what is this ? "ARA" ???
rojas
Spain
C?ID=261996
equipment_ARA_mechanical
equipmen_ARA_optical
what is ARA ???
thx
rojas
Spain
C?ID=261996
thx Sebastian , more later i make a autoscan and adapmap
the fault is in ABS , after of change the pump for PLA 3.0
this is the faults:
03 Brakes 1
System description: ESC
Software number: 3Q0907379AB
Software version: 0723
Hardware number: 3Q0907379G
Hardware version: H42
Serial number: 62615000000403
ODX name: EV_Brake1UDSContiMK100IPB
Long coding: 20EE629214210973007F060241C9240446289000608224F2D461F0024006
Trouble codes:
U112100 - Databus missing message
static
static
rojas
Spain
C?ID=261996
Any further context? Module, Auto-Scan?
Wednesday,21,September,2016,20:51:23:22717
VCDS Version: 16.8.1.3 (x64)
Data version: 20160902 DS256
Chassis Type: 5F (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 3C 42 44 52 55 5F 65 6C A5
VIN: VSSZZZ5FZER117826   Mileage: 16885km-10491miles
Address 01: Engine (J623-CLHA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 M    HW: 04L 907 309 B
   Component: R4 1.6l TDI   X22 9210
   Revision: 84X22---
   Coding: 01110032034401090000
   Shop #: WSC 92521 052 12345
   ASAM Dataset: EV_ECM16TDI01104L906021M 002013
   ROD: EV_ECM16TDI01104L906021M.rod
   VCID: 2F43E82D7645F13A07-807A
   Revision: 00000000    Serial number: 62615000000403
   Coding: 20EE629214210973007F060241C9240446289000608224F2D461F0024006
   Shop #: WSC 12345 123 61029
   ROD: EV_Brake1UDSContiMK100IPB_SE37.rod
   VCID: 7AD50979FD87E492E0-802E
8370 - Databus
                    Reset counter: 57
                    Mileage: 16885 km
                    Date: 2016.09.20
                    Time: 20:46:31
8377 - Databus
                    Reset counter: 57
                    Mileage: 16885 km
                    Date: 2016.09.20
                    Time: 20:46:27
   Part No SW: 5F0 907 044 E    HW: 5F0 907 044 E
   Component: Climatronic   H03 1403
   Revision: 00001K07
   Coding: 01000104202100011105004210101002
   ASAM Dataset: EV_ACClimaBHBVW37X 005134
   ROD: EV_ACClimaBHBVW37X_VW37.rod
   VCID: 2871033153ABA602C6-807C
   Air quality sensor:
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011408501699
   Coding: 08000B46424102FB4FE44080B10C0308100E000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 012001
   ROD: EV_BCMBOSCH_SE37.rod
   VCID: 7BDB0C7DF2BDDD9AFB-802E
   Subsystem 1 - Part No SW: 5F1 955 119     HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 140325  041 0574
   Serial number:         140326073449
   Coding: 0BC5FD
   Component: RLFS  024 0042
   Serial number: Y14M03D27H02M52S25S7
   Coding: 06885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY152290JCQ
   Serial number: 00000000000031592682
   Part No SW: 5Q0 919 298 C    HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0010
   Serial number: ATW-00121.03.14
   Coding: 0071163841
   Shop #: WSC 50178 001 104857
   ASAM Dataset: EV_EPHVA2CAU3700000 008017
   ROD: EV_EPHVA2CAU3700000_VW37.rod
   VCID: 3FA3B86DA62501BA97-806A
12658704 - Databus
                    Reset counter: 57
                    Mileage: 16885 km
                    Date: 2016.09.20
                    Time: 20:46:26
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 H    HW: 5Q0 907 567 G
   Component: ACC3          H07 0096
   Serial number: 27071276240359
   Coding: 00000400FE030B
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ACCBoschMQB 001023
   ROD: N/A
   VCID: 40A1BB91DBDB7E42EE-8014
No ASAM data for: "EV_ACCBoschMQB" (SE37)
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0189
   Revision: --------    Serial number: 003P4P79TV59
   Coding: 98CCC000000000005C0000CC000800000065
   Shop #: WSC 00049 770 00106
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F23F86DE6A5C1BAD7-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 304 14
   Serial number: 3576U000000947145F0A
   Subsystem 2 - Part No SW: -----------    HW: 454 000 404 14
   Serial number: 3586U000000945814F0C
   Subsystem 3 - Part No SW: -----------    HW: 454 802 703 14
   Serial number: 3516R0B2D4D030000002
   Subsystem 4 - Part No SW: -----------    HW: 454 802 703 14
   Serial number: 3526R55ED44030000005
