'04 A8L 4.2L throttle tip-in issue
terbogoat
C?ID=263032
The new MAF sensor seems to have fixed the issue regarding DTC 17743. It happened twice more (on the same grade near our home) before installing the new part; it has not recurred since.
Regarding the tip-in issue, that remains unchanged. However, a momentary lean code developed on bank 1. I discovered that the intake manifold bolts were not very tight. In fact I was able to remove one of them on the bank 1 side with my fingers. It passed the smoke test earlier so I failed to take a closer look.
So I'm in the middle of replacing those gaskets as well as the valley pan gasket which is beginning to weep oil. I'm replacing the front O2 sensors too as long as I'm there, and all indications are that they are the originals.
Furthermore, the crankcase vent valve had a failed diaphragm, allowing constant venting to/from atmosphere. I don't know if that was a factor; certainly it wasn't helping.
Uwe and Jack, again, thanks for the guidance!
Mike
   #22
:thumbs:
Mike
This is why a smoke test is bad and I do not use..........and it never beats the pressurized garbage bag test to create an atmosphere of magical chemicals or mighty vac
   #23
terbogoat
C?ID=263032
Hi, I'm back.
The repairs that I made, while necessary, did not fix the hesitation issue.
I tried puffing propane around the areas of possible vacuum leaks on bank 1 with no indication that the O2 sensor smelled anything.
My wife reports that the first time the MIL illuminated, she was puttering around town at low speed/throttle. The second time she was stationary idling in Drive. No driveability symptoms were noticed when the MIL came on.
The long term fuel trim readings are also quite different for banks 1 and 2. Bank 1 is -0.4% and 13.3% (additive and multiplicative, respectively). Bank 2 is 3.2% and 3.1%.
Is it possible that an injector on that bank is lazy or partially clogged, causing fuel to be added? I wondered if VCDS could be used to perform a cylinder balance test, but no lack of smoothness is ever noted so perhaps such a test would not reveal anything.
To recap, I have replaced the MAF sensor (it fixed the 17743 issue), IM gaskets, front O2 sensors, crankcase vent valve and the spark plugs.
Thanks... Mike
VCDS Version: Release 15.7.4 Running on Windows Vista x86
Data version: 20160216
Sunday,01,May,2016,13:41:01:51993
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
          47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAUML44E44N014589   Mileage: 205300km-127567miles
Address 01: Engine        Labels: 077-910-560-BFM.lbl
   Part No SW: 4E0 910 560 A    HW: 4E0 907 560
   Component: 4.2L V8/5V      G   0070
   Revision: 00000000    Serial number: AUX3Z0CN528115
   Coding: 0007773
   Shop #: WSC 02313 785 00200
   VCID: 1F4D81B0CE76C5C667-804A
17536 - Fuel Trim; Bank 1 (Mult)
            P1128 - 001 - System too Lean - Intermittent - MIL ON
   Part No SW: 4E0 910 156 E    HW: 09E 927 156 A
   Component: AG6 09E 4,2L5V USA  0110
   Revision: 00000001    Serial number:        0024615
   VCID: 24478E5CE710E61E3A-8070
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 BC
   Component: ESP 5.7 allrad  H44 0510
   Coding: 0007597
   VCID: 224B8844FD04E82E48-8076
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 A
   Component:     FBS AUDID3  H03 0130
   Revision: 01303703    Serial number: AUX3Z0CN528115
   Coding: 0263168
   Shop #: WSC 02311 785 00200
   VCID: 58BFEAACEBD872FE66-800C
00171 - Key 1 not learned
                    Fault Frequency: 0
                    Reset counter: 113
                    Mileage: 205120 km
                    Date: 2016.04.26
                    Time: 16:19:12
   Part No SW: 4E0 910 760 C    HW: 4E0 959 760
   Component: Sitzmemory BFS H07  0060
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 3940448
   Shop #: WSC 00000 785 00200
   VCID: 23458D40E21EE12643-8076
Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
   Part No SW: 4E0 910 729 J    HW: 4E0 035 729
   Component: Interfacebox    H43 0600
   Revision: 00000000    Serial number: 346KT037507830
   Coding: 0000103
   VCID: 2F6D7170BED65546D7-807A
   Subsystem 1 - Part No: 4E0 910 609 A
   Component: Bedienteil MMI  H42 0020
   Subsystem 2 - Serial number: 301KM037528811
   Subsystem 3 - Serial number: 7411.11.030000000000010097ÿ
   Subsystem 4 - Serial number: 010097ÿ
   Part No SW: 4E0 910 043     HW: 4E0 820 043 B
   Component: KLIMAAUTOMAT    016 0240
   Revision: 00000022    Serial number: 00000000030152
   Coding: 1085761
   VCID: 5ABBF0A495D460EE50-800E
   Subsystem 1 - Part No: 4E0 910 772 A
