Brake set swap Superb 2016 312mm --> 340mm
Enriquez
Poland
C?ID=72075
Hi.
I will do a SWAP my front brake set from 312 to 340 in my MY2016 Skoda Superb 2.0 TSI 220 hp.
What do You think, do I need to recode something in my ABS unit? Lot of people say no, but it's always something what I don't sure.
My current coding is as follow:
Monday,09,May,2016,21:15:34:24735
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: TMBAD9NP9G7083724   License Plate: ELWAU47
Mileage: 110km-68mi   Repair Order: enri
Chassis Type: NP (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 36 3C 42 44 52 55
          5F 6D A5
VIN: TMBAD9NP9G7083724   Mileage: 110km-68miles
Address 01: Engine (J623-CHHB)       Labels: 06K-907-425-V1.clb
   Part No SW: 3G0 906 259     HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0004
   Revision: --H13---
   Coding: 0C1D00122464010B3000
   Shop #: WSC 33361 790 00063
   ASAM Dataset: EV_ECM20TFS0203G0906259 001007
   ROD: EV_ECM20TFS0203G0906259.rod
   VCID: 69F772AF88197D76C9-803C
Readiness: 1000 0000
   Part No SW: 0D9 300 041 C    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4937
   Revision: 06253104    Serial number: TFK01603311888
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 1811076BE3F334FEA6-804C
   Revision: 00000000    Serial number: 61046000001234
   Coding: 1D076A9C34282B6F077E060241C749B8562CD4E0608292F51841F0F8C2A9
   ROD: EV_Brake1UDSContiMK100IPB_SK37.rod
   VCID: 7AD53DE3FDBFC6EE30-802E
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Component: VWKESSYMQB    036 0710
   Revision: 00036000    Serial number: 0401307540
   Coding: 030C0C0703
   ASAM Dataset: EV_KessyHellaMQBAB 004032
   ROD: EV_KessyHellaMQBAB_SK48.rod
   VCID: 3A55FDE3BD3F06EE70-806E
Address 08: Auto HVAC (E87)       Labels: None
   Part No SW: 3V0 907 044 AL    HW: 3V0 907 044 AL
   Component: AC Automat    H32 3701
   Revision: 20K05000    Serial number: 00000B00102995
   Coding: 11010004000100011005100000101102
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_ACClimaPrehVW37X 002012
   ROD: EV_ACClimaPrehVW37X_SK48.rod
   VCID: 7EDD31F3E197EACE0C-802A
   Slave 1:
   Serial number: 01061610503196
   Coding: 0C019E46C2C72AFB17844086B11817280800000000000000000000000000
   ROD: EV_BCMBOSCH_SK48.rod
   VCID: 0429431B8F7B801E5A-8050
   Slave 1:
   Subsystem 1 - Part No SW: 3V1 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x LL 160401  032 0121
   Serial number: 00000001603290301742
   Coding: 165DDD
   Slave 2:
   Component: RLHS  037 0059
   Serial number: S4Y16M04D21H09M34S41
   Coding: 00084D
   Serial number: 000000000ZY160322A1D
   Serial number: 00000000000035189828
   Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0101
   Serial number: ESE0139605
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0076170
   Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0077628
   Subsystem 8 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0076193
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39391610306214
   Coding: 0071057851
   ROD: EV_EPHVA18AU3700000_SK48.rod
   VCID: 44A9831BCFFB401E1A-8010
Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
   Component: ACC BOSCH MQB H04 0194
   Coding: 320067C255FFC428949C804D
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3449D3DB9F5BF09EAA-8060
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0120
   Serial number: 10041641350245
   ROD: EV_DRCONTITEMIC.rod
   VCID: 3753E4D78E2D1B868F-8062
   Part No SW: 5Q0 959 655 AE    HW: 5Q0 959 655 AE
   Component: AirbagVW21    005 0130
   Serial number: 003NSR1MYJE%
   Coding: 98FCC0C0000000005C5400CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
   ROD: EV_AirbaVW20SMEVW37X_SK48.rod
