2007 VW Passat 2.0T No Start
CrazyCajun
C?ID=238320
Hello all I am new to this but am very grateful for any help.
Tuesday,13,February,2018,11:54:58:09859
VCDS Version: 18.1.0.2 (x64)
Data version: 20180122 DS285.1
VIN: WVWJK73C47E246480   License Plate:
Mileage: 151280km-94001mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 72
VIN: WVWJK73C47E246480   Mileage: 151280km-94001miles
00-Steering Angle Sensor -- Status: INTERFACE NOT COMPATIBLE
02-Auto Trans -- Status: Malfunction 1010
08-Auto HVAC -- Status: Cannot be reached 1100
15-Airbags -- Status: Malfunction 1010
1C-Position Sensing -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 1010
53-Parking Brake -- Status: Cannot be reached 1100
65-Tire Pressure -- Status: Malfunction 1010
72-Door, Rear Right -- Status: Malfunction 1010
   Part No SW: 3C0 907 115 S    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWZCZ000000000
   Coding: 0404010A19070160
   Shop #: WSC 25642 444 92495
   VCID: 3041E2B0A305D0C505-8064
               P1653 - 004 -
                    Fault Frequency: 25
                    Mileage: 151281 km
                    Date: 2018.02.10
                    Time: 10:57:15
                    Temperature: 18.0°C
                    Temperature: 19.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 12.192 V
049448 - No Communications with Parking Brake Control Module
               U0128 - 008 -
                    Fault Status: 01101000
                    Mileage: 151281 km
                    Date: 2018.02.10
                    Time: 10:57:16
                    Temperature: 19.0°C
                    Temperature: 19.0°C
                    Voltage: 12.192 V
049508 - No Communications with HVAC Control Module (J301)
               U0164 - 008 -
                    Mileage: 151281 km
                    Date: 2018.02.10
                    Time: 10:57:16
                    Temperature: 19.0°C
                    Temperature: 20.0°C
                    Voltage: 12.192 V
012425 - Signal Line for Fuel Pump Electronics
               P3089 - 002 - Electrical Malfunction
                    Fault Status: 01100010
                    Mileage: 151281 km
                    Date: 2018.02.10
                    Time: 10:57:42
                    RPM: 258 /min
                    Load: 67.0 %
                    Temperature: 19.0°C
                    Temperature: 20.0°C
                    Voltage: 11.176 V
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage
                    Mileage: 151281 km
                    Temperature: 9.0°C
                    Temperature: 11.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 12.319 V
008852 - Fuel Pressure Regulator Valve (N276)
               P2294 - 004 - Open Circuit - Intermittent
                    Mileage: 151281 km
                    RPM: 236 /min
                    Load: 67.4 %
                    Temperature: 9.0°C
                    Temperature: 11.0°C
                    Voltage: 11.938 V
Readiness: 0110 0101
   Part No SW: 09G 927 750 HJ    HW: 09G 927 750 FP
   Component: AQ 250 6F           1068
   Revision: 00H69000    Serial number:
   Coding: 0000072
   VCID: 0021727053258045B5-8054
                    Fault Frequency: 27
                    Reset counter: 0
                    Mileage: 42756 km
                    Date: 2009.03.25
                    Time: 13:35:04
            013 - Check DTC Memory
                    Fault Frequency: 27
                    Reset counter: 0
                    Mileage: 42756 km
                    Date: 2009.03.25
                    Time: 13:35:04
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 109 A    HW: 3C0 614 109 A
   Component: ESP 440 C4     H018 0001
   Revision:  H018       Serial number: 0775412325
   Coding: 0013755
   Shop #: WSC 05311 000 00000
   VCID: 1C192600DF8D44A549-8048
                    Fault Frequency: 170
                    Reset counter: 161
                    Mileage: 151281 km
                    Date: 2018.01.30
                    Time: 18:45:08
                    Reset counter: 161
                    Mileage: 151281 km
                    Date: 2018.01.30
                    Time: 19:39:59
                    Fault Status: 01101101