   Component: Sitzluefter  FS H01  010
   Subsystem 2 - Part No: 4E0 910 772 A
   Component: Sitzluefter BFS H01  010
   Subsystem 3 - Serial number: 898053000
   Subsystem 4 - Serial number: HO12112003065A000000000035ÿ†89
   Subsystem 5 - Serial number: 000035ÿ†898053000      000-SHO
   Subsystem 6 - Serial number:     000-SHO12112003065A00000000
   Subsystem 7 - Serial number: 65A000000000023ÿ
00003 - Control Module
                    Fault Status: 00100011
                    Reset counter: 110
                    Mileage: 205070 km
                    Date: 2016.04.23
                    Time: 22:05:01
                    Temperature: 19.0°C
Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
   Part No SW: 4E0 910 279 E    HW: 4E0 907 279 E
   Component: ILM Fahrer      H11 0100
   Coding: 0111113
   VCID: 2A5B60648534306E00-807E
   Subsystem 1 - Part No: 4E1 910 113
   Component: Wischer WWS D3  H30 0320
   Coding: 00000030
   Shop #: WSC 02311
   Part No SW: 4E0 910 111 C    HW: 4E0 035 111
   Component: CD-Changer      H43 0340
   Revision: 00000501    Serial number: AUZ5ZBC1026285
   VCID: 1939AFA8D052ABF699-804C
Address 15: Airbags        Labels: 4E0-910-655-84.lbl
   Part No SW: 4E0 910 655 A    HW: 4E0 959 655 E
   Component: Airbag 8.4E+    H10 0920
   Coding: 0530707
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549 A
   Component: Lenksäulenmodul H12 0040
   Coding: 0012241
   VCID: 65C1D358ACAADF16ED-8030
   Component: Lenkradmodul    H03 0070
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 900     HW: 4E0 920 950 B
   Component: KOMBIINSTR. VDO H44 0080
   Revision: D13         Serial number: AUDID3CN004124
   Coding: 0016233
   Shop #: WSC 04344 002 1048576
   VCID: 5CB7F6BC9FE09EDE42-8008
Address 19: CAN Gateway        Labels: 4E0-910-468.clb
   Part No SW: 4E0 910 468 A    HW: 4E0 907 468 C
   Component: Gateway         H07 0030
   Revision: 07          Serial number: 0200503A100CBB
   Coding: FCFE7BDD1B2304
   VCID: 26439454912C140E24-8072
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Coding: 0263168
   XXXXXXXXXXX ELV                 XXXX
                    Fault Frequency: 0
                    Reset counter: 113
                    Mileage: 205120 km
                    Date: 2016.04.26
                    Time: 16:19:12
Address 34: Level Control        Labels: 4E0-910-553.lbl
   Part No SW: 4E0 910 553 E    HW: 4E0 907 553 E
   Component: LUFTFDR.-CDC    H05 4290
   Coding: 0015510
   Shop #: WSC 02301 444 66613
   VCID: 25419358EC2A1F162D-8070
01772 - Signal from Level Control Pressure Sensor (G291)
                    Fault Frequency: 7
                    Reset counter: 115
                    Mileage: 205114 km
                    Date: 2016.04.26
                    Time: 14:37:10
   Component: Sitzmemory FS  H07  0060
   Coding: 4071522
   Part No SW: 4E0 910 887 K    HW: 4E0 919 887 C
   Component: MNS US          H42 0570
   Revision: 00000000    Serial number: 355KQ037510860
   VCID: 356143185C8A6F969D-8060
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135
   Component: Dachknoten D3   H01 0090
   Serial number: 00000330900038
   Coding: 0003989
   VCID: 1D31BBB8C47AD7D675-8048
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802     HW: 4E1 959 801
   Component: Türsteuer.FS BRM005 0110
   Coding: 0028196
   VCID: 5EB3FCB489FC8CCE2C-800A
Address 46: Central Conv.        Labels: 4E0-910-289.lbl
   Part No SW: 4E0 910 289 A    HW: 4E0 907 289
   Component: Komfortgeraet   H03 0030
   Revision: 00300003    Serial number:  W040311070089
   Coding: 0065086
   VCID: 275D995096260D061F-8072
   Component: Heckdeckel   P14H06 0070
   Component: Neigungssensor  H02 0020
01134 - Alarm Horn (H12)
                    Reset counter: 74
                    Mileage: 174290 km
                    Date: 2014.12.03
                    Time: 13:01:00
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 H    HW: 4E0 035 223 B
   Component: DSP-High D3/AUX H13 0370
   Revision: Dev_D01     Serial number: 00000000573506
   Coding: 0000016
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H08 0020
   Revision:             Serial number: 00000000027105
   Coding: 0010111
   VCID: 1E33BCB4C97CCCCE6C-804A
   Subsystem 1 - Part No: 4E0 910 511 A
   Component: UGDO HL US      H02 0030
   Subsystem 2 - Serial number: VK4978T08JYE
                    Reset counter: 114
                    Date: 2023.06.06
                    Time: 00:00:00
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802     HW: 4E1 959 802
   Component: Türsteuer.BF BRM005 0110
   Coding: 0028196
