2017 VW Golf Alltrack coding questions
shwagondawheels
C?ID=146532
I tried this sequence tonight with no luck on the 2018 Alltrack. I have the option in the vehicle setting menu for rain closing now just like I got on the 2016 Golf R but it still doesn't work.
I put the translations in parentheses next to the adaption channels for better understanding of what we are doing.
Auto Close Windows When Raining
When rain is detected on the rain sensor, the windows will automatically close.
Select Control unit 09 (Central Electrics)
Security access
Access code 31347
Adaptation
(15) Access Control 2-Regenschliessen_ein_aus (Access Control 2- Rain closing one of)
Value: Permanent
(16) Access Control 2-Regenschliessen_art (Access Control 2-Rain Close Art)
Value: Permanent
(28) Zugriffskontrolle 2-Menuesteuerung Regenschliessen (Access Control 2-Menu control Rain Closing)
Value:Aktif (Active)
Control unit Long Coding
Subsystem: Rain / Light Sensor (RLS)
Byte 0
Bit 1-Bit 2 DeActivate < I’ve tried both deactivated and activated here with the same result! Also it will not allow me to activate one bit opposite of the other. I get a message in a VCDC saying coding not accepted every time.
Something has to be missing
hadez16
C?ID=289891
RLHS = rain closing not possible
RLFS = rain closing possible
What's so hard to understand here?
   #23
shwagondawheels
C?ID=146532
Check out the auto scan. It comes up as RLS so where does that fit? Is is RLFS or nothing then?
Monday,02,July,2018,19:26:26:24261
VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
VIN: 3VWH17AUXJM761673   License Plate: UYB3474
Mileage: 1658km-1030mi   Repair Order: Christians's alltrack
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 15 16 17 19 22 42 44 52 5F
VIN: 3VWH17AUXJM761673   Mileage: 1658km-1030miles
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 M    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 311D00122426002F0000
   Shop #: WSC 00066 790 00424
   ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
   ROD: EV_ECM18TFS0208V0906264M.rod
   VCID: 46D5AAC7282201670BB-8012
   Part No SW: 0D9 300 018     HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5201
   Revision: 06454104    Serial number: TFK01707061446
   ROD: EV_TCMDQ250021.rod
   VCID: 59EF71BB899C9E9F569-800C
Address 03: ABS Brakes (J104)       Labels:| 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AQ    HW: 5Q0 614 517 AF
   Component: ESC           H62 0400
   Revision: 00000000    Serial number: 53057000002614
   Coding: 43FA6AA13426096D807D0307A0C629C2562C9001C005943C00435050E009430000010312121212B435351919323200
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
   ROD: EV_Brake1UDSContiMK100ESP_036_VW37.rod
   VCID: 00597CDF4A86EF57717-8054
   Part No SW: 5GM 907 426 G    HW: 5GM 907 426 G
   Component: AC Manuell    H03 2001
   Revision: 00001K05
   Coding: 02020004200110000000000000000002
   ASAM Dataset: EV_ACManueBHBVW37X 004134
   ROD: EV_ACManueBHBVW37X_004_VW37.rod
   VCID: 4CC198EF364EFB37DDF-8018
   Part No SW: 5Q0 937 087 AR    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 034 0245
   Revision: --------    Serial number: C86407121700VC
   Shop #: WSC 00066 790 00395
   ROD: EV_BCMCONTI.rod
   VCID: 0B435BF373C0BC0F145-805E
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    171021  043 0551
   Serial number: 97022066171028153214
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  047 0105
   Serial number: S4Y17M09D13H12M27S26
   Coding: 00A8DD
   Serial number: 003GCR08VLSH
   VCID: 47CBA7C32F28186FF0D-8012
   Occupant Detection:
   Serial number: IBH000000000008162M%
   Coding: 303135
   Subsystem 2 - Part No SW: -----------    HW: 480 001 310 17
   Serial number: 35700000000D4D31282I
   Subsystem 3 - Part No SW: -----------    HW: 480 001 310 17
