2017-5N-Tiguan-Sedan-CCTA 2.0 L-Auto Trans-USA J527 STEERING FAULT IN TRANS
Dana
Western PA, USA
Adding to Jef's comments, something is very odd with that 5K0 953 501 CL "multiple supersession". This won't quote well at all so try to wrap it:
5K0 953 501 CL steering column multi-switch
Part number is replaced by several parts (multiple supersession)
5K0 953 502 L 9B9 steering column multi-switch 1 satin black
5K0 953 569 AJ electronic modul for steering 1 col. combination switch
5K0 905 865 ignition starter switch
5K0 953 223 mounting plate for 1 steering col. comb. switch
1K0 905 851 B steering lock
That's one hell of a list of extra parts.
Moving forward, 5K0 953 569 AJ then supers to 5K0 953 569 AL but it almost looks as if you need to verify all of those other parts are also matching part numbers? If so that doesn't directly explain the initial TCM concern because I don't see how the part number of the ignition switch and mechanical steering lock is gonna help with a Powertrain Data Bus DTC.
   #42
I will put this out there again.
Did you all know the CL is still available? ............. :rolleyes:
2Q==
   #45
Mills83
C?ID=136383
Jef, Dana, and Jack thanks for going above and beyond the call of duty to help out with this little blue devil! :thanks:
Spent some time with car today looking at data and more inspection just to be completely certain no faults exist in car. As expected nothing out of place. Car was hit in RF corner and all the repairs look solid. Really no wiring to speak of in RF. Removed TCM in LF wheel housing to inspect and it was clean. Just to be sure scoped data lines and SCCM and TCM. As expected no faults in signals and patterns matched. Data line pins at TCM and SCCM in correct slots and tight. I see no faults with this car like before. I put PMI ODIS scan next to latest VCDS scan with AL part and all modules part numbers, HW/SW VERSION numbers and coding matched. Only difference being J527 P/N.
Crash picture, however car is repaired/re-assembled
Shop had picked up another AL to program lol. Knowing its was probably a waste of time I gave it a whirl anyway. Surprise surprise fault 18275 set in trans. Hunted all over car to make sure no aftermarket electronics and none fitted to car. Had shop drive car a ways but fault still wouldn't unlatch to clear. I really have no idea what "missing message" from J527 trans is expecting to see. I should also mention all the column switches function, wipers, signals, lights etc... The thought crossed our mind if we could find a tsb for trans possibly we could flash the garbage out of it. No such luck not appears this trans has no updates.
Jef "Or due to how super rare it is, this was a factory "hack job" to get a very limited run of vehicles out the door since 99.9% of Tiguans are not stripped down like this.... and now the parts departments has no info on said hack"
Jef I think this is hilarious but very possibly true. This car was a total cast off anomaly given lack of options, strange part numbers and crazy supers. Otherwise ya could be an issue with TCM but I'm just not willing to go there without a solid baseline J527. Still possible code was pre-existing to repairs and clockspring replacement. Would simply be a massive coincidence. I looked at shops pre scan and it was completely botched. Only 5 modules reported and no codes. Seems they didn't configure scan tool right or something. So the door is shut on the pre-existing debate.
Dana
"5K0 953 501 CL steering column multi-switch
Dana I think you observation with all the steering column part supersession is brilliant. If I'm understanding you right your saying what if the AL J527 needs the updated switches to be compatible to the car."
Dana thats a brilliant observation!
Makes me wonder if the AL would need the updated column parts to truly be compatible. Would like to think the parts catalog would lay that out but as we know they can get things twisted up here and there. I'm sort of glad I'm won't be making the call from this point forward considering who knows many pricey modules the dealer might wing at this thing.
Jack
Great find with the ebay part! The listing says "Doesn't post to US". Not sure how I could get around that. Also I noticed the pic of part seems to be missing the clockspring ya?
I'll post a final scan up once the car gets back from dealer. Appreciate the time guys!:thumbs:
Was an example there are plenty for sale even new when searching online.
