Enable High Beam Assist- 2016 VW GTI- USA w/DAP
McSpiffy
Oswego, IL
C?ID=224526
Twelve choices listed for "Assistance light functions"
DV52
C?ID=194404
ZY7P2Z
Greetings: I attempted the High Beam Assist on my 2016 NAR Golf Sportwagen TSI SEL but ran into an issue when I followed the directions from post #29; it appears that the only option for headlight styles following this is the halogen whereas I have the bi-xenon. I did get the correct sub-menu to pop up in my MMI but each time I attempted to activate it, an error code would be thrown. I included the twelve different options under "Assistance Light Functions". Attempting the "IDE08786-ENG116637-Assistance light functions-Menueesteuerung Fernlichtassistent" will not provide an option for bi-xenon. Any insight would be appreciated!
McSpiffy (Jock?): I'm intrigued by your exercise! My understanding is that the Bi-Xenons for the mk7 come in 3 x separate versions (albeit the last two types physically look the same)
- Bi-xenon headlights
- Bi-xenon headlights with dynamic cornering light (AFS)
- Bi-xenon with dynamic light assist (DLA)
According to an earlier version of your autoscan, Btye 2 of the BCM was hex1A - so the pertinent Bits for the headlight functions was hex2 (i.e 010). This means according to the new "yellow" screens on the latest RT software, Xenon_AFS. This strongly suggests that your vehicle has the 2nd headlight fittings in the list above.
Your latest autoscan has Byte 2 = hex1B - therefore Bits0-2 are hex3 (i.e. 011), which means Xenon_AFS_and_main_beam_assist. So the BCM now thinks that it has to support the last headlight fitting in the list above.
According to VW:
The layout of the bulbs and the appearance of the bixenon
headlight with advanced frontlighting system
(AFS) and dynamic main beam control (MDF) is the
same as that of the bi-xenon headlight with AFS.
The design of the inside of this bi-xenon headlight is,
however, different. It features a group of individually
moveable screens which can be swivelled into the
light cone cast by the main beam lamp. 
The dynamic main beam control function, that is, the
partial masking of certain areas of illumination, is
implemented through a combination of the screens
and the horizontal adjustment of the module.​
So herein lies my confusion - if the "innards" of the MDF version of the bi-xenon headlights are different to the version in your car, changing the BCM code to operate main-beam-assist would appear to be inherently problematic.
Or have I missed something - entirely likely?
McSpiffy
Oswego, IL
C?ID=224526
Don, thanks for the prompt reply!
I didn't see an option for bi-xenon, only the standard lamps. I'm wondering if I should pick one of the eleven other options under "Assistance Light Functions" to see if the bi-xenon is there.
The only difference between my earlier and latest autoscan is my resetting of the original parameters and removing any error codes.
What are the new "yellow" screens you refer to in the latest RT software?
Thanks again and I look forward to your reply!
P.S. The McSpiffy derives from an adult Scouting program (WoodBadge); we were the Beaver Patrol and each of us had to personalize our mascot as a signature. Since I bagpiped, I had a bagpiping beaver as my signature (kinda like McSquizzy from the animated movie "Open Season") http://openseason.wikia.com/wiki/File:Quizzy3.jpg
   #44
DV52
C?ID=194404
McSpiffy: The yellow screens are described HERE - but as Uwe has confirmed, only available to the HEX series products
Here's the options under Byte 2, Bits 0-2 (from another cable)
No Function=hex0
Basic_FLA=hex1
AFS,BCM-Highbeam=hex2
AFS,FLA,BCM-Highbeam=hex3
AFS,Highbeam+ueber AFS=hex4
AFS, FLA Highbeam+ueber AFS=hex5
AFS,FLA_High_beam(GLW,MDF)= hex6
And here's the VCDS "yellow" screen:
AFS, (Advanced Frontlighting System)-dynamic cornering light (Initialism for the cornering light CAN bus)
FLA (Main beam assist) Assistance system which supports the driver when changing from main beam to low beam headlights, in order to prevent dazzling other road users
PS: And in the words of Bayden Powell ............DYB DYB DYB (DOB?)!!!
