No ROD file - VW T5.1 2012 2.0 TDI
DGMotors
C?ID=57532
Im having a issue with this 2012 T5.1 Transporter, I cant reset the service light because no ASAM data or rod file found in 17- Instruments
Can anyone help?
Cheers Toby
Wednesday,16,May,2018,14:33:49:06091
VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4411.4
Dealer/Shop Name: DG Motor Services
VIN: WV1ZZZ7HZCH087089   License Plate:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 09 15 17 19 25 56 0B
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 022 CH    HW: 03L 907 309 K
   Component: R4 2,0L EDC   H43 9970
   Revision: 26H43---    Serial number: 00000000000000
   Coding: 01194010230400080000
   Shop #: WSC 81903 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906022CH 002013
   ROD: EV_ECM20TDI01103L906022CH_002.rod
   VCID: ED929FB53C86B52C43-80B8
5196 - Relay for Fuel Pump 2 (J49)
          P2632 00 [032] - Open Circuit
5200 - Fuel Pump Relay Control Circuit
          P0627 00 [032] - Open Circuit
9531 - Manifold / Barometric Pressure Sensor (G71) / (F96)
          P0105 00 [032] - Malfunction
                    Mileage: 142104 km
                    Engine speed: 0.00 /min
                    Coolant temperature: 20 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 12.240 V
                    Charge air pressure: actual value: 1011.8 hPa
                    Intake air pressure sensor after air cleaner: raw value: 1150 hPa
                    Engine status: COENG_STANDBY
                    Outside air temperature: 16.5 °C
                    Particle filter: difference pressure: -2 hPa
                    Sensor for particle filter differential press: raw value: 0 hPa
Address 03: ABS Brakes (-----)       Labels:. 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 J    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0109
   Revision: 00H43001
   Coding: 508724AD89AC0A9C24A29179A96710
   Shop #: WSC 02748 790 49152
   VCID: B93A7BE5304ED98C9F-80EC
   Part No SW: 7H0 937 086 H    HW: 7H0 937 086
   Component: BCM T5GP M++4 H47 0254
   Revision: BM047001    Serial number: 0428 003121077
   Coding: A0A0393A0E212011002008102C2B8CD00000430F60060000300000000000
   Shop #: WSC 02736 790 00000
   VCID: B83C7EE10B44C08460-80EC
   Subsystem 1 - Part No SW: 7E0 959 801 C    HW: 7E0 959 801 C  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  003 3311
   Coding: 050000
   Subsystem 2 - Part No SW: 7E0 959 802 C    HW: 7E0 959 802 C  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  003 3311
   Coding: 040000
03303 - Response Closing Status of Rear Left Door
                    Reset counter: 64
                    Mileage: 134805 km
                    Date: 2000.14.27
                    Time: 10:55:57
   Component: VW10Airbag009 H06 0013
   Revision: --------    Serial number: 003HL009HJXX
   Shop #: WSC 02734 790 50316
   VCID: B52277D514563DEC7B-80E0
Address 17: Instruments (J285)       Labels:. 5K0-920-xxx-17.clb
   Part No SW: 7E0 920 960 E    HW: 7E0 920 960 E
   Component: KOMBI         H04 0305
   Coding: 460200
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_Kombi_cÿ_VDD_RM09 A04113
   ROD: N/A
   VCID: AB1651ADC2127B1C1D-80FE
No ASAM data for: "EV_Kombi_cÿ_VDD_RM09" (VW36 *)
   Part No SW: 6N0 909 901     HW: 7H0 937 086
   Component: GW-K-CAN TP20 H47 0254
   Revision: BM047001
   Coding: 042300
   VCID: F0AC86C123B458C468-80A4
   Component: IMMO          H04 0305
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: EA9894A90D68A21426-80BE
   Part No SW: 7E0 035 156 B    HW: 7E0 035 156 B
   Component: Radio         H42 0105
   Revision: R0000000    Serial number: VWZAZ1L2284017
   Coding: 0000020001
   Shop #: WSC 02734 790 00000
   VCID: A208BC89BDD8BA54AE-80F6
End----------(Elapsed Time: 01:08, VBatt start/end: 14.4V/14.5V)-----------
DGMotors
C?ID=57532
I had a feeling that it might be something like the mileage has been rolled back or someone has been fiddling,
Customer has only owned the van for 6 months.
Is there any way to copy and alter the rod file to match the cluster so I can reset the service light correctly?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
No, somebody who usually tweaks clusters/mileages should be able to fix it - other than that, install a new cluster.
