Friday,26,April,2024,21:56:38:33887
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WVWZZZ1KZBW047896 License Plate: SALMAANGOLF 6 GTI
Mileage: 209130km-129947mi Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZBW047896 Mileage: 209130km-129947miles
Address 01: Engine (CCZ) Labels:. 06J-907-115-CCZ.clb
Part No SW: 5K0 907 115 N HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0010
Revision: AAH17--- Serial number:
Coding: 0403000C1C070160
Shop #: WSC 63354 002 1048576
VCID: 3536D91A89493352CC5-8060
VINID: 9E69EAAAA05BA929C010720918C4D306D3
001674 - ECM Power Relay Load Circuit
P068A - 000 - Opens Too Early - Intermittent
Date: 2047.15.31
Time: 31:63:63
Temperature: 20.0°C
Temperature: 28.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 6.096 V
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 000 - Implausible Signal - MIL ON
Fault Status: 11100000
Fault Frequency: 26
Mileage: 209095 km
Date: 2018.09.17
Time: 00:03:60
RPM: 1215 /min
Load: 33.3 %
Temperature: 18.0°C
Temperature: 20.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.970 V
008801 - Boost Pressure Control Valve (N249)
P2261 - 000 - Mechanical Malfunction
Mileage: 209095 km
Date: 2018.09.17
Time: 00:19:43
RPM: 1682 /min
Load: 10.6 %
Speed: 16.0 km/h
Temperature: 87.0°C
Temperature: 27.0°C
Voltage: 13.970 V
P2015 - 000 - Implausible Signal - Intermittent - MIL ON
Fault Status: 10100000
Fault Frequency: 26
Mileage: 209108 km
Date: 2018.09.17
Time: 19:46:01
RPM: 2928 /min
Load: 100.0 %
Speed: 39.0 km/h
Temperature: 96.0°C
Temperature: 41.0°C
Voltage: 13.335 V
000564 - Boost Pressure Regulation
P0234 - 000 - Limit Exceeded (Overboost Condition) - MIL ON
Mileage: 209095 km
Date: 2018.09.17
Time: 00:20:55
RPM: 3956 /min
Load: 99.6 %
Speed: 54.0 km/h
Temperature: 90.0°C
Temperature: 23.0°C
Voltage: 13.970 V
Readiness: 0000 0001
Part No SW: 02E 300 053 N HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2207
Revision: 05151112 Serial number: 00001007151247
VCID: 2018184E26CBA6FA0F3-8074
Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
VCID: 045074DE9E135ADA0BB-8050
Reset counter: 164
Date: 2018.09.17
Time: 17:49:33
Count: 3
Count: 12
Count: 20992
Count: 195
Count: 41216
Fault Status: 01100101
Reset counter: 164
Mileage: 209101 km
Date: 2018.09.17
Time: 17:49:33
Count: 3
Count: 14
Count: 28672
Count: 279
Count: 41216
Count: 256
Reset counter: 164
Mileage: 209101 km
Date: 2018.09.17
Time: 17:49:33
Count: 3
Count: 14
Count: 28672
Count: 295
Count: 41216
Count: 256
Reset counter: 164
Mileage: 209101 km
Date: 2018.09.17
Time: 17:49:33
Count: 3
Count: 14
Count: 28672
Count: 270
Count: 41216
Count: 256
Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000001002
VCID: 7EA40636F07F300A5DF-802A
13701936 - Function Restriction due to Faults in Other Modules
U1113 00 [00001000] - -
[Steuergerät für Bordnetz - bitte Fehlerspeicher auslesen]
Reset counter: 203
Mileage: 209101 km
Date: 2024.04.26
Time: 03:06:08
B10AB F0 [00001001] - Too Low
Reset counter: 162
Mileage: 209095 km
Date: 2024.04.26
Time: 00:00:05
Address 09: Cent. Elect.
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKRA9X9FC Dataset Number: 5K0003v____ 0094
Coding: 00003135
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3B22CF22A3EDE5223A1-806E
Component: S.Sens.Fahr.V U01 ----
Serial number: 3572MSME6A076448ZZZ
Component: S.Sens.Beif.V U01 ----
Serial number: 3582MSME032B7240ZZZN
Serial number: 3512QSME1A1E2E09ZZZ%
Serial number: 3522QSME0E392F45ZZZ1
13635840 - Supply voltage
U1011 00 [00001000] - Voltage too Low
[Powersupply lower threshold fall short of]
Reset counter: 202
Mileage: 209095 km
Date: 2024.04.26
Time: 00:01:23
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90440JFL00189 Dataset Number: 5K0953507AH D005
Coding: 1892140000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76B41E16D84F784A05F-8022
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Serial number: 0003175
Coding: 830000
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [00001000] - -
Reset counter: 202
Mileage: 209095 km
Date: 2024.04.26
Time: 00:40:49
Part No SW: 5K6 920 871 HW: 5K6 920 871
Component: KOMBI H04 0406
Coding: 170F00
VCID: 71BE2D0AB1215F72D0D-8024
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 100710F1002714
Coding: ED817F0600020200000003
VCID: 6D86317AA199BB92F45-8038
Fault Frequency: 39
Reset counter: 206
Mileage: 209095 km
Date: 2018.09.17
Time: 01:57:25
Component: IMMO H04 0406
VCID: 6A8C3A669CF7ACAA917-803E
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2110
Coding: 0000692
VCID: 313EED0A7D211F7290D-8064
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
Fault Status: 11100101
Mileage: 209095 km
Date: 2018.09.17
Time: 01:57:30
Battery Volts: 11.2 V
DD
Temperature: 26.0°C
Count: 3
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Address 46: Central Conv.
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0000692
VCID: 323CE2067827246AE97-8066
Address 55: Headlight Range Labels: 5M0-907-357-V2.clb
Component: AFS-Steuergeraet 0142
Coding: 1443164
VCID: 3430E41E82332A5AFBB-8060
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Coding: 00000022
02988 - Left-Hand/Right-Hand Traffic Switchover Active
Reset counter: 162
Mileage: 209095 km
Date: 2018.09.17
Time: 01:57:37
Voltage: 11.08 V
ABS 1
Address 56: Radio
Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 01357 011 1012552
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
Coding: 0000144
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End----------(Elapsed Time: 01:05, VBatt start/end: 12.1V/12.1V)-----------
