- Jan 24, 2018
- 17
- 2
- Middle East
- C?ID=322802
vw t5 2015
Address 01,,channel IDE01637-Service regeneration of particulate filter while driving,adapted from,0 ,to,1 ,
Thursday,18,October,2018,13:17:23:08971
VCDS Version: 18.9.0.2 (x64) HEX-NET CB: 0.4436.4
VIN: WV2ZZZ7HZFH127303 License Plate:
Mileage: 312260km-194029mi Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 56 0B
VIN: WV2ZZZ7HZFH127303 Mileage: 312260km-194029miles
Address 01: Engine (J623-CAAC) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 GH HW: 03L 907 309 M
Component: R4 2,0L EDC H45 6303
Revision: 26H45--- Serial number: 00000000000000
Coding: 01194012230400080000
Shop #: WSC 02757 790 50316
ASAM Dataset: EV_ECM20TDI01103L906019GH 003004
ROD: EV_ECM20TDI01103L906019FM_003.rod
VCID: F7BE832B4EEECFF264-80A2
5111 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit
P0135 00 [039] - Malfunction
Mileage: 312261 km
Date: 2018.10.18
Time: 13:57:49
Engine speed: 0.00 /min
Coolant temperature: 58 °C
Intake air temperature: 35 °C
Ambient air pressure: 910 mbar
Voltage terminal 30: 12.440 V
5253 - Diesel Particle Filter; Differential Pressure Sensor
P2452 00 [039] - Elect. Malfunction
Mileage: 312261 km
Intake air temperature: 34 °C
Voltage terminal 30: 12.600 V
Sensor for particle filter differential press: raw value: 1057 hPa
Particle filter: difference pressure: -5 hPa
Particle filter: offset for differential press.: 3 hPa
Particle filter: differential pressure: dynamic offset: 5 hPa
Outside air temperature: 26.5 °C
Particle filter: soot mass measured: 8.02 g
Particle filter: soot mass calculated: 22.77 g
4911 - Exhaust Gas Temperature Sensor; B1 S3
P242A 00 [167] - Malfunction
Mileage: 312261 km
Date: 2018.10.18
Time: 13:57:47
Voltage terminal 30: 12.460 V
Exh.gas temp.sen 1: 65.0 °C
Exh.gas temp.sen 2: -0.0 °C
Exh.gas temp.sen 3: 1000.0 °C
Exh.gas temp.sen 4: 1000.0 °C
Shut-off timer: last engine shut-off time: 907 s
4912 - Exhaust Gas Temperature Sensor 4 Bank 1
P246E 00 [167] - Electrical Malfunction
Mileage: 312261 km
Date: 2018.10.18
Time: 13:57:47
5257 - Exhaust Gas Temperature Sensor; B1 S3
P242A 00 [039] - Malfunction
Mileage: 312261 km
Date: 2018.10.18
Time: 13:57:43
Shut-off timer: last engine shut-off time: 903 s
5258 - Exhaust Gas Temperature Sensor 4 Bank 1
P246E 00 [039] - Electrical Malfunction
Mileage: 312261 km
Date: 2018.10.18
Time: 13:57:43
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 L HW: 7E0 907 379 L
Component: ESP MK25A XT H50 0113
Revision: 00H50001
Coding: 108724AD09A6089C24A590713A6112
Shop #: WSC 02757 790 49152
VCID: BB365F1B3A462B9240-80EE
02214 - Tire Pressure Warning
Reset counter: 34
Mileage: 308536 km
Date: 2018.10.04
Time: 03:35:31
Count: 16384
Count: 4097
Count: 397
Count: 766
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 15021504650684
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: FEB0960F61D4FEBA27-80AA
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E5 907 040 AF HW: 7E5 907 040 AF
Component: ClimatronicT5 H19 0407
Revision: 00001004
Coding: 0000000502
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: EC94AC4707A87C2A99-80B8
Slave 1:
Subsystem 1 - Part No SW: 7E5 907 049 B HW: 7E5 907 049 B
Component: Heckbedienung H10 0202
Serial number: BHB-0010403150015283
9474929 - Motor for Rear Air Distribution
B1093 71 [008] - Actuator stuck
Reset counter: 43
Mileage: 295502 km
Date: 2018.08.19
Time: 00:03:55
9476629 - Position Sensor for Rear Air Distribution Flap Motor
B109A 15 [008] - Open or Short to Plus
Fault Frequency: 61
Reset counter: 25
Mileage: 291167 km
Date: 2018.08.06
Time: 01:06:19
9480753 - Control/Display Unit for Rear Climatronic
B10AA 31 [008] - No Signal
Reset counter: 42
Mileage: 309740 km
Date: 2018.10.08
Time: 22:09:48
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 P HW: 7H0 937 087
Component: BCM T5GP H+4 H34 0424
Revision: BO034001 Serial number: 0673 055150167
Coding: 62B0F93A0A212012002008106C2B8DD40000612F60840000320000000800
Shop #: WSC 02739 790 00000
VCID: C1CA2DF358AA41421A-8094
Subsystem 1 - Part No SW: 7E0 959 801 J HW: 7E0 959 801 J Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8654
Serial number: KU0KU025021550563840
Coding: 0000A1
Subsystem 2 - Part No SW: 7E0 959 802 J HW: 7E0 959 802 J Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8654
Serial number: KU0KU024021550553425
Coding: 1000A1
03301 - Response Closing Status of Drivers Door
Fault Status: 01101000
Fault Frequency: 118
Reset counter: 17
Mileage: 309652 km
Date: 2018.10.08
Time: 07:10:46
03589 - Switch for Driver Side Window Regulator
Fault Status: 00101110
Reset counter: 41
Mileage: 309652 km
Date: 2018.10.08
Time: 07:11:54
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28231501901837
Coding: 108004
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_VW75XParkAssis8K 001003
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: BB365F1B32462B9240-80EE
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag003 H07 0013
Revision: -------- Serial number: 003HL00VPM6$
Coding: 000000000000000000000000000000003033
Shop #: WSC 02754 790 50316
VCID: B52249231462FDE2B6-80E0
Part No SW: 7E0 920 870 N HW: 7E0 920 870 N
Component: KOMBI H04 0805
Coding: 160E01
Shop #: WSC 02737 790 50316
VCID: B42474271F18E4EA81-80E0
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 H34 0424
Revision: BO034001
Coding: 042200
VCID: F0ACB837238098CAA5-80A4
Component: IMMO H04 0805
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: EA98AA5F0D5C621AEB-80BE
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: Radio RCD510 037 0144
Revision: 00000001 Serial number: VWZ1Z3I4290532
Coding: 0500040004
VCID: E582D963EC424D62C6-80B0
Reset counter: 29
Mileage: 171155 km
Date: 2017.03.26
Time: 03:14:09
Reset counter: 29
Mileage: 171155 km
Date: 2017.03.26
Time: 03:14:09
Reset counter: 143
Mileage: 171155 km
Date: 2017.03.26
Time: 03:14:05
00877 - Treble Speaker Rear Right (R16)
Reset counter: 143
Mileage: 171155 km
Date: 2017.03.26
Time: 03:14:05
Reset counter: 143
Mileage: 171155 km
Date: 2017.03.26
Time: 03:14:17
03138 - Input AUX IN
Reset counter: 143
Mileage: 171155 km
Date: 2017.03.26
Time: 03:14:08
End----------(Elapsed Time: 01:09, VBatt start/end: 12.5V/12.4V)-----------