                    Fault Frequency: 12
                    Reset counter: 161
                    Mileage: 151281 km
                    Date: 2018.02.10
                    Time: 18:34:04
                    Fault Frequency: 12
                    Reset counter: 161
                    Mileage: 151281 km
                    Date: 2018.02.10
                    Time: 18:34:04
Address 08: Auto HVAC
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000007061522
   Coding: 10840F0340041A00470000000F00000000285D435C0001
   VCID: 6CF936C04FAD742579-8038
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 020407 003  0205
   Coding: 00046997
   Shop #: WSC 05311
10 Faults Found:
                    Fault Status: 01101100
                    Reset counter: 162
                    Mileage: 150459 km
                    Date: 2017.12.16
                    Time: 17:52:00
                    Voltage: 11.80 V
00906 - Horn (H1)
                    Fault Status: 00101001
                    Reset counter: 202
                    Mileage: 151281 km
                    Date: 2018.01.30
                    Time: 17:15:00
                    Voltage: 12.25 V
01516 - Terminal 30; Left
                    Fault Status: 00101011
                    Reset counter: 202
                    Mileage: 151281 km
                    Date: 2018.01.30
                    Time: 17:57:00
                    Voltage: 12.30 V
                    Fault Frequency: 15
                    Reset counter: 202
                    Mileage: 151280 km
                    Date: 2018.01.27
                    Time: 23:52:00
                    Voltage: 12.25 V
                    Reset counter: 202
                    Mileage: 151280 km
                    Date: 2018.01.28
                    Time: 01:38:00
                    Voltage: 12.15 V
                    Reset counter: 202
                    Mileage: 149648 km
                    Date: 2017.11.29
                    Time: 10:30:00
                    Voltage: 13.75 V
                    Fault Frequency: 106
                    Reset counter: 162
                    Mileage: 151280 km
                    Date: 2018.01.28
                    Time: 00:47:00
                    Voltage: 11.95 V
                    Reset counter: 202
                    Mileage: 151280 km
                    Date: 2018.01.28
                    Time: 01:15:00
                    Voltage: 11.80 V
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                    Reset counter: 202
                    Mileage: 151281 km
                    Date: 2018.01.30
                    Time: 19:41:00
                    Voltage: 9.70 V
                    Reset counter: 202
                    Mileage: 151280 km
                    Date: 2018.01.28
                    Time: 01:15:00
                    Voltage: 11.80 V
   Part No SW: 3C0 909 605 N    HW: 3C0 909 605 N
   Component: 17 AIRBAG VW8R  032 2522
   Revision: 13032000    Serial number: 003B2P7ZGJ7$
   Coding: 0012599
   VCID: 3147E7B4A80FD9CD0A-8064
   Subsystem 1 - Part No: 3C0 959 339 B
   Component: BF-Gewichtsens. 007 0003
   Subsystem 2 - Serial number: 0000000003LESJ
   Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332MSME19425E29Hÿ†63
   Subsystem 5 - Serial number: 25E29Hÿ†6342MSME13170139/ÿ†63
   Subsystem 6 - Serial number: 70139/ÿ†6351HTS6LNFST6K6Sÿ†63
   Subsystem 7 - Serial number: ST6K6Sÿ†6361HTS6LNF4L576Qÿ†63
   Subsystem 8 - Serial number: 4L576Qÿ†63727TS6LNFCA8C7Oÿ†63
   Subsystem 9 - Serial number: CA8C7Oÿ†63827TS6LNFCA5H6Qÿ
   Subsystem 10 - Serial number: CA5H6Qÿ
03032 - Supply Voltage for Seat Occupied Recognition Control Module
   Part No SW: 3C0 953 549 N    HW: 3C0 953 549 N
   Component: J0527               0015
   Revision: 00006000    Serial number: 3C5953507AK
   Coding: 0002013
   Shop #: WSC 25642 444 04951
   VCID: 3753D9AC466B07FD44-8062
            000 -  -
   Part No SW: 3C0 920 971 A    HW: 3C0 920 971 A
   Component: KOMBIINSTRUMENT VD1 1614
   Revision: V0007000    Serial number: 00000000000000
   Coding: 0007205
   VCID: 236B1DFCE2F37B5D88-8076
                    Fault Frequency: 30
                    Reset counter: 162
                    Mileage: 151281 km
