Hi!
First post here!
I would like some help with my climatronic fault codes!
This code appears only when the climatronic is on!
So I think I have to replace it!
But what about coding?
I have to use security access code!
First post here!
Wednesday,09,December,2015,06:20:39:61255
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
VIN: WVWZZZ6RZBY199045 License Plate:
Mileage: 52740km-32771mi Repair Order:
Chassis Type: 6R (6N0)
Scan: 01 02 03 08 09 10 15 17 19 25 2E 44 55 0B
VIN: WVWZZZ6RZBY199045 Mileage: 52740km-32771miles
Address 01: Engine (J623-CAVE) Labels: 03C-907-309-V1.clb
Part No SW: 03C 906 027 AR HW: 03C 906 027 AR
Component: 1.4l R4 TSI H15 9971
Revision: L2H15--- Serial number: 00000000000000
Coding: 00250012002400000000
Shop #: WSC 00017 666 02801
ASAM Dataset: EV_ECM14TSI01103C906027AR 001014
ROD: EV_ECM14TSI01103C906027AR.rod
VCID: 71E9B694A0465DB694-8024
Readiness: 1110 0101
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 050 K HW: 0AM 927 769 D
Component: GSG DSG AG7 403 9032
Revision: 00040034 Serial number: TFK01012130269
Shop #: WSC 22643 000 1048576
VCID: 31697694ABC61DB6D4-5124
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0001
Revision: --------
Coding: 210248E3417602BB842512E682D640411700
Shop #: WSC 00788 648 00255
VCID: 071DF84CB2C273062A-8052
Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb
Part No SW: 6R0 907 044 E HW: 6R0 907 044 E
Component: Climatronic H09 0609
Revision: V0000000
VCID: 356142849CAE319688-8060
Fault Status: 00101101
Reset counter: 236
Mileage: 52722 km
Date: 2015.12.08
Time: 22:32:16
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 089 D HW: 7H0 937 089
Component: BCM T5GP Li4 H47 0230
Revision: BS047001 Serial number: 0398 334100688
Coding: 3DB029BF08E124009A2808B17C2B0DD05AC0670F60051041200000000000
Shop #: WSC 124697 483 00190
VCID: 377D488C86A2C3869A-8062
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 007 1621
Coding: 08BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 007 1621
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Component: LIN BACKUP HO H11 9005
Subsystem 5 - Part No SW: 6R0 959 591 A HW: 7P0 959 591
Component: J245 PS72.015 H05 0006
Coding: 081001
Subsystem 6 - Part No: 1K8 951 171 A
Subsystem 7 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H06 0010
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 B HW: 7E0 919 475
Component: PARKHILFE 4K H10 0012
Revision: -------- Serial number: 12831100507630
Coding: 108104
ASAM Dataset: EV_VW250ParkiAssis2 S01008
ROD: EV_VW250ParkiAssis2.rod
VCID: 3D715AA4AC9EE9D640-8068
Part No SW: 6R0 959 655 M HW: 6R0 959 655 M
Component: VW10Airbag012 H09 0020
Revision: -------- Serial number: 003GZ0006BWH
Coding: 003132
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 4C970760E724505EC7-8018
Serial number: 3575HRB406509RECAH8F
Serial number: 3585HRB406109REC297
Serial number: 3515RRB405709GGUGHB
Serial number: 3525RRB405B09GGU5OD+
Part No SW: 6R0 920 870 HW: 6R0 920 870
Component: KOMBI H20 0320
Coding: 140E00
VCID: 72EBB998A54066AE6D-8026
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 089
Component: GW-K-CAN TP20 0230
Coding: 002000
VCID: 70EFB390A34C54BE9B-8024
Component: IMMO H20 0320
VCID: 6ADBA1F88D90AE6ED5-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial number: 7669057627
VCID: 285F9BF05B1C5C7E03-807C
01304 - Radio
Reset counter: 197
Mileage: 52741 km
Date: 2015.12.09
Time: 06:12:47
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11241
Shop #: WSC 00788
VCID: 2F6D70ECEAF20B46C2-807A
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Coding: 0110000001000000
ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
ROD: EV_HeadlRegulVWLWRPt_VW25.rod
VCID: 77FD888CCE2203865A-8022
End-------------------------(Elapsed Time: 03:00)--------------------------
