2007 Audi S5 climate control
89forever
C?ID=30146
First post and already a question to those way more knowledgeable than I.
So, my car is an 2007 Audi S5 V8.
I have retro fitted the later style face lift climate panel, so I have the white on black display. I had component protection removed and I have coded the unit so the blower all works as it should.
However I want to know if it is possible to change some coding somewhere so
a) the errors go and
b) I can get the display working as originally was back on the screen in the dashboard.
I have ran the scan after everything was installed and the codings changed that I could find.....
Any one able to help please?
Chassis Type: 8T-AU48 (8T0)
Scan: 01 03 05 06 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 42 46 47
          52 53 55 56 77
Address 01: Engine (J623-CAUA)       Labels:. 079-907-560-CAU.clb
   Part No SW: 8T0 907 560     HW: 8T0 907 560
   Component: 4.2l V8/4V    H10 0007
   Revision: 76H10---
   Coding: 01140003180F0120
   Shop #: WSC 00402 210 92240
   VCID: 77F66A3BC68D27F2E4-8022
   Part No SW: 8K0 907 379 J    HW: 8K0 907 379 J
   Component: ESP8 quattro  H03 0190
   Coding: 110500
   Shop #: WSC 06325 000 00000
   VCID: 4084C1E7D3C3A04A95-8014
   Part No SW: 8K0 907 289 C    HW: 8K0 907 289 C
   Component: BCM2.01       H37 0253
   Coding: 031000
   VCID: 3972AC03B019F182D2-806C
   Subsystem 1 - Part No SW: 8T0 959 754 Q    HW: 8T0 959 754 Q
   Component: FBSAUDIB8 IDG  H32 0047
   Serial number: 0107000030903001
   Subsystem 2 - Part No SW: 8K0 905 852 A    HW: 8K0 905 852 A
   Component: ELVAUDIB8  H34 0039
   Serial number: 0207000000136002
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760     HW: 8T0 959 760
   Component: MEM-BFS       H08 0027
   Revision: AA000000    Serial number: 00001001010854
   Coding: 00217025002C44440000
   VCID: 55AA00B33C4135E2D6-8000
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 T    HW: 4E0 035 729
   Component: Interfacebox    H43 5570
   Revision: 00000000    Serial number: 329FU077512394
   Coding: 0015002
   VCID: 4A90E3CF25FF6A1A4B-801E
   Subsystem 1 - Part No: 8T0 919 609
   Component: E0380 BedienteilH07 0100
   Subsystem 2 - Serial number: 00000000007791
   Subsystem 3 - Serial number: 0104.06.070000000100010033ÿ
   Subsystem 4 - Serial number: 010033ÿ
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 54
                    Mileage: 133367 km
                    Date: 2018.10.21
                    Time: 15:13:51
01043 - Control Module; Incorrect Software Version
            000 -  -
                    Reset counter: 54
                    Mileage: 133367 km
                    Date: 2018.10.21
                    Time: 15:14:00
                    Bin. Bits: 00000000 00000010
                    Bin. Bits: 00000000 00000000
   Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
   Revision: D1000000    Serial number: 01090320151271
   Coding: 4806000000
   VCID: 78F46907CB93288AED-802C
00457 - Control Module for Network (J519)
                    Reset counter: 54
                    Mileage: 133367 km
                    Date: 2018.10.21
                    Time: 15:09:10
   Part No SW: 8K0 907 063 D    HW: 8K0 907 279 D
   Component: BCM1 1.0      H19 0253
   Revision: 05019001    Serial number: 00000000021528
   Coding: 2600D0910014AF011709000300005D5D4F9D03C800010141000000
   Shop #: WSC 00164 210 82222
   VCID: 30649127636330CA65-8064
   Subsystem 1 - Part No SW: 8T2 955 119 B    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 060607  H11 0040
   Serial number: SWFBIE 0000032
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8T0 955 559     HW: 4E0 955 559 B
   Component: RLS  H12 0001
   Serial number: 10007422
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000000106070451
   Part No SW: 8T2 035 110 C    HW: 8T2 035 110 A
   Component: MP3-Changer     H42 0390
   Revision: 00042001    Serial number: AUZ5ZBG4511019
   VCID: 2B5E864B8A45531250-807E
Address 0F: Digital Radio        Labels: None
   Part No SW: 4E0 910 563 C    HW: 4E0 035 563
