Part No. 06J906262AA
Now just explain the SVM
16556/P0172 - System Too Rich, Bank 1
Possible Symptoms
Possible Causes
- Irregular behavior
Special Notes
- Fuel system
- Excessive fuel pressure
- Leaking or contaminated fuel injectors
- Leaking fuel pressure regulator
- Low fuel pressure or running out of fuel
- Vapor recovery system
- Air leaks after the MAF
- Vacuum leaks
- Improper seated engine oil dipstick
- Stuck EGR valve
- Oil overfill
- Cam timing
- Cylinder compression
- Exhaust leaks before or near HO2Ss.
Fuel Trim Info
Vehicle Identification No. | WVWZZZ1KZDW095264 |
Model | Golf GTI GOLF |
Date of production | 27.09.2012 |
Year | 2013 |
Sales type | 5K19V3 |
Engine Code | CCZB |
Transmission Code | PBH |
Special editions E0A Without special action equipment Lockable wheel bolts 1PE Wheel bolts with anti-theft protection
(unlockable) Vehicle class differentiation
units/platform components 0HA Vehicle class differentiation -1K0/5K0- tail pipe 0P1 Rear side exhaust tailpipe drive-off assistance UG4 Hill hold assist + comfort driving assist Emission standard 0GV Emission standard EU2
(critical vapor pressure) Trailer hitch 1D0 without trailer towing airbag 4UP Airbag for driver and front passenger
with knee airbag and front passenger
airbag deactivation Aktivkohlebehälter / Ottopartikelfilter 1E1 Activated carbon canister Aerials 8L6 "diversity" window antenna Exterior mirror setting 6XQ Exterior mirrors with memory feature,
power-folding/adjustable, separately
heated Follow-on warranty EA0 Without subsequent warranty Left exterior mirror 5SL Left exterior mirror, aspherical Right exterior mirror 5RQ Right exterior mirror: convex Drive type 1X0 Front-wheel drive "Multimedia"video/DVD/notebook connection 9WL Jack for external audio source Equipment levels A8H Top sports equipment Brake type in rear 1KT Disc brakes in rear (Geomet D) batteries J1L Battery 280 A (60 Ah) Brake type, front 1ZB Disc brake in front Components with special surface 6FF Exterior mirror housing and various attachments
colour coded to vehicle Battery/alternator capacity NY0 Standard battery/alternator capacity Component part sets with
country-specific design requirements B2L Component parts set, complying with
vehicle type for Ecuador, various parts vehicle tools and jack 1S1 vehicle tools and jack Brake systems 1AT Electronic stability control (ESC) Owner's manuals 0VD Information kit in Spanish Operating voltage 9Z0 Operating voltage 12 V brake wear indicator 9U0 Without brake pad wear indicator Heated washer nozzles 9T0 Without heated washer nozzles CD ROM/DVD/SD card 7QA Without CD/DVD for navigation CD changer/CD player 7A0 Without CD changer/CD player "Charism" 2H0 Without "drive select" Chrome package QJ3 Chrome package (version 2) General operating permit, alterations C44 Operating permit, alteration Roof insert/convertible top 3FE Tilting and sliding glass sunroof with
sunbshade Suspension system in rear 1JH Rear shock absorption Suspension system in front G11 Shock absorption in front Load-through hatch/ski bag 3X0 without load through system Insert for the filling up of unleaded
fuel/fuel type 2G7 Filler neck module 1 with insert Installation differentiation for components 0ES Installation differentiation for
transmission DQ250
-- vehicle components -- Theft protection system 7AS Anti-theft alarm system, interior
monitoring, backup horn and towing
protection Inserts 5MD Decorative aluminum inserts Scuff plates 7M5 Without impact protection film for door sill Park distance control 7X2 Park distance control in front and rear Electric interface for external use UF0 Without electric interface Manufacturing sequence differentiation 0FA Standard manufacturing sequence window regulator 4R4 Power windows with comfort operation and
circuit breaker fire extinguisher 6A0 without fire extinguisher Pedestrian protection VL1 Extended pedestrian protection measures Pedal cluster VF1 pedal cluster Headlight activation 8K3 Daytime headlights with automatic headlight control
