polo 6R power steering problem
MUROGIS
Pirate
Walking the Plank
Lithuania
Hello. Please help. I have changed power steering module 6r423156. Replaised with new TRW JER162. Now i have a fault 816.(Power Steering Sensor (G250): Open or Short to Plus ). But there no are sensor in steering column. Like I understand I have to change coding, but I need to login and I do not know the code and what parameters to change.
Am I right ? Can anyone help ?
DrPeter
16.4905° S, 151.7375° W
If you could post up an Auto-Scan of the vehicle in question, this will help us see the concerns, coding, etc...
In the meantime have a look at this Ross-Tech user manual page for more information about coding, VCDS could have a pop-up for coding options.
And, if you truly have a short to ground, this Ross-Tech form page about testing for short to grounds/positives, etc.. is a good place to start.
Hope this helps,
drpeter
MUROGIS
Pirate
Walking the Plank
Lithuania
Data from pirated copies of VCDS is not welcome here
AIB Wolfgang
Hi Murogis,
thats why there is allways the request for complete AUTO-SCAN. VIN to see the PR numbers and out of the scan, what devices are mounted.
maybe you have installed a wrong steering, because G250 must be mounted, after looking in the Repair manual
MUROGIS
Pirate
Walking the Plank
Lithuania
Data from pirated copies of VCDS is not welcome here.
AIB Wolfgang
Hello Murogis,
just looked for parts and wiring diagram:)
Correct parts number is 6R1 423 055 K
and on the top, your car is mounted with ABS / ESP and so in the WD the G250 is mounted in the Steering / top of the input shaft.
Think there are some things wrong
MUROGIS
Pirate
Walking the Plank
Lithuania
but until I have changed the modul I had not a fault 816.
A modul I have changed because I had a fault in CAN, now it is gone and is only fault 816.
MUROGIS
Pirate
Walking the Plank
Lithuania
I find out that my car is with ESP ant there are no sensor G250 at all. There is only sensor G85. But I have a fault with problem in sensor G250.
AIB Wolfgang
As Uwe mentioned:
