Hello, new guy here. Lots of info, did some searching but looking for some assistance to a no response from the controller issue I receive while trying to access some menus. Specifically, the hidden menu.
Some details:
Battery fully charged but I do have some draw when car is off.
2009 Audi A4 quattro 2.0T
MMI version 0211
Hex-V2 cable
Surface 3 using Windows 10
Was wondering if my MMI software version was too old?
Here's my latest auto scan. If anyone has some input to any of the fault codes you see (besides intake manifold lol) don't hesitate to give advice. Thank you
Some details:
MMI version 0211
Hex-V2 cable
Thursday,13,September,2018,11:49:42:29144
VCDS Version: 18.2.1.5 (x64) HEX-V2 CB: 0.4411.4
VIN: WAUSF78K79N028560 License Plate:
Mileage: 150050km-93236mi Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 42 46 47 52 53 55 56 62
65 72 77
VIN: WAUSF78K79N028560 Mileage: 150050km-93236miles
Address 01: Engine (-----CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 D HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H14 0002
Revision: E1H14---
Coding: 0104010A190F0160
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_ECM20TFS8K2907115D A01002
ROD: EV_ECM20TFS8K2907115D.rod
VCID: 303913AA2AA44E07C14-8064
14 Faults Found:
4629 - ECM Power Relay Load Circuit
P068A 00 [032] - Opens Too Early
Fault Frequency: 14
Coolant temperature: 27 °C
Intake air temperature: 27 °C
Voltage terminal 30: 8.787 V
2975 - Intake Manifold Flap; Bank 1
P2004 00 [104] - Stuck Open
Fault Frequency: 29
Mileage: 148239 km
Date: 2015.07.30
Time: 12:06:26
Engine speed: 873.50 /min
Normed load value: 30.6 %
Vehicle speed: 5 km/h
Coolant temperature: 72 °C
Intake air temperature: 49 °C
Voltage terminal 30: 12.298 V
2977 - Intake Manifold Flap; Bank 1
P2004 00 [096] - Stuck Open
2968 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 00 [096] - Implausible Signal
2970 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 00 [237] - Implausible Signal
Mileage: 149568 km
Date: 2015.10.11
Time: 20:21:53
Engine speed: 3746.00 /min
Normed load value: 63.1 %
Vehicle speed: 55 km/h
Coolant temperature: 90 °C
Intake air temperature: 43 °C
Ambient air pressure: 960 mbar
Voltage terminal 30: 12.816 V
5671 - Boost Pressure Regulation
P0299 00 [096] - Control Range Not Reached
4054 - Cylinder 1
P0301 00 [096] - Misfire Detected
Mileage: 150036 km
Date: 2016.08.12
Time: 09:28:33
Engine speed: 755.00 /min
Normed load value: 16.9 %
Coolant temperature: 52 °C
Voltage terminal 30: 13.028 V
Unlearning counter according OBD: 29
4060 - Cylinder 3
P0303 00 [096] - Misfire Detected
Mileage: 150036 km
Date: 2016.06.29
Time: 14:21:38
Engine speed: 710.00 /min
Normed load value: 17.3 %
Intake air temperature: 28 °C
Voltage terminal 30: 12.604 V
Unlearning counter according OBD: 28
4063 - Cylinder 4
P0304 00 [096] - Misfire Detected
Mileage: 150036 km
Date: 2016.06.29
Time: 14:21:38
4057 - Cylinder 2
P0302 00 [096] - Misfire Detected
Mileage: 150038 km
Date: 2008.12.02
Time: 22:41:44
Engine speed: 753.00 /min
Coolant temperature: 60 °C
Intake air temperature: 30 °C
Voltage terminal 30: 13.075 V
Unlearning counter according OBD: 32
4051 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
7781 - Engine Off Timer Performance
P150A 00 [096] - -
Mileage: 150050 km
Date: 2008.05.27
Time: 00:10:07
Coolant temperature: 55 °C
Intake air temperature: 24 °C
Voltage terminal 30: 11.779 V
4201 - Fuel Level too Low
P1250 00 [101] - -
Mileage: 150050 km
Date: 2008.05.30
Time: 03:05:52
Engine speed: 1277.00 /min
Normed load value: 28.2 %