and coming home function Vehicle specifications F0A No special purpose vehicle, standard
equipment Alternators 8GU Alternator 140 A Weight category rear axle 0YC Weight range 3
installation control only, no
requirement forecast Weight category front axle L35 Suspension range 35
requirement forecast Base engine TD6 4-cyl. petrol engine 2.0 l assembly 06J.D Luggage netting/pocket on backrest(s) 4U5 Luggage pockets on backrest Luggage compartment cover 3U4 Luggage compartment cover cruise control system 8T0 Without cruise control system (CCS) Luggage compartment trim 5A7 Comfort luggage compartment trim with
service lid/snap-on cover Transmission specifications G1A 6-speed automatic transmission handle for hand brake lever 6PC handbrake lever grip (leather) Rear spoiler 5J4 Body-colored rear spoiler Rear window wiper and washer system 8M1 Rear window wiper washer system with
intermittent wipe Molded headliner 6NW Unsplit molding roof liner Rear seats 3NU Rear bench seat, not split, split backrest, folding
centre armrest Heating and air-conditioning system 9AK Climatronic with impact pressure
control, CFC-free Headlamps 8BI Twin headlight for driving on the right
(gas discharge) w/ integrated high beam Customized installation FC0 Without individual installation Interior light in footwell 6T1 Interior light in footwell Instrument clusters U5A Instrument insert, km/h speedometer Breakaway interior rearview mirror 4L6 Breakaway interior rearview mirror,
auto-dimming Sticker (customized or special edition) 0KA Without decals and emblems Body style K8G Hatchback coolbox 1W2 Glove compartment cooling system Climatic zones 0Y7 Tropical zones and high-water country Compass/road sign display QR0 Without compass/road sign display/
dynamic road sign display headrest for seat, rear 3Q6 Three rear head restraints Head restraints 5ZF Front head restraints Fuel tank treatment 2LD Fuel tank without differentiation of
special material treatment
(fluorination/co-extrusion) Fuel quantity for initial filling 1Z2 Increase in initial standard fuel
filling Fuel systems 1A5 Fuel system for SI engine Body measures 5C0 Without special body measures Radiator grille 6KA Radiator grille License plate lighting KL1 LED license plate lighting Rear license plate bracket 6P1 Rear license plate carrier (ECE) Front license plate bracket 6W1 Front license plate carrier (large) Paint preservative/transit coating 5K7 Transport protection film (minimum
protection) with additional transport
protection measures Paint coating FB0 standard paint coating Steering system arrangement L0L Left-hand drive Reading lamp 8S4 Two reading lights front, two rear steering 1N3 Speed-related variable steering assist
(Servotronic) Backrest release 3H9 Backrest release for front seats with
Easy Entry feature Air duct, front area VK1 Air duct, type 1 Light control systems 8G0 Without Light Assist Lumbar support 7P1 Power adjustable lumbar support in front
seats steering wheels 2FU Leather-wrapped multi-function sports
steering wheel with tiptronic Speaker installation 8RM 8 speakers (passive) Headlight range control 8Q5 Dynamic headlight range control,
with cornering light (AFS 1) Center armrest 6E3 Front center armrest Marten repeller UM0 Without marten repeller Multi-function display/trip computer 9Q5 Multi-function display with control Engine cooling 8Z4 moderately hot country Engine specifications D2D 4-cylinder SI engine 2.0 l/155 kW 16V
turbo FSI, homogeneous; base engine is
TM2/TV2/TG6/TJ6/TD6/TP6/TL5/TL6/TI6 Left vanity mirror 4SD Vanity mirror, left, illuminated Right vanity mirror 4TD Vanity mirror, right, illuminated Navigation device 7Q0 without navigation system rear fog lamp 8TC Rear fog light for driving on the right Front fog lamp/additional headlamp 8WD Integrated front fog light Upgrading measures GP1 Vehicles with special upgrade measures Rear of platform module base 4P0 Rear floor panel module, type 1 Platform group class 7PA Platform group class 1 Hubcaps 1NL Trims for alloy wheels Wheels CG6 Alloy wheels 7.5J x 17 Radios 8DD Radio "RCD510 World Variant" Smoker's/non-smoker's package 9JB Smoker's package, ashtrays in front and
