ACC retrofit
Dutchie
C?ID=125479
Hi lads,
I have been working on this retrofit quite some time now.
I know it is possible all i run in is the fact that VCDS wont let me reconfigure the ABS ECU
The plan:
Buy an ACC radar (PN: 7E937090)
Buy an BCM from a T6 ( PN: 7E0 937 090)
Buy a 6C MFSW steeringwheel, including the steeringwheel module
Get an ABS-ECU (PN:7E0907375Q)
Reflash the tacho to support ACC
Get some connectors and wiring
Now the problem, VCDS cant program an ABS controle unit. The dealer only ships modules with the correct VIN, thus i cant get a new unit and program it to my car specs. The same goes for a 2nd hand unit. Maybe i am missing something?
Sun,May,29,2016,15:38:08
VCDS Mobile 0.4321.0.4
VIN: WVWZZZ6RZDY******
Scan: 01 02 03 08 09 10 15 17 19 25 2E 37 44 56 61
VIN: WVWZZZ6RZDY149893
Address 01: Engine  (CPTA2 J623)	Labels: None
	Part No SW: 04E 906 016 R	HW: 04E 907 309 D
	Component: 1,4l R4 TSI   H08 5764
	Revision: WCH08---
	Coding: 00250032242411000000
	Shop #: WSC 21756 000 1048576
	ASAM Dataset: EV_ECM14TFS01104E906016R 002008
	ROD: EV_ECM14TFS01104E906016R.rod
	VCID: 312586C7FCAAD2C64CED0F411-8064
No fault codes found.
Address 02: Auto Trans	Labels: 0AM-927-769.clb
	Part No SW: 0AM 300 060 C	HW: 0AM927769D
	Component: GSG DSG AG7     431  5271
	Revision: 00043014	Serial Number: CU501211096629
	Shop #: WSC 63623 001 1048576
	VCID: 2A1791ABD17C381E8DA7C0F54-5160
Address 03: ABS Brakes  (J104)	Labels: None
	Part No SW: 6R0 907 379 AS	HW: 6R0 907 379 AS
	Component: ESP9.0i front H01 0002
	Coding: 21DD4885432700C9841C1272C25400550905
	Shop #: WSC 01383 785 00200
	ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
	ROD: EV_Brake1ESP90iBOSCH_VW25.rod
	VCID: 8F61A03FCADE6436FA9939B97-80DA
Address 08: Auto HVAC  (J255)	Labels: 6R0-907-044.clb
	Part No SW: 6R0 907 044 H	HW: 6R0 907 044 H
	Component: Climatronic   H11 0711
	Revision: V0000000
	Shop #: WSC 00000 000
	VCID: 3833BBE31FD01B8E0B337AADA-806D
00898 - Control Circuit A/C compressor
Address 09: Cent. Elect.  (J519)	Labels: 7H0-937-08x-09.clb
	Part No SW: 7H0 937 090	HW: 7H0 937 090
	Component: BCM PQ25 Max4 H72 0708
	Revision: B9072001
	Coding: 3AB0293F48E12400B3280FB07EEB9ED95FC0412F7E840040200000020000
	Shop #: WSC 00788 648 00255
	VCID: EB99D4AF9E06E016B6310D093-80BE
	Subsystem 1 - 	Part No SW: 1K0-955-559-AH	Labels: 1K-09-01.lbl
	Component: RLS 241012 0554  0403
	Coding: 02302D
	Subsystem 2 - 	Part No SW: 6R0-959-801-AB=Ì}ÐÈ;J386__TSG_FT 008 1621	Labels: 6R-09-02.lbl
	Component: J386__TSG_FT 008 1621
	Coding: 58BC30