   VCID: 032B40078A75872663-8056
   Subsystem 1 - Part No SW: -----------    HW: 480 001 604 16
   Serial number: 35700000000AD321E91P
   Subsystem 2 - Part No SW: -----------    HW: 480 001 604 16
   Serial number: 358000000001B06CDA1R
   Subsystem 3 - Part No SW: -----------    HW: 480 401 404 16
   Serial number: 3510002B91FA342151E1
   Subsystem 4 - Part No SW: -----------    HW: 480 401 404 16
   Serial number: 3520002B320178D3D3F5
   Subsystem 5 - Part No SW: -----------    HW: 480 401 404 16
   Serial number: 3550002A520178D4912Y
   Part No SW: 3Q0 953 521 BA    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20160415501293
   Coding: 6010
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 70C11FCBABC38CBE8E-8024
   Part No SW: 3V0 920 710     HW: 3V0 920 710
   Component: KOMBI         306 6422
   Coding: 07A5011A7F800008018B6A0B5000000000000000
   Shop #: WSC 73430 031 00063
   ROD: EV_DashBoardVDDMQBAB_SK25.rod
   VCID: 6CF90BBB87EB685EB2-8038
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 15041610801939
   Coding: 0B0100047F085900EB00025A9C0F00010001070000000000000000000000
   Shop #: WSC 33361 790 00114
   ROD: EV_GatewConti.rod
   VCID: 79D722EFF8B9CDF639-802C
   Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000B0555020416
   Serial number: 3091799903
   Inverter power receptacle:
   Subsystem 4 - Part No SW: 5Q0 907 155 B    HW: 5Q0 907 155 B
   Component: WECHSELRICHTE  H55 0033
   Serial number: 0216654
   Serial number: 16000075874012
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71C71ACFA0C985B681-8024
Address 36: Seat Mem. Drvr (J810)       Labels: None
   Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
   Component: Sitzmemory    H06 0009
   Serial number: Y0006PDD18881
   Coding: 001000000000010001A080808080000000008181000000D4
   ASAM Dataset: EV_SeatMemorDriveSide 001015
   ROD: EV_SeatMemorDriveSide_SK37.rod
   VCID: 3B5BF8E7B2053FE66B-806E
Address 3C: Lane Change (J1086)       Labels: None
   Component: HRE_Master    H12 0071
   Serial number: 0401370608
   Coding: 02011103
   ROD: EV_HREntryHella_SK37.rod
   VCID: 3C59FBFBB70B38DE62-8068
   Lane Change Assistant 2:
   Serial number: 190316ECI0941A
   Coding: 001D0820DE00040000001100
   ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
   VCID: 43AB8007CAF5472623-8016
Address 44: Steering Assist (J500)       Labels: 5Q0-909-143.clb
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000737072
   Coding: 01000011005001
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_SK48.rod
   VCID: 3D5FF6FFAC1131D655-8068
   Serial number: 070416ED523015
   Coding: 001D0220DE00040000001100
   ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
   VCID: 42A58503D5EF4E2E28-8016
   Coding: 06D202007F010000
   ROD: EV_HeadlRegulVWAFS_SE26.rod
   VCID: 40A18F0BDBE35C3E3E-8014
   Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0013
   Coding: B30000
   Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0013
   Coding: B30000
Address 5F: Information Electr. (J794)       Labels: 3V0-035-MIB-HGH2.clb
   Part No SW: 3V0 035 020 B    HW: 3V0 035 020
   Component: MU-H-ND-EU    H50 0318
   Serial number: A676D0GB019547
   Coding: 03840101000000001111120200880A002F0003E401200100DE
   VCID: 256F3E9F248199162D-8070
   Media Player Position 1:
   Radio Tuner - Digital:
   Subsystem 2 - Part No SW: 3V0 919 606     HW: 3V0 919 606
   Component: ABT_High-2  H46 1031
   Serial number: SKZ8Z9SFP00ESX
   Engine Control Module 2:
   Subsystem 3 - Part No SW: -----------    HW: -----------
   Component: -------------  --- ----
   Seat Adjustment Driver Side:
   Subsystem 4 - Part No SW: V03 959 801 JK    HW: -----------
