- Joined
- Jan 29, 2014
- Messages
- 21,923
- Reaction score
- 9,309
- Location
- Montgomery, NY, USA
- VCDS Serial number
- C?ID=57337
Well a few things......Heat and shield or rotation......
1. The foil or foil tape and shaped .........added to the module helps remove heat as an additional cooling source....sort of like an amp cooling fins.
2. The foil acts as a shield since the system is filled with moving parts and the particles are also flowing like a charge you get B+ creation.
An example of this can be seen in coolant sensor codes when anti freeze is contaminated.
Search it and quick result will show short to B+ codes but no one finds the voltage........
http://wiki.ross-tech.com/wiki/index.php/17664/P1256
Still misses the contaminated coolant in the wiki.......
Examples .......No shit you can measure the current with a meter..........
I have seen all kinds of havoc for improper shield.
Where a flywheel turning can hit the right resonance based on speed of RPM .......via induction, make a speedo or miles count operate....... not driving down the road.
A timing belt having a metal cover. and the belt being underside with steel belts while turning .....generate high tension arc's as if a secondary miss.
There are many insulators in the CVT and motion to break a field.......
T
https://en.wikipedia.org/wiki/Tesla_(unit)
I kind of wish the lightning strike voltage was a reportable event in the controller DTC log.
This makes me think that either the TCT sensor is bonkers maybe as aforementioned or you have a serious car blood clot.
Advised to observe flow and better observe the external filter kidney.
T
when the car was last driven, the temp within 5 minutes of the error, was 96*. i didnt get a full log or anything. i let the car sit until temps were 45* and the error still wouldnt clear, thats when i had the car towed for the last time. it hasnt been driven since then.
edit: just went outside to start it, car started right up (as usual) and no error. its so hard to pinpoint the cause to this error, really frustrating. ive never been stumped by a car in all my 15+ years of wrenching.
