
   No. de sÈrie: 35800000000FBA41182P
   Codage: 2D2D2D
   Capteur de collision du sac gonflable latÈral AR: cÙtÈ cond.:
   Sous-systËme 3 - No. piËce Log: -----------    Mat: 480 401 310 17
   PiËce: SideSensor_Dr  000 6149
   No. de sÈrie: 3510001C9274279674A3
   Codage: 2D2D2D
   Capteur de collision du sac gonflable latÈral AR: cÙtÈ pass.:
   Sous-systËme 4 - No. piËce Log: -----------    Mat: 480 401 310 17
   PiËce: SideSensor_Pr  000 6149
   No. de sÈrie: 3520001A12742795E590
   Codage: 2D2D2D
   Capteur de collision du sac gonflable frontal: cÙtÈ conducteur:
   Sous-systËme 5 - No. piËce Log: -----------    Mat: 480 401 710 17
   PiËce: FrontSensor_D  000 6149
   No. de sÈrie: 3550001C92685271838%
   Codage: 2D2D2D
Adresse 16: Volant multifonct. (J527)       Labels:| 5Q0-953-549.clb
   No. piËce Log: 5Q0 953 507 HN    Mat: 5Q0 953 549 E
   PiËce: Lenks. Modul  003 0140
   RÈvision: --------    No. de sÈrie: 10101704221396
   Codage: 0C10
   Jeu de donnÈes ASAM: EV_SMLSKLOMQB 020002
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 094F9F3919BCDF2FC9B-805C
Adresse 17: Instruments
Impossible ‡ contacter
Adresse 19: Gateway CAN (J533)       Labels:| 3Q0-907-530-V1.clb
   No. piËce Log: 3Q0 907 530 G    Mat: 3Q0 907 530 C
   PiËce: GW MQB High   518 5304
   No. de sÈrie: 10101710800316
   Codage: 030100047F085900FB00827A9C0F00010001070000000000000000000000
   Jeu de donnÈes ASAM: EV_GatewNF 013023
   ROD: EV_GatewNF_VW48.rod
   VCID: 33331DD12BB0F5FF537-8066
   Alternateur:
   Calculateur de volant de direction multifonction:
   Sous-systËme 2 - No. piËce Log: 5G0 959 442 N    Mat: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   PiËce: E221__MFL-DC1  H11 0040
   No. de sÈrie: 29170002158900067386
   Codage: 2DFFFF
   Calculateur de surveillance de la batterie:
   Sous-systËme 3 - No. piËce Log: 5Q0 915 181 K    Mat: 5Q0 915 181 K
   PiËce: J367-BDMHella  H10 9070
   No. de sÈrie: 9923225504
Adresse 22: Transm. intÈgrale (J492)       Labels:* 0CQ-907-554.clb
   No. piËce Log: 0CQ 907 554 J    Mat: 0CQ 525 130
   PiËce: Haldex4Motion H52 7084
   No. de sÈrie: HA1-00011.08.17
   Codage: 0001
   Jeu de donnÈes ASAM: EV_AllWheelContrHA1VW37X 004013
   VCID: 4CC1662D564E8A0732D-8018
Adresse 29: Feu gauche (J1018)       Labels: 8V0-907-399.clb
   No. piËce Log: 8V0 907 399 D    Mat: 8V0 907 399 D
   PiËce: LCM_MLBevoH08 0014
   Jeu de donnÈes ASAM: EV_LCMLeftHELLAAU736 001012
Adresse 2B: Verr. Col. Direct. (J764)       Labels:* 5Q0-905-861.clb
   No. piËce Log: 5Q0 905 861 A    Mat: 5Q0 905 861 A
   PiËce: ELV-MQBA      H01 0120
   RÈvision: 00000000    No. de sÈrie: 17000290404004
   Codage: 5D00000000000000
   Jeu de donnÈes ASAM: EV_ELVMarquMQB 004111
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311ECD2EBEF2C74AD-8060
Adresse 39: Feu droit (J1023)       Labels: 8V0-907-399.clb
   Jeu de donnÈes ASAM: EV_LCMRightHELLAAU736 001012
Adresse 3C: Chgt de file (J1086)       Labels:| 5Q0-907-686.clb
   No. piËce Log: 5Q0 907 686 C    Mat: 5Q0 907 686 C
   PiËce: HRE_Master    H12 0080
   No. de sÈrie: 0456699955
   Codage: 02011103
   Jeu de donnÈes ASAM: EV_HREntryHella 001028
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D273BE91DF4338FB53-8068
   Calculateur 2 d'assistant de changement de voie:
   Sous-systËme 1 - No. piËce Log: 5Q0 907 685 C    Mat: 5Q0 907 685 C
