Audi A3 2.0T FSI BPY Crank with no start.
botscoolnesss
C?ID=66573
Please see thread on vwvortex for full story.: http://forums.vwvortex.com/showthre...h-no-start&p=110357482&posted=1#post110357482
TL;DR of the thread, My 2007 audi a3 2.0t FSI is cranking but wont start, Only code i get is a P0321 after cranking for a while and it not starting. this code doesn't pop up right away or even after cranking a couple times.
I've replaced the crank position sensor (Tested Resistance @ 850 ~ohms)
Tested for timing(GOOD)
compression (GOOD)
spark (GOOD, Tested by pulled a plug and coil and grounded plug to block and saw spark)
Fuel pressure in rail (Measured with VAGCOM) is good, however after cranking for extended periods rail shows 115ish BAR (Is this normal?)
I just replaced the HPFP, and also suffered bad camfollower failure around 300 miles before all this happened.
ALL Fuses were checked and non are blown,
this is how its been crnaking, almost sounds like it wants to fire but cant.
https://www.youtube.com/watch?v=eKaqCxB3Kco&feature=youtu.be
Saturday,24,February,2018,18:10:51:34933
VCDS Version: 17.8.1.0 (x64)
Data version: 20171130 DS276.6
VIN: WAUHF78P87A091838   License Plate: BEFORE
Mileage: 226700km-140864mi   Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 25 37 42 44 46 52 55 56 62 72 77
VIN: WAUHF78P87A091838   Mileage: 226700km-140864miles
   Part No SW: 8P0 907 115 P    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: AUX7Z0F9FN20E1
   Coding: 0103010A18070160
   Shop #: WSC 03134 067 57207
   VCID: 3FA3B5F56EF5C9BEA8-806A
Readiness: 0110 0101
   Revision: 00H11001
   Coding: 0021122
   Shop #: WSC 06314 000 00000
   VCID: 73CB29C5123D5DDE9C-8026
   Part No SW: 8P0 820 043 AD    HW: 8P0 820 043 AD
   Component: KlimavollautomatH19 0360
   Revision: 112073      Serial number: 8P0820043AD
   VCID: 6EFD38B1791F703673-803A
                    Fault Status: 01101000
                    Reset counter: 247
                    Mileage: 226700 km
                    Date: 2018.02.18
                    Time: 00:05:23
Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 F    HW: 8P0 907 279 F
   Component: Bordnetz-SG     H43 1201
   Revision: 00H43000    Serial number: 00000006283303
   Coding: F38C5F81C014100000181800180000000028EE175A1500
   Shop #: WSC 06314 123 08192
   VCID: 40A1B609130BB646D1-8014
   Subsystem 1 - Part No: 8P1 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H01 0130
   Coding: 00062736
   Shop #: WSC 06314
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00150573
   Shop #: WSC 06314
   Part No SW: 8E0 035 593 F    HW: 8E0 035 593 F
   Component: SDAR SIRIUS     H03 0120
   Revision: 00000000    Serial number: AUZ4Z7F1042294
   VCID: 2C79F2B98F8342261D-8078
            000 -  -
                    Reset counter: 90
                    Mileage: 214741 km
                    Date: 2017.05.22
                    Time: 16:18:07
Address 15: Airbags        Labels: 8P0-959-655-94.lbl
   Part No SW: 8P0 959 655 A    HW: 8P0 959 655 A
   Component:    Airbag 9.41  H12 3890
   Revision: 91H12389    Serial number: 0035W0G02WX.
   Coding: 0032605
   Subsystem 1 - Part No: 8P0 910 339
   Component: BF-Gewichtsens. 001 0020
   Subsystem 2 - Serial number: 3C78M
   Subsystem 3 - Serial number: 0001.01.000000100000000000ÿ† 63
   Subsystem 4 - Serial number: 000000ÿ† 6332DRB404088C31Jÿ† 63
   Subsystem 5 - Serial number: 88C31Jÿ† 6342DRB4040908A0Fÿ† 63
   Subsystem 6 - Serial number: 908A0Fÿ† 63528RB401BAA6EA%ÿ† 63
   Subsystem 7 - Serial number: AA6EA%ÿ† 63628RB401B6DCAF6ÿ† 63
   Subsystem 8 - Serial number: 6DCAF6ÿ† 63729RB401B83BDB+ÿ† 63
   Subsystem 9 - Serial number: 83BDB+ÿ† 63829RB4007E79E0Zÿ
   Subsystem 10 - Serial number: E79E0Zÿ
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0004042
   VCID: 41A7B30D1801BF4EDE-8014
   Component: E0221           H06 0030
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY7.lbl
   Part No SW: 8P0 920 981 H    HW: 8P0 920 981 H
   Component: KOMBIINSTR. VDO H19 0570
   Revision: D0H19003    Serial number: 2249F003003839
   Coding: 0036203
   Shop #: WSC 12345 067 57207
   VCID: 3D5FCFFD64F9DBAEBA-8068
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 030608F2001252
   Coding: E9817F064007022102
   Shop #: WSC 06314 321 54231
   VCID: 354FD7DD5CC903EE72-8060
   Revision: D0H19003    Serial number: AUX7Z0F9FN20E1
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8P0 035 192 G    HW: 8P0 035 192 G
   Component: RNS-E US        H72 0260
   Revision:      03S    Serial number: AUZBZ7F2372180
   Coding: 0209677
   VCID: 334BE9C552BD1DDE5C-8066
                    Reset counter: 32
                    Mileage: 226699 km
                    Date: 2018.02.12
                    Time: 19:57:25