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 A    HW: 4E0 907 801
   Component: EPB  AV1C1010   H01 1010
   Revision: AV1C1010
   Coding: 0000532
   Shop #: WSC 22102 384 58782
02596 - Rear Brake Pads Worn
                    Fault Status: 01111000
                    Reset counter: 194
                    Voltage: 9.83 V
                    Count: 61
Address 55: Headlight Range        Labels: 4E0-910-357.lbl
   Part No SW: 4E0 910 357     HW: 4E0 907 357
   Component: Pre-AFS         H01 0040
   VCID: 62CBC844BD84A82E08-8036
   Part No SW: 4E0 910 541 C    HW: 4E0 035 541
   Component: TUNER EU/US/RDW H41 0290
   Revision: 00000000    Serial number: 304KH037552140
   VCID: 204F824CF308FA3E5E-8074
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 A    HW: 4E0 915 181
   Component: ENERGIEMANAGER  H02 0230
   Revision: 00000000    Serial number: 00000005111827
   Subsystem 1 - Part No: 000 915 105 AK
   Component: von VA0  2343265789
   Coding: 303030393135313035414B56413032333433323635373839
   Shop #: WSC 57899 001 1048576
00532 - Supply Voltage B+
                    Fault Status: 00100001
                    Reset counter: 115
                    Mileage: 205277 km
                    Date: 2016.04.29
                    Time: 19:28:53
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 801 A
   Component: Türsteuer.HL BRM005 0110
   Coding: 0028196
   VCID: 5DB1FBB884FA97D635-8008
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273     HW: 4E0 907 273
   Component: Reifendruck 2   H01 0210
   Coding: 0212127
   Shop #: WSC 02301 444 54128
   VCID: 5FCDC1B08EF685C627-800A
01477 - System Switched Off
            000 -  -  - Intermittent
                    Fault Frequency: 12
                    Reset counter: 113
                    Mileage: 205070 km
                    Date: 2016.04.23
                    Time: 22:12:43
                    Temperature: 18.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Fault Status: 11100100
                    Reset counter: 72
                    Mileage: 205076 km
                    Date: 2016.04.26
                    Time: 11:04:02
                    Speed: 45.0 km/h
                    Temperature: 8.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 802 A
   Component: Türsteuer.HR BRM005 0110
   Coding: 0028196
Address 75: Telematics        Labels: None
   Part No SW: 4E0 910 616 A    HW: 4E0 035 616
   Component: Telematik USA1      0070
   Revision: 00000004    Serial number: 0000ATD3006073
   Coding: 0000005
   Shop #: WSC 05111 444 57921
   VCID: 21498748FB02F33651-5140
01531 - Emergency Battery
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
   Component: Parkhilfe 8-Kan H11 0010
   Revision: --.--.--    Serial number: 00000332100217
   Coding: 0001208
   VCID: 21498748F802F33651-8074
End-------------------------(Elapsed Time: 03:43)--------------------------
   #24
I am wondering if the old maf already damaged the OXS sensor. Yeah an injector could be an issue.
   #25
terbogoat
C?ID=263032
Hi Jack, no, that is not likely as I replaced the O2 sensors after I installed the new MAF sensor.
The old O2 sensor probes are identical in appearance, being light gray in color at the tip and black closer to the threaded portion. Also, the old spark plugs are uniform in appearance.
An observation: The tailpipes have a bit of black soot on them which returns after I wipe it off. The engine uses no oil so it has must be due to incomplete combustion.
Mike
   #26
I meant the rear unit OXS not front.
Fuel psi could be also lacking but usually would be across banks.
Have you verified booster circuit for a possible leak internally?
   #27
terbogoat
C?ID=263032
Jack, I was of the belief that the rear sensors merely reported cat performance. Are they also a player in the fuel trim decision making process?
Mike
   #28
ivagp
C?ID=95551
yes they can fine tune the fuel trim. can u please check cam phasers on both banks. u can usally find them group 90somethings. check them cold and hot. and also what jack said about brake booster.
   #29
The rear OXS sensors not only play a role in CAT monitoring, they are superior for trim control after being scrubbed by the CAT.
This is why tuners who delete the function of these OXS sensors after the CAT's........... are nothing but lazy!
   #30
terbogoat
C?ID=263032
Here is a (crude) snapshot of the cam phaser data. The phase position of banks 1 and 2 appear to my untrained eye to be way different from each other. Unless I did not dig deep enough, I didn't find an explanation in The Fine Book. Mike
terbogoat
C?ID=263032
OK, thanks, I'll have a look at the timing marks.