Coolant temperature: 25 °C
Intake air temperature: 23 °C
Voltage terminal 30: 12.510 V
4261 - System Voltage
P0562 00 [096] - Too Low
Fault Frequency: 6
Mileage: 150050 km
Date: 2008.06.02
Time: 23:23:31
Voltage terminal 30: 7.491 V
Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
Part No SW: 8K0 927 158 C HW: 0B6 927 156
Component: 0B6 20TFSIUSA H04 0030
Revision: --H04---
Coding: 001002
ASAM Dataset: EV_TCMAL651 A01004
ROD: EV_TCMAL651.rod
VCID: 363525B2C8C060379B8-8062
Part No SW: 8K0 907 379 AB HW: 8K0 907 379 AB
Component: ESP8 quattro H04 0060
Coding: 150500
Shop #: WSC 02399 823 56573
VCID: 79AFEE8EB9DE4F4F36A-802C
Part No SW: 8K0 907 064 F HW: 8K0 907 064 F
Component: BCM2 1.1 H80 0141
Coding: 090100
VCID: 33331CA6DB32751FBC6-8066
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0508000050612013
Component: ELVAUDIB8 H36 0041
Serial number: 0208000047789006
00956 - Key 2
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 141
Mileage: 150050 km
Date: 2008.05.27
Time: 00:32:34
00955 - Key 1
Reset counter: 182
Mileage: 150050 km
Date: 2008.05.27
Time: 01:22:24
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC
Component: KLIMA 3 ZONEN H06 0140
Revision: C1000000 Serial number: 0103.09.081347
Coding: 64002000
VCID: 72BDD9A2E4A83C17770-8026
Reset counter: 181
Mileage: 150050 km
Date: 2008.06.02
Time: 23:22:21
008 - Implausible Signal
Fault Status: 01101000
Fault Frequency: 10
Reset counter: 142
Mileage: 150036 km
Date: 2008.05.27
Time: 01:19:25
Reset counter: 170
Mileage: 150036 km
Date: 2008.05.27
Time: 00:20:30
Reset counter: 172
Mileage: 150036 km
Date: 2008.05.27
Time: 00:23:37
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000226508
Coding: 26001011063CAF010000080300003D0D0F1C520800010161000000
Shop #: WSC 60173 123 10485
VCID: 303913AA2A244E07C14-8064
Component: WWS 120908 H06 0070
Serial number: SWF08090125666
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10244318
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Serial number: 00000000001609080843
Subsystem 4 - Part No SW: 8K0 907 410 A HW: 8K0 907 410 A
Component: UGDO HL US H04 0060
Part No SW: 8K0 959 655 F HW: 8K0 959 655 F
Serial number: 0039KD14648P
VCID: 40D9436A9A04DE87314-8014
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R0800001FLF
Serial number: 6334MSME41344A7BH
Serial number: 6344MSME3F762660J
Serial number: 6352QSME100E2F2EP
Serial number: 6362QSME100D171CD
Serial number: 63732SME480A1322T
Serial number: 63832SME240A222CY
13697280 - Component Protection
U1101 00 [008] - Active
Fault Frequency: 11
Mileage: 150036 km
Date: 2016.08.12
Time: 17:42:48
13635840 - Supply voltage
[Powersupply lower threshold fall short of]
Reset counter: 181
Mileage: 150036 km
Date: 2016.08.12
Time: 18:00:36
9483264 - Seat Occupied Recognition
B10B4 00 [008] - Function Restriction due to Undervoltage
[Bladder Mat: functional restriction because of low voltage]
Reset counter: 181
Mileage: 150036 km
Date: 2016.07.08
Time: 06:38:14
Component: Lenks.Modul H13 0013
Revision: -------- Serial number: 90315HIA000EI
Coding: 000036
VCID: 3D273A9EED76B36F5A2-8068
Part No SW: 8K0 920 950 A HW: 8K0 920 950 A
Component: KOMBIINSTR. H17 0224
Revision: 00000000 Serial number: 9DR39EA98
Coding: 8B1F09000300D705020000
VCID: 2D070ADE3D1623EFEA2-8078
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0094
Revision: 4GB20042 Serial number: 4200G088318141
Coding: 000303
VCID: 46D55572B8A0F0B70B8-8012
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 18041AE6270808