   #47
Mills83
C?ID=136383
Well guys vehicle returned from dealer and is FIXED. I’ll post some data later today when I get a minute. Basically the dealer couldn’t produce the correct part for this hacked Tiguan so they hacked the coding. I’ll explain later...
   #48
Jef
HQ
The follow up Auto-Scan should be interesting and helpful to the person that owns the other stripper Tiggy.
   #49
Mills83
C?ID=136383
Well as I mentioned earlier car is fixed.... well depends on the definition of fixed :)
I suspect the dealer realized rather quickly from the 5 parts they sent to client shop that legacy part wasn't an option. They ended up falsifying the coding in the J527 Steering module that vehicle is equipped with CRUISE CONTROL!!. Obviously vehicle has no such option on car or on build report. It seems the TCM missing message (18275 - Powertrain Data Bus - P1867 - 000 - Missing Message from Steering Wheel (J527) was the lack of cruise data. Given the fast turn around on this I imagine the tech sent data to VW Support of sorts and they came back with this bullet, but who knows maybe the guys a super genius lol :D
Evidently this car can be taught something that doesn't exist and have no ill effects. If this steering module ever looses coding some poor tech somewhere is going to have a real battle on his hands due to false coding. As a tech I find it perplexing that an OE would have to resort to this type of configuration fudging on a 2017! A final question and food for thought wonder why the TCM was looking for cruise data in the first place hmm...
FINAL AUTO SCAN
Friday,10,April,2020,11:11:29:41049
VCDS Version: 20.4.0.1
VIN: WVGBV7AX7HK045804   License Plate:
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 4C 52 53 5F 62 72
VIN: WVGBV7AX7HK045804   Mileage: 30080km-18690miles
   Part No SW: 06J 906 027 KB    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 07 3231
   Revision: P3H08---    Serial number:
   Coding: 0423010A190F0060
   Shop #: WSC 00040 028 00001
   VCID: 75EBEE841C616F2E21-8020
Readiness: 0010 0101
   Part No SW: 09G 927 750 PP    HW: 09G 927 750 PP
   Component: AQ 250 6F           3435
   Revision: 00H97000    Serial number:
   Coding: 0000840
   Shop #: WSC 07348 004 104857
   VCID: 0E19A16819F73CF680-805A
Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
   Part No SW: 5N0 614 109 CN    HW: 5N0 614 109 CN
   Component: J104   C6 450M VD4B 0023
   Revision: --H07---    Serial number: 00000009298375
   Coding: 0005161
   VCID: 79F3E2B430790B4E45-802C
   Part No SW: 561 907 426 F    HW: 561 907 426 F
   Component: AC Manuell    H03 0506
   Revision: 00001K02
   Coding: 0010001002
   Shop #: WSC 00040 028 00018
   ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 1E39D12801178C7610-804A
   Part No SW: 5K0 937 084 N    HW: 5K0 937 084 N
   Component: BCM PQ35 B    122 0186
   Revision: BG122001
   Coding: EF1A0A1B80232EC4008800C11000044448010086524D8960648000000040
   VCID: 3D7B36A4A4D1F76E29-8068
   Subsystem 1 - Part No SW: 5N1 955 119 B    HW: 5N1 955 119 B  Labels: 1KX-955-119.CLB
   Component: WWS316 100517  24  0664
   Coding: 009795
   Part No SW: 5N0 959 655 AB    HW: 5N0 959 655 AB
   Component: J234__005 VW10 HI   5418
   Revision: 36023000    Serial number: 003MAP6KD7H.
