Help HVAC ECON Fault criteria code 4
colinmuir
C?ID=263094
I have a 2004 B6 Audi A4 Quattro with APR K04 upgrade kit. A few months back, the AC got stuck in ECON mode. I have tried replacing both the G65 and the console HVAC controller, but neither has been able to rectify the issue. The EMC seems to be sending full 12 V through the signal wire, which is preventing the AC from kicking on (as return is then 12V and reads as max pressure from the G65). I have traced back the wires, and there seem to be no shorts. I took the car to Audi, and they confirmed that the AC blows cold if they manually cycle the compressor. I have tried in vain to use VCDS to clear the fault codes, and there seems to be little information on SHUT-OFF CODE 4 on the web. I think I somehow need to clear or disable the number 4 shut-off code, as it is stuck on. Here is some info from the VCDS readouts. Any advice would be greatly appreciated (I'll even paypal you $40 if you can help me fix it!). I've spent about 12 hours myself, and 2 hours shop time with Audi and there's no solution in sight. SoCal is not much fun without AC!
Address 08: Auto HVAC (8E0 820 043 AD)
16:25:23 Group 002: Compressor Shut-Off Criteria
4.0 Current Shut-Off Criteria
0.0 Last Shut-Off Criteria
0.0 Second to Last Shut-Off Criteria
0.0 Third to Last Shut-Off Criteria
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Control Module Part Number: 8E0 820 043 AD
Component and/or Version: A4 Klimaautomat 1324
Software Coding: 00000
Work Shop Code: WSC 63351
VCID: 63CBA326F191BF5994-5178
01172 - Temperature Sensor; Driver's Heated Seat (G59)
30-00 - Open or Short to Plus
01171 - Temperature Sensor; Passenger Side Heated Seat (G60)
Mr. M
Leicestershire, UK
C?ID=256600
Shut off code 4 is "Fault code stored", so you will need to fix at least the 00819 error to clear it.
Can you post a full autoscan in code (see the "how to post an autoscan" thread) and also MVB group 001 as you did with group 002 in your first post?
colinmuir
C?ID=263094
So I found some interesting behavior. I shorted the signal wire to ground, shut off the car, reconnected the G65, then turned the car back on again and checked for faults. This time was still the number 4 shut-off code, but the stored code became short to ground. It's like the car is stuck in shut-off code 4, and will just report whatever the last fault condition was. No matter what sequential combination I try, I cannot clear the shut-off code 4 from the EMC. I am wondering if there is some manual way to clear a shut-off code 4, or otherwise disable storing. Here is the additional information you requested, thanks in advance for any help or insight.
          67 69 75 76 77
VIN: WAULC68E14A   Mileage: 280030km-174002miles
Address 01: Engine        Labels: 06B-909-518-AMB.lbl
   Part No SW: 8E0 909 518 AK    HW: 8E0 909 018 A
   Component: 1.8L R4/5VT     G   0003
   Coding: 0016711
   Shop #: WSC 13111 281 411174
   VCID: 79F7E14E331D5589AE-5178
Readiness: 0000 1000
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517 A
   Component: ABS/ESP allrad      4529
   Coding: 04275
   Shop #: WSC 06435
   VCID: 264DFA32C2230A71B3-513C
            35-10 -  -  - Intermittent
   Part No: 8E0 820 043 AD
   Component:   A4 Klimaautomat   1324
   Coding: 00000
   Shop #: WSC 63351
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  USA 0617
   Coding: 01013
   Shop #: WSC 63351
   VCID: 356F2D7E0F8571E90A-4B32
01494 - Bulb for Parking Lamps; Left (M1)
            57-00 - Electric Circuit Failure
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 K
   Component: Airbag 8.4EP        1001
   Coding: 0010607
   Shop #: WSC 63351 000 00000
   VCID: 3F834F566DB9BBB9D0-5178
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0611
   Coding: 01041
   Shop #: WSC 63351
   VCID: 3E7D32523AB3B2B1DB-4B32
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8E0 920 950 P
   Component: KOMBI+WEGFAHRS. RB4 D42
   Coding: 01201
   Shop #: WSC 22103
   VCID: 366D2A7212837AF103-515A
   WAULC68E14A275803     AUZ6Z0D0137934
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.clb
   Part No: 8E0 959 433 BB
   Component: Komfortgerát T7B    1512
   Coding: 11788
   Shop #: WSC 14138
   VCID: 72E5D6623E6B26D1EF-4B18
   Subsystem 1 - Part No: 8E1959801
   Component: Tõrsteuer.FS BRM 0205
   Subsystem 2 - Part No: 8E1959802E
   Component: Tõrsteuer.BF BRM 0204
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0204
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0204
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00060
   Shop #: WSC 63351
   VCID: 040980BA14DF1861CD-4B32
End-------------------------(Elapsed Time: 04:58)--------------------------
Groups log:
19:06:56 Group 001
  0.000 A  A/C Valve (N280) Current
  0.0 %  A/C Valve (N280) Duty Cycle
  100.0 %  High-Pressure Signal (G65)
  33.0 bar  Refrigerant Circuit Pressure
19:06:56 Group 002: Compressor Shut-Off Criteria
19:06:56 Group 010: Temperatures II
  41.0°C  Evaporator Outflow Temp. (G263)
  38.5°C  Fresh Air Intake Duct Temp. (G89)
  31.0°C  Calculated Ambient Temp.