McSpiffy
Oswego, IL
C?ID=224526
Surprise! More issues!!! High beam assist not working + tons more DTCs
Greetings:
So i thought my troubles were over after clearing the previous DTCs and restoring the car back to the previous coding (pre-Enable High Beam Assist efforts). Much to my chagrin, I still receive an error message when I first click on my high beams, even though there is no longer an option for High Beam Assist in the MMI. I put 1000 mi. on the car the past few days while traveling to visit my parents who live in NE Arkansas (8 hr trip from Chicago). Needless to say, I still have an issue with the A/C bug (cold air stops and I lose fan control option; however, restarting the car seems to resolve the issue). I did an oil change this evening and decided to run a VCDS scan . . . sixteen status malfunctions!!!! I've never had this many and they all say "missing message". Did I clear out something I wasn't supposed to? The only existing DTC from my previous efforts had to do with the humidity sensor (does anyone know where that is located?). I'm not sure if my headlight coding caused an issue or if it was possibly the detailers whom inadvertently sprayed something where it shouldn't have been . . .
Saturday,01,July,2017,22:38:11:06278
VCDS Version: 17.6.0.2 (x64)  HEX-NET CB: 0.4341.4
Data version: 20170602 DS274
VIN: 3VWC17AU4GM501532   License Plate: V93 8607
Mileage: 31994km-19880mi   Repair Order: 070117B
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 47 52 55 5F
          75 A5
VIN: 3VWC17AU4GM501532   Mileage: 31994km-19880miles
Address 01: Engine
   Part No SW: 09G 927 749 AP    HW: 09G 927 749 AP
   Component: AISIN AG6 G3  129 2943
   Coding: 010200000C000000000000000000000000000000
   Shop #: WSC 00066 790 00221
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW25.rod
   VCID: 075E5B89BE35B27F80-8052
   Revision: 00000000    Serial number: 61255000000354
   Coding: 04FA6AA12420096D007C020381C5292056249000408194B416435052C082
   Shop #: WSC 01383 790 50316
   VCID: 7AB8327DFDC7DF978F-802E
10 Faults Found:
8246 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:36:01
8250 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:36:02
8252 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
8254 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
8256 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:58
8258 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
8264 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
8351 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:59
16409 - Display for Tire Pressure Monitoring
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:36:07
16410 - Display for Tire Pressure Monitoring
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:36:07
   Revision: 00021000    Serial number: 0367374266
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3A38F27DBD471F97CF-806E
12716804 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
   Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
   Revision: 00001K01
   Coding: 02020024200100000105000012111402
   VCID: 42C88A9DD597575797-8016
459525 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
459023 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 86581605150679
   Coding: 00511B464041A2E969E44000001407001800000000000000000000000000
   Shop #: WSC 00066 790 00211
   ROD: EV_BCMBOSCH_015_VW37.rod
   Component: WWS    150430  043 0581
   Serial number:         150628095715
   Component: RLHS  037 0059
   Serial number: S5Y15M05D11H20M57S08
   Coding: 90A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H03 0004
   Serial number: 0000FST0009CPKU00000
   Coding: 191800
   Roof Blind:
   Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS22.409  H03 0004
   Serial number: 0000FST0009CQ2D00000
   Coding: 191800
7 Faults Found:
534549 - Databus
                    Fault Frequency: 11
                    Reset counter: 69
                    Mileage: 30204 km
                    Date: 2017.06.27
                    Time: 20:10:25
541973 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
559125 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:36:01
555541 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
542229 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
542485 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:36:01
                    Reset counter: 107
                    Mileage: 31152 km
                    Date: 2017.06.30
                    Time: 10:46:10
   Part No SW: 5Q0 919 298 K    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0054
   Revision: --------    Serial number: 39431513200575
   Coding: 0031165011
   ASAM Dataset: EV_EPHVA2CAU3700000 003021
   ROD: EV_EPHVA2CAU3700000_003_VW37.rod
   VCID: 47DE9B89FEB5727F40-8012
13637426 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
12648465 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0400
   Serial number: 13031503210237
   Coding: 01045400FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
10 Faults Found:
1066 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:58
                    Control Module temperature: 51 ∞C
                    Voltage terminal 15: 12.4 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s≤
1056 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:58
0276 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:58
0277 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:36:01
0278 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:36:01