                    Date: 2018.01.30
                    Time: 18:44:39
                    Reset counter: 202
                    Mileage: 151281 km
                    Date: 2018.01.30
                    Time: 19:39:12
                    Reset counter: 202
                    Mileage: 151281 km
                    Date: 2018.01.30
                    Time: 19:40:08
Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
   Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
   Component: Gateway         007 0040
   Revision: 00007000    Serial number: 0700C0750404F2
   Coding: 3FFD0E04D21002
   VCID: 216717F4F8EF694D9A-8074
9 Faults Found:
                    Reset counter: 144
                    Mileage: 150581 km
                    Date: 2017.12.20
                    Time: 17:35:28
                    Reset counter: 202
                    Mileage: 151280 km
                    Date: 2018.01.27
                    Time: 23:26:02
                    Reset counter: 202
                    Mileage: 151280 km
                    Date: 2018.01.27
                    Time: 23:52:34
                    Reset counter: 162
                    Mileage: 151280 km
                    Date: 2018.01.28
                    Time: 00:47:40
                    Reset counter: 202
                    Mileage: 151280 km
                    Date: 2018.01.28
                    Time: 01:38:06
                    Reset counter: 202
                    Mileage: 151280 km
                    Date: 2018.01.28
                    Time: 01:38:10
                    Reset counter: 202
                    Mileage: 151280 km
                    Date: 2018.01.28
                    Time: 01:38:10
                    Reset counter: 202
                    Mileage: 151280 km
                    Date: 2018.01.28
                    Time: 01:38:10
                    Reset counter: 162
                    Mileage: 151280 km
                    Date: 2018.01.28
                    Time: 23:35:27
   Part No SW: 3C0 919 965     HW: 3C0 919 965
   Component: Kompass         005 0003
   Revision: 00005000    Serial number: 1166279TRF6R06
   VCID: 6DFF3BC474B77D2D6E-8038
                    Fault Frequency: 26
                    Reset counter: 202
                    Mileage: 151280 km
                    Date: 2018.01.28
                    Time: 01:15:46
   Part No SW: 3C0 959 433 AK    HW: 3C0 959 433 AK
   Component:    IMMO         051 0383
   Revision: 00051000    Serial number: VWZCZ000000000
   Shop #: WSC 25642 444 12164
   VCID: 73CB2DBC1293ABDDB8-8026
02823 - Requirements for Locking the Steering Column Lock not met
            000 -  -  - Intermittent
                    Reset counter: 202
                    Mileage: 151281 km
                    Date: 2018.01.29
                    Time: 00:00:25
02828 - Enabling Steering Column Lock from Diagnostic Interface
                    Reset counter: 202
                    Mileage: 151280 km
                    Date: 2018.01.28
                    Time: 02:17:25
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Reset counter: 202
                    Mileage: 151281 km
                    Date: 2018.01.30
                    Time: 19:40:54
   Component: J386  TUER-SG FT    1131
   Revision: 32008001    Serial number: 00000063678424
   Coding: 0001205
   VCID: 3B5BC59C7A43239DA0-806E
                    Fault Status: 00100101
                    Reset counter: 202
                    Reset counter: 202
                    Mileage: 151280 km
                    Date: 2018.01.28
                    Time: 01:38:11
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.135 H07 1806
   VCID: 3449EEA0571DECE561-8060
            000 -  -
   Component:    KSG PQ46 RDK 051 0221
   Coding: 13910F8001862E521004141FF08A0F0E085800
                    Fault Frequency: 9
                    Reset counter: 162
                    Mileage: 151280 km
                    Date: 2018.01.28
                    Time: 00:47:41
                    Reset counter: 202
                    Mileage: 151281 km
                    Date: 2018.01.30
                    Time: 19:39:17
                    Reset counter: 202
                    Mileage: 151280 km
