Amarok uneven idling
RyMar
South Africa
C?ID=133909
This vehicle has history, Was taken to VW for poor power. VW diagnosed new high pressure pump, new common rail and 4 x injectors. Client bought the items at Bosch (cheaper) and VW fitted it. After the fitment the idling was uneven and before the fitment the idling was fine. The fuel pressure is jumping up and down quite a bit. VW states the high pressure pump needs to be replaced and is noisy. I compared with stetoscope between 2 Amaroks and the sound was similar. This looks like the fuel pressure regulating valve N276 on the fuel rail. I will test it tomorow morning.
Client also told me during the installation the high pressure pump timing locking mechanism broke of one piece. VW reckons the pump timing is correct. I am not sure but will double check the timing (maybe it could influence the idling?).
Wednesday,09,May,2018,12:34:29:48706
VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4411.4
Dealer/Shop Name: RyMar Auto
Workshop Code: 000 00000 001753
VIN: WV1ZZZ2HZB8077227   License Plate: DRM290L
Mileage: 216386km   Repair Order:
                Address 01: Engine  (03L 906 019 EM)
12:34:04
  IDE00188   Fuel high pressure: actual value 282900 hPa
  IDE00201   High fuel pressure: specified value 280000 hPa
  IDE00357   Fuel temperature 47.2 °C
  IDE00475   Fuel Pressure Regulator Valve 27.94 %
  IDE00476   Fuel Metering Valve 48.13 %
  IDE00589   Fuel pressure 22040 kPa rel
12:35:08
  IDE00188   Fuel high pressure: actual value 278800 hPa
  IDE00357   Fuel temperature 48.0 °C
  IDE00365   Injection amount deviation cylinder 1 -0.39 mg/stroke
  IDE00366   Injection amount deviation cylinder 2 -0.03 mg/stroke
  IDE00367   Injection amount deviation cylinder 3 -0.19 mg/stroke
  IDE00368   Injection amount deviation cylinder 4 0.55 mg/stroke
  IDE00475   Fuel Pressure Regulator Valve 23.61 %
  IDE00476   Fuel Metering Valve 49.85 %
  IDE00589   Fuel pressure 19710 kPa rel
12:38:41
  IDE00188   Fuel high pressure: actual value 332300 hPa
  IDE00201   High fuel pressure: specified value 280800 hPa
  IDE00357   Fuel temperature 48.1 °C
  IDE00365   Injection amount deviation cylinder 1 -0.68 mg/stroke
  IDE00366   Injection amount deviation cylinder 2 0.86 mg/stroke
  IDE00367   Injection amount deviation cylinder 3 -0.96 mg/stroke
  IDE00368   Injection amount deviation cylinder 4 0.97 mg/stroke
  IDE00475   Fuel Pressure Regulator Valve 23.54 %
  IDE00476   Fuel Metering Valve 39.54 %
  IDE00589   Fuel pressure 11710 kPa rel
  IDE03892   Fuel high pressure sensor: unconditioned voltage 1030.8 mV
12:42:18
  IDE00188   Fuel high pressure: actual value 244700 hPa
  IDE00365   Injection amount deviation cylinder 1 0.07 mg/stroke
  IDE00366   Injection amount deviation cylinder 2 0.62 mg/stroke
  IDE00367   Injection amount deviation cylinder 3 -0.12 mg/stroke
  IDE00368   Injection amount deviation cylinder 4 -0.12 mg/stroke
  IDE00475   Fuel Pressure Regulator Valve 26.48 %
  IDE00476   Fuel Metering Valve 44.66 %
  IDE00589   Fuel pressure 28690 kPa rel
  IDE03892   Fuel high pressure sensor: unconditioned voltage 1027.4 mV
Chassis Type: 2H-VN81 (6N0)
Scan: 01 03 08 09 15 17 19 22 25 32 69
VIN: WV1ZZZ2HZB8077227   Mileage: 216380km-134452miles
Address 01: Engine (J623-CDBA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 EM    HW: 03L 907 309 K
   Component: R4 2.0l TDI   H37 9977
   Revision: 26H37---    Serial number: 00000000000000
   Coding: 01190000230400080000
   Shop #: WSC 01317 996 00000
   ASAM Dataset: EV_ECM20TDI01103L906019EM 004007
   ROD: EV_ECM20TDI01103L906019EM_004.rod
   VCID: 7AB81705FD611B9456-802E
5568 - Sensor for Ambient Air Temperature (G17)
          P0073 00 [175] - Signal too High
                    Mileage: 216373 km
                    Date: 2018.05.09
                    Time: 11:00:44
                    Engine speed: 883.00 /min
                    Normed load value: 28.2 %
                    Coolant temperature: 81 °C
                    Intake air temperature: 56 °C
                    Ambient air pressure: 930 mbar
                    Voltage terminal 30: 16.180 V
                    Exh.gas temp.sen 1: 156.0 °C
                    Exh.gas temp.sen 2: -0.0 °C
                    Exh.gas temp.sen 3: -0.0 °C
                    Exh.gas temp.sen 4: -0.0 °C
                    Shut-off timer: last engine shut-off time: 1202 s
8623 - Sensor for Ambient Air Temperature (G17)
          P0071 00 [036] - Implausible Signal
                    Date: 2018.05.09
                    Time: 12:31:58
                    Engine speed: 0.00 /min
                    Coolant temperature: 94 °C
                    Voltage terminal 30: 13.100 V
                    Exh.gas temp.sen 1: 187.1 °C
                    Shut-off timer: last engine shut-off time: 356 s
4978 - Glow Plug Module 1; Glow Plug Circuit
          P0670 00 [047] - Electrical Malfunction
                    Mileage: 216373 km
                    Date: 2018.05.09
                    Time: 11:00:43
                    Engine speed: 855.00 /min
                    Normed load value: 32.5 %
                    Voltage terminal 30: 15.480 V
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
                    Electric auxiliary heater: relay activation-Bits 0-7: 0
                    Preheat time: 0 ms
                    Glow status-Bits 0-7: 0
                    Glow status-Bits 0-7: 255
                    Glow cycles above temperature threshold-Bits 0-7: 21
                    Glow cycles above temperature threshold-Bits 0-7: 32
                    Glow cycles below temperature threshold-Bits 0-7: 0
                    Glow cycles below temperature threshold-Bits 0-7: 5
                    Outside air temperature: 3003.6 °C
Readiness: 1 1 0 0 0
Address 03: ABS Brakes        Labels: Redir Fail!