   Component: DAB-Tuner       H41 0830
   Revision: 00000001    Serial number: KE1276V7201080
   Coding: 0000001
   VCID: 244C6D77E79B9C6A91-8070
   Part No SW: 8K0 919 475     HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0003
   Revision: 11001001    Serial number: 46130716301713
   Coding: 100002
   VCID: 76E8673FC1875EFAFF-8022
   Part No SW: 8K0 959 655     HW: 8K0 959 655
   Component: AirbagVW-AU10 H21 0334
   Serial number: 0038GD0823HR
   Coding: 30323232333030303030554A305238543053
   ASAM Dataset: EV_AirbaECUVWAUDI010 A02001
   VCID: 7AF0730FFD9F3A9A9B-802E
   Serial number: 6334LSME1A4D653BP
   Serial number: 6344LSME18565917F
   Serial number: 6352QSME2D47794BY
   Serial number: 6362QSME2D4B3A5D$
   Serial number: 63734SME2F305319$
   Serial number: 63834SME2F241723
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20120703001132
   Coding: 000036
   VCID: 4FA6F2DB1E9D4F321C-801A
   Part No SW: 8T0 920 980 N    HW: 8T0 920 980 N
   Component: KOMBIINSTR.   H20 0136
   Revision: 00200000    Serial number: 6C3113467
   Coding: 2F9F010002002600010001
   VCID: 4688D7FFF1E78E7AAF-8012
   Part No SW: 8T0 907 468 F    HW: 8T0 907 468 F
   Component: GW-BEM 4CAN-M H07 0084
   Revision: EB002032    Serial number: 3200E0760181C0
   Coding: 000003
   Shop #: WSC 00353 210 91474
   VCID: 448CCDF7C7DBBC6AB1-8010
   Subsystem 1 - Part No SW: 8K0 915 181     HW: 8K0 915 181
   Component: J367-BDM  H06 0120
   Serial number: 17001FC5250507
            000 -  -  - Intermittent
                    Reset counter: 94
                    Mileage: 133367 km
                    Date: 2018.10.21
                    Time: 15:12:42
Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 A
   Component: SG ext.Player H09 0850
   Revision: 00000000
   VCID: 2B5E864B4A45531250-FFFE
   Component: MEM-FS        H08 0027
   Revision: AA000000    Serial number: 00001001011134
   Coding: 00397325002C44440000
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 M
   Component: MNS ECE         H49 1060
   Revision: 00000000    Serial number: 333EQ077511487
   VCID: 3B7EB60B7A25C392C0-806E
   Part No SW: 8K0 959 793     HW: 8K0 959 793
   Component: TSG FA        H09 0149
   Revision:             Serial number: 0F5`
   Coding: 011C02225E012201
   VCID: 7DFA7813E4B10DA2BE-8028
   Revision: 00002001    Serial number: 0104283408
   Coding: 011F0682003904C0033000
   Component: DWA-Sensor  H02 0030
   Part No SW: 8T0 035 223 T    HW: 8T0 035 223 C
   Component: DSP Prem      H11 0400
   Revision: 00H11003    Serial number: 34812000432300
   Coding: 020101
   Shop #: WSC 12336 024 394758
   VCID: 3F86C21BAE3DDFB2EC-806A
   Part No SW: 8K0 959 792     HW: 8K0 959 792
   Component: TSG BF        H09 0149
   Revision:             Serial number: 0… `
   VCID: 7CFC7517FFAB04AA89-8028
   Part No SW: 8K0 907 801 C    HW: 8K0 907 801 C
   Component: EPB Audi B8   H03 0030
   Revision: 00000001    Serial number: 00000000007404
   VCID: 2F66925B7E5D2F327C-807A
   Part No: 8K0 907 357
   Coding: 0000002
   VCID: 72E05B2F6DEF42DAD3-8026
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 336FI077510035
   Coding: 0000001
   VCID: 2E588F5FB957263A77-807A
Address 77: Telephone        Labels: 4F1-910-336.lbl
   Part No SW: 4F1 910 336 D    HW: 4F1 862 335
   Component: BTA             H09 1120
   Revision: 00H09000    Serial number: 00000007535623
   Coding: 0010021
   VCID: 254A7073ECA1656286-8070
End-------------------------(Elapsed Time: 03:33)
myounus
Northwest UK
C?ID=321059
Module 07 http://wiki.ross-tech.com/wiki/index.php/Audi_A8_(4E)_Control_Head_Front#Adaptation
The error in the module 08, says that the climate panel is not communicating to the BCM. When you retrofitted it did you check the pin outs to make sure the CAN wires are connected to the correct pins on the replacement panel? If not check erwin (you can search this forum for the link to the site) and download the wiring diagrams to check. Or some people have elsawin which also displays wiring diagrams and pinouts.
