AC compressor is not turning ON / A6 C5 Allroad 2.7t
Molemans
C?ID=215708
Hello Guys,
when turning the AC On, the compressor does not turn on.
After I connect my vcds cable and check for faults, there is no fault stored in HVAC 08 control unit.
when turning on the AC, the measuring blocks shows the following:
Group 001:
Valve n280 current (blank) Regulating valve 280 (100%) refrigerant circuit pressure 7 bar
the G65 shows a percentage of 26%
I need help on how to get my ac running again, can someone help.
Thank you in advance.
DrPeter
16.4905° S, 151.7375° W
Could you pleas provide us with an Auto-Scan of the vehicle so we can have some more information about the vehicle.
Also could you have a look in Measuring Value Block Group - [002] and post the values while trying to operate the AC.
Thank you.