rear Tire pressure monitoring system 7K0 Without tyre pressure monitor tire H6L Tires 225/45 R17 91W Tire suppliers V0A Tires without specification of tire
brand Spare wheel/breakdown kit 1G9 Space-saving spare wheel for temporary
use, radial tire
(5-hole) Restraint systems, front 3QT 3-point seat belts in front, with
tensioner and height adjustment PAA Tray areas package PH2 Air conditioning system Climatronic PLB Mirror package PS5 Electric tilt/slide glass sunroof PXG Xenon headlamps with bending light and
LED separate daytime running lights RK5 "RCD 510" mercados especiales con antena
Diversity para luna WD6 Anti-theft alarm system "Plus" WDA Park distance control WL2 Leather trim "Vienna" with top sports
seats in front Side airbag 4X3 Side airbag in front, with curtain
airbag Gearshift knob/handle 6Q6 Gearshift knob/handle in aluminum Special labels/plates 2KY Labels in Italian, Spanish and
Portuguese Tail lamp assemblies 8SD Taillight assembly w/ red colored lens Locking mechanism for boot lid/cover
rear 4E0 Tailgate/trunk lid unlocking
from outside Service indicator QI4 Service indicator 15 000 km or 1 year
( fix ) Front seat, left 3TU Sports seat, front left Front seat, right 3SU Sports seat in front, right Nameplates for sales name QD0 Without lettering for sales name Seat belt check 9P3 Seat belt reminder, electric contact in
buckle Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE
label Center rear seat belts 3C7 3-point seat belt for center rear seat seat covers N7F Seat trim covers in part-leather,
embossed leather Seat adjustment 3L3 Manual height adjustment for front seats seat heater 4A3 seat heating for front seats separat controlable Safety head restraint system 3K0 w/o safety head restraint system Side lights 7R3 Side turn signal lights (white) Start-stop system/regenerative braking 7L3 Without start/stop system without
regenerative braking Horns 8Y1 Two-tone horn Control number (no PR family) S1X Special built-in parts (w/o police) in
After-Sales Serv. Worksh. contr. distr.
type 02, with separate AS invoice Side and rear windows 4KC Side and rear windows in heat-insulating
glass power outlet 7B2 12 volt socket in luggage compartment Bumper 2JG bumper in color of vehicle Rear stabilizer 0BF Rear stabilizer Front stabilizer bar 0AE Front stabilizer bar Drawers under front seats QN3 Drawers under front seats Heavy-duty/sports version 2UC Sports version Headlamp washer system 8X1 Headlamp washer system Windshield wiper intermittent control/
light/rain sensor 8N3 intermittent windscreen wiper with rain sensor Special approval measures 3M0 Without special measures Nameplate set 0NH Nameplate set "GTI" Mass damper for steering wheels 1Q1 Mass damper for steering wheel, 26.5Hz Door and lid locking system 4K3 Central locking w/ radio remote control,
interior controls and SAFELOCK Type approval countries/countries with
special requirements BG9 Special requirements for Guatemala Carrier frequency for remote control 5D1 Carrier frequency 433.92 to 434.42 Mhz Partition 3CA without partition Door and side trim panels 3LJ Door and side trim panel in foam film,
insert in leatherette doors 0A1 2 doors TV reception/digital radio reception QV0 without TV/digital radio reception Front underbody guard 1SB Additional front underbody guard Identification plates 1EY Special identification label
with weight data, but without general
operating permit (ROW) Delivery equipment 2A8 Delivery equipment, water border First aid kit / warning triangle 1T2 warning triangle Two-way radio installation preparation 9D0 without prepared for two way radio system Telephone / telematics 9W7 Mobile phone interface (NAR) Additional warning lights 9TC Additional retro-reflectors (door area) LongLife Service Regime QG2 LongLife Service Regime cannot be
activated Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating Windshield Glass 4GF Windshield in heat-insulating glass Washer fluid level indicator 8W1 Washer fluid level indicator Additional tires (snow tires) 2WA without spare tyre floor mats 0TD Front and rear floor mats Additional body panels,
side 6EA Without additional side body covers
(stone guard) Additional child seat anchors 3B4 Child seat anchors for
child seat system ISOFIX Auxiliary heating system 9M0 Without auxiliary heater/parking heater
Monday,19,November,2018,15:09:25:22246
VIN: WVWZZZ1KZDW095264 License Plate:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 4C 52 55 56 77
VIN: WVWZZZ1KZDW095264 Mileage: 73630km-45751miles
2E-Media Player 3 -- Status: Not registered 0001
Address 01: Engine (CCZ) Labels:. 06J-907-115-CCZ.clb
Part No SW: 5K0 907 115 A HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0040
Revision: AAH18--- Serial number:
Coding: 040300101C070060
Shop #: WSC 00642 210 45725
VCID: 2809FB468EF67527F65-807C
001056 - Catalyst System; Bank 1
P0420 - 000 - Efficiency Below Threshold
Mileage: 73611 km
Date: 2013.04.10
Time: 16:46:55
RPM: 1989 /min
Load: 11.8 %
Temperature: 104.0°C
Temperature: 69.0°C
Absolute Pres.: 840.0 mbar
Voltage: 13.462 V
000370 - Fuel Trim; Bank 1
P0172 - 000 - System Too Rich
Mileage: 73627 km
Date: 2013.04.11
Time: 14:39:44
RPM: 2973 /min
Load: 16.5 %
Speed: 39.0 km/h
Temperature: 96.0°C
Temperature: 28.0°C
Absolute Pres.: 850.0 mbar
Voltage: 14.097 V
Readiness: 0000 0001
Part No SW: 02E 300 058 P HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3514
Revision: 05551213 Serial number: 00001208151501
VCID: 270BF87A83E87A5FFFF-8072
Revision: 00H31001
Coding: 143B600D092B80FF280D06EA901D0141350D50
VCID: 7DA7FA123DF4008FF53-8028
Part No SW: 5K0 907 044 GK HW: 5K0 907 044 GK
Component: Climatronic H19 1313
Revision: 00001004
Coding: 0010004002
VCID: 7AADF10E2C5A37B7D01-802E
Address 09: Cent. Elect.
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 10: Park/Steer Assist (J791) Labels:| 3AA-919-475.clb
Part No SW: 3AA 919 475 L HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0025
Revision: -------- Serial number: 56231203401265
Coding: 348103
ASAM Dataset: EV_EPHVA2C000000000 002008
ROD: EV_EPHVA2C000000000.rod
VCID: 44D14FF61E1EB147FAD-8010
12658720 - Databus
[Steuergerät für elektrische Park-/Handbremse-J540 - mEPB_1 - kein Signal/keine Kommunikation]
Reset counter: 193
Mileage: 73423 km
Date: 2018.11.16
Time: 10:24:24
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 013 0613
Serial number: 003G5RANTBE9
Coding: 00003957
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 313F1622B1AC34EF21B-8064
Serial number: 3572MSME1D5A5274ZZZ/
Serial number: 3582MSME37616074ZZZS
Serial number: 3512QSME74221B13ZZZM
Serial number: 3522QSME66471730ZZZQ
Part No SW: 5K0 953 507 AF HW: 5K0 953 549 A
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440LIF000HS
Coding: 189A040000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 74B1DF360E3E41C78AD-8020
Subsystem 1 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H30 0032
Serial number: 0068085
Coding: 830000
Part No SW: 5K6 920 873 HW: 5K6 920 873
Component: KOMBI H05 0705
Coding: 170E01
VCID: 73B3DC2A0B3046FF937-8026
Part No SW: 7N0 907 530 AB HW: 7N0 907 530 AB
Component: J533 Gateway H47 1633
Revision: H47 Serial number: 030912F1001490
Coding: 350000
Shop #: WSC 12345 528 03869
VCID: 70B9D3267AA67DE76E5-8024
Fault Frequency: 78
Mileage: 73423 km
Date: 2013.04.08
Time: 10:24:24
Component: IMMO H05 0705
VCID: 6A8DC14E5CFA8737201-803E
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7660899436
VCID: 290FFE4299FC4C2FE9B-807C
Part No SW: 5K0 959 701 C HW: 5K0 959 701 C
Component: Tuer-SG 009 2117
Coding: 0004150
VCID: 323D192EB82A0FF7581-8066
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 74 3305
Revision: 00H22000
VCID: 372B283A5348EADF6FF-8062
Address 46: Central Conv.
