HELP- A-C-Climate Control Display
DANNY25SS
C?ID=348966
Good Morning,
After making some simple VCDS Coding changes, I now do not have access to my Climate Control screen. I can operate the controls , just not see what I actually am setting them to. It was fine until I made the changes.
Any and all help/Suggestions are appreciated.
I have tried to reset the MMI and it will not work. It does not perform the reset.
Thank you,
Daniel
NZDubNurd
New Zealand
C?ID=230482
Post an autoscan so people have info to work with.
If you made a scan before you started, you can revert the coding to match what it was, and see if it goes back to working.
DANNY25SS
C?ID=348966
Tuesday,23,October,2018,08:24:46:13308
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 56 62 72 77
VIN: WAUBFAFL2BN003631   Mileage: 139390km-86612miles
Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AD    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H17 0002
   Revision: E1H17---
   Coding: 0104010A290F0160
   ASAM Dataset: EV_ECM20TFS0118K2907115AD 001005
   ROD: EV_ECM20TFS0118K2907115AD.rod
   VCID: 71BFD67EF12A254F61B-8024
4054 - Cylinder 1
          P0301 00 [096] - Misfire Detected
                    Mileage: 139077 km
                    Date: 2018.10.16
                    Time: 16:22:00
                    Engine speed: 1208.50 /min
                    Normed load value: 12.5 %
                    Coolant temperature: 41 °C
                    Intake air temperature: 26 °C
                    Ambient air pressure: 930 mbar
                    Voltage terminal 30: 12.910 V
                    Unlearning counter according OBD: 24
4060 - Cylinder 3
          P0303 00 [096] - Misfire Detected
                    Mileage: 139077 km
                    Date: 2018.10.16
                    Time: 16:22:00
4063 - Cylinder 4
          P0304 00 [096] - Misfire Detected
                    Mileage: 139077 km
                    Date: 2018.10.16
                    Time: 16:22:00
4051 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [096] - -
                    Mileage: 139077 km
                    Date: 2018.10.16
                    Time: 16:21:15
                    Engine speed: 783.50 /min
                    Normed load value: 9.8 %
                    Coolant temperature: 31 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 11.897 V
   Part No SW: 8K0 927 158 K    HW: 0BK 927 156 N
   Component: 0BK 20TFSIUSA H08 1014
   Revision: --H08---
   Coding: 001102
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_TCMAL551211 001013
   ROD: EV_TCMAL551211_001.rod
   VCID: 3E253D42F0F48A37AC9-806A
   Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
   Component: ESP8 quattro  H04 0050
   Coding: 1D0D10
   Shop #: WSC 02391 823 56573
   VCID: 025D89B2C40C2ED7881-8056
   Part No SW: 8K0 907 064 CF    HW: 8K0 907 064 CF
   Component: BCM2 2.0      H04 0430
   Coding: 090100
   Shop #: WSC 02399 823 56573
   VCID: 76B5E56298C40277B49-8022
   Subsystem 1 - Part No SW: 8K0 959 754 B    HW: 8K0 959 754 B
   Serial number: 0815000146611018
   Serial number: 0210000087940014
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 99
                    Mileage: 138778 km
                    Date: 2018.10.11
                    Time: 14:49:12
   Part No SW: 8T1 820 043 AN    HW: 8T1 820 043 AN
   Component: KLIMA 1 ZONE  H08 0180
   Revision: A1000000    Serial number: 01220520100327
   Coding: 64182000
   VCID: 7DA7FA4EBDF2512FF53-8028
                    Reset counter: 106
                    Mileage: 139057 km
                    Date: 2018.10.15
                    Time: 17:49:46
03023 - Running-in Requirement
                    Fault Status: 01100101
                    Reset counter: 120
                    Mileage: 139319 km
                    Date: 2018.10.21
                    Time: 10:24:17
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H29 0392
   Revision: 10029001    Serial number: 00000000552995
   Coding: 69080031003CBE010001010300007F5F4F14520802000021000000
   VCID: 3C21374AE668982782D-8068
   Component: WWS 010610  H06 0070
   Serial number: SWF10060010851
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 941 531 AK    HW: 8K0 941 531 AK
   Component: E1 - LDS  H08 0090
   Serial number: 00000000001905100711
02258 - Door Opener Transmitter
                    Reset counter: 98
                    Mileage: 138778 km
                    Date: 2018.10.11
                    Time: 14:46:00
   Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
   Component: AirbagVW-AU10 H41 0610
   Serial number: 003GLD0G3UL.