   Component: ECE 2016  --- 0134
   Air Conditioning Compressor:
   Diesel Pump Control Unit:
   Door Electronics Driver Side:
   Subsystem 7 - Part No SW: -----------    HW: -----------
   Brake Assistance:
   Subsystem 8 - Part No SW: -----------    HW: -----------
   Interior Monitoring:
   Subsystem 9 - Part No SW: -----------    HW: -----------
   Sound System:
   Door Electronics Rear Left:
   Subsystem 12 - Part No SW: -----------    HW: -----------
   Subsystem 13 - Part No SW: -----------    HW: -----------
   Subsystem 14 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1012
Address 6D: Trunk Elect. (J605)       Labels: None
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30641108100000
   Coding: 1008
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   ROD: EV_DeckLidCONTIAU736_SK48.rod
   VCID: 3FA38CF7A61D23C647-806A
Address A5: Frt Sens. Drv. Assist (R242)       Labels: None
   Part No SW: 3Q0 980 654 D    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0024
   Serial number: 15041611P10361
   Coding: 0204080100000401002223468040A00088000E100040
   ROD: EV_MFKBoschMQBB_SK48.rod
   VCID: 3851E7EB833314FE86-806C
End-------------------------(Elapsed Time: 04:51)--------------------------
I own as well Octy RS with 340 brake set, the coding is:
Friday,15,January,2016,20:11:18:24735
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: TMBAE7NE6F0189796   License Plate: ELWAF68
Mileage: 14825km-9211mi   Repair Order: Enriquez
Chassis Type: NE (5Q0)
Scan: 01 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F A9
VIN: TMBAE7NE6F0189796   Mileage: 14825km-9211miles
   Part No SW: 5G0 906 259     HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0010
   Revision: --H13---
   Coding: 0C1900322424010B1000
   Shop #: WSC 73430 031 00138
   ASAM Dataset: EV_ECM20TFS0215G0906259 001014
   ROD: EV_ECM20TFS0215G0906259_AU37.rod
   VCID: 6BFB08A782E56F66B4-803E
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Component: ESC           H32 0385
   Revision: 00000000    Serial number: 60435000000558
   Coding: 1A076B9154282975007E060941C92958D62A9400608294F600430070C009
   Shop #: WSC 73430 790 00000
   ROD: EV_Brake1UDSContiMK100ESP_SK37.rod
   VCID: 47B39417FECD6B06F0-8012
   Revision: 00021000    Serial number: 0359162908
   Coding: 030C0C
   Shop #: WSC 73430 790 00138
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: 3A55FDE3BD3F06EE7F-806E
   Part No SW: 5E0 907 044 L    HW: 5E0 907 044 L
   Component: Climatronic   H03 0907
   Revision: 00001K06
   Coding: 01010004000100011005004000101002
   Shop #: WSC 00070 000 00000
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 2E7DC1B37177DA4ED3-807A
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011503702321
   Coding: 0C010A46C24722FB07A04082B10807280800000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 00214F0B9B639C3E71-8054
   Slave 1:
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 150131  041 0570
   Serial number:         150206012601
   Coding: 065DDD
   Slave 2:
   Serial number: S4Y15M02D16H21M18S36
   Coding: 02805D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY150073ZPB
   Serial number: 00000000000061557176
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39391503411950
   Coding: 0031051041
   ROD: EV_EPHVA18AU3700000_SK37.rod
   VCID: 3D5FF6FFAC1131D65A-8068
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0200
   Revision: --------    Serial number: 003P4P1UBDK3
   ROD: EV_AirbaVW20TS6VW48X_SK37.rod
   VCID: 7F23CCF7E69DE3C608-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 002 201 15
   Serial number: 3576U000000FD110D21B
   Subsystem 2 - Part No SW: -----------    HW: 454 002 401 15
