VW MK5 GLI ABS swap. Please help
rjeffers2k4
C?ID=241366
Having issues uploading this pic. The PR code for the brakes is 1LV and VIN 3VWFJ71K69M035794 Eng/Tran code CCT KPV
   #22
rjeffers2k4
C?ID=241366
Code 113B600D492500FF881206ED921D0041B100 accepted. Ran scan again and everything that comes up is 0010
Wednesday,15,July,2015,19:17:22:47509
VCDS Version: 14.10.2.0
Data version: 20150311
VIN: 3VWFJ71K69M035794   License Plate:
Mileage: 158300km-98363mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 55 56 62 65
          72
VIN: 3VWFJ71K69M035794   Mileage: 158300km-98363miles
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 1K0 907 115 AE    HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0030
   Revision: AAH03---    Serial number: VWX7Z0H53ND86W
   Coding: 0403010A1C070160
   VCID: 69F74C7D40C07769D91-803C
008577 - Performance Malfunction in Cooling System
               P2181 - 000 -
                    Mileage: 158250 km
                    Time: 22:23:26
                    RPM: 2071 /min
                    Load: 83.5 %
                    Speed: 55.0 km/h
                    Temperature: 76.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 13.843 V
   Part No SW: 02E 300 051 C    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1815
   Revision: 05144002    Serial number: 00001006080718
   Shop #: WSC 04940 001 00001
   VCID: 130B4E9532CC1DB9C3D-8046
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Revision: 00H45001
   Shop #: WSC 39433 001 104857
   VCID: 7EDD0F21E94EE0D11C3-802B
7 Faults Found:
            000 -  -  - Intermittent
                    Reset counter: 254
                    Count: 7
                    Count: 14
                    Count: 12800
                    Count: 195
                    Count: 50176
                    Fault Status: 01100101
                    Reset counter: 0
                    Mileage: 158231 km
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 279
                    Count: 49920
                    Reset counter: 0
                    Mileage: 158231 km
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 270
                    Count: 49920
                    Reset counter: 1
                    Mileage: 158300 km
                    Count: 7
                    Count: 12
                    Count: 12288
                    Count: 212
                    Count: 43008
                    Count: 1
                    Reset counter: 1
                    Mileage: 158300 km
                    Count: 7
                    Count: 12
                    Count: 12288
                    Count: 211
                    Count: 43008
                    Count: 1
02085 - Incorrect Control Module Installed
                    Reset counter: 1
                    Mileage: 158300 km
                    Count: 7
                    Count: 12
                    Count: 12288
                    Count: 204
                    Count: 43008
                    Count: 1
                    Reset counter: 254
                    Mileage: 158231 km
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 291
                    Count: 49920
   Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
   Component: Climatic PQ35   142 1111
   Revision: 00142031    Serial number: 00000000000000
   VCID: 7CD905293F52F2C1327-8029
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Revision: 00H54000    Serial number: 00000001005035
   Coding: 17058E234004150007140000001400000028770B5C000120000000000000
   VCID: 71C7241D68108FA9911-8024
   Component: Wischer 200808 021  0501
   Coding: 00038805
   Shop #: WSC 00066
   Revision: 05034000    Serial number: 003B6M06CYT.
   Coding: 0013889
   VCID: 6CF935694F326241A27-8039
   Subsystem 2 - Serial number: 6332MSME3B336E55L
   Subsystem 3 - Serial number: 6342MSME3B344B7AP
   Subsystem 4 - Serial number: 6351HSME1725327A4
   Subsystem 5 - Serial number: 6361HSME17251D197
   Subsystem 6 - Serial number: 63727SME1671006E
   Subsystem 7 - Serial number: 63827SME16700526V
   Part No SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
   Coding: 0012121
   VCID: 04297DC947A28A014A7-8051
   Part No SW: 1K6 920 974 H    HW: 1K6 920 974 H
   Component: KOMBIINSTRUMENT VDD 2416
   Revision: V0003000    Serial number: VWX7Z0H53ND86W
   Coding: 0023203
   Shop #: WSC 05074 444 67019
   VCID: 3957DC3D70E007E9691-806C
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 010708F2000370
   Coding: ED817F074002121002
   VCID: 354FD00D5CF8E3898D9-8060
   Component: IMMO            VDD 2416
   Part No SW: 5N0 035 342 A    HW: 5N0 035 342 A
   Component: SG EXT.PLAYER H13 0062
   Revision: A1001003    Serial number: 7667013716
   VCID: 256F004D2C5893093D9-8070
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3C0 035 684 B    HW: 3C0 035 684 B
   Component: RNS-MID       H02 0360
   Revision: AB001001    Serial number: VWZ6Z7J6363040
   Coding: 040004000400000200
   Shop #: WSC 03203 444 53622
   VCID: 22651B513D76643158B-8077
                    Reset counter: 40
                    Mileage: 158224 km
   Revision: 72009005    Serial number: 00000526188726
   Coding: 0001205
   VCID: 6FC322657E249959875-803A
   Part No: 1K0 909 144 C
   Revision: 00H15000
   VCID: 2A75F3718546BC7110B-807F
                    Fault Status: 11100101
                    Mileage: 158231 km
                    Time: 04:48:19
                    Battery Volts: 13.8 V
                        DU
                    Temperature: 36.0°C
                    Count: 3
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Coding: 13900F880186281B0904058FB0880F0488DC00
   Revision: 72009005    Serial number: 00000786588731
   Coding: 0001204
   VCID: 70C12119631A86A19EF-8025
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74C92D091702BA817A7-8021
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
                    Reset counter: 40
                    Mileage: 158224 km
   Revision: 12006001    Serial number: 00000003347050
   Coding: 0001168
   VCID: 76CD1701017EA891443-8023
   Coding: 0100101
   Revision: 12006001    Serial number: 00000003355434
   Coding: 0001168
   VCID: 77D31A050674D1995F5-8022
End-------------------------(Elapsed Time: 01:35)--------------------------
That's because you have to complete all the adaptations before next key cycle or hardware is wrong.
   #24
rjeffers2k4
C?ID=241366
Shows code accepted and ABS and BRAKE lights stop flashing. The beeping stops. Then the chimes start again. And I check the code for ABS and it shows all 00000000 again.
   #25
Yes because you didn't complete the ADP while in the session or the hardware is incorrect.
   #26
rjeffers2k4
C?ID=241366
UPDATE: So, I got the code accepted and completed adaptions. Car is now light indicator free and beep free. Thank you all for your assistance on this issue. I love forums and will continue to share my knowledge in forums to assist others. Thanks again.