   Part No SW: 2H0 907 379 H    HW: 2H0 907 379 B
   Component: ASR MK25 E          0107
   Revision: 00H23001
   Coding: 0000069
   Shop #: WSC 07456 790 50316
   VCID: 3522C4395CFF34ECFB-8060
   Part No SW: 2H0 907 047 D    HW: 2H0 907 047 D
   Component: Climatic-T5   H11 0303
   Revision: 00006001
   Coding: 0000000002
   ROD: EV_ClimaT5Basis.rod
   VCID: 291A18494847600C6F-807C
13701968 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Steuergerät im Schalttafeleinsatz - bitte Fehlerspeicher auslesen]
                    Fault Frequency: 12
                    Reset counter: 219
                    Mileage: 216357 km
                    Date: 2018.05.09
                    Time: 08:09:41
   Part No SW: 6R7 937 085 D    HW: 6R7 937 085 D
   Component: PQ25 BCM      H12 0022
   Revision: -5------    Serial number: 1002480401
   Coding: 190000180C13000000000800240A04840000410F600200003000
   Shop #: WSC 01751 996 87609
   VCID: 43C6AAE1C22B9A5C45-8016
   Part No SW: 2H0 959 655 B    HW: 2H0 959 655 B
   Component: VW10Airbag00C H06 0013
   Revision: --------    Serial number: 003HN003DW9E
   Coding: 000000000000000000000000000000003043
   Shop #: WSC 07446 790 50316
   VCID: 3326FA219A8B2ADCD5-8066
   Serial number: 3555YRB404V0DOAA78OA
   Serial number: 3565YRB40690DD24DGUT
   Part No SW: 2H0 920 851 A    HW: 2H0 920 851 A
   Component: KOMBI         H05 0304
   Coding: 170000
   VCID: 2404097D2F65BD645C-8070
9453330 - Outside temperature sensor
          B103F 1B [009] - Resistance Too High
                    Reset counter: 218
                    Mileage: 216357 km
                    Date: 2018.05.09
                    Time: 08:09:42
   Part No SW: 6N0 909 901     HW: 6R7 937 085 D
   Component: GW-K-CAN TP20 0022
   Revision: -5------
   Coding: 742100
   VCID: 70AC352DA31D51C4E8-8024
   Part No SW: 2H0 927 755 B    HW: 2H0 927 755 B
   Component: SG offroad VTG      0153
   Revision: 00H06000    Serial number: T1IYC010111PMC
   Coding: 0000013
   VCID: 2F2EF651BEA30E3CB1-807A
   Component: IMMO          H05 0304
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A9827458DC1AB14A6-803E
Address 32: Differential Locks (J647)       Labels:* 2H0-927-771.clb
   Part No SW: 2H0 927 771     HW: 2H0 927 771
   Component: Quersperre    H04 0014
   Revision: 11001001    Serial number: 4DG 10.02.11 00
   ASAM Dataset: EV_QuersUDSAAMVN817 A01005
   ROD: EV_QuersUDSAAMVN817.rod
   VCID: 6B962241823BB21CDD-803E
   Revision: 3A001001    Serial number: 00000141672921
   Coding: 0100000100000000
   VCID: 302CF52D639D11C4A8-8064
End----------(Elapsed Time: 00:33, VBatt start/end: 14.1V/14.1V)-----------
Gone But Not Forgotten
Yes Bosch ECD17CP20 controllers factor the stroke of the pump & is of particular importance for idle balance unlike the EDC17CP14 platforms in the USA "that really doesn't give a shit" & maybe for other reasons connected to stupid choices doing what ever it wants.
Just like VW to take what it wants..........
2Q==
Z
Z
Larry Manton
C?ID=112505
Jack, have seen several Honey Badger videos, I kind of like them much like road runner cartoons.
Larimore.
RyMar
South Africa
C?ID=133909
Timing was incorrect and we reset it with the help off the special tools. Problem stayed. Now and again the idling will be uneven with the fuel pressure fluctuating.
Since the client took the vehicle to VW for no power, we swopped the old fuel regulator valve and it made no difference.
Will investigate further but I think the history of the vehicle explained to me is not true.
RyMar
South Africa
C?ID=133909
Checked the fuel supply pressure from fuel tank to high pressure pump. Pressure gauge needle jumps continuously between 2.8 & 4 bar.
Could the fluctuating needle be from the high pressure pump? Fuel pressure according to specs is equal and greater than 3.5bar.
RyMar
South Africa
C?ID=133909
When we dropped the fuel tank there was very fine metal chavings in the tank. The pick up screen of the fuel pump also dirty (muddy).
I think my client will have to redo the whole excercise over again (hp pump, common rail and injectors).
Yup.........
This is why I think post filter and screens after an HPP are a ( no brainier for strainer ) for the dude keeping his car forever & not to mention the GHG factor reduction from the engine running far better.
Fuel lubricants have importance too...........