0279 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
                    Control Module temperature: 50 ∞C
0280 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:36:01
0281 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
1050 - Transmission in Limp Mode
          P305B 00 [008] - -
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
1043 - Automatic Distance Control
          B10E7 F0 [008] - Disconnected
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:59:33
                    Control Module temperature: 53 ∞C
                    Voltage terminal 15: 12.2 V
   Serial number: 003GCR01Y1DL
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH0000J1500031ZIL0K
   Coding: 303137
   Subsystem 2 - Part No SW: -----------    HW: 480 002 305 15
   Serial number: 357000000000A560A418
   Subsystem 3 - Part No SW: -----------    HW: 480 002 205 15
   Serial number: 358000000000D0B06418
   Subsystem 4 - Part No SW: -----------    HW: 480 402 704 15
   Serial number: 3510002C91A91E714070
   Subsystem 5 - Part No SW: -----------    HW: 480 402 804 15
   Serial number: 35200029B1A87872711+
   Subsystem 6 - Part No SW: -----------    HW: 480 400 505 15
   Serial number: 3550002AF1A8787292DL
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 505 15
   Serial number: 3560002B31A878729376
   Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150328500718
   Coding: 0C10
   ROD: EV_SMLSVALEOMQB_VW37.rod
   VCID: 73A61F59DAADAEDFCC-8026
   Part No SW: 5G1 920 840 A    HW: 5G1 920 840 A
   Component: KOMBI         242 6420
   Coding: 0BA4111AED98CF0502886A0B5000000000000000
   Shop #: WSC 00066 790 00194
   VCID: 2502310124F9806F92-8070
16776971 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
16776988 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2223
   Revision: --------    Serial number: 22051510000845
   Coding: 0901000830085900FB00021A1C0F00000001050000000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 75A22141D4D9B0EFE2-8020
   Subsystem 2 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0040
   Serial number: 29150000641010105136
   Coding: 35FFFF
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0071941
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:36:00
                    Supply voltage: Terminal 30: 12.3 V
                    Terminal 15: On
   Revision: 00000000    Serial number: 15000127554002
   Coding: 5D00000000000000
   Shop #: WSC 00066 790 07025
   ROD: EV_ELVMarquMQB_004_VW37.rod
   VCID: 3424DC459F23E9E715-8060
12666369 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:56
                    ELV State: 04
                    Information Clamps: 77 60
                    CoCo State: A0 01
                    WFS State: 17 06
                    Vehicle speed: 0.00 km/h
                    Voltage: 6B
                    AD-Value H-bridge: 35
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 00
12666381 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
                    ELV State: 04
                    CoCo State: A0 01
                    WFS State: 17 06
                    Voltage: 6B
                    CAN signals: 00
Address 3C: Lane Change (J1086)       Labels:* None
   Component: HRE_Master    H11 0071
   Serial number: 0368374670
   Coding: 02011103
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3C34F465B77321A7DD-8068
   Lane Change Assistant 2:
   Serial number: 0506150605043U
   Coding: 003A13200000040000000000
   VCID: 43C68F99CA8D5E5F9C-8016
   Serial number: 00000000000001360106
   Coding: 011000
458803 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 1302
   ROD: EV_SteerAssisMQB.rod
6 Faults Found:
22272 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:58
                    Motor status: 00
                    Supply voltage: 12.25 V
                    Temperature: 52.0 ∞C
                    KFC: 57
                    KFA: 00 00
                    Environmental conditions: 20
                    uioUdNotFilt_xdu16: 12.30 V
                    uAdSensI_SwitchedKl30_xdu16: 12.31 V
22528 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:58
                    Motor status: 00
                    KFC: 58
                    KFA: 00 00
23040 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:58
                    Motor status: 03
                    System status: Driving mode
                    KFC: 5A
                    KFA: 00 00
22784 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:58
                    Motor status: 03
                    KFC: 59
                    KFA: 00 00
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 12.50 V
                    uAdSensI_SwitchedKl30_xdu16: 12.49 V
19460 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:59
                    Motor status: 03
                    KFC: 4C
                    KFA: 00 04
23296 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:36:01
                    Motor status: 03
                    KFC: 5B
                    KFA: 00 00
   Part No SW: 5Q0 035 456     HW: 5Q0 035 456
   Component: MIB2_lite_amp H20 0110
   Revision: 00000001    Serial number: VWZ8Z1FBA00BE4Z
   Coding: 2200000000AAAAAA000000000000
   ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 6D920921BC89782F1A-8038
   Serial number: 170615060504TQ
   Serial number: 00000000000001369331
   Coding: 091000
458803 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
   Coding: 061A00010B000400