                    Date: 2018.01.28
                    Time: 01:38:07
                    Reset counter: 202
                    Mileage: 151280 km
                    Date: 2018.01.28
                    Time: 01:38:07
   Component: J387  TUER-SG BT    1131
   Revision: 32008001    Serial number: 00000597178502
   Coding: 0001204
   VCID: 3C59C6807F4D24A5A9-8068
                    Reset counter: 202
                    Mileage: 151280 km
                    Date: 2018.01.27
                    Time: 23:53:11
                    Fault Status: 01111000
                    Fault Frequency: 18
                    Reset counter: 162
                    Mileage: 151280 km
                    Date: 2018.01.28
                    Time: 22:02:30
00106 - Signal Central Locking SAVE/LOCK Passenger Side
                    Reset counter: 162
                    Mileage: 135588 km
                    Date: 2016.08.10
                    Time: 20:38:12
Address 53: Parking Brake
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 B    HW: 1K0 035 161 B
   Component: Radio DE2       014 0017
   Revision: 00014000    Serial number: VWZ4Z7G6236642
   Coding: 0040401
   Shop #: WSC 05314 000 00000
   VCID: 1E1D2C08C99156B5A7-804A
   Component: J388   TUER-SG HL   1118
   Revision: 12006001    Serial number: 00000001660661
   Coding: 0001168
   VCID: 3E5DCC88695136B587-806A
01813 - Supply Voltage for Door Controller; Rear Left (J388)
                    Reset counter: 202
                    Mileage: 147941 km
                    Date: 2017.10.25
                    Time: 19:39:34
   Coding: 0100101
00625 - Vehicle Speed Signal
                    Fault Frequency: 21
                    Reset counter: 202
                    Mileage: 151280 km
                    Date: 2018.01.28
                    Time: 22:39:32
   Component: J389   TUER-SG HR   1118
   Revision: 12006001    Serial number: 00000001528899
   Coding: 0001168
   VCID: 3FA3B18C6E5B3FBD8C-806A
01814 - Supply Voltage for Door Controller; Rear Right (J389)
                    Reset counter: 202
                    Mileage: 147941 km
                    Date: 2017.10.25
                    Time: 19:39:34
End-------------------------(Elapsed Time: 02:33)--------------------------
Have you carefully checked all fuses?
I would clear all fault codes (the slow way):
[Auto-Scan]
[Gateway Installation List]
After it pulls it up (just a second or three), un-check "Use CAN Command" and then:
[Clear all DTCs]
After it's done, cycle the ignition off, wait 60 seconds, turn it on again, and do another full scan to see what faults come back.
CrazyCajun
C?ID=238320
I’m on it, I will let you know thanks
Gone But Not Forgotten
As Uwe aforementioned on all &........
Battery voltage is poor...........correct it first because 0x25 immobilizer is unhappy!
Sort open circuit on N276 first using WD.
Verify wire and FP control module using WD as well.
Verify 0x08 not running interference for COM errors.
http://forums.ross-tech.com/showthread.php?3147-What-is-Jack-talking-about-0x01-08-000
JPPSG
http://forums.ross-tech.com/showthr...essional-Problem-Solver-Guide-quot-JPPSG-quot
RTFB at ERWIN + print to PDF to save money.
http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
CrazyCajun
C?ID=238320
It’s saying “Professional Grade interface required for this function”
CrazyCajun
C?ID=238320
That is when trying to clear dtc’s
CrazyCajun
C?ID=238320
As you mentioned Jack about the Battery voltage I had it checked at Autozone one day and they said it was fine, then a couple of days later I brought it back for a second opinion and they said it was bad and I had enough warranty to just get another one so the battery is new now. Uwe I have to ask, why would I get that response when trying to clear the DTC’s doing it the way you described and is their a work around I mean maybe with the new battery and clearing the dtc’s a lot of this could correct itself maybe?
Sorry, I didn't check what you had -- looks like a Micro-CAN...
I'm afraid you'll have to do it the old-fashioned way. Go to each module individually and clear fault codes.
CrazyCajun
C?ID=238320
thanks so much I will try anything at this point. I will report back with the results.