   Coding: 0012341
   Shop #: WSC 07348 004 1048576
   VCID: 7DFBF6A42451376E69-8028
   Subsystem 1 - Part No: 5N0 959 339 B
   Component: BF-Gewichtsens. 003 0001
   Subsystem 2 - Serial number: 0000000000UHVF
   Subsystem 3 - Serial number: 0024.03.170000300000630116ÿ†63
   Subsystem 4 - Serial number: 630116ÿ†6332MTS6341511870ÿ†63
   Subsystem 5 - Serial number: 511870ÿ†6342MTS6265511876ÿ†63
   Subsystem 6 - Serial number: 511876ÿ†6351HTS6VQC3NEKJSÿ†63
   Subsystem 7 - Serial number: 3NEKJSÿ†6361HTS66N23NEKR%ÿ†63
   Subsystem 8 - Serial number: 3NEKR%ÿ†63727TS69OUITEKJ-ÿ†63
   Subsystem 9 - Serial number: ITEKJ-ÿ†63827TS6PK9GTEKJQÿ
   Subsystem 10 - Serial number: GTEKJQÿ
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20191215200038
   Coding: 5980440000
   Shop #: WSC 32263 003 104857
   VCID: 0201855895AF489614-8056
   Part No SW: 5N0 920 973 M    HW: 5N0 920 973 M
   Component: KOMBI         H02 1104
   Coding: 221F010000
   Shop #: WSC 00040 028 00058
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 3E7931A8A1D7EC7630-806A
   Part No SW: 7N0 907 530 BH    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1682
   Revision:   H57       Serial number: 300517F1000801
   Coding: 356022
   VCID: 77F7E48CC66D1D3E33-8022
   Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7540
   Serial number: HA1-00029.04.17
   Coding: 0001
   Shop #: WSC 00040 028 00008
   ROD: EV_AllWheelContrHA1VW37X_002.rod
   VCID: 52A17518054F1816E4-8006
   Component: IMMO          H02 1104
   VCID: 6AD1CDF88DDFB0D6BC-803E
   Part No SW: 5N0 959 701 H    HW: 3C0 959 793 H
   Component: TUER-SG FT    002 0601
   Revision: 13100010    Serial number: 0010982374
   Coding: 0004B4
   Shop #: WSC 00040 028 00056
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
   VCID: 3A713DB8BDFFC0560C-806E
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  010 1505
   Serial number: 00000009890503
   Coding: 000490
   Part No SW: 5N1 909 144 S    HW: 5N1 909 148 K
   Component: J500__APA-BS KL.285 1501
   Revision: 1BH04843    Serial number: 00171430029901
   Coding: 0000258
   VCID: 428145581D2F889654-8016
   Part No SW: 5N0 959 702 H    HW: 3C0 959 792 H
   Component: TUER-SG BT    002 0601
   Revision: 15100010    Serial number: 0011004698
   Coding: 0004B4
   ASAM Dataset: EV_TSGBPQ35BRFVW46X A04004
   VCID: 3B7F38BCB2C5F95E17-806E
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  010 1505
   Serial number: 00000009892580
   Coding: 000490
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H21       Serial number: 00000000017846
   Coding: 0026156
   VCID: 387527B04BF3D246FA-806C
   Part No SW: 561 035 150 B    HW: 561 035 150 B
   Component: MU-E--ER      056 7227
   Serial number: 23061700010694
   Coding: 02130600FF00000041220001001000009F0000140000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001032
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 0C1DAB60A7EB0EE66E-8058
End-------------------------(Elapsed Time: 02:35)--------------------------
SCAN COMPARISON
   #50
So I guess my question is, was this fault present in OBD2 mode before in transmission and was there an MIL for it?
   #51
Mills83
C?ID=136383
If your asking for codes standard or OBD2 global format prior to J527 replacement they have no record of a useful scan. I came in after repair. I did not scan TCM in global mode. CEL/SES/Engine lamp was never on at any point. Just wrench light.
   #52
Interesting indeed.......... :popcorn:
   #53
Dana
Western PA, USA
Thanks for the detailed feedback! We already had a Passat (ESCL specific) Special note related to 5K0-953-569-AL here but I added a new NAR 5N Limited comment today:
http://wiki.ross-tech.com/wiki/inde...ntrol_Module_Versions#Part_Number_5K0-953-569
Hopefully, the Wiki searchable P1867/18275 DTC info helps the next guy that encounters one of these goofy low-spec Limited models.