   Subsystem 5 - Part No SW: -----------    HW: 454 801 903 14
   Serial number: 3556VCFA02D03000000J
   Part No SW: 5Q0 953 507 DK    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 05041408490170
   Coding: 6C00
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 022571999557AC52B8-8056
   Part No SW: 5F0 920 873 A    HW: 5F0 920 873 A
   Component: KOMBI         C02 F150
   Coding: 07ED12806C8C000800887E0F4401000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009043
   ROD: EV_DashBoardVDDMQBAB_SE37.rod
   VCID: 2977063548A19F0AD9-807C
10485826 - Internal Control Module Memory Check Sum Error
          B2000 41 [009] - General checksum failure
                    Mileage: 73 km
                    Date: 2015.12.19
                    Time: 19:06:07
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
   Component: GW MQB High   131 1223
   Revision: --------    Serial number: 0004274265
   Coding: 030100F40B087300A0000648080F00010000000000000000000000000000
   Shop #: WSC 24973 002 104857
   ROD: EV_GatewLear.rod
   VCID: 75CF1A45D4998BEA8D-8020
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Component: E221__MFL-PR6  H03 0100
   Serial number: 000000000A0636230113
   Coding: 002000
   Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Component: J367-BDMHella  H03 8043
   Serial number: 4475232803
Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
   Part No SW: 5Q0 907 566     HW: 8T0 907 566
   Component: SWA Master    H16 0046
   Serial number: 0162026687
   Coding: 030311
   Shop #: WSC 00123 123 12345
   ROD: N/A
   VCID: 77D3104DCE95F9FA9F-8022
No ASAM data for: "EV_LaneChangAssis" (SE37)
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000097358999
   Coding: 00100320DE00040000001000
   Shop #: WSC 00049 770 00125
   VCID: 44A9B781CFC36262CA-8010
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000002245433
   Coding: 310000
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 P
   Component: EPS_MQB_ZFLS  123 1063
   Coding: 1703
   ROD: EV_SteerAssisMQB_VW37.rod
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000097584970
   VCID: 43ABB49DCACD655AF3-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000002203632
   Coding: 290000
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 048A000009000000
   ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 5QA 035 858     HW: 5QA 035 858
   Component: MU-S-ND-ER    H24 0245
   Serial number: SEZAZ2R0672174
   Coding: 04730001FF0A00001111110100080A002F0302D40120010086
   ASAM Dataset: EV_MUStd6C3TSAT 001015
   ROD: EV_MUStd6C3TSAT_SE26.rod
   VCID: 042977818F43A2628A-8050
   Subsystem 1 - Part No SW: 5F0 919 604 A    HW: 5F0 919 604 A
   Component: ABTm_Std2_Nav  H43 1031
   Serial number: SEZ8Z9RFT006HB
   Subsystem 2 - Part No SW: 6P0 919 866     HW: -----------
   Component: ECE 2015/16  --- 0430
   Serial number: 40000000013741
   ROD: EV_RDKBERU30_VW36.rod
   VCID: 3449E7419F63D2E27A-8060
Address 6C: Back-up Cam. (J772)       Labels: Redir Fail!
   Part No SW: 5Q0 980 568 A    HW: 5Q0 980 568 A
   Component: RVC Compact+  H07 0180
   Coding: 018402010600201F000040
   Shop #: WSC 36892 120 02221
   ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 006008
   ROD: N/A
   VCID: 3B5BCC7DB23D1D9ABB-806E
No ASAM data for: "EV_CamSysRVRVCARPANAMQBAB" (SE37)
10489856 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 57
                    Mileage: 16885 km
                    Date: 2016.09.20
                    Time: 20:46:26
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0060
   Serial number: 10000060385
   Coding: 0101010001020308000500010100000100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3C59CF61B7331AA2B2-8068
End-------------------------(Elapsed Time: 03:26)--------------------------
	SW:3Q0-907-379-AB   HW:3Q0-907-379-G ---  ABS Brakes
	Component:ESC           H42 0723, Coding:20EE629214210973007F060241C9240446289000608224F2D461F0024006
	EV_Brake1UDSContiMK100IPB,034036,EV_Brake1UDSContiMK100IPB_SE37.rod
	Wednesday,21,September,2016,20:52:53:22717
	VCDS Version: Release 16.8.1 (x64)  Data version: 20160902 DS256
IDE00001-Production mode,not active
IDE00252-Brake system vacuum pump,5