CrazyCajun
C?ID=238320
I tried to manually clear the codes get out of it wait a few minutes and tried again
Tuesday,13,February,2018,14:56:30:09859
               P1653 - 004 -
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 18:36:51
                    Temperature: 18.0°C
                    Temperature: 21.0°C
                    Voltage: 11.811 V
               U0128 - 008 -
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 18:36:52
                    Temperature: 18.0°C
                    Temperature: 21.0°C
                    Voltage: 11.684 V
               U0164 - 008 -
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 18:36:52
                    Temperature: 18.0°C
                    Temperature: 21.0°C
                    Voltage: 11.811 V
   Coding: 0000072
   Coding: 0013755
                    Reset counter: 161
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 18:41:49
                    Reset counter: 161
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 18:41:49
   Coding: 00046997
   Shop #: WSC 05311
                    Reset counter: 162
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 19:02:00
                    Voltage: 12.10 V
01259 - Fuel Pump Relay (J17)
                    Fault Status: 01101001
                    Reset counter: 162
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 18:37:00
                    Voltage: 11.65 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 162
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 19:02:00
                    Voltage: 12.10 V
                    Reset counter: 162
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 18:37:00
                    Voltage: 11.65 V
   Coding: 0012599
   Coding: 0002013
            000 -  -
   Coding: 0007205
                    Fault Frequency: 9
                    Reset counter: 162
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 17:57:19
                    Reset counter: 162
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 18:20:46
                    Reset counter: 162
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 18:20:46
   Coding: 0001205
CrazyCajun
C?ID=238320
               P1653 - 004 -
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 18:36:51
                    Temperature: 18.0°C
                    Temperature: 21.0°C
                    Voltage: 11.811 V
               U0128 - 008 -
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 18:36:52
                    Temperature: 18.0°C
                    Temperature: 21.0°C
                    Voltage: 11.684 V
               U0164 - 008 -
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 18:36:52
                    Temperature: 18.0°C
                    Temperature: 21.0°C
                    Voltage: 11.811 V
   Coding: 0000072
   Coding: 0013755
                    Reset counter: 161
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 18:41:49
                    Reset counter: 161
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 18:41:49
   Coding: 00046997
   Shop #: WSC 05311
                    Reset counter: 162
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 19:02:00
                    Voltage: 12.10 V
                    Reset counter: 162
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 18:37:00
                    Voltage: 11.65 V
                    Reset counter: 162
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 19:02:00
                    Voltage: 12.10 V
                    Reset counter: 162
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 18:37:00
                    Voltage: 11.65 V
   Coding: 0012599
   Coding: 0002013
            000 -  -
   Coding: 0007205
                    Fault Frequency: 9
                    Reset counter: 162
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 17:57:19
                    Reset counter: 162
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 18:20:46
                    Reset counter: 162
                    Mileage: 151281 km
                    Date: 2018.02.11
                    Time: 18:20:46
   Coding: 0001205
I'm still seeing numerous electrical faults and several modules that "Cannot be reached".
Have you checked all fuses? How about the relays? Particularly the fuel pump relay.. You're going to need a wiring diagram and a multimeter...
CrazyCajun
C?ID=238320
latest update- the car runs again and I can't thank you guys enough. that is the short version, if you care to read the long version its that we had a headlight go out and upon trying to change the bulb I noticed that the plastic coating on the wires inside the headlight housing were melted. I proceeded to remove the wiring harness making repairs to work long enough for the new set I ordered came in. When I finished the repair I forget which light wouldn't work right so I played with some of the fuses.(some of the fuses\and locations aren't right in the manual found another setup online) got the car working and had 2 lights on the dash and upon trying to troubleshoot those lights went back to playing with the fuses and the car wouldn't start. played around some more and got it to start but wouldn't go into gear then it wouldn't start then would start and would go into gear but the back brakes were locked then back to no start at which point I found this site and it was the guidance I needed to hang in there and figure it out THANKS AGAIN SO MUCH SO WORTH EVERY PENNY SPENT ON VAG COM
