- Joined
- Sep 5, 2016
- Messages
- 1,229
- Reaction score
- 1,311
- Location
- Riga, Latvia
- VCDS Serial number
- C?ID=268515
Look's like I have got similar situation like this T5 http://forums.ross-tech.com/showthread.php?7619-Transporter-T5-strange-communication-issues
Only I have Touareg. Mainly everything directly on K-line talks to diagnostics, everything on CAN - not. Can gateway is part of Instrument panel. Is there the same as for T5, that CAN to diagnostic socket as by WD is not active? Do Instruments have separate fuse for CAN Gateway part? Panel is illuminated with ignition on, several warning lights (ABS, battery, seatbelts, etc) came on and off as they should do. Any ideas?
Friday,16,September,2016,02:07:52:32442
VCDS Version: 16.8.1.1
Data version: 20160902 DS256
VIN: WVGZZZ7LZ3D008689 License Plate:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
Part No SW: 070 906 016 D HW: 028 101 073 6
Component: V10 5,0L EDCG000AGMŖ5264
Coding: 0000127
Shop #: WSC 00018 264 05222
VCID: 1129DF7B0B17C0CA37-517C
Readiness: 0 0 X X X
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No: 09D 927 750 E
Component: AL 600 6Q 0318
Coding: 0012328
Shop #: WSC 31414 000 00000
VCID: 306F7AFFA05DE9C218-50E8
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 B
Component: ESP ALLRAD MK25 0106
Coding: 0022785
VCID: 387F42DF482D318250-5140
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 D
Component: CLIMAtronic R/L 0302
Coding: 0001020
VCID: 31697FFBAB57E0CA17-5140
6 Faults Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
00710 - Defroster Flap Positioning Motor (V107)
010 - Open or Short to Plus
013 - Check DTC Memory
Address 11: Engine II Labels: Redir Fail!
Component: V10 5,0L EDCG000AGSŖ5264
Coding: 0000127
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0122
VCID: 7F0D69C32D83C6BAD1-515E
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L6 907 553 B
Component: LUFTFDR.-CDC- 3C1P1 3650
Coding: 0015520
Shop #: WSC 02237 264 61425
VCID: 387F42DF482D318250-515E
00145 - Rear Right Dampening Adjustment Valve (N339)
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 C
Component: BF HSG 3214
Coding: 0000065
Shop #: WSC 00020 264 61507
VCID: 3C775ECF7C151DA2B4-4ACE
Subsystem 1 - Part No: 7L0 959 701 B
Component: Tuersteuergeraet FS 0104
Subsystem 2 - Part No: 7L0 959 702 B
Component: Tuersteuergeraet BF 0104
Subsystem 3 - Part No: 7L0 959 703 B
Component: Tuersteuergeraet HL 0104
Subsystem 4 - Part No: 7L0 959 704 B
Component: Tuersteuergeraet HR 0104
Subsystem 5 - Part No: 7L0 907 719
Component: Neigungssensor 0018
Subsystem 6 - Part No: 7L6 951 171
Component: A Innenraumsensor 0019
00486 - Front Passengers Outside Door Handle Central Locking Button (E370)
007 - Short to Ground
00108 - Signal Central Locking SAVE/LOCK Rear Right
End-------------------------(Elapsed Time: 10:29)--------------------------