   Serial number: 3580000000063D31282B
   Subsystem 4 - Part No SW: -----------    HW: 480 401 211 17
   Serial number: 3510001B32777383415S
   Subsystem 5 - Part No SW: -----------    HW: 480 401 211 17
   Serial number: 3520001C927FFB82455K
   Subsystem 6 - Part No SW: -----------    HW: 480 401 810 17
   Serial number: 3550002AF25629A63298
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 810 17
   Serial number: 3560002AF25629A4A29E
   Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 18111704221447
   Coding: 0410
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 025D76D7448AFD47673-8056
   Part No SW: 5G1 920 840 C    HW: 5G1 920 840 C
   Component: KOMBI         242 0310
   Coding: 0BB4100DA180CF0502082B001000000000000000
   VCID: 270B07438F68F86F10D-8072
16777020 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Fault Frequency: 40
                    Reset counter: 88
                    Mileage: 219 km
                    Date: 2018.06.21
                    Time: 19:28:40
   Part No SW: 3Q0 907 530 F    HW: 3Q0 907 530 B
   Component: GW MQB Mid    517 5304
   Serial number: 17101700840125
   Coding: 0101000830085900FB0020081E0F00000001070000000000000000000000
   Shop #: WSC 00066 790 00067
   ROD: EV_GatewNF_VW27.rod
   VCID: 323DE617B4AA8DC7B73-8066
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 26170001894540071439
   Coding: 31FFFF
   Component: Haldex4Motion H52 7084
   Serial number: HA1-00024.08.17
   Coding: 0001
   Serial number: 5038731600287
   Coding: 003A03200000020000000000
   Serial number: 00000000000006814883
   Coding: 011000
   Part No SW: 5QM 909 144 A    HW: 5QM 909 144 A
   Component: EPS_MQB_ZFLS  171 1072
   Coding: 8102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 4FFB8FE3C758C02FB8D-801A
   Serial number: 6038731702967
   Serial number: 00000000000007105428
   Coding: 091000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 5G6 035 868     HW: 5G6 035 868
   Component: MU-E--ER      671 8395
   Serial number: 01091700021479
   Coding: 02731200FF00000041220001001000009F0008D40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001041
   ROD: EV_MUEnt4CGen2LGE_VW12.rod
   VCID: 70B92C1F7A26FFD7817-8024
End----------(Elapsed Time: 01:25, VBatt start/end: 12.4V/12.4V)-----------
hadez16
C?ID=289891
As your coding above is correct without anything missing, I'd say "not possible"
   #25
shwagondawheels
C?ID=146532
I'd say you're correct even though I wish you weren't. Figured I would give it a shot.
   #26
hadez16
C?ID=289891
Bit 2 in RL(F/H)S has to be activated of course
   #27
shwagondawheels
C?ID=146532
In Byte 0 of RLS in this car I had bit 1 and 2 activated. I tried to do just bit 2 and I got an error massage every time for coding not accepted after clicking do it. I tried to do just bit 1 after that and same thing. I could either activate both bit 1 and 2 with no issues and deactivate with no issues but not one or the other.
   #28
hadez16
C?ID=289891
That's a known issue / workaround.
Bit 1 stands for "Rain light" (activation of light when rain is detected)
   #29
shwagondawheels
C?ID=146532
Here is a screen shot I stole of the same RLS window. Not one I took but found online for reference.
Is not being able to activate one or the other an issue with the ross-tech interface / software or is it something VAG wont allow?
   #30
shwagondawheels
C?ID=146532
Also in his vehicle both bits 1 and 2 where not active from the factory but the auto wiping function works fine with the wiper stalk in the intermittent position. You would think if bit 1 wasn't activated the auto wipers would not work, correct?
   #31
TBAx
C?ID=287144
Byte 0 Bit 1 in RLS enables the car to automatically activate the low beam when a certain amount of rain is detected.
