VW T5.1 2015 - Parking Sensor Issues
thundercatr6
C?ID=313554
Hi All,
I have bought and fitted genuine VW front and rear parking sensors to my VW Transporter 2015 and experiencing issues with the front sensors.
The rear sensors work correctly and the fronts also when in close proximity to an object, but when moving forward after being in reverse, the front sensors flash\bleep away with nothing in front of the vehicle, until they switch off after about 7mph.
PDC module part no: 7E0 919 475 J
Front parking sensors part no: 1S0 919 275 C
I believe the PDC module is a slightly older variant as it covers various VW models, so I'm not too sure if I need a newer PDC module or the settings within it.
The company I bought the retro kit from said they would re-flash the PDC module but I'm not sure that will resolve the issue.
Any help or advice would be greatly appreciated, plus I've added my VCDS output.
Saturday,30,September,2017,12:44:17:15268
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4401.4
VIN: WV2ZZZ7HZFH139336   License Plate: N4VWV
Mileage: 17920km-11134mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 18 19 25 37 56 61 69 6C 0B
VIN: WV2ZZZ7HZFH139336   Mileage: 17920km-11134miles
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GQ    HW: 03L 907 309 L
   Component: R4 2,0L EDC   H38 6305
   Revision: 22H38---    Serial number: 00000000000000
   Coding: 0119401A233401080000
   Shop #: WSC 02757 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906019GQ 003004
   ROD: EV_ECM20TDI01103L906019FH_003.rod
   VCID: 005A8841FA80B9475BA-8054
Address 03: ABS Brakes (-----)       Labels:. 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 L    HW: 7E0 907 379 L
   Component: ESP MK25A XT  H50 0113
   Revision: 00H50001
   Coding: 608724AD09A7069E24A59074B96492
   Shop #: WSC 02757 790 49152
   VCID: 3B203FADD3661A9F4E8-806E
   Serial number: 20031504650683
   Coding: 01
   ROD: EV_LWSKLOVW25X_VW25.rod
   VCID: 7EA6F6B98074CFB7296-802A
   Part No SW: 7E5 907 047 BM    HW: 7E5 907 047 BM
   Component: Climatic-T5   H20 0506
   Revision: 00001012
   Coding: 0000000003
   ROD: EV_ClimaT5Basis.rod
   VCID: 7BA0FFAD9366DA9F0E8-802E
   Part No SW: 7H0 937 090 D    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H78 0725
   Revision: B9078001    Serial number: 0671 080151050
   Coding: B8A4393A0A613412922049706E2B9CD40790602F7E844440320000020800
   Shop #: WSC 61584 001 104857
   VCID: 2F381BFD171EF63FF20-807A
   Subsystem 1 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8653
   Serial number: KU0KU013031550722788
   Coding: 1400B0
   Subsystem 2 - Part No SW: 7E0 959 802 K    HW: 7E0 959 802 K  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8653
   Serial number: KU0KU013031550726115
   Coding: 0400A0
   Subsystem 3 - Part No: 7E1 951 172
   Subsystem 5 - Part No: 7E1 951 172
   Part No SW: 7E0 919 475 J    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0105
   Revision: --------    Serial number: 28261201602080
   Coding: 318002
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_VW75XParkAssis8K 001003
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 392C25A5D9DA288F5C4-806C
   Part No SW: 7E0 959 655 C    HW: 7E0 959 655 C
   Component: VW10Airbag00P H07 0013
   Revision: --------    Serial number: 003HM0064X21
   Coding: 000000000000000000000000000000003050
   Shop #: WSC 02754 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 36362E99E8C4C7F7B16-8062
   Serial number: 3495ZRB400U52PK4F9UN
   Serial number: 3505ZRB405533RVQN0VT
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 7E0 920 970 N    HW: 7E0 920 970 N
   Component: KOMBI         H04 0805
   Coding: 460B01
   Shop #: WSC 02737 790 50316
   ROD: EV_Kombi_UDS_VDD_RM09_004_VN35.rod
   VCID: 35342995F5C2CCEFB8C-8060
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 815 071 C
   Component: J737__Standheizung  0605
   Revision: 00087000    Serial number: 09024900A00000
   Coding: 0020031
   Shop #: WSC 02757 790 00000
   VCID: 2514F9D549E2BC6F08C-8070
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H78 0725
   Revision: B9078001
   Coding: 042300
   VCID: 70BAD881CAA0A9C7ABA-8024
   Component: IMMO          H04 0805
   VCID: 6A8ECAE9ECFC5317E5E-803E
   Part No SW: 1T0 035 680 H    HW: 1T0 035 680 H
   Component: RNS-MID       H64 4020
   Revision: AB001001    Serial number: VWZ6Z7M6132157
   Coding: 04000400040000900014
   Shop #: WSC 00704 210 90535
   VCID: 3330178DFB36D2DF968-8066
   Part No SW: 7H0 907 534     HW: 7H0 937 090
   Component: Batt.regelung H78 0725
   Coding: 330B1A73
   Shop #: WSC 02737 790 00000
   VCID: 6B80CFEDE3864A1F9E8-803E
   Subsystem 1 - Part No SW: 7E0 915 181 E    HW: 7E0 915 181 E
   Component: J367-BDM  H08 0223
   Serial number: 62064248594261657485
   Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
   Component: Towbar module H10 0110
   Revision: 3A001001    Serial number: ÀÁ006789000000
   Coding: 0100000100000000
   VCID: 313C1D85012AE0CFE44-8064
   Part No SW: 7E0 907 441     HW: 7E0 907 441
   Revision: 00H13000    Serial number: 525PA8-J470733
   Coding: 0030015
   Shop #: WSC 02637 002 1048576
   VCID: 6594B9D509627C6FC8C-8030
End----------(Elapsed Time: 01:59, VBatt start/end: 12.1V/12.1V)-----------
thundercatr6
C?ID=313554
Has anybody got any help or advice on this issue please.
myounus
Northwest UK
C?ID=321059
Hi Thundercatr6
It sounds like you might have a damaged or faulty sensor. Try disabling 1 sensor at a time and see if it helps diagnose the problem. Go through the usual checks of all wires securely fitted and good clean contacts.
Spacewalker
Poland
C?ID=159607
look into MB to check each sensor if detect any object
could be a SW issue too