Could an incorrect cam position on bank 2 be causing the hesitation symptom and/or could it be related to the lean condition on the opposite bank? ...or am I looking at two separate issues? I expect that the bank 1/bank 2 problems are unrelated, but then again I'm rarely accused of being an Einstein.
   #33
It might be related and it might not.
Cam duration/lift/timing, do effect vacuum in the intake, and could very well upset the mixture if not in sync.
   #34
terbogoat
C?ID=263032
Alright, thanks, I'll get the cam alignment issue corrected and then go from there.
   #35
terbogoat
C?ID=263032
Detours popped up along the way but I finally got it done.
Tuesday,02,August,2016,19:19:01:51993
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 16.8.0.1
Data version: 20160801 DS254
VIN: WAUML44E44N014589   License Plate:
VIN: WAUML44E44N014589   Mileage: 205670km-127797miles
   Coding: 0007773
   VCID: 1F4D81B0CE76C5BABB-804A
   VCID: 24478E5CE710E662E6-8070
   Coding: 0007597
   VCID: 224B8844FD04E85294-8076
   Coding: 0263168
   VCID: 58BFEAACEBD87282BA-800C
                    Fault Frequency: 0
                    Reset counter: 121
                    Mileage: 205616 km
                    Date: 2016.07.31
                    Time: 19:04:22
   Coding: 3940448
   VCID: 23458D40E21EE15A9F-8076
   Coding: 0000103
   VCID: 2F6D7170BED6553A0B-807A
   Coding: 1085761
   VCID: 5ABBF0A495D460928C-800E
   Coding: 0111113
   VCID: 2A5B606485343012DC-807E
   Coding: 00000030
   Shop #: WSC 02311
   VCID: 1939AFA8D052AB8A45-804C
   Coding: 0530707
   Coding: 0012241
   VCID: 65C1D358ACAADF6A31-8030
   Coding: 0016233
   VCID: 5CB7F6BC9FE09EA29E-8008
   VCID: 26439454912C1472F8-8072
   Coding: 0263168
                    Fault Frequency: 0
                    Reset counter: 121
                    Mileage: 205616 km
                    Date: 2016.07.31
                    Time: 19:04:22
   Coding: 0015510
   VCID: 25419358EC2A1F6AF1-8070
                    Reset counter: 122
                    Mileage: 205609 km
                    Date: 2016.07.31
                    Time: 12:40:13
   Coding: 4071522
   VCID: 356143185C8A6FEA41-8060
   Coding: 0003989
   VCID: 1D31BBB8C47AD7AAA9-8048
   Coding: 0028196
   VCID: 5EB3FCB489FC8CB2F0-800A
   Coding: 0065086
   VCID: 275D995096260D7AC3-8072
                    Reset counter: 81
                    Mileage: 174290 km
                    Date: 2014.12.03
                    Time: 13:01:00
   Coding: 0000016
   Coding: 0010111
   VCID: 1E33BCB4C97CCCB2B0-804A
   Coding: 0028196
   Revision: AV1C1010
   Coding: 0000532
                    Reset counter: 194
                    Voltage: 9.83 V
                    Count: 61
   VCID: 62CBC844BD84A852D4-8036
   VCID: 204F824CF308FA4282-8074
   Coding: 0028196
   VCID: 5DB1FBB884FA97AAE9-8008
   Coding: 0212127
   VCID: 5FCDC1B08EF685BAFB-800A
                    Reset counter: 82
                    Mileage: 205596 km
                    Date: 2016.07.31
                    Time: 10:16:55
                    Speed: 91.0 km/h
                    Temperature: 24.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 0028196
   Coding: 0000005
   VCID: 21498748FB02F34A8D-5140
   Coding: 0001208
   VCID: 21498748F802F34A8D-8074
End-------------------------(Elapsed Time: 03:44)--------------------------
The cam sprockets were indeed out of alignment. They were tight to the shafts so I don't think they slipped. According to receipts, the timing service was done by an independent repair facility; perhaps they did not use alignment tools.
http://imgur.com/kn7ZtDj
http://imgur.com/a/qf4IX
Measurements are much better but not exact... I don't know what went wrong there, as I used the alignment bar and the crankshaft lock:
http://imgur.com/a/P6Xwb
The fuel trim readings have improved as well:
http://imgur.com/a/OYGxb
However, the tip-in hesitation/lurch issue remains in all it's glory... no improvement is evident.
I noticed that the ignition timing bounces around quite a bit at idle, with an approximate range of 6 to 17 degrees BTDC. Is that a concern or is it normal?
Mike
P.S. I checked the brake booster and associate plumbing per previous advice... it is is great shape.