The error on module 19 just needs clearing.
89forever
C?ID=30146
Thanks for replying, it is helpful.
I have Elsawin so no worries there.... I didn't think of the pin outs being incompatible... i'll update when I know more
89forever
C?ID=30146
From what I can see the control unit is J255 which is connected to the dash panel J285 via connector T20e on pics 4 and 5 on the original climate unit as fitted to the 2007
The new climate panel, connector T20e on the same pins connects to J533 (Data bus diagnostic interface) which then feeds to the dash panel J285 on
what I can't see is what to change? is anyone more knowledgeable able to assist please?
myounus
Northwest UK
C?ID=321059
Check the wires going to the bcm are the same also
89forever
C?ID=30146
The wires coming from the CAN separating connect into the BCM J519 are exactly the same between the old and the new.
I have no idea if i'm looking at the right wires....
I may not be able to assist but posting the scan prior to the retrofit may shed light on the issue.
myounus
Northwest UK
C?ID=321059
Did you do the adaptation on the control head.
89forever
C?ID=30146
adaption done on the control head
Saturday,27,October,2018,15:00:43:16483
VCDS Version: 18.9.0.2 (x64)
VIN: WAUZZZ8T08A005427   License Plate:
          52 53 55 56 77
VIN: WAUZZZ8T08A005427   Mileage: 133370km-82872miles
   Revision: 76H10---
   Coding: 110500
   Coding: 031000
   Coding: 0015002
   Coding: 4806000000
                    Reset counter: 54
                    Mileage: 133371 km
                    Date: 2018.10.27
                    Time: 14:56:50
   Coding: 00FD11
   Coding: 02532C
   Coding: 0000001
   Coding: 100002
   Coding: 000036
   Coding: 000003
   Revision: 00000000
   VCID: 2B5E864B4A45531250-807E
   Coding: 020101
   Coding: 0000002
   Coding: 0000001
   Coding: 0010021
End-------------------------(Elapsed Time: 03:09)--------------------------
so, just that one issue remaining, I think if that can be cracked then the climate should then display correctly on the dash display.....
myounus
Northwest UK
C?ID=321059
No signal in retrofits is usually a wiring issue or a missing pin on the bcm. If it's coded correctly then I'd recommend you recheck all the connections again
89forever
C?ID=30146
I suspect the same... I need to find the pin outs of the connectors.
89forever
C?ID=30146
struggling with the wiring diagrams I must admit... elsawin doesn't show the pinouts for the J255 climatronic panel or J519 control module for the 2007 S5
myounus
Northwest UK
C?ID=321059
If elsawin doesn't have it then erwin
89forever
C?ID=30146
Erwin shows exactly the same information as Elsawin, no pin outs of the connectors...
89forever
C?ID=30146
J255 into the CAN separator J533 is the same between the old and new
2007 Audi S5
2015 Audi SQ5 (what the new panel came from)
same connectors, pins and wires....
so from the J533 in to the J519 (which is where the issue is)
2007 Audi S5
2015 Audi SQ5
All looks the same to me, that's if i'm looking in the correct place???
89forever
C?ID=30146
Any suggestions from those more knowledgeable?
