- Apr 17, 2015
- 278
- 87
- South Africa
- C?ID=133909
This vehicle has history, Was taken to VW for poor power. VW diagnosed new high pressure pump, new common rail and 4 x injectors. Client bought the items at Bosch (cheaper) and VW fitted it. After the fitment the idling was uneven and before the fitment the idling was fine. The fuel pressure is jumping up and down quite a bit. VW states the high pressure pump needs to be replaced and is noisy. I compared with stetoscope between 2 Amaroks and the sound was similar. This looks like the fuel pressure regulating valve N276 on the fuel rail. I will test it tomorow morning.
Client also told me during the installation the high pressure pump timing locking mechanism broke of one piece. VW reckons the pump timing is correct. I am not sure but will double check the timing (maybe it could influence the idling?).
Wednesday,09,May,2018,12:34:29:48706
VCDS Version: 18.2.0.3 (x64) HEX-NET CB: 0.4411.4
Dealer/Shop Name: RyMar Auto
Workshop Code: 000 00000 001753
VIN: WV1ZZZ2HZB8077227 License Plate: DRM290L
Mileage: 216386km Repair Order:
Address 01: Engine (03L 906 019 EM)
12:34:04
IDE00188 Fuel high pressure: actual value 282900 hPa
IDE00201 High fuel pressure: specified value 280000 hPa
IDE00357 Fuel temperature 47.2 °C
IDE00475 Fuel Pressure Regulator Valve 27.94 %
IDE00476 Fuel Metering Valve 48.13 %
IDE00589 Fuel pressure 22040 kPa rel
12:35:08
IDE00188 Fuel high pressure: actual value 278800 hPa
IDE00357 Fuel temperature 48.0 °C
IDE00365 Injection amount deviation cylinder 1 -0.39 mg/stroke
IDE00366 Injection amount deviation cylinder 2 -0.03 mg/stroke
IDE00367 Injection amount deviation cylinder 3 -0.19 mg/stroke
IDE00368 Injection amount deviation cylinder 4 0.55 mg/stroke
IDE00475 Fuel Pressure Regulator Valve 23.61 %
IDE00476 Fuel Metering Valve 49.85 %
IDE00589 Fuel pressure 19710 kPa rel
12:38:41
IDE00188 Fuel high pressure: actual value 332300 hPa
IDE00201 High fuel pressure: specified value 280800 hPa
IDE00357 Fuel temperature 48.1 °C
IDE00365 Injection amount deviation cylinder 1 -0.68 mg/stroke
IDE00366 Injection amount deviation cylinder 2 0.86 mg/stroke
IDE00367 Injection amount deviation cylinder 3 -0.96 mg/stroke
IDE00368 Injection amount deviation cylinder 4 0.97 mg/stroke
IDE00475 Fuel Pressure Regulator Valve 23.54 %
IDE00476 Fuel Metering Valve 39.54 %
IDE00589 Fuel pressure 11710 kPa rel
IDE03892 Fuel high pressure sensor: unconditioned voltage 1030.8 mV
12:42:18
IDE00188 Fuel high pressure: actual value 244700 hPa
IDE00365 Injection amount deviation cylinder 1 0.07 mg/stroke
IDE00366 Injection amount deviation cylinder 2 0.62 mg/stroke
IDE00367 Injection amount deviation cylinder 3 -0.12 mg/stroke
IDE00368 Injection amount deviation cylinder 4 -0.12 mg/stroke
IDE00475 Fuel Pressure Regulator Valve 26.48 %
IDE00476 Fuel Metering Valve 44.66 %
IDE00589 Fuel pressure 28690 kPa rel
IDE03892 Fuel high pressure sensor: unconditioned voltage 1027.4 mV
Chassis Type: 2H-VN81 (6N0)
Scan: 01 03 08 09 15 17 19 22 25 32 69
VIN: WV1ZZZ2HZB8077227 Mileage: 216380km-134452miles
Address 01: Engine (J623-CDBA) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 EM HW: 03L 907 309 K
Component: R4 2.0l TDI H37 9977
Revision: 26H37--- Serial number: 00000000000000
Coding: 01190000230400080000
Shop #: WSC 01317 996 00000
ASAM Dataset: EV_ECM20TDI01103L906019EM 004007
ROD: EV_ECM20TDI01103L906019EM_004.rod
VCID: 7AB81705FD611B9456-802E
5568 - Sensor for Ambient Air Temperature (G17)
P0073 00 [175] - Signal too High
Mileage: 216373 km
Date: 2018.05.09
Time: 11:00:44
Engine speed: 883.00 /min
