Took an odd phone call today. Caller was dealing with a 2005 Touareg and the wipers didn't work, and could not scan address 68 - Wiper Electronics. If I understood him correctly, he got a used unit, no change. Got a second used unit that was tested prior to being removed and was confirmed to be a working unit, but once installed into the project vehicle, wipers did not work.
Noticed in the wiring diagram, the wiper motor, J400, has the Gateway wiring daisy chained off the radio. Odd, but whatever. Informed that the radio is in SAFE mode, but that shouldn't effect the wipers. Have the tech try to scan the radio, address 56. No luck. Remove radio and unplug. Wipers still not working.
So I start digging through the wiring diagram and put 2 and 2 together and notice, the wiper motor is on the Infotainment Gateway, not the Comfort Gateway. So more digging we start looking for other modules on the Infotainment Gateway:
Kind of worked our way through, did have a J602, but not a J702 or J499. The last item, the R12 is located in the right rear of the vehicle. Had to remove a few items to get to it and unplug it. With the Amplifier unplugged, the wipers started to work again. The R12 was corrupting the Infotainment Gateway, so no module on that network could communicate. Also learned that in address 19 - CAN Gateway, there was a fault code for the Infotainment Gateway.
The two big things to take away from this.... expect the unexpected... and knowing how to read the wiring diagrams can be the difference between a 20 minutes of diagnostics and 2 weeks of chasing your tail. I don't know how long the tech has been working on this prior to calling.
I swear, the Germans are still at war with us.
TLDR: wipers don't work, unplug amp.
- Tested power and ground, good. Even load tested with a fog light bulb, no problem.
- Checked Gateway wiring for voltage activity, checked out good.
- Telematics, J499
- Roof Display Unit, J702
- Vehicle Position Recognition Module (compass), J603
- Amplifier, R12