   VCID: 40CC8095DB9B454781-8014
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
13705475 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
   Part No SW: 3Q0 035 876     HW: 3Q0 035 876
   Component: MU-S-NS-US    H25 0241
   Serial number: VWZAZ2R0154122
   Coding: 027302020000000051220002001808001F0100F401200105C6
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 71AA1551A0B19CCF3E-8024
   Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
   Component: ABT_Std-2_Nav  H52 1028
   Serial number: VWZ8Z9RFC000K0
   Subsystem 2 - Part No SW: 3G0 919 866 B    HW: -----------
   Component: NAR 2015/16  --- 0220
6708 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
                    Voltage terminal 30: 12.4 V
   Component: OCULowMQBUS   007 0564
   Coding: 02730202C2823A017F1E06000000
   Shop #: WSC 00066 790 00323
   ROD: EV_OCULowMQB_VW37.rod
0041 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:56
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000355732
   Coding: 0100000000020306000400010100000100
   ROD: EV_MFKBoschAU370.rod
3080192 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:58
                    Control Module temperature: 61 ∞C
                    Outside air temperature: 29.5 ∞C
                    Voltage terminal 15: 12.3 V
                    System run time: 1513.1 s
3670016 - Databus
                    Reset counter: 106
                    Mileage: 30278 km
                    Date: 2017.06.29
                    Time: 14:35:57
                    System run time: 1512.5 s
End----------(Elapsed Time: 02:03, VBatt start/end: 13.8V/13.7V)-----------
   #46
PetrolDave
Westbury, UK
C?ID=1423
VCDS stores a log of all coding & adaptation changes, have you checked that you have reverted all of the changes you made (and no others)?
   #47
McSpiffy
Oswego, IL
C?ID=224526
No - I haven't but now I will! Where would I find the logs (Applications>History Data)? I'm wondering why these would populate when my previous scan posted (#40) only showed "Relative Air Humidity Interior Sender: 1 Fault Found: 534549 - Databus U1121 00 [009] - Missing Message" - the only other change to the car was a APR Stage 1 coding by an installer. Is it possible that the programming done by the installer would have caused all the error messages (i.e. multiple missing message databus errors)?
   #48
DV52
C?ID=194404
McSpiffy: hello again. First-off, do you notice a pattern in your DTCs? Many of them have the following detail:
Mileage: 30278 km
Date: 2017.06.29
which means that these errors have occurred only once and on no subsequent ignition cycle since then. When you say "after clearing the previous DTCs and restoring the car back to the previous coding (pre-Enable High Beam Assist efforts)" - did this occur on this date and mileage?
Also, the second part of your quote above seems to be at odds with the code-string for your BCM - see below:
As Dave has suggested, might be prudent to look in the directory C:\Ross-Tech\VCDS\Debug. Find the files AdpLog.CSV and CodingLog.CSV which contain a complete record-set of all the changes that you made with your laptop. If you used a Beta version software for some changes, also look at C:\Ross-Tech\VCDS-Beta\Debug subdirectory for a duplicate set of files.
McSpiffy
Oswego, IL
C?ID=224526
Thank you Don and Dave for your helpful guidance! 062917 was the APR Stage 1 install - my previous VCDS scan was 062817 and the most-recent VCDS was last night (070117) so my thinking is that the APR installer was the source of the error codes. I'll peruse my Debugging files (thank you for pointing me in the right direction!) and see where I erred.
   #50
McSpiffy
Oswego, IL
C?ID=224526
Auto High Beam indicator displays in center cluster momentarily then Fault: Light Ass
Here is a list of the fault codes from my attempts at the HBA:
Address 09,5Q0 937 087 AA,channel IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,adapted from,Not Present ,to,present ,Thursday,22,June,2017,12:36:27:06278
Address 09,5Q0 937 087 AA,channel IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,adapted from,present ,to,present ,Thursday,22,June,2017,12:52:07:06278
Address 09,5Q0 937 087 AA,channel IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,adapted from,present ,to,Not Present ,Tuesday,27,June,2017,19:51:31:06278
Address 09,5Q0 937 087 AA,channel IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,adapted from,Not Present ,to,present ,Saturday,01,July,2017,22:29:14:06278
Address 09,5Q0 937 087 AA,channel IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,adapted from,Not Present ,to,present ,Saturday,01,July,2017,22:30:20:06278
Address 09,5Q0 937 087 AA,channel IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,adapted from,present ,to,Not Present ,Saturday,01,July,2017,22:33:03:06278
Address 09,5Q0 937 087 AA,channel IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,adapted from,Not Present ,to,present ,Friday,07,July,2017,18:04:26:06278
and my coding log:
Address 09,5Q0 937 087 AA,recoded (Long Coding),from,00511A464041A2E969E44000001407001800000000000000000000000000,to,00511B464041A2E969E44000001407001800000000000000000000000000,(00066/790/00211),Thursday,22,June,2017,12:55:02:06278
So should I switch my coding to the original line where the sixth alpha-numeric is an "A" instead of a "B"? Could this be the reason why an option for bi-xenon isn't displayed and all I get is for halogen? How do I go about changing the letter back?