Normed load value: 28.2 %
Coolant temperature: 81 °C
Intake air temperature: 56 °C
Ambient air pressure: 930 mbar
Voltage terminal 30: 16.180 V
Exh.gas temp.sen 1: 156.0 °C
Exh.gas temp.sen 2: -0.0 °C
Exh.gas temp.sen 3: -0.0 °C
Exh.gas temp.sen 4: -0.0 °C
Shut-off timer: last engine shut-off time: 1202 s
8623 - Sensor for Ambient Air Temperature (G17)
P0071 00 [036] - Implausible Signal
Date: 2018.05.09
Time: 12:31:58
Coolant temperature: 94 °C
Voltage terminal 30: 13.100 V
Exh.gas temp.sen 1: 187.1 °C
Shut-off timer: last engine shut-off time: 356 s
4978 - Glow Plug Module 1; Glow Plug Circuit
P0670 00 [047] - Electrical Malfunction
Mileage: 216373 km
Date: 2018.05.09
Time: 11:00:43
Engine speed: 855.00 /min
Normed load value: 32.5 %
Voltage terminal 30: 15.480 V
Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
Electric auxiliary heater: relay activation-Bits 0-7: 0
Preheat time: 0 ms
Glow status-Bits 0-7: 0
Glow status-Bits 0-7: 255
Glow cycles above temperature threshold-Bits 0-7: 21
Glow cycles above temperature threshold-Bits 0-7: 32
Glow cycles below temperature threshold-Bits 0-7: 0
Glow cycles below temperature threshold-Bits 0-7: 5
Outside air temperature: 3003.6 °C
Readiness: 1 1 0 0 0
Address 03: ABS Brakes Labels: Redir Fail!
Part No SW: 2H0 907 379 H HW: 2H0 907 379 B
Component: ASR MK25 E 0107
Revision: 00H23001
Coding: 0000069
Shop #: WSC 07456 790 50316
VCID: 3522C4395CFF34ECFB-8060
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 2H0 907 047 D HW: 2H0 907 047 D
Component: Climatic-T5 H11 0303
Revision: 00006001
Coding: 0000000002
ROD: EV_ClimaT5Basis.rod
VCID: 291A18494847600C6F-807C
13701968 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[Steuergerät im Schalttafeleinsatz - bitte Fehlerspeicher auslesen]
Fault Frequency: 12
Reset counter: 219
Mileage: 216357 km
Date: 2018.05.09
Time: 08:09:41
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R7 937 085 D HW: 6R7 937 085 D
Component: PQ25 BCM H12 0022
Revision: -5------ Serial number: 1002480401
Coding: 190000180C13000000000800240A04840000410F600200003000
Shop #: WSC 01751 996 87609
VCID: 43C6AAE1C22B9A5C45-8016
Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
Component: VW10Airbag00C H06 0013
Revision: -------- Serial number: 003HN003DW9E
Coding: 000000000000000000000000000000003043
Shop #: WSC 07446 790 50316
VCID: 3326FA219A8B2ADCD5-8066
Serial number: 3555YRB404V0DOAA78OA
Serial number: 3565YRB40690DD24DGUT
Part No SW: 2H0 920 851 A HW: 2H0 920 851 A
Component: KOMBI H05 0304
Coding: 170000
VCID: 2404097D2F65BD645C-8070
9453330 - Outside temperature sensor
B103F 1B [009] - Resistance Too High
Reset counter: 218
Mileage: 216357 km
Date: 2018.05.09
Time: 08:09:42
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R7 937 085 D
Component: GW-K-CAN TP20 0022
Revision: -5------
Coding: 742100
VCID: 70AC352DA31D51C4E8-8024
Address 22: AWD Labels: None
Part No SW: 2H0 927 755 B HW: 2H0 927 755 B
Component: SG offroad VTG 0153
Revision: 00H06000 Serial number: T1IYC010111PMC
Coding: 0000013
VCID: 2F2EF651BEA30E3CB1-807A
Component: IMMO H05 0304
VCID: 6A9827458DC1AB14A6-803E
Address 32: Differential Locks (J647) Labels:* 2H0-927-771.clb
Part No SW: 2H0 927 771 HW: 2H0 927 771
Component: Quersperre H04 0014
Revision: 11001001 Serial number: 4DG 10.02.11 00
ASAM Dataset: EV_QuersUDSAAMVN817 A01005
ROD: EV_QuersUDSAAMVN817.rod
VCID: 6B962241823BB21CDD-803E
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00000141672921
Coding: 0100000100000000
VCID: 302CF52D639D11C4A8-8064
End----------(Elapsed Time: 00:33, VBatt start/end: 14.1V/14.1V)-----------
