Can anyone be of assistance? Ive done a DSG reset and the Trans fault has gone. TPS has been replaced with a new one and TBA done. However intake flap fault code still showing. I have checked connectors and they LOOK fine. Any wiring checks I can do with a multimeter easily? TPS idling shows 85.9%. Thats the fault surely? Its a 140 TDI
Sunday,18,December,2016,15:52:09:32772
VCDS Version: 16.8.4.2 (x64)
Data version: 20161129 DS267.0
VIN: WVWZZZ13Z9V016080 License Plate: ROCCO LEYIA
Mileage: 199900km-124212mi Repair Order:
Chassis Type: 13 (1K0)
Scan: 01 02 03 08 09 14 15 16 17 19 25 2E 42 44 46 52 56
VIN: WVWZZZ13Z9V016080 Mileage: 199900km-124212miles
Address 01: Engine (CBD) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 KE HW: 03L 906 022 G
Component: R4 2,0L EDC G000AG 3929
Revision: 13H01--- Serial number: VWX7Z0H93NM1BC
Coding: 0001078
Shop #: WSC 00490 210 61674
VCID: 72E0A13D6D2F25D2CF-8026
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 000 - Implausible Signal - MIL ON
Fault Status: 11100000
Lambda: 11.0 %
Lambda: 2.4 %
Voltage: 0.304 V
Bin. Bits: 00000000
001674 - ECM Power Relay Load Circuit
P068A - 000 - Opens Too Early - Intermittent
Voltage: 0.00 V
Hex Value: 0xFF00
Bin. Bits: 00000000
Temperature: -90.0°C
P0087 - 000 - Too Low
Mileage: 199907 km
Time: 10:34:53
RPM: 1173 /min
Inj. Quantity: 1.9 mg/str
(no units): 17.0
Pressure: 240.0 bar
Pressure: 96.0 bar
Temperature: 13.5°C
Tank Cont.: 23.2 l
Readiness: 1 1 0 0 0
Part No SW: 02E 300 052 HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1904
Revision: 04844002 Serial number: 00000810070134
Shop #: WSC 44551 111 44551
VCID: 51A20EB1C8693ECA16-8004
19143 - Unexpected / Implausible Mechanical Gear Disengagement
P2711 - 004 - - Intermittent - MIL ON
Fault Status: 10100100
Fault Frequency: 255
Reset counter: 40
Mileage: 199759 km
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 763B40F5092300006E0B02EC90190082B100
Shop #: WSC 00020 790 00000
VCID: 75EA9A21DC4132EAEA-8020
Reset counter: 235
Mileage: 199761 km
Count: 16386
Count: 15
Count: 4096
Count: 128
Count: 30464
Part No SW: 1K0 820 047 JD HW: 1K0 820 047 JD
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000
VCID: 6FE6A8497E1D083A20-803A
00532 - Supply Voltage B+
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000008293294
Coding: EC880F0300041A0067960E001900000000087B075C400124000000000000
VCID: 3260613DADAF65D20F-8066
Subsystem 1 - Part No: 1K8 955 119 C
Component: Wischer 180808 022 0602
Coding: 00038805
Shop #: WSC 00020
Component: RLS 291008 054 0402
Coding: 00209133
Shop #: WSC 00020
Reset counter: 235
Mileage: 199761 km
Voltage: 8.20 V
02385 - Rain / Light Recognition Sensor Function Restricted due to Under-Voltage
Reset counter: 235
Voltage: 9.65 V
00154 - Windshield Wiper Motor; Passenger Side (V217)
Reset counter: 235
Mileage: 199761 km
Voltage: 9.70 V
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
Reset counter: 235
Mileage: 199761 km
Voltage: 9.70 V
Address 14: Susp. Elect. (J250) Labels: 3C0-907-376.clb
Part No SW: 3C0 907 376 HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0069
Revision: 00000000 Serial number: 23100800150002
Coding: 000180
VCID: 66C8CD6D91E7C97253-8032
03264 - Functionalty Shut Off
Fault Frequency: 7
Reset counter: 235
Mileage: 199755 km
Time: 13:52:14
Error Code: 9
Bin. Bits: 00000000
Part No SW: 1K0 909 605 AE HW: 1K0 909 605 AE
Component: 0H AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 003D1D00EJ6Q
Coding: 0012360
Subsystem 1 - Serial number: 6332MSME40304B632
Subsystem 2 - Serial number: 6342MSME4131320B/
Subsystem 3 - Serial number: 6352QSME1C0F1E12N
Subsystem 4 - Serial number: 6362QSME1A0F510CM
Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
Component: J0527 052 0111
Coding: 0001034
Shop #: WSC 00490 210 84728
VCID: 0200F1FD5D8F1552DF-8056
Part No SW: 1K8 920 960 E HW: 1K8 920 960 E
Component: KOMBIINSTRUMENT VDD 1244
Revision: V0003000 Serial number: VWX7Z0H93NM1BC
Coding: 0003403
Shop #: WSC 80093 222 69422
VCID: 336E643952B56CDA04-8066
Reset counter: 235
Mileage: 199761 km
Time: 08:51:23
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400
Coding: ED881F06000212004001
VCID: 3776502946CD80FA38-8062
Component: IMMO VDD 1244
00003 - Control Module
014 - Defective
Fault Status: 01101110
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 A HW: 5N0 035 342 A
Component: SG EXT.PLAYER H13 0062
Revision: A1001003 Serial number: 7667296593
VCID: 254A8A612C61026A9A-8070
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1Q0 959 701 F HW: 1Q0 959 701 F
Component: Tuer-SG 008 2022
Coding: 0016949
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 179 2301
Revision: 00H15000
VCID: 2A50795D857F2D12B7-807E
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0205
Revision: 00020000 Serial number: 00000000000000
Coding: 81900A0002830C7F3F04840570085ACE903CA0
VCID: 030EF4F942951C5AD4-8056
Subsystem 2 - Part No: 1K8 951 171
Component: DWA-Sensor 001 0104
007 - Short to Ground
Fault Status: 01100111
Fault Frequency: 83
Reset counter: 195
Mileage: 199755 km
Time: 14:21:18
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1Q0 959 702 F HW: 1Q0 959 702 F
Coding: 0016948
VCID: 387453154BD38F8231-806C
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: Radio RCD510 036 0130
Revision: 00000001 Serial number: VWZ1Z3H3373760
Coding: 0100040004
VCID: 65CACA616CE1C26A5A-8030
Reset counter: 235
Mileage: 199761 km
Time: 10:45:02
End-------------------------(Elapsed Time: 02:06)--------------------------