IDE00820-Activating and deactivating all development messages,0
IDE01763-Dimming,activated
IDE02332-Deactivate production mode,Deactivating
IDE03493-Driver door status,activated
IDE03659-Roller test bench mode,Manual activation: possible
IDE04456-Brake disk drying,Medium
IDE04508-Hydraulic brake booster,8
IDE04643-Overboost in brake system,activated
IDE04645-IDE05287-Electromechanical parking brake-Automatic application,activated
IDE04645-MAS05667-Electromechanical parking brake-Driver presence recognition via brake pedal,not activated
IDE04765-Counter steer support,Strong
IDE04774-Vehicle and trailer stabilization,not activated
IDE04871-Dynamic starting assist,normal
IDE04939-Tire pressure monitoring display,0
IDE04944-Brake pedal evaluation,activated
IDE04949-Engine drag torque control,activated
IDE04951-Brake booster,4
IDE04952-Braking torque boost for distance regulation,3
IDE05055-Hydraulic brake assistant,normal
IDE05057-Brake prefill,activated
IDE05161-Straight ahead brake stabilization,activated
IDE05263-AUTO HOLD functionality,not activated
IDE05264-AUTO HOLD increase threshold: reduced tensioning force,0 %
IDE05265-AUTO HOLD increase threshold: full tensioning force,10 %
IDE05286-Expanded electronic differential lock,Standard
IDE05337-IDE05337-Starting vibration reduction-,Strong
IDE05337-MAS02653-Starting vibration reduction-Torque limitation,Deactivated
IDE05711-Automatic application during engine stalling,activated
IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7
IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button,7
IDE06139-AUTO HOLD slippage recognition,activated
IDE06425-Roller test bench mode: functional,not activated
IDE06505-Electromechanical parking brake: delay level,6
IDE07006-Tire pressure monitoring display: tire selection,0
IDE07565-ABS in lower speed range,activated
IDE07848-Thresholds for brake performance,activated
MAS00122-Electronic Stability Program,not activated
MAS00970-Running manufacturer number,activated
MAS01180-AUTO HOLD functional status,Last setting
MAS01299-Offroad,0
MAS02080-XCP calibration protocol,not activated
MAS02138-Hill-start assistant,normal
MAS02666-Seat belt buckle scan,activated
MAS08145-Hill-start assistant: increase threshold,3 %
MAS09008-MAS00988-Plausibility check-Reverse gear,activated
MAS09008-MAS09009-Plausibility check-Neutral gear sensor,activated
MAS09008-MAS10668-Plausibility check-Clutch movement,activated
ENG118148-Developer_Function_1,0
ENG130301-Developer_Function_121,not activated
ENG122844-ENG101574-dimming_characteristic_1-X1,0
ENG122844-ENG99557-dimming_characteristic_1-X2,50
ENG122844-ENG102140-dimming_characteristic_1-X3,220
ENG122844-ENG102936-dimming_characteristic_1-X4,6
ENG122844-ENG103548-dimming_characteristic_1-X5,8
ENG122844-ENG113992-dimming_characteristic_1-X6,80
ENG122844-ENG99777-dimming_characteristic_1-Y1,10
ENG122844-ENG100480-dimming_characteristic_1-Y2,100
ENG122844-ENG100773-dimming_characteristic_1-Y3,253
ENG122844-ENG100631-dimming_characteristic_1-Y4,6
ENG122844-ENG102174-dimming_characteristic_1-Y5,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100
ENG122845-ENG101574-dimming_characteristic_2-X1,0
ENG122845-ENG99557-dimming_characteristic_2-X2,50
ENG122845-ENG102140-dimming_characteristic_2-X3,220
ENG122845-ENG102936-dimming_characteristic_2-X4,6
ENG122845-ENG103548-dimming_characteristic_2-X5,8
ENG122845-ENG113992-dimming_characteristic_2-X6,80
ENG122845-ENG99777-dimming_characteristic_2-Y1,10
ENG122845-ENG100480-dimming_characteristic_2-Y2,100
ENG122845-ENG100773-dimming_characteristic_2-Y3,253
ENG122845-ENG100631-dimming_characteristic_2-Y4,6
ENG122845-ENG102174-dimming_characteristic_2-Y5,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100
Elapsed Time: 00:22
	Wednesday,21,September,2016,20:53:30:22717
MAS01299-Offroad,0
Elapsed Time: 00:22
thx for you help ;)
Zenerdiode
Newcastle, England
C?ID=24330
Have you asked the VCP people? Might be a Polish acronym?
XaGiCo
Ponferrada of Spain
C?ID=243154
ARA is Trailer Assist!
You know I like to see my Golf MKVII ,few to few!
I send by PM a video of Odis E.
Activate TRAILER ASSIST in 17 and consequential fail ARA
rojas
Spain
C?ID=261996
Trailer assist is disabled in all modules