On a personal note I'm really glad I had my dealer seek out a dealer trade with Kessy, MFSW, CCS, etc when I got my mom's Tiggy Limited at this point. The Limited was desirable to us when seeking a new car because it is one of the German (non-Mexican) made models, the price was great, the current body Tiguan was too large and she loved the 2012 5N SEL we currently own.
The reality is, those Limited models were left-over (parts bin) vehicles so I can see exactly how this happened with one that was low-spec.
   #54
vinnie_russo
C?ID=157801
Dana and fellow ross-tech forum members:
I too have a 2017 NAR Tiguan S Limited with a factory installed 5K0-953-569-AJ clock spring. I ordered a turn signal stalk with Cruise Control and installed it. Coded the 5K0-953-569-AJ for Cruise Control - the module accepted the coding fine, but the Cruise Control function does not work. I don't get any other faults so I was at a loss until I saw this thread... Is it possible that due to some leftover parts bin mismatch for these cars, there are other pieces "missing" to allow the Cruise Control to function?
Separately, I got a MK6 GTI MFSW wheel and then ordered a 5K0-953-569-BD clock spring. I installed the new clock spring but when I ran an Auto-Scan I got faults on a number of modules - essentially, I failed to realize that the 5K0-953-569-BD does not have a steering angle sensor, and the Tiguan does need that. That was my bad for not double-checking that detail ahead of time... :(
However, just to check functionality (without driving the car), I tried to code for the MFSW, but the module kept rejecting that coding???...
Now I am wondering if that was due to the steering angle sensor faults, or will I not be able to properly add a fully working MFSW to the Tig? I've done that successfully on previous MK6 Golfs I owned (and family members owned), so I thought it would be no problem for the Tig also....
I now found two clock springs that "should" work a 5K0-953-569-T and 5K0-953-569-AS. The "T" model is less expensive than the "AS", but it is not listed in your chart here "http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions". However, on the great wide web I saw some note stating that the "AS" is the replacement of the "T" model. Do you know anything about this?
More importantly, is there any reason why this will not work? I already got stuck with the 5K0-953-569-BD clock spring and don't want to order another clock spring if this will not work for whatever reason...
I am including my scan (from the 5K0-953-569-BD) with all the faults caused by the lack of steering angle sensor.
Any ideas or suggestions would be greatly appreciated.
Thank you. Vic
Friday,24,July,2020,09:24:43:39032
VCDS Version: 20.4.1.0 (x64)
VIN: WVGAV7AX2HK051280   License Plate:
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 4C 52 53 5F 62 72
VIN: WVGAV7AX2HK051280   Mileage: 46680km-29005miles
04-Steering Angle -- Status: Cannot be reached 1100
   Part No SW: 06J 906 027 KA    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 07 3230
   Coding: 0423010A19070060
   VCID: 74C9073E172357261F-8020
049682 - Steering Column Control Module
               U0212 - 000 - No Communications
                    Mileage: 46681 km
                    Date: 2020.07.24
                    Time: 00:00:00
                    Load: 0.0 %
                    Temperature: 21.0°C
                    Temperature: 28.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 12.192 V
   Coding: 0000328
   VCID: 0E3D75D619CF1DF689-805A
   Component: J104   C6 450M VD9E 0023
   Revision: --H07---    Serial number: 00000009304224
   Coding: 0005158
   VCID: 79D7360A30412A4E4C-802C
   Revision: 00001K03
   Coding: 0010001002
   Shop #: WSC 00040 028 00009
   VCID: 1E1D0596012FAD7619-804A
   Revision: BG122001
   Coding: EF1A0AB888212EC4000800C1150000E84C81AD86505D8960648020000040
   VCID: 3D5FE21AA4E9D66E20-8068
   Component: WWS316 260717  24  0664
   Coding: 009795
                    Reset counter: 158
                    Mileage: 46681 km
                    Date: 2020.07.24
                    Time: 00:00:03
                        Term 15 On
                    Voltage: 12.30 V
01800 - Light Switch (E1)
                    Reset counter: 188
                    Mileage: 44699 km
                    Date: 2020.07.11
                    Time: 02:08:33
                        Term 15 On
                    Voltage: 13.70 V
   Revision: 36023000    Serial number: 003MAPHK528Q
   Coding: 0012341
   VCID: 7DDF221A2469166E60-8028
   Subsystem 2 - Serial number: 0000000000V9T8
   Subsystem 3 - Serial number: 0020.04.170000300000650005ÿ† 63
   Subsystem 4 - Serial number: 650005ÿ† 6332MTS607022157.ÿ† 63
   Subsystem 5 - Serial number: 22157.ÿ† 6342MTS610372157/ÿ† 63
   Subsystem 6 - Serial number: 72157/ÿ† 6351HTS6IPG1OEKRPÿ† 63
   Subsystem 7 - Serial number: 1OEKRPÿ† 6361HTS6G602OEKJPÿ† 63
   Subsystem 8 - Serial number: 2OEKJPÿ† 63727TS6S26LPEKJ8ÿ† 63
   Subsystem 9 - Serial number: LPEKJ8ÿ† 63827TS6QA0LPEKRHÿ
   Subsystem 10 - Serial number: LPEKRHÿ
   Part No SW: 1K5 953 521 CT    HW: 5K0 953 569 BG
   Component: LENKS.MODUL   018 0230
   Revision: FF010042    Serial number: 20170317000985
   Coding: 4000140000
   Shop #: WSC 00078 790 00241
   ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 01275EEA9091728E04-8054
226827 - Turn Signal Switch
          B1144 13 [008] - Open Circuit
                    Reset counter: 53
227339 - Windshield Wiper Switch
          B1145 13 [008] - Open Circuit
                    Reset counter: 53
227355 - Windshield Wiper/Washer Switch
          B1149 13 [009] - Open Circuit
                    Reset counter: 158
   Coding: 221F010000
   VCID: 3E5DE516A1EFCD7639-806A
   Revision:   H57       Serial number: 170817F1000283
   Coding: 356022
   VCID: 77D33032C6553C3E3A-8022
                    Reset counter: 158
                    Mileage: 46681 km
                    Date: 2020.07.24
                    Time: 00:00:01
   VCID: 6AF519468DE791D6B5-803E
   Revision: 13100010    Serial number: 0011018423
   Coding: 0004F6
   VCID: 3A55E906BDC7E15605-806E
   Slave Driver:
   Serial number: 00000009900480
   Coding: 0004D0
67584 - Warning Light for Front Door
          B11F5 01 [008] - Electrical Failure
                    Reset counter: 198
                    Mileage: 30359 km
                    Date: 2019.09.23
                    Time: 23:58:47
133120 - Warning Light for Rear Door
          B11F7 01 [008] - Electrical Failure
                    Fault Frequency: 20
                    Reset counter: 195
                    Mileage: 38927 km
                    Date: 2020.05.20
                    Time: 20:38:16
   Revision: 1BH04843    Serial number: 00172010031301
   Coding: 0000258
   VCID: 42A591E61D17A9965D-8016
                    Fault Status: 11100100
                    Reset counter: 158
                    Mileage: 46681 km
                    Date: 2020.07.24
                    Time: 00:00:02
                        Term 15 On
                    (no units): 4.0
                    Voltage: 12.20 V
   Revision: 15100010    Serial number: 0011018901
   Coding: 0004F6
   VCID: 3B5BEC02B2FDD85E1E-806E
   Slave Passenger:
   Serial number: 00000009902269
   Coding: 0004D0
                    Fault Frequency: 34
                    Reset counter: 187
                    Mileage: 38611 km
                    Date: 2020.04.24
                    Time: 07:33:55
                    Fault Frequency: 11
                    Reset counter: 190
                    Mileage: 38927 km
                    Date: 2020.05.20
                    Time: 20:38:16
   Revision:   H19       Serial number: 00000000193955
   Coding: 0026156
   Shop #: WSC 29997 003 1048576
   VCID: 3851F30E4BCBF346F3-806C
   Serial number: 10071700010291
   VCID: 0C397FDEA7D32FE667-8058
End-------------------------(Elapsed Time: 01:48)--------------------------