	Subsystem 3 - 	Part No SW: 6R0-959-802-AD-AB	Labels: 6R-09-03.lbl
	Component: J387__TSG_BT 008 1621
	Coding: 58BC30
	Subsystem 4 - 	Part No SW: 1K8-951-171-A
	Component: DWA-Sensor 00001 0103
	Subsystem 5 - 	Part No SW: 1K0-951-605-C
	Component: LIN BACKUP HOH05 1501
	Subsystem 6 - 	Part No SW: 1K8-951-171-A
	Subsystem 7 - 	Part No SW: 5K0-959-542-B
	Component: E221__MFL-TASH30 0032
	Coding: 830000
Address 10: Park/Steer Assist  (J446)	Labels: 6R0-919-475.clb
	Part No SW: 6R0 919 475 C	HW: 7E0 919 475
	Component: PARKHILFE 4K  H11 0013
	Revision: --------
	Coding: 108104
	ASAM Dataset: EV_VW250ParkiAssis2 S01008
	ROD: EV_SE250ParkiAssis2.rod
	VCID: 3E3FADFB3DF43DBEC16FBCE58-806B
Address 15: Airbags  (J234)	Labels: 5K0-959-655.clb
	Part No SW: 6R0 959 655 K	HW: 6R0 959 655 K
	Component: VW10Airbag01S H10 0020
	Revision: --------
	Coding: 003153
	ROD: EV_AirbaVW10BPAVW250_VW25.rod
	VCID: 4AD7F12B713C811E6DE720754-801F
	Subsystem 1 - 	Serial Number: 3575HRB40064UNBCA1PT
	Subsystem 2 - 	Serial Number: 3585HRB401I4UOJA90UA
	Subsystem 3 - 	Serial Number: 3515RRB400E4UOFEI9RN
Address 17: Instruments  (J285)	Labels: 5K0-920-xxx-17.clb
	Part No SW: 6R0 920 870 C	HW: 6R0 920 870 C
	Component: KOMBI         H05 0607
	Coding: 140A01
	ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
	VCID: 352DB2D708C2FEE610155B715-8060
Address 19: CAN Gateway  (J533)	Labels: 6N0-909-901-19.lbl
	Part No SW: 6N0 909 901	HW: 7H0 937 090
	Component: GW-K-CAN TP20 H72 0708
	Revision: B9072001
	Coding: 002000
	VCID: F0A3C3C3B72003CE8363424D2-80A5
Address 25: Immobilizer  (J334)	Labels: 5K0-920-xxx-25.clb
	Part No SW: 5K0 953 234	HW: 5K0 953 234
	Component: IMMO          H05 0607
	VCID: EA97D1AB91FCE11ECD2700F54-80BF
Address 2E: Media Player 3  (J650)	Labels: 5N0-035-342.lbl
	Part No SW: 5N0 035 342 F	HW: 5N0 035 342 F
	Component: SG EXT.PLAYER H19 0550
	Revision: A1001003
	Coding: 020100
	VCID: 2A1791ABD17CB91E8DA7C0F54-807F
Address 37: Navigation  (J794)	Labels: 1K0-035-27x-37.clb
	Part No SW: 3C8 035 279 A	HW: 3C8 035 279 A
	Component: RNS315-EU
	Coding: 040004110200010000001308
	ROD: EV_RNS315EUV2UDS.rod
	VCID: 29156EA7D47AAA06849DD7E19-807C
Address 44: Steering Assist	Labels: 6Q0-423-156.clb
	Part No SW: 6R0 423 156 C
	Component: LenkhilfeTRW        V278
	Coding: 11241
	Shop #: WSC 00788 000
	VCID: 302383C3F7A057CE43E3024D2-8065
Address 61: Battery Regul.  (J840)	Labels: 1K0-907-534.clb
	Part No SW: 7H0 907 534	HW: 7H0 937 090
	Component: Batt.regelung H72 0708
	Coding: 032B7A64
	Subsystem 1 - 	Part No SW: 6R0-915-181-E
	Component: J367-BDM     H08 0181
cilitkas
LT
any update?