                    Voltage: 10.60 V
                    Mileage: 226700 km
                    Count: 1802
                    Clock: 05:09
00856 - Radio Antenna
                    Fault Status: 00101011
                    Reset counter: 32
                    Mileage: 226699 km
                    Date: 2018.02.11
                    Time: 12:31:12
                    Mileage: 226690 km
                    Count: 1102
                    Clock: 12:39
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN2.lbl
   Part No: 8P0 959 801 H
   Component: Tuer-SG         020 0090
   Coding: 0001209
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.079 H07 1806
   Shop #: WSC 02069 000 90108
   VCID: 3449EAD957B31AE645-8060
            000 -  -
                    Mileage: 226680 km
                    Temperature: 13.0°C
                    Voltage: 11.50 V
                    Voltage: 11.30 V
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 D
   Component: 02 KSG          H04 0050
   Coding: 9AC003002D2C850FC88F047300
   Shop #: WSC 06314 123 12345
00956 - Key 2
            000 -  -
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN2.lbl
   Part No: 8P0 959 802 H
   Coding: 0001209
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   VCID: 29770BAD8071570EE6-807C
   Subsystem 1 - Part No: 8E0 941 329 A
   Component: AFS-Modul links H03 0020
   Subsystem 2 - Part No: 8E0 941 329 A
   Component: AFS-Modul rechtsH03 0020
                    Mileage: 226696 km
                    Date: 2018.01.27
                    Time: 14:27:15
                    Reset counter: 32
                    Mileage: 226696 km
                    Date: 2018.01.28
                    Time: 13:00:41
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0209677
                    Reset counter: 32
                    Mileage: 226699 km
                    Date: 2018.02.12
                    Time: 19:57:25
                    Voltage: 10.70 V
                    Mileage: 226700 km
                    Count: 1802
                    Clock: 05:10
                    Reset counter: 32
                    Mileage: 226699 km
                    Date: 2018.02.11
                    Time: 12:31:12
                    Mileage: 226690 km
                    Count: 1102
                    Clock: 12:39
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No: 8P4 959 801 D
   Component: Tuer-SG         020 0070
   Coding: 0001176
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No: 8P4 959 802 D
   Coding: 0001176
01814 - Supply Voltage for Door Controller; Rear Right (J389)
   Part No SW: 8P0 862 335 J    HW: 8P0 862 335 J
   Component: DSE_255x BT     H26 0290
   Revision: 00000000    Serial number: 00000005010936
   Coding: 0011477
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 188176 km
                    Date: 2016.03.08
                    Time: 08:14:50
End-------------------------(Elapsed Time: 01:21)--------------------------
Gone But Not Forgotten
Hello OP:
Welcome to the VCDS forum & are you not glad you came here?
Have you measured and verified the signal for G28 to the ECU & is correct at ECU and has ECU not taken on water with ingress via inspection?
Let me know if you find the JPPSG helpful?
http://forums.ross-tech.com/showthr...essional-Problem-Solver-Guide-quot-JPPSG-quot
16705/P0321/000801 - Engine Speed Sensor (G28): Implausible Signal [h=4]Possible Symptoms[/h]
  • Engine shuts off
  • Engine doesn't start
  • Speedometer inoperative
  • Glow Plug Indicator Lamp (K29) flashes
[h=4]Possible Causes[/h]
  • Engine Speed Sensor (G28) loose
  • Engine Speed Sensor (G28) faulty
[h=4]Possible Solutions[/h]
  • Check Engine Speed Sensor (G28)
[h=4]Special Notes[/h]
  • The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position and correlates with the Camshaft Position Sensor Bank 1 (G40) and Camshaft Position Sensor Bank 2 (G163).
    • When an engine will not start due to mechanical (spark/fuel/compression/timing) related issues it is not uncommon to set a false G28 fault codes due to extended cranking with a no-start condition.
  • When found in a VW Golf/Jetta (1J/9M) or Audi A3 (8L) with 1.9l TDI-PD (AXR), check TPI 2007067 which explains issues with electro magnetic interference. A modification to the wiring will fix this problem, extensive details can be found in the named TPI. Even though this TPI was originally released for VW Golf/Jetta (1J/9M), a customer of ours came across the same issue on an Audi A3 (8L).
  • When found in a 2004 VW Golf, Jetta, or New Beetle with 1.9l TDI-PD (BEW), check for TSB 2010461 (01-07-45 formerly 97-05-03) or 201463 (01-07-44 formerly 97-05-04) calling for a flash update to the ECU and a secondary ground installation.