   Coding: 303837354230303030304A55304C384B3053
   Shop #: WSC 02135 785 00200
   VCID: 45D752AE9522D9EFED3-8010
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R1000000602
   Serial number: 6334MSME540417734
   Serial number: 6344MSME54050631+
   Serial number: 6352QSME4C633808L
   Serial number: 6362QSME2F5F0C22V
   Serial number: 63732SME39631E181
   Serial number: 63832SME0A621508W
   Component: Lenks.Modul   H16 0014
   Revision: --------    Serial number: 90304JES0006X
   Coding: 000014
   VCID: 3D273A4EFD72912FB53-8068
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 950 H    HW: 8K0 920 950 H
   Component: KOMBIINSTR.   H20 0258
   Revision: 00100000    Serial number: EIL21KJ5A
   Coding: 8337090003005705820001
   VCID: 34311F6ACE3850674AD-8060
                    Reset counter: 138
                    Mileage: 138778 km
                    Date: 2018.10.11
                    Time: 14:14:08
   Part No SW: 8T0 907 468 AB    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0117
   Revision: GB800053    Serial number: 5300G1051883EC
   Coding: 00C303
   VCID: 015F86BEC10A35CF91B-8054
   Component: J367-BDM  H07 0170
   Serial number: 1001C077200510
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020302
   VCID: 392F2E5EE95AAD0F99B-806C
   Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
   Component: TSG FA        H08 1401
   Coding: 011C03204000410001
   VCID: 53F37CF66BF6775F737-8006
   Revision: 00002001    Serial number: 0131033247
   Coding: 0126163A00FA40048030013200000000
   Component: GTO BF  H06 0050
   Serial number: 00000000000000264255
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS039  H06 0041
01403 - Glass-Break Sensors; Rear
                    Fault Status: 01101011
                    Reset counter: 98
                    Mileage: 138778 km
                    Date: 2018.10.11
                    Time: 14:46:37
   Part No SW: 8T0 035 223 AH    HW: 8T0 035 223
   Component: DSP STD       H07 0230
   Revision: S2200000
   Coding: 0203010102
   VCID: 74B1DF6A8EB810678AD-8020
   Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
   Component: TSG BF        H08 1401
   VCID: 52FD79F254EC7E57781-8006
   Revision: 00000003    Serial number: 10000000532403
   Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
   Component: Con3 Sirius   H06 0351
   Revision: 00000009    Serial number: AUZ5Z6J1413356
   Coding: 0402000201018503DD198F0803
   VCID: 46D555A2A8A4D2F7E49-8012
   Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
   Component: Display
            000 -  -
                    Reset counter: 98
                    Mileage: 138778 km
                    Date: 2018.10.11
                    Time: 14:46:47
            000 -  -
                    Fault Frequency: 42
                    Reset counter: 125
                    Mileage: 138934 km
                    Date: 2018.10.12
                    Time: 14:41:05
                    Bin. Bits: 00100000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
01043 - Control Module; Incorrect Software Version
            000 -  -
                    Reset counter: 106
                    Mileage: 139057 km
                    Date: 2018.10.15
                    Time: 17:49:47
                    Bin. Bits: 00000010
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
   Part No SW: 8T0 959 795 N    HW: 8T0 959 795 B
   Component: TSG HL        H06 1401
   Coding: 010C03204000210001
   VCID: 56F585E278046277949-8002
   Component: TSG HR        H06 1401
   Part No SW: 8T0 862 336 E    HW: 8T0 862 336 E
   Component: FSE_256x BT     H42 0650
   Revision: 00000000    Serial number: 00000005083289
   Coding: 0010370
   Shop #: WSC 02335 785 00200
   VCID: 3D273A4EF172912FB53-8068
End----------(Elapsed Time: 01:37, VBatt start/end: 12.4V/12.4V)-----------
THANK YOU!!
NZDubNurd
New Zealand
C?ID=230482
There is likely a "basic settings" procedure to clear that fault code... but it also says it can't communicate with the auxiliary heater - you probably don't have one...
What were the coding changes you made? I'd change them back, and find the basic settings procedure before trying anything else.
DANNY25SS
C?ID=348966
It actually populated the options for Aux heater. I can turn it on and off as well as select duration and days and times.
It seems like the only thing I can do is go through the log line by line and see what happened.
If there is anything that anyone sees let me know and again,
Thank you for your input and assistance.
-Daniel
PS: The misfires are being handled tomorrow new coils and plugs on the way. :)