   Serial number: 3586U0000001929C1213
   Subsystem 3 - Part No SW: -----------    HW: 454 800 102 15
   Serial number: 3516R50F5D5050000004
   Subsystem 4 - Part No SW: -----------    HW: 454 800 102 15
   Serial number: 3526R26FDD505000000G
   Subsystem 5 - Part No SW: -----------    HW: 454 802 401 15
   Serial number: 3556VB862CB05000000J
   Part No SW: 5Q0 953 507 DR    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 04021504220758
   Coding: 1000
   ROD: EV_SMLSKLOMQB_SK37.rod
   VCID: 0937522FA859DD7626-805C
   Part No SW: 5E0 920 756     HW: 5E0 920 756
   Component: KOMBI         310 4311
   Coding: 07AD01102980000801087A001000000000000000
   Shop #: WSC 00070 790 00001
   VCID: 67F374979E0D4B06D0-8032
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1204
   Revision: --------    Serial number: 0003054869
   Coding: 030100042F085900FF00026A080F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear.rod
   VCID: 72C515C3A5CFBEAE77-8026
   Subsystem 2 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
   Component: E221__MFL-PR6  H05 0130
   Serial number: 000000000B0791050215
   Subsystem 3 - Part No SW: 5Q0 915 181 F    HW: 5Q0 915 181 F
   Component: J367-BDM  H08 0223
   Serial number: 52016041454291303582
   Revision: 00000000    Serial number: 15000036954003
   Coding: 5500000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 3449D3DB9F5BF09EA5-8060
   Part No SW: 5Q4 959 593 C    HW: 5Q4 959 593 B
   Component: TSG FS        009 0015
   Serial number: 0000137003730
   Coding: 001D0020D000040000001100
   VCID: 45AF9E1FC4C1791602-8010
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000005190347
   Coding: 010200
   Coding: 8103
   ROD: EV_SteerAssisMQB.rod
   VCID: 3753E4D78E2D1B8680-8062
   Part No SW: 5Q4 959 592 C    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0015
   Serial number: 0000136867732
   Shop #: WSC 73430 790 00001
   VCID: 44A9831BCFFB401E15-8010
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000005206436
   Coding: 190200
   Coding: 03DA00003F010000
   VCID: 40A18F0BDBE35C3E31-8014
   Coding: 3E0000
   Coding: 3E0000
   Part No SW: 5E0 035 043 D    HW: 5E0 035 043 C
   Component: MU-H-N-EU     H43 0370
   Serial number: A312A0F7517484
   Coding: 03735101FF00000011110001000002002F0001D401000100FE
   ASAM Dataset: EV_MUHig6C3HBAS 001041
   ROD: EV_MUHig6C3HBAS_SK37.rod
   VCID: 1D1F167F0CD151D67A-8048
   Subsystem 1 - Part No SW: 5E0 919 606     HW: 5E0 919 606
   Component: ABT_High  H60 0030
   Serial number: SKZ8Z9PT600J4U
   Subsystem 2 - Part No SW: V03 959 800 MF    HW: -----------
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 150131200801
   VCID: 69F772AF88197D76C6-803C
End-------------------------(Elapsed Time: 03:37)--------------------------
WordBank
C?ID=52953
My experience is that there is no coding change needed for normal braking function, this is even going from single piston to 6 piston brakes and having them operate and modulate the ABS just fine on several applications.
I went from the stock I think 290mm??? to the gti/A3 312s on my 2016 Sportwagen and had no issues or need to change coding, ABS operated as it should.
Stability control programming is another issue and not one that I've investigated.
Enriquez
Poland
C?ID=72075
Thank you for sharing your thoughts. I was replacing my brake set on saturday without any coding changes. Beside of the proper bleeding of the brake system where my mechanics did wrong I have no problems in ABS/ESP at all. Everything works great after a while to "adapt" new parts. Thanks a lot!
sherlock
C?ID=78933
Its a mod i have helped with and there is no recoding required just a good old bleed of the braking system. Phil.