I'm puzzled with the steps I've seen published since they don't match my vehicle. I make sure my light switch is off and I select control module>Common tab: 09-Cent. Elect.>Advanced Functions: Security Access-16 button>enter the code and select Do it!>select Advanced Functions: Adaptation-10 button>then select from a HUGE list of options IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent (instead of what most posts show as a simple "go to (2) Assistance light functions - menu light assistant and change to 'Present'. Am I misinterpreting the "09-Centreal Electronics adaptations: [2] Assistance Light Functions-Menuesteuerung Fernlichtassistent for the IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent that is listed in my huge dropdown window? Should I be doing the adaptation in a different menu of VCDS?
Don[/QUOTE]
   #51
DV52
C?ID=194404
McSpiffy: Great to hear from you again!! My apology if I'm getting this wrong, but I suspect that the problem here is the difference between the adaptation channel database and the code-string in a control module (I think). The two are entirely different albeit, I freely admit that I have never understood the fundamental reason why! Nevertheless, these two aspects of a control module are different and they are accessed in a different way.
Here's a visual instruction-set for how to change the code string on "the sixth alpha-numeric" (which nerds like me call the "lower nibble on Byte 2") from hexB to hexA. Please make sure that you use either a Beta, or release version 17.6 software - because this is the only way that you will access the now famous "yellow" long helper screens (and I assume that you are using a HEX series cable/dongle).
Hopefully the steps are self evident. If I have confused you, my apology - please ask for directions
PS: If you are using an older style HEX+CAN, you may still be able to access the options in the "pull-down" facility on the 2nd last picture using the traditional long coding helper screen . Give it a try!!
McSpiffy
Oswego, IL
C?ID=224526
That's AWESOME, Don! Thanks so much for clarifying (+visuals) . . . I'm starting to see the light! I guess my next question is should I go back and change the sixth alpha-numeric from a "B" back to an "A"?
   #53
DV52
C?ID=194404
MacSpiffy: Hi again. Was the word-play in your response a deliberate "paronomasia" (look it up), or was it an intentional pun? :facepalm:
If you have understood my visuals, you will see how easy it is to change the coding for Byte 2 - so yes, try restoring Byte 2 back to its original factory setting. If you haven't retrofitted any new headlight components to the car, then IMO it makes more sense to use the factory setting than a value that is meant for a higher-order piece of kit.
I'm not sure if you will get a an error message saying that re-calibration of the headlight range control modules is needed, but if it does - use the Ross Tech instructions HERE
McSpiffy
Oswego, IL
C?ID=224526
Don,
A new "wrinkle" in my latest adjustment is that my backup camera no longer functions; would one of the other options under Byte 2 allow for the backup camera?
   #55
DV52
C?ID=194404
Don,
McSpiffy: You are aware that the ONLY reason that I respond is because I like writing "McSpiffy"? ;)
Seriously tho, no - the software switches in Byte 2 are as follows (in English):
Suggestions: Do you have any DTCs? If so, perhaps you might share a copy of your auto-scan with us.
Also, a perusal of the "history" report for the changes that have been made by your cable might be useful. Not sure if you are aware of this facility, but look in the C:\Ross-Tech\VCDS\Debug sub-directory (and C:\Ross-Tech\VCDS-Beta\Debug sub-directory if you also have the Beta SW version loaded) on the laptop that you use to make changes. In that sub-directory, you should find AdpLog.CSV and CodingLog.CSV - open these files and check the records for unintentional tweaks.