Part No SW: 5K0 959 702 J HW: 5K0 959 702 J
Component: Tuer-SG 009 2103
Coding: 0004406
VCID: 3A2D310E605AF7B7901-806E
Component: AFS-Steuergeraet 0148
Coding: 1442908
VCID: 34311F36423E01C74AD-8060
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 B HW: 5K0 035 190 B
Component: Radio RCD510 005 0236
Revision: 00000001 Serial number: VWZ1Z3M7282520
Coding: 05000410040005
VCID: 2411EF76FEDE9147DAD-8070
03138 - Input AUX IN
Fault Status: 01101011
Reset counter: 193
Mileage: 73423 km
Date: 2013.04.08
Time: 10:24:40
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663415370
Coding: 0A00000000010100
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A2D310E6CDAF7B7901-806E
End----------(Elapsed Time: 00:56, VBatt start/end: 13.6V/13.6V)-----------
My Money is on bad N80 and contaminated charcoal canister as failed evap process or HPFP dumping fuel in the oil........
Is oil PSI too high or too low causing a valve timing or lash issue?
Maybe a fake lean response due to lift pump being faulty or pre lift pump/regulation & maybe a volume issue such as filter restriction or pickup screen in tank but that oil has to be going someplace!
Plugs being white and clean says lean............
2 liters in 5k........?
UNACCEPTABLE!
VAG logical ? LOL either operating system is indeed the inverse in the televerse, no?
Email me the mod and alleged stock read please, eeprom and flash.
Please default and recode controller with new WSC.
PM me your valid email address.
* removed and checked HPFP for any symptom
UNACCEPTABLE!
Are you positively sure............?
https://forums.ross-tech.com/showth...ssion-figures!&p=147564&viewfull=1#post147564
We removed it to check physically and all looks good, if we had fuel with the oil the fuel level would "raise" or be higher not the engine consuming oil and beeping that it needs more. Will ask the guys if they checked the spring but double checking doesn't harm anybody.
Okay Jack, always learning here and would like some input. As I state I own 2 VW, but don't work on them for a living. I do however take about 40 hours a year of ongoing tech training along with ATE seminars, and not does not me an expert, but seeing a trend here. What if does do, is make me aware of just what I don't know, hurts sometimes. These are part of my ongoing training as a company maintenance mechanic but mostly on diesel, but some gas operated sales rigs.
Just finished 6 hours on Chev ECO Tech motors, and seems this is quite common whether Subaru, VW, all of them seem to when striving for fuel mileage to meet all the CARB requirements are using oil. Chevy ECO TECH say 1.5 liters of oil per 2000KM normal. The sad part here is the system only holds 4.6 quarts, OKAY, liter very close to a Quart for argument sake. But They state change oil at 7500 miles, and if your using 1.5 qts (near a Litre) per 2000, you are technically out of oil long before an oil change. If you are not Johnny at the rat hole which most owners aren't this car just melted down.
Okay back to the subject, seeing complaints on all models mostly newer than 14, but oil consumption of what is seen here does not seem to be out of the normal, and from what I have been told a lot of it has to do with lighter ring pressures trying to remove resistance. OKAY, not sure of everything I'm taught, but all of it is trying to be proactive, but just seeing oil consumption as a normal trend, exacerbated by turbos, PCV systems, HPP, all creating a night mare, JMO.
By the way, like this site, and would not own a VW without it.
Larimore