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8T0 035 785 HW: 8T0 035 785
Revision: 00000000
Coding: 020302
VCID: 78A9EB8A82D45647494-802C
Part No SW: 8K0 959 760 HW: 8K0 959 760
Component: MEM-FS H05 0043
Revision: AA000000 Serial number: 00001001149775
Coding: 00581300000000000000
VCID: 77ABE8B68FCA593F40E-8022
Reset counter: 172
00532 - Supply Voltage B+
Fault Frequency: 25
Reset counter: 181
Mileage: 150036 km
Date: 2008.05.27
Time: 01:19:28
Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000007645919
Coding: 011C03204E00410001
VCID: 41DF466E918ED78F3EA-8014
Revision: 00002001 Serial number: 0114316859
Coding: 0106063A007A440400B001
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0040
Serial number: 00000000000000072208
Subsystem 3 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J245 PS034 H06 0037
02616 - Fuel Tank Cap; Unlock
Fault Status: 00101001
Reset counter: 182
Mileage: 150050 km
Date: 2008.05.27
Time: 00:56:45
02615 - Fuel Tank Cap; Lock
Reset counter: 182
Mileage: 150050 km
Date: 2008.05.27
Time: 00:57:58
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AB HW: 8T0 035 223
Component: DSP STD H07 0220
Revision: S2100000
Coding: 0203010102
VCID: 6E85CDD2F09018F7938-803A
Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000007650507
VCID: 40D9436A9A84DE87314-8014
Reset counter: 142
Mileage: 150050 km
Date: 2008.05.27
Time: 00:32:23
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000215968
VCID: 313F16AE212E470FCEA-8064
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Coding: 0000004
VCID: 34311FBAD23C7227A5C-8060
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 195 L HW: 8T1 035 195 L
Component: Symph3 Sirius H02 0211
Revision: 00000004 Serial number: AUZ5Z4H1046196
Coding: 040200020101850043D9070800
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
Reset counter: 141
Mileage: 150050 km
Date: 2008.05.27
Time: 00:21:36
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 N HW: 8K0 959 795 C
Component: TSG HL H10 0251
Revision: Serial number: 0000100269263
Coding: 010C03204000210001
VCID: 44D14F7A8E9CC2A715C-8010
Reset counter: 142
Mileage: 150050 km
Date: 2008.05.27
Time: 00:32:24
Address 65: Tire Pressure (J502) Labels:. 8K0-907-273.clb
Part No SW: 8K0 907 273 A HW: 8K0 907 273 A
Component: J502-RDK H03 0250
Revision: 00001001 Serial number: 13140781776533
Coding: 0CD154
Fault Frequency: 8
Reset counter: 181
Mileage: 150050 km
Date: 2008.06.02
Time: 23:24:27
Bin. Bits: 00001000 10101001
Voltage: 8.20 V
Text: 28,0°C;n.erkannt; n.erkannt
02214 - Tire Pressure Warning
Fault Frequency: 8
Reset counter: 181
Mileage: 150050 km
Date: 2008.06.01
Time: 18:31:10
Bin. Bits: 00001000 00100101
Voltage: 13.30 V
Text: 24,5°C; -0,43bar;3441736486;A0h; 30°C
Reset counter: 170
Mileage: 149972 km
Date: 2016.01.29
Time: 13:12:15
Bin. Bits: 00001000 10100011
Voltage: 14.00 V
Text: 25,0°C;n.erkannt; n.erkannt
Reset counter: 172
Mileage: 150036 km
Date: 2016.07.08
Time: 06:37:34
Bin. Bits: 00001000 00000000
Voltage: 11.10 V
Text: 27,0°C;n.erkannt;3441736486;--h;---°C
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000100269260
Part No SW: 8T0 862 336 C HW: 8T0 862 336 C
Component: FSE_256x BT H33 0550
Revision: 00000000 Serial number: 00000005019121
Coding: 0010370
VCID: 3B233486FF62BD5F646-806E
Fault Status: 00100001
Reset counter: 172
Mileage: 150036 km
Date: 2008.05.27
Time: 00:23:15
Reset counter: 181
Mileage: 150036 km
Date: 2016.08.12
Time: 17:44:10
Reset counter: 170
Mileage: 150036 km
End----------(Elapsed Time: 01:58, VBatt start/end: 12.2V/12.2V)-----------
