Hey guys, I've spent hours learning the car's HVAC system and I'm pretty well educated at this point.
I *previously* had this error: 00792 - A/C Pressure Switch (F129) 00 - Open or Short to Ground
I added some r134, bringing the static pressure (read with physical gauges) to about 50psi. (will add more once the compressor is engaging) Since I added that, there are no errors in the system. It's held a few days, and I haven't seen/found any leaks.
I have the g65 switch, so I can't jumper the f129 a-b terminals as many would think.
Is it possible to jumper the wires some other place rather than checking / applying 12v right at the compressor? That seems really awkward but it looks like that's the next step.
I also haven't found a guide to replacing the clutch on its own without taking the compressor out. Any feedback?
Resources I found:
http://forums.ross-tech.com/showthread.php?633-Tis%92-the-HVAC-Season&highlight=compressor+clutch
http://www.ross-tech.com/vcds/tour/b-settings.php
Thanks in advance for any pointers....
Note: a CLEAN scan... YAY... so many hours to get to that point.
Resources I found:
Saturday,08,April,2017,13:04:02:17476
VCDS Version: 17.1.3.0 (x64)
Dealer/Shop Name: Home
Workshop Code: 444 04738 087694
VIN: TRUUT28N641004001 License Plate:
Mileage: 107874 Repair Order:
Chassis Type: 8N (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Address 01: Engine Labels: None
Part No: 8N0 906 018 CJ
Component: 1.8L R4/5VT G 0001
Coding: 07710
Shop #: WSC 04738
VCID: 7BFBE47F69A12499BC-513C
TRUUT28N641004001 AUZ5Z0C5036104
Address 03: ABS Brakes Labels: 8N0-907-379-MK60-A.lbl
Part No: 8N0 907 379 H
Component: ESP ALLRAD MK60 0101
Coding: 0022544
Shop #: WSC 01236 785 00200
VCID: 418756971BCD8E49A6-5178
Address 08: Auto HVAC Labels: 8N0-820-043.lbl
Part No: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00140
Shop #: WSC 01236
VCID: 2851EB33C8B75F0181-2592
Address 15: Airbags Labels: 8N0-959-655.lbl
Part No: 8N0 959 655 B
Component: Airbag Front+Seite 6000
Coding: 01103
Shop #: WSC 01236
VCID: 3F83506F3D39F8B9D0-515A
Address 17: Instruments Labels: 8Nx-920-xxx-17.lbl
Part No: 8N1 920 980 A
Component: KOMBI+WEGFAHRS. M73 D06
Coding: 05244
VCID: 34690F43047F2BE13D-FFFE
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 C
Component: HALDEX LSC ECC 0010
VCID: 2041F313A087A741C9-4B32
Address 35: Centr. Locks Labels: 8Nx-962-267.lbl
Part No: 8N7 962 267 F
Component: Central Lock/Alarm D09
Coding: 15900
Shop #: WSC 01236
VCID: 438B5C9F51D19C59B4-4F1E
Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00010
Shop #: WSC 01236
VCID: 65CFA207FF2582697A-51B2
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 4B0 035 186 R
Component: concert II NP2 0008
Coding: 00202
Shop #: WSC 08219
VCID: 2F63002FED59083940-4ECA
End-------------------------(Elapsed Time: 06:24)--------------------------