   PiËce: HRE_Slave  H12 0080
   No. de sÈrie: 0455957990
   Codage: 020111
Adresse 42: Porte conducteur (J386)       Labels:| 5QX-959-X93-42.clb
   No. piËce Log: 5Q0 959 593 E    Mat: 5Q0 959 593 B
   PiËce: TSG FS        020 0041
   No. de sÈrie: 021017EJ112544
   Codage: 003F1220D000040000001000
   Jeu de donnÈes ASAM: EV_DCUDriveSideEWMAXKLO 006003
   VCID: 43D34D117B10457FC37-8016
   Calculateur de porte cÙtÈ conducteur: arriËre:
   Sous-systËme 1 - No. piËce Log: 5Q0 959 811 D    Mat: 5Q0 959 811 D  Labels: 5QX-959-81X-V1.CLB
   PiËce: FOND_FHSG_DRV  006 0007
   No. de sÈrie: 00000000000016851370
   Codage: 110000
Adresse 44: Direction assistÈe (J500)       Labels:| 5Q0-909-144.clb
   No. piËce Log: 3Q0 909 144 K    Mat: 3Q0 909 144 H
   PiËce: EPS_MQB_ZFLS  506 5072
   Codage: 9107
   Jeu de donnÈes ASAM: EV_SteerAssisMQB 013144
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2D30F50CDA04B7901-806E
Adresse 47: Sonorisation (J525)       Labels:| 5Q0-035-456.clb
   No. piËce Log: 5Q0 035 456 A    Mat: 5Q0 035 456 A
   PiËce: MIB2_lite_amp H40 0200
   RÈvision: 00000001    No. de sÈrie: VWZ8Z1HMD01172X
   Codage: 12000000008AAA8A000000000000
   Jeu de donnÈes ASAM: EV_AMPMst11CGen2ALPI 001003
   ROD: EV_AMPMst11CGen2ALPI.rod
   VCID: 2E050CA5C092D8173C9-807A
Adresse 4B: Module Multifonc. (J745)       Labels:* Aucun
   No. piËce Log: 3Q0 907 338     Mat: 3Q0 907 338
   PiËce: FCM MQB Low   002 0286
   No. de sÈrie: 06101710803868
   Codage: 000000050100165206204F01020000000000000000000000000000000000
   Jeu de donnÈes ASAM: EV_MultiModulContiVW48X 001010
   VCID: 72BDD8D5142ABCF7981-8026
Adresse 52: Porte passager (J387)       Labels:| 5QX-959-X92-52.clb
   No. piËce Log: 5Q0 959 592 E    Mat: 5Q0 959 592 B
   PiËce: TSG BFS       020 0041
   No. de sÈrie: 300917EIU02511
   Codage: 003F1020DE00040000801000
   Jeu de donnÈes ASAM: EV_DCUPasseSideEWMAXKLO 006003
   VCID: 42DD4815640A4C77C81-8016
   Calculateur de porte arriËre cÙtÈ passager: arriËre:
   Sous-systËme 1 - No. piËce Log: 5Q0 959 812 D    Mat: 5Q0 959 812 D  Labels: 5QX-959-81X-V1.CLB
   PiËce: FOND_FHSG_PSG  006 0007
   No. de sÈrie: 00000000000016942355
   Codage: 090000
Adresse 5F: Electr. d'informat. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
   No. piËce Log: 5NA 035 020 A    Mat: 5NA 035 020
   PiËce: MU-H-ND-EU    H54 1161
   No. de sÈrie: A845J0HS020034
   Codage: 02731001000000004111010200880A231F0107F4012004009F
   Jeu de donnÈes ASAM: EV_MUHig4CGen2HBAS 001001
   VCID: 2F3B11A1C798D11F37F-807A
   UnitÈ d'affichage et de commande†1 pour Èlectronique d'info.:
   Sous-systËme 1 - No. piËce Log: 5G6 919 606     Mat: 5G6 919 606
   PiËce: ABT_High-2  H50 9130
   No. de sÈrie: VWZ6ZJT2831072
   Support de donnÈes:
   Sous-systËme 2 - No. piËce Log: V03 959 800 QQ    Mat: -----------
   PiËce: ECE 2017  --- 0157
   No. de sÈrie: --------------------
   Base de donnÈes Compact Disc:
   Sous-systËme 3 - No. piËce Log: V03 959 800 EG    Mat: -----------
   PiËce: Gracenote2  --- 1016
Adresse A5: Capt Av. Assist. Cond. (R242)       Labels:| 3Q0-980-65X-A5.clb
   No. piËce Log: 3Q0 980 654 H    Mat: 3Q0 980 654 A
   PiËce: MQB_B_MFK     H07 0272
   No. de sÈrie: 13101712K21068
   Codage: 0003070000000401002223548150A90094000E300040
   Jeu de donnÈes ASAM: EV_MFKBoschMQBB 001001
Adresse A9: Son portÈ par structure (J869)       Labels: 4H0-907-159.clb
   No. piËce Log: 5G0 907 159 D    Mat: 4H0 907 159 A
   PiËce: SAS-GEN 2     H07 0001
   No. de sÈrie: 170920201111
   Jeu de donnÈes ASAM: EV_SoundActuaGen2AU64X 003010
Adresse D6: Ctrl feu gauche 2 (A31)       Labels: 7PP-941-572.clb
   No. piËce Log: 7P5 941 572 A    Mat: 7P5 941 572 A
   PiËce: LED1L         H06 0002
   Jeu de donnÈes ASAM: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 392F2FF909DC0FAF99B-806C
Adresse D7: Ctrl feu droit 2 (A27)       Labels: 7PP-941-572.clb
   PiËce: LED1R         H06 0002
   Jeu de donnÈes ASAM: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxR_KEBODAVW481.rod
Fin----(Temps ÈcoulÈ: 02:14, VBatt dÈbut/fin: 12.1V/11.7V. Vign 11.8V)-----
darkchina811
ITALY
C?ID=333184
this is what the mechanic told me to do, and I did, when I had to disconnect a hose to insert the Webasto in series with the circuit. I know the official procedure uses a device that screws on the coolant tank and create vacuum.
I never had any problem using the old-school method. so now I am asking you professional mechanics, why is the vacuum machine better and what is the risk when doing old-school?
MasterTommy
Amsterdam
C?ID=295586
Are you talking from experience with this specific model of car? Because newer TDI’s (and probably anything else with a charge cooler) really do need to be bled using VCDS/ODIS. The low-(charge cooler, EGR, engine block) and high (cylinder head, turbo’s, DPF’s, etc) temperature coolant circuits share the same fluid reservoir, but are only directly linked during very specific engine conditions. Running the bleed procedure opens up all valves (and probably engages all 2/3 fluid pumps at 100%) to let the air out. Waiting until this happens by chance will have you running a partially empty cooling system, and these circuits definitely do not link during engine warm-up.
@TS, with my car the engine needs to be running and the brake pressed down and held during the procedure. I dont remember if you also need to push the htrottle but VCDS provided all directions. If you release anything you need to hold down the procedure immediately aborts.
vario
France
C?ID=351985
Hello MasterTommy
Could you give me the exact procedure with VCDS thanks
TimP
Stoke-on-Trent, UK
C?ID=289525
Hi Master Tommy
Sorry to gate crash an old thread, but I have run this procedure on my TDI 184 Alhambra and I had to keep both the brake pedal and accelerator pressed throughout and it completed successfully. However, there is also a function for bleeding the low temperature cooling circuit which will not work on my car - it just returns an error message. Presumably this is because this is not applicable to my car and the procedure I have run is adequate?
If you could confirm, that would be great.
Thanks
DrPeter
16.4905° S, 151.7375° W
Hello TimP,
I sent a reply to your email you sent to Ross-Tech support, basically is says ....
I would suspect one would need to verify the vehicle's heater system is functional and that there is not an overheat condition after a road test.
There should be more information about the cooling system in the Official Factory repair manuals.
Thank you for your patience, hope this helps
If you need more help, you can post your questions and Auto-Scan in a new thread,
Again, hope this helps...
drpeter
