Seat cruise control issue
Marty.h
Norwich, UK
C?ID=382098
I have got the job of sorting a mess up the person has fitted a new Squib and has binned the original so no coding available from original ive managed to get steering buttons ect all working but the cruise I cant I can see the switch working in measuring blocks and all faults now clear on 16: steering wheel that was present however there is a fault in 01: engine I cant seem to get my head round it experimental coding all in German which does not help either.
if someone could have a look at the coding would appreciate it or offer some advice
regards
Marty
Thursday,26,March,2020,11:45:23:16673
VIN: VSSZZZ1PZBR059418   License Plate: SEAT
Mileage: 168460km-104676mi   Repair Order:
Chassis Type: 1P-SE35 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72
VIN: VSSZZZ1PZBR059418   Mileage: 168460km-104676miles
Address 01: Engine (BK2-CAXC)       Labels:. 03C-906-016-CAX2.clb
   Part No SW: 03C 906 016 AP    HW: 03C 906 016 AP
   Component: 1.4l R4/4V TS H12 8179
   Revision: LCH12---    Serial number:
   Coding: 00190012002400000000
   Shop #: WSC 06402 785 00200
   ASAM Dataset: EV_ECM14TFS01103C906016AP 001006
   ROD: EV_ECM14TFS01103C906016AP.rod
   VCID: 6D87CEB6AD15EC7F123-8038
4714 - Steering Column Control Module
          U0212 00 [039] - No Communications
                    Mileage: 168462 km
                    Date: 2020.03.26
                    Time: 11:41:21
                    Coolant temperature: 94 °C
                    Intake air temperature: 57 °C
                    Voltage terminal 30: 12.415 V
                    CAN status - engine control module-Bits 0-7: 00000000
                    Generator power: 0 W
                    CAN TimeOut meter - gateway-Bits 0-7: 00000000
Readiness: 1110 0101
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Revision: 00H31001
   Coding: 133B401209270003C80F02E590210080350800
   Shop #: WSC 04941 000 00000
   VCID: 76B5E1DAD8C32FA7E39-8022
   Part No SW: 5P0 907 044 P    HW: 5P0 907 044 P
   Component: Climatronic   H15 0702
   Revision: 00001001
   Coding: 0000000002
   ROD: EV_ClimaAutoBasis_SE35.rod
   VCID: 3D273EF6BDF5BCFFE23-8068
Address 09: Cent. Elect.
Unable to communicate with address 09. Are you sure the doors are unlocked?
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__A0E VW10 HI   1918
   Revision: 22014000    Serial number: 003K0P3018EV
   Coding: 0012357
   VCID: 4CC16332FACF057765D-8018
   Subsystem 1 - Serial number: 6332MTS644130321
   Subsystem 2 - Serial number: 6342MTS648160321
   Subsystem 3 - Serial number: 6351HTS6UBQCP9KJ
   Subsystem 4 - Serial number: 6361HTS6HI7DP9KJ
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20191016200241
   Coding: 1002100008
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 025D8D0A848B0307DF1-8056
   Subsystem 1 - Part No SW: 1P0 959 538 C    HW: 1P0 959 538 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP  H02 0102
   Serial number: 00000000000000239363
   Coding: E20000
   Part No SW: 1P0 920 910 M    HW: 1P0 920 910 M
   Component: KOMBI         H06 0404
   Coding: 410B00
   VCID: 333318CE8BB17A8F047-8066
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 260211F2000399
   Coding: 350203
   VCID: 303917C27A274197795-8064
   Component: IMMO          H06 0404
   VCID: 6A8DC5AA9CFBFB47771-803E
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Component: SG EXT.PLAYER H13 0150
   Revision: A1001003    Serial number: 7669489500
   VCID: 2809FFA242F70957A15-807C
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0508
   Revision: 12110009    Serial number: 0001823611
   Coding: 0012B0
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 704 AF    HW: 1K0 959 794 S
   Component: J389__TSG-HR  006 1401
   Serial number: 00000005596206
   Coding: 000290
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 142    3201
   Revision: 00H20000
   VCID: 34311BD2823F7DB71DD-8060
Address 46: Central Conv.
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0508
   Revision: 14110009    Serial number: 0001821946
   Coding: 0012B0
   VCID: 6E85C9BAA01317672B9-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 703 AF    HW: 1K0 959 795 S
   Component: J388__TSG-HL  006 1401
   Serial number: 00000005583882
   Coding: 000290
   Part No SW: 5P0 035 186     HW: 5P0 035 186
   Component: Media2.0      H01 0007
   Revision: 00000001    Serial number: SEZ1Z3L0207617
   Coding: 0106040004
   VCID: 6C81C3B2968FE57705D-8038
End----------(Elapsed Time: 00:57, VBatt start/end: 12.5V/12.5V)-----------
Mari
C?ID=150535
Sorry for my ignorance... but what is a "Squib"?
HMC
C?ID=28246
Hi Mari,
For some reason many people miss-name the clock spring or module that carries the connection to the steering wheel airbag a "squib". It derives from an English name for a firework or small explosive, you may have heard the saying "went off like a damp squib" meaning something did not work correctly. So the squib is really the explosive charges (pyro techniques) in the air bags and belt tensioners.
Regards HMC
langers2k
C?ID=224085
Similar cars online have an older controller installed:
Part No SW: 5K0 953 521 BN HW: 5K0 953 569 E
Component: LENKS.MODUL 009 0136
Revision: FF010039 Serial number: 20110103100351
Coding: 1082140002
VCID: 79F3CA8BF8F45287E0-802C
Coding: E20000
Assuming the new part is compatible with the above, it might be worth trying 1082140002 for the coding?
Marty.h
Norwich, UK
C?ID=382098
Hi Mari,
Regards HMC
It's what we have always called it in the trade squib/clockspring
Marty.h
Norwich, UK
C?ID=382098
Coding: 1082140002
Coding: E20000
Thanks I will give that a try would of been a lot easier if I could of done a scan of the original before it was removed and binned 🙈
Dana
Western PA, USA
I agree with the 1082140002 suggestion. We had one 1P-SE35 (7N0) scan with that 01 module and it was nearly identical:
Coding: 108A140002
Subsystem 1 - Part No SW: 1P0 959 538 D HW: 1P0 959 538 D Labels: 3C8-959-537.CLB
Coding: E20000
The difference is with/without PTT phone button.
Marty.h
Norwich, UK
C?ID=382098
Thanks I will give it a go tou think that would explain the 01: fault then
HMC
C?ID=28246
The clockspring doesn't explode, at least it's not deigned to:). I have been in the trade 54 years, don't start me on calling suspension dampers shock absorbers!
Regards HMC
Regards