  43.0°C  Measured Ambient Temp. (G17)
vodonnell
Ireland
C?ID=5525
Over pressure switch G65 is saying that the system is overpressurised 33bar static is very high, put on a set of refrigeration gauges on the high and low sides and check actual pressure.
Mr. M
Leicestershire, UK
C?ID=256600
If the actual pressure in the system is ok, check MVB 001.3 again with the G65 disconnected. If it stays at 100%, you'll need to get a WD and trace that signal wire back to find out where the 12v signal is coming from.
If your G65 has 3 pins, there should be a 12v+, a 12v-, and a PWM signal. Am I correct in thinking you have checked the signal wire at the G65 connector with the G65 disconnected and found 12v+?
colinmuir
C?ID=263094
Thank you vodonnell and Mr M for the help. I disconnected the G65 and checked the MVB values (pasted below): the signal is still at 100%. I then followed it up by measuring the signal wire (pin 2) at the connector and found 13V in the disconnected setting. Voltage stayed at 13V with the HVAC turned off, and with it on (stuck in ECON). I tried to ground out the signal wire on the alternator, but when I measured again, it was back up to 13V. So 13V is being sent down the signal wire at all times. Furthermore, with the car off and key out of the ignition, I was still picking up 12V from the signal wire (slowly dropping). I will trace back the wire to see if there is a short. Question that might help me: is the signal wire to the G65 normally 6V? Is there ever a time when the computer would send a 12V signal down the wire (like if the computer is disabling the compressor by sending a 100% signal due to shutoff code 4). I suspect that the computer is disabling the compressor with a 12V to the G65, but I'll do my due diligence. Thanks again.
14:08:48 Group 001
14:08:48 Group 002: Compressor Shut-Off Criteria
14:08:48 Group 010: Temperatures II
  44.0°C  Evaporator Outflow Temp. (G263)
  42.5°C  Fresh Air Intake Duct Temp. (G89)
  32.0°C  Calculated Ambient Temp.
  32.0°C  Measured Ambient Temp. (G17)
colinmuir
C?ID=263094
So I disconnected the signal wire from the back of the E87 (HVAC head unit) with all other wires/connectors still attached to the E87 (isolated the signal wire only). With the car running, the disconnected wire shows 0V (no short) and the signal male pin from the E87 connector has 13V. So the HVAC head is sending full voltage through the signal wire to disable the AC. I suspect it's because I can't clear the shut-off code 4 that's somehow stored in the computer. Any ideas? Please and thank you!
Gone But Not Forgotten
Sounds like water ingress on the floor to the seat heaters to me............and causing an implausible issue for the controller resulting in AC shut down.
Mr. M
Leicestershire, UK
C?ID=256600
If I was looking at this, my next action would be to connect the G65, and disconnect the signal wire from the back of the HVAC panel again. Then check the following on the signal wire with the engine running:
DC voltage
Frequency
Duty cycle
These need to be checked using a DVOM, with black lead to ground and red lead to signal wire.
No, the sensor is powered with 12v and it then generates a pulsed (or square wave) 12v signal on the signal pin/wire. The HVAC controller requires this signal to allow correct control of the system, therefore without it the compressor will not be activated. Have you measured 6v with a meter on the signal wire? If so, this could be correct for a 12v PWM signal
Shut-off codes cannot be manually cleared; they can only be cleared by the module itself when it is satisfied that the reason for the code has gone. In your case, once the stored fault codes have been addressed and cleared by you, shut-off code 4 will be cleared by the module.
This is a good point, why are there DTCs stored relating to the seat heaters?
I have seen this a few times already.........and it is not likely to have temp sensor issues in both circuits all sharing a short to B+...........
NostraJackAss Has Spoken Ipse-Dixit !
colinmuir
C?ID=263094
Hello folks
The heated seats have always had a fault since I bought the car. The AC used to work even with the seats throwing a code, so I suspect the seat heater fault is unrelated to my current issues.
I'm starting to suspect it's my G65, but I have a question for the group. I have two G65 sensors (my old one, and a new one), but I mixed them up and I'm not sure which is which. They are slightly different: the grey one has a solid nipple in the middle (to depress the check valve) with a tiny hole in the very base of the sensor to measure the pressure (i presume). The other black one has a hollow nipple with a hole in it for pressure measurement. With the car running I did some tests on the signal wire back to the HVAC head (signal wire connected only to voltmeter).
With the black G65 plugged into the high pressure port on the cooler, signal back to HVAC measures 12.3V and 3.6Hz. With the black G65 open to atmosphere it measures 12.3V and 3.6Hz.
With the grey G65 plugged into the high pressure port on the cooler, signal back to HVAC measures 0V and 0Hz. With the grey G65 open to atmosphere it measures 0V and 0Hz.
I can go back and forth multiple times with either G65 and re-create these identical measurements.
I checked the low pressure side of the system and it does have a charge (but reading without the compressor running is not useful). Also, the check valve on the G65 port lets out a little pressure poof everytime I swap sensors.
So I'm thinking both the new and old G65 sensors are pooched. What do you guys think? The G65 sends a square wave reference signal back through the signal wire, correct?
Photo of G65s: https://goo.gl/photos/oHicYP4tZcKVMSWy8