  • General note for any engine type: Check the wiring to/from the sensor and engine control module to rule out harness and module damage due to engine oil or coolant from a failed sensor or tensioner. This is an example from a 2012 Tiguan with Coolant in the ECM which resulted in G28 DTCs in addition to intermittent stalling.
botscoolnesss
C?ID=66573
Hello OP:
I have not verified the wires to the ECU, I looked at the ECU and externally it looks good but I know that doesn't mean a whole lot.
I have the wiring diagrams so ill trace that and check everything out for the G28, The only reason I haven't is I was told that if the G28 isnt working then i wouldnt get any spark.
Nonetheless I will check all that when it stops raining.
Is your cars ECU FOD tuned?
Will it run with just carb cleaner sprayed in intake to isolate a fuel condition verse an ignition or timing issue from being out due to setup or oil PSI problem.
botscoolnesss
C?ID=66573
Yes ECU is tuned Stage 2
Yes I ran it with starting fluid,sprayed it in short bursts while my friend cranked and it even backfired out of the hole when it died, it didn't run stable but it definitely sputtered a lot more and even idled for about half of a second.
Timing belt was checked vs the ref marks on the cam gear and crank gear.
Most stage 2 tunes out there are ignoring the misfire recognition in low rpm range, and which is monitored by g28 in addition they seem to also delete g40 calibrations so it will never report many DTC's.
There is a good chance chain jumped or adjuster broke key way on back of adjuster of exhaust cam.
Take apart to inspect.
Best to start with stock controller with some type of consistent stack.
botscoolnesss
C?ID=66573
That's good info to know moving forward, I did have the cam chain cover off and valve cover and nothing looked incorrect, chain had tension, wasn't broken.
I do see the camshaft rotating if I turn the motor. Wish I had another ecm to test with :/
Keithuk
Stoke on Trent, England
C?ID=122432
Jack
Possible Symptoms
• Engine shuts off
http://wiki.ross-tech.com/wiki/index.php/16706/P0322/000802
Tachometer / Rev Counter inoperative
You say Speedometer inoperative, is that something you've found?
Not tensioner OP.
Adjuster barrel on reverse side where cam bolts on, it shears the pin and still turns just is out of time.
vwtech
Verified Coal Cracker
Wilkes-Barre, PA
C?ID=7573
Jack I sent the guy here because I was lost as to why no codes?
He had a G68 code went it stalled but no cam code. Don't know if the G68 was bad or just from over cranking with no start?
He has RPM on VCDS and the tack moves and has spark. Only bad thing I see is he replaced G68 with one from Auto Zone which is a NO NO! But it seems to be working.
What has me is he said it back fires at times and compression was only 150. But was using an AZ tool loaner tester for compression.
I said timing but why no cam sensor & RPM sensor correlation code?
Good Luck
Good Luck
Dam right it's a NO NO for FOD I think on G28, especially if wrong or possible wrong air gap etc..
LOL you are mixing up G68 with those harnesses I have to make you? FYI: I'm still waiting for Wurth WSO out of Germany. :banghead:
vwtech
Wilkes-Barre, PA
C?ID=7573
Okay not G68!
And your still an ASS! LOL:)
Why no codes??????
Good Luck
Okay I just read why no codes.
"Most stage 2 tunes out there are ignoring the misfire recognition in low rpm range, and which is monitored by g28 in addition they seem to also delete g40 calibrations so it will never report many DTC's."
I go with timing jumped then. :(
NZDubNurd
New Zealand
C?ID=230482
I'm no expert... but that thing sounds WRONG when cranking - potentially like when timing is out ;)
Okay not G68!
SLMC .....that is You Are or You're not "Yours"...... truly!
Indeed I am a regular asshole!.......... :rolleyes:
OP
Take it to STAGE NONE Immediately! & inspect the equipment I aforementioned..........
Do as I say, not as you think!
NostraJackASS Has Spoken!
botscoolnesss
C?ID=66573
OP
AYE SIR!
Joking aside, i have had the ecu turned over to the stock program, not sure if thats what you meant or you meant throw a stock ecu in there (Unfortunately i dont have a spare at the moment)
When the rain stops i will pull the whole valve cover and timing chain cover off again.
How would i go about checking to see if the valves are in time?
EDIT: i see a post that stan posted on vwvortex, the nothes on each end of the cam have to face eachother, got it. as long as it doesnt rain tomorrow ill check this again.
vwtech
Wilkes-Barre, PA
C?ID=7573
I sent you a link on the basics and it clearly show the tool installed on top of the head and pins of tool in the slots of both cams.
All this of coarse with timing marks for timing belt lined up and installed.
You need the tool you can't just let them look like they face each other.
I myself would want the tool.
Good Luck
botscoolnesss
C?ID=66573
Well I pulled it all apart again, didn't see anything out of the ordinary, other than a piece of the failed HPFP stuck in one of the oil valleys in the head(see video link).
https://youtu.be/FGaAqM2r6Iw
Set the belt to the timing marks on both crank and cam and the Cam's look to be in time( can't tell for sure without the tool)
Cam adjuster checked out good it turns with the Cam's and everything.
