2001 TT 1.8t 225hp
emserg
C?ID=39273
wi fi:
VCDS Version: Beta 14.7.1 (x64)
Data version: 20140601
edge motors
Wednesday,16,July,2014,14:44:54:23346
Chassis Type: 8N - Audi TT (1999 > 2007)
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
   Mileage: 152940km-95032miles
Address 01: Engine        Labels: 06A-906-032-AMU.lbl
   Part No: 8N0 906 018 T
   Component: 1.8L R4/5VT     G   0003
   Coding: 06710
   Shop #: WSC 01236
   VCID: C2C80C17CCD4632AA3-5184
8 Faults Found:
16885 - Vehicle Speed Sensor
            P0501 - 35-00 - Implausible Signal
16706 - Engine Speed Sensor (G28)
            P0322 - 35-10 - No Signal - Intermittent
16806 - Main Catalyst; Bank 1
            P0422 - 35-10 - Efficiency Below Threshold - Intermittent
17987 - Throttle Actuator (J338)
            P1579 - 35-10 - Adaptation Not Started - Intermittent
17925 - Power Supply Relay for ECU (J271 or J363)
            P1517 - 35-10 - Electrical Malfunction - Intermittent
17965 - Charge Pressure Control
            P1557 - 35-00 - Positive Deviation
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
            P1297 - 35-10 -  - Intermittent
16795 - Secondary Air Injection System
            P0411 - 35-10 - Incorrect Flow Detected - Intermittent
Address 03: ABS Brakes        Labels: 8N0-907-379-MK20-E.lbl
   Part No: 8N0 907 379 E
   Component: ESP     20    CAN  V004
   Coding: 18446
   Shop #: WSC 01236
   VCID: BE3078E7B82C07CAC7-4B3C
            27-00 - Implausible Signal
            16-10 - Signal Outside Specifications - Intermittent
Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
   Part No: 8N0 820 043 A
   Component: TT-KLIMAVOLLAUTOMAT D03
   Coding: 00140
   Shop #: WSC 01236
   VCID: A81CBEBF4AA8A97A9D-2596
Address 15: Airbags        Labels: 8N8-909-601.lbl
   Part No: 8N8 909 601
   Component: Airbag Froft+Seite 1005
   Coding: 10102
   Shop #: WSC 16999
   VCID: F7BEADC3D796F682C4-5184
00532 - Supply Voltage B+
Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
   Part No: 8N1 920 930 E
   Component: KOMBI+WEGFAHRS. M73 D10
   Coding: 07242
   Shop #: WSC 16999
   VCID: B32659D3836EDAA238-4B3C
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 B
   Component: HALDEX LSC  ECC     0006
   VCID: 9F0EA5631FE66EC2EC-4B3C
65535 - Internal Control Module Memory Error
            00-00 - -
Address 35: Centr. Locks        Labels: 8Nx-962-267.lbl
   Part No: 8N7 962 267 A
   Component: Central Lock/Alarm  D04
   Coding: 15900
   Shop #: WSC 01236
   VCID: BE3078E7B82C07CAC7-4F0C
01370 - Alarm triggered by Interior Monitoring
            35-00 - -
01559 - Drivers Door
01617 - Please Check DTC Memory of Interior Monitoring
            35-10 - - - Intermittent
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8N7 951 177
   Component: Innenraumueberw.    D14
   Coding: 00001
   VCID: FBB6B1F3EBBED2E2A0-5160
01463 - Alarm triggered by Sensor for anti-theft alarm System
            81-00 - OPEN
01462 - Anti-theft alarm ultra sonic Sensor (G209)
            53-10 - Supply Voltage Too Low - Intermittent
Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
   Part No: 4B0 907 357
   Component: LEUCHTWEITEREGLER  D004
   Coding: 00010
   Shop #: WSC 44051
   VCID: E582F78B7D3A741266-51CE
            35-00 - -
01537 - Vehicle Level Sensor; Supply Voltage
End-------------------------(Elapsed Time: 03:39)--------------------------
usb:
Wednesday,16,July,2014,11:55:52:23346
   Coding: 06710
   Shop #: WSC 01236
   VCID: 42C88C174CD4E32A23-5184
9 Faults Found:
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96)
            P0106 - 35-10 - Implausible Signal - Intermittent
   Coding: 18446
   Shop #: WSC 01236
   VCID: 3E30F8E7382C87CA47-4B3C
   Coding: 00140
   Shop #: WSC 01236
   VCID: 281C3EBFCAA8297A1D-2596
   Coding: 07242
   Shop #: WSC 16999
   VCID: 3326D9D3036E5AA2B8-4B3C
   VCID: 1F0E25639FE6EEC26C-4B3C
            00-00 - -
   Coding: 15900
   Shop #: WSC 01236
   VCID: 3E30F8E7382C87CA47-4F0C
No Faults Found
   Coding: 00001
   VCID: 7BB631F36BBE52E220-5184
            81-00 - OPEN
   Coding: 00010
   Shop #: WSC 44051
   VCID: 6582778BFD3AF412E6-51CE
            35-00 - -
End-------------------------(Elapsed Time: 03:58)--------------------------