   #56
McSpiffy
Oswego, IL
C?ID=224526
Backup camera no longer works and isn't recognized when selecting channel in VCDS
Since my recent change, I no longer have a backup camera functioning and now I have options under ACC for Eco/Normal/Sport . . . I don't recall having the choice previously.
Tuesday,18,July,2017,17:44:58:06278
Dealer/Shop Name: Moose Lodge VW Den
Mileage: 33052km-20537mi   Repair Order: 071817B
          75 A5
VIN: 3VWC17AU4GM501532   Mileage: 33052km-20537miles
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 F    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 091A00322464002F1000
   ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
   ROD: EV_ECM18TFS0208V0906264F.rod
   VCID: 3FCE8369A6653ABFF8-806A
   Coding: 030C0C
   Revision: 00001K01
   Coding: 005122464041A2E969E44000001407001800000000000000000000000000
   Coding: 90A8DD
   Sun Roof:
   Coding: 191800
   Roof Blind:
   Coding: 191800
534549 - Databus
                    Reset counter: 121
                    Mileage: 32152 km
                    Date: 2017.07.07
                    Time: 20:44:55
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 77
                    Mileage: 32316 km
                    Date: 2017.07.08
                    Time: 12:45:16
                    Reset counter: 124
                    Mileage: 32152 km
                    Date: 2017.07.07
                    Time: 20:46:01
   Coding: 0031165011
1542 - Sensor for Automatic Distance Control
                    Reset counter: 118
                    Mileage: 32741 km
                    Date: 2017.07.12
                    Time: 12:12:43
                    Control Module temperature: 33 ∞C
                    Voltage terminal 15: 13.7 V
                    Vehicle speed: 28.17 m/s
                    Acceleration: 0.02 m/s≤
   Occupant Detection:
   Coding: 303137
   Coding: 0C10
   Coding: 35FFFF
   Coding: 02011103
   Coding: 011000
   Coding: 1302
   Coding: 091000
   Coding: 2E0000
   Coding: 2E0000
End----------(Elapsed Time: 01:44, VBatt start/end: 13.4V/13.5V)-----------
McSpiffy
Oswego, IL
C?ID=224526
Don, thanks for the info. I do have a few DTCs
   Coding: 90A8DD
   Sun Roof:
   Coding: 191800
   Roof Blind:
   Coding: 191800
534549 - Databus
                    Reset counter: 121
                    Mileage: 32152 km
                    Date: 2017.07.07
                    Time: 20:44:55
                    Reset counter: 77
                    Mileage: 32316 km
                    Date: 2017.07.08
                    Time: 12:45:16
                    Reset counter: 124
                    Mileage: 32152 km
                    Date: 2017.07.07
                    Time: 20:46:01
                    Reset counter: 118
                    Mileage: 32741 km
                    Date: 2017.07.12
                    Time: 12:12:43
I'm not sure why Relative Air Humidity Interior Sender keeps popping up; as soon as I clear it, it re-appears.
My spare key is dead so I replaced the battery - still doesn't work. I'll need to pop the protective cap off my door handle and pair the key with the car (assuming it was done in the first place from the dealership . . . )
No idea why the heated passenger seat safety shut-off came up; could it be that my MacBook Air is too heavy and the seat sensed it?
The sensor for the ADC flashed while driving home from WI last weekend; it was during a driving rain so I'm guessing the conditions caused it to fail. The date/time coincide with the occurence and since restarting, the ADC works fine. I can probably clear that DTC.
Another "weird" thing that occurs when attempting the adaptations is that a VCDS coding error 81: RPM too high pops up when the engine is running with VCDS. When I shut off the engine but leave the ignition on, I'm able to have the coding accepted.
   #59
McSpiffy
Oswego, IL
C?ID=224526
Don: Do you have a favorite cigar, coffee or beer that I can send you for all your help?
(That applies to you too, Ewe, if you're in Chicago for the trade show this week!):popcorn:
   #60
DV52
C?ID=194404
McSpiffy: hmm......... not quite sure how to say this tactfully and I certainly don't intend any offense, but can you explain the curious value that has been applied to Byte 2 - see comparison table below
With your current setting for Byte 2 and by my reckoning - the binary string 00100010 means that BCM believes that the headlights are Xenon with AFS, the Brake control unit is not energized, the car has manual transmission and a manual spoiler is fitted! Shirley this can't be correct (except for the headlights)?
I'm totally confused!!!:confused:
