Limp mode! APR Chipped!
skoukiadakis
Greece
C?ID=262443
Good morning to all!
Should I worry?
What is this?
Monday,18,January,2016,06:31:37:61255
VCDS Version: 15.7.3.0
Data version: 20151216
VIN: WVWZZZ6RZBY199045   License Plate:
Chassis Type: 6R (6N0)
Scan: 01 02 03 08 09 10 15 17 19 25 44 55 0B
VIN: WVWZZZ6RZBY199045   Mileage: 54070km-33597miles
Address 01: Engine (J623-CAVE)       Labels: 03C-907-309-V1.clb
   Part No SW: 03C 906 027 AR    HW: 03C 906 027 AR
   Component: 1.4l R4 TSI   H15 9971
   Revision: L2H15---    Serial number: 00000000000000
   Coding: 00250012002400000000
   Shop #: WSC 00017 666 02801
   ASAM Dataset: EV_ECM14TSI01103C906027AR 001014
   ROD: EV_ECM14TSI01103C906027AR.rod
   VCID: 71E9B694A0465DB68E-8024
4043 - Boost Pressure Regulation
          P0234 00 [101] - Limit Exceeded (Overboost Condition)
                    Mileage: 54053 km
                    Date: 2016.01.17
                    Time: 19:52:24
Readiness: 0000 0001
   Part No SW: 0AM 300 050 K    HW: 0AM 927 769 D
   Component: GSG DSG AG7     403 9032
   Revision: 00040034    Serial number: TFK01012130269
   Shop #: WSC 22643 000 1048576
   VCID: 31697694ABC61DB6CE-5124
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0001
   Revision: --------
   Coding: 210248E3417602BB842512E682D640411700
   Shop #: WSC 00788 648 00255
   VCID: 071DF84CB2C2730630-8052
Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
   Part No SW: 6R0 907 044 E    HW: 6R0 907 044 E
   Component: Climatronic   H09 0609
   Revision: V0000000
   VCID: 356142849CAE319692-8060
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 089 D    HW: 7H0 937 089
   Component: BCM T5GP Li4  H47 0230
   Revision: BS047001    Serial number: 0398 334100688
   Coding: 3DB029BF08F324009A2808B17C2B0DD05AC0670F60051041200000000000
   Shop #: WSC 124697 483 00190
   VCID: 377D488C86A2C38680-8062
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  007 1621
   Coding: 08BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  007 1621
   Coding: 08BC30
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Component: LIN BACKUP HO  H11 9005
   Subsystem 5 - Part No SW: 6R0 959 591 A    HW: 7P0 959 591
   Component: J245 PS72.015  H05 0006
   Coding: 081001
   Subsystem 6 - Part No: 1K8 951 171 A
   Subsystem 7 - Part No SW: 5K0 959 542     HW: 5K0 959 542
   Component: E221__MFL-TAS  H06 0010
   Coding: 830000
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 B    HW: 7E0 919 475
   Component: PARKHILFE 4K  H10 0012
   Revision: --------    Serial number: 12831100507630
   Coding: 108104
   ASAM Dataset: EV_VW250ParkiAssis2 S01008
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3D715AA4AC9EE9D65A-8068
   Part No SW: 6R0 959 655 M    HW: 6R0 959 655 M
   Component: VW10Airbag012 H09 0020
   Revision: --------    Serial number: 003GZ0006BWH
   Coding: 003132
   ROD: EV_AirbaVW10BPAVW250_SE25.rod
   VCID: 4C970760E724505EDD-8018
   Serial number: 3575HRB406509RECAH8F
   Serial number: 3585HRB406109REC297
   Serial number: 3515RRB405709GGUGHB
   Serial number: 3525RRB405B09GGU5OD+
   Part No SW: 6R0 920 870     HW: 6R0 920 870
   Component: KOMBI         H20 0320
   Coding: 140E00
   VCID: 72EBB998A54066AE77-8026
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 7H0 937 089
   Component: GW-K-CAN TP20 0230
   Coding: 002000
   VCID: 70EFB390A34C54BE81-8024
   Component: IMMO          H20 0320
   VCID: 6ADBA1F88D90AE6ECF-803E
   Part No: 6R0 423 156 B
   Component: LenkhilfeTRW        V277
   Coding: 11241
   Shop #: WSC 00788
   VCID: 2F6D70ECEAF20B46D8-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Part No SW: 6R0 907 357     HW: 6R0 907 357
   Component: LWR-ECU       H02 0070
   Coding: 0110000001000000
   ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
   ROD: EV_HeadlRegulVWLWRPt_VW25.rod
   VCID: 77FD888CCE22038640-8022
End-------------------------(Elapsed Time: 02:57)--------------------------
Fix the over boost condition from stuck WG or faulty DV.
Jef
HQ
Yes, you should worry.
Is the N75 working correctly? You should be able to use the Output test to help locate the N75. Are the hoses to and from the N75 good?
Check the factory repair manual for details on testing the turbo's "vacuum unit". Basically, it making sure it moves.
By default boost is directed to the WG valve so it opens and blows off boost.......
The N75 closes this boost .......,however, "if stuck", will never direct boost to the WG spring moving it open: further because the spring PSI holds it shut, until boost is above spec, forcing it open.
skoukiadakis
Greece
C?ID=262443
I think that my next step is to change the n75 valve and the dv with brand new pieces,as I have never changed them!
Do you agree with that?
Nope.........
I think that you should test components and verify what is the actual problem verse just change parts .........but hey......... what ever you want.
Scorched Earth Parts change policy,........... is the most expensive, and sometimes isn't the solution.
