Hi, like many users I've just downloaded Windows 10 & my installed VCDS didn't work.
So I uninstalled & reinstalled VCDS again.
Message displayed: Cannot complete the device driver install wizard was the first major error message - that set alarm bells.
The events TAB of the HEX-USB Properties displayed these two errors:
1. - Ross Tech HEX-USB Device USB\VID_0403&PID_FA24\RT000001 requires further installation.
2. _ Driver Management concluded the process to install driver NULL Driver for Device Instance ID USB\VID_0403&PID_FA24\RT000001 with the following status: 0x0.
I tried to do a port test on my car using my OEM VCDS cable - the error message was: "Ross Tech USB interface not found! USB Library Version 03.02.07 Interface: Not Found!
Major issues remain with VCDS drivers errors, I'm unable to use VCDS totally.
Is this just me - or have other users had this problem - noting my computer skills are sub-optimal.
Naturally happy to take advice here - thanks.
