- Joined
- Apr 9, 2014
- Messages
- 2,309
- Reaction score
- 2,257
- Location
- Tartu, Estonia
- VCDS Serial number
- C?ID=195131
Following the question...
Is there USB-C /// USB-B cable available already?
If that cable works, I'd appreciate it if you'd post the part number.Yup, Belkin sells them. They also have USB-C > anything else.
Split from Replacement USB Cable
At some point, RT will probably have a batch made with our HEX-V2 screw-lock on the USB-B end (which is coming to the HEX-NET as well), but so far we haven't seen the enough demand to have a run of them done (the MOQ is in the thousands).
I second that, this specific cable works really well (seamless).Oh yeah it works like a charm. I used to use Apple’s USB-C to USB-A adapter and that occassionally resulted in an ‘interface not found!’ error at VCDS startup. With this cable it works like its supposed to.
Anyway, Belkin partno. is: F2CU035bt06-BLK
I thought un-boosted USB was specced to 5m, so you can't use a dumb USB extension over 3m as you're tagging a 2m cable onto the end of it, but 5m direct to the interface should be ok?I have been using one from InLine (P/N 35762) for quite some time, available in up to 5m (which is technically not supported, I know).
It's really hard to predict what will and won't work. In principle, all dumb USB extension cables (regardless of length) are prohibited by the USB spec, yet some do work.I thought un-boosted USB was specced to 5m, so you can't use a dumb USB extension over 3m as you're tagging a 2m cable onto the end of it, but 5m direct to the interface should be ok?
https://en.wikipedia.org/wiki/USB#Cabling
Tell you what, any member of this forum with a 4-digit post count who wants one can have one at no cost just by asking.Not an advantageous purchase for this canard-noir
Is there a time limit on the post count threshold?Tell you what, any member of this forum with a 4-digit post count who wants one can have one at no cost just by asking.
Dave: as well as having the rare advantage of living in a country that has made the "right" decision (pun intended) about which car-side to install a steering wheel - what could possibly prompt the insanity of some one with your obvious intelligence to contemplate driving a car that has LHD?The USB-A sockets are even on each side, so there's one suitable whether you drive a LHD or RHD vehicle.
Don: in the past (pre-divorce) visiting step-children in the US 'tricked' me into driving LHD vehicles, but now it will be vacations to continental Europe - so I will still have the need to drive while sitting in the passenger seatwhat could possibly prompt the insanity of some one with your obvious intelligence to contemplate driving a car that has LHD?
