Error 152 and 156 while updating MMI to 4610
terrya6c6
Canada
C?ID=233251
I have a 2007 Audi A6C6 4.2. My iPhone 4s has to be paired each time and I am unable to access many of the phone functions in the MMI. So I updated the MMI software first to 3360 and then attempted disc 1 of 4610. I keep getting error 152 or 156 from device. In short disc 1 will not update the Handyvorb from 700 to 999. Disc 2 installed without issue. Does anyone have any insights into what my problem might be.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Due to the lack of vehicle information - represented by an Auto-Scan - your questions are really tough (if not impossible) to answer. In general your problem lacks any relation to VCDS at this point and in fact the issues you are experiencing are 100% caused by ignoring the instructions Audi has provided for these updates. Wanna bet that you didn't even have a decent battery charger connected? It wouldn't be the first time an incorrectly applied update blows a telephone module, in that case it would be 100% your fault... But the again, this is all guessing due to the lack of vehicle information...
terrya6c6
Canada
C?ID=233251
Thanks.
I spent several weeks reading forums on updating the MMI software before I attempted the update. As I mentioned the update to 3360 did run without a hitch. On updating to 3360, I was for the first time able to pair my iPhone. Unfortunately the update to 4610 - CD1 is problematic it starts to load before giving an error message. Errors 152 156 160. Each time the Battery was being charged by a 6 amp battery charger. I did read all the instructions several times before each attempt as I had read that one could brick the Bluetooth unit. Being a beginner at using the vag com my early attempts at scanning indicated that the Bluetooth module is working just fine. But then again I am probably missing something. I appreciate the feedback. I am a beginner when it comes to Audis and the Vag com scanning tools. Any help is appreciated and apologies for not attaching a scan in the original.
Saturday,28,February,2015,10:59:37:40091
VCDS Version: 14.10.1.1 (x64)
Data version: 20150130
VIN: WAUEV74F17N007807   License Plate:
Mileage: 118050km-73352mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 37 42 46 47 4F 52 53
          55 56 61 62 67 72 77
VIN: WAUEV74F17N007807   Mileage: 118050km-73352miles
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: None
   Part No SW: 4F1 910 560 A    HW: 4F1 907 560
   Component: 4.2l V8/4V          0030
   Revision: --H03---    Serial number:
   Coding: 01050009190F0120
   Shop #: WSC 91445 999 84053
   VCID: 2149D716F855712941E-8074
   Part No SW: 4F2 910 156 H    HW: 09L 927 156 C
   Component: AG6 09L 4,2lFSI USA 0010
   Revision: --H01---    Serial number:        4184607
   Shop #: WSC 02325 785 00200
   VCID: 2A5B303A8563B271104-807F
   Part No SW: 4F0 910 517 AD    HW: 4F0 614 517 AA
   Component: ESP8 quattro    H01 0060
   Coding: 0020840
   VCID: 66C3840A51FB5611F4C-8033
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Component: FBSAUDIC6 ELV   H31 0210
   Revision: 27120501    Serial number: 10601000438954
   Coding: 0000015
   Shop #: WSC 02323 785 00200
   VCID: 63C59D1EA2C92339132-8036
   Subsystem 1 - Part No: 4F0 910 131 L
   Component: FBSAUDIC6 KSG   H27 0080
   Subsystem 3 - Part No: 4F0 910 220 G
   Component: FBSAUDIC6 IDG   H01 0060
00190 - Driver's Door Handle Touch Sensor (G415)
                    Fault Status: 01111011
                    Reset counter: 168
                    Mileage: 116985 km
                    Date: 2015.02.21
                    Time: 13:10:18
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
   Part No SW: 4F0 910 732 Q    HW: 4E0 035 729
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 303EI067523381
   Coding: 0000003
   Shop #: WSC 02335 785 00200
   VCID: 31692756A8B5C1A9D1E-8064
   Component: Bedienteil MMIC6H02 0060
   Subsystem 2 - Serial number: 00000000427894
   Subsystem 3 - Serial number: 0129.05.060000000100010421ÿ
   Subsystem 4 - Serial number: 010421ÿ
                    Reset counter: 168
                    Mileage: 116985 km
                    Date: 2015.02.21
                    Time: 10:54:43
                    Reset counter: 169
                    Mileage: 117097 km
                    Date: 2015.02.23
                    Time: 08:14:16
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Reset counter: 40
                    Mileage: 116985 km
                    Date: 2015.02.21
                    Time: 11:08:12
Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
   Part No SW: 4F0 910 043     HW: 4F1 820 043 AC
   Component: KLIMABETAETIGUNGH20 0170
   Revision: 00000030    Serial number: 00000030128773
   Coding: 0524328
   VCID: 5BB5A5FE9AB91BF95B2-800E
                    Reset counter: 209
                    Mileage: 117396 km
                    Date: 2015.02.23
                    Time: 11:48:11
   Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
   Coding: 0113114
   VCID: 306F2252A3BFC8A1DE0-8065
   Subsystem 1 - Part No: 4F1 910 113 B  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0210
   Coding: 00064784
   Shop #: WSC 02335
   Component: REGENLICHTSENSORH12 0090
   Coding: 00146221
   Shop #: WSC 02335
                    Reset counter: 172
                    Mileage: 117700 km
                    Date: 2015.02.27
                    Time: 14:24:00
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBF8123477
   VCID: 1C37E6E2DF375CC1928-8049
Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
   Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
   Component: 64 AIRBAG AUDI8RH29 0300
   Revision: 14H29000    Serial number: 00359D0B7T4
   Coding: 0013876
   Subsystem 1 - Serial number: 6332CSME0F0A071D7
   Subsystem 2 - Serial number: 6342CSME0F22745C9
   Subsystem 3 - Serial number: 6352QSME0B4F2525L
   Subsystem 4 - Serial number: 6362QSME0E7B3E63-
   Subsystem 5 - Serial number: 63734SME0E62312D%
   Subsystem 6 - Serial number: 63834SME0E4E1223%
   Component: Lenksäulenmodul H07 0230
   Revision: 00H07000    Serial number: 90026061300597
   Coding: 0012141
   Part No SW: 4F0 910 930 C    HW: 4F0 920 931 T
   Component: KOMBIINSTR. M73 H18 0070
   Revision: 00000000    Serial number: 5HN39XP56
   Coding: 2113363
   Shop #: WSC 25984 067 57207
   VCID: 2345DD1EE2496339532-8076
Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
   Component: Gateway         H11 0070
   Revision: 11          Serial number: 130080651780C2
   Coding: 6CFE73CC1B7104
   Shop #: WSC 02334 785 00200
   VCID: 275DC90E96718F190FA-8072
                    Reset counter: 208
                    Mileage: 116985 km
                    Date: 2015.02.21
                    Time: 11:11:27
   Coding: 0082954
   VCID: 61C99716B8D5312901E-8034
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 D
   Component: MNS US          H48 1100
   Revision: 00000000    Serial number: 381EL067500194
   VCID: 387F1A724BCF10E1960-806D
   Component: TSG FA          H12 0120
   Revision: 00000000    Serial number: 2�c
   Coding: 0051947
   Shop #: WSC 02327 785 00200
   VCID: 2C5736228F97AC41E28-8079
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Component: Komfortgeraet   H22 0170
   Revision: 01700022    Serial number: 01013939150000
   Coding: 4618269
   VCID: 2E533C2AB98BDE51CCC-807B
   Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
   Component: DSP-High C6     H09 0240
   Revision: PROD_01     Serial number: 00000000001799
   Coding: 0000026
   VCID: 2541C306EC7D9D093D6-8070
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Revision:             Serial number: 00000000025408
   Coding: 0012014
   VCID: 5EB3ACEA89AB0ED13CC-800B
   Component: TSG BF          H12 0120
   Revision: 00000000    Serial number: “b
   Coding: 0051947
   Part No SW: 4F0 910 801 B    HW: 4F0 907 801 A
   Component: EPB  CB4C0060   H04 0060
   Revision: --H04---
   Coding: 0007022
   VCID: 1F4DD1EECE2147D977A-804A
   Coding: 0000016
   VCID: 2959CF368065B96919E-807C
   Subsystem 1 - Part No: 4F0 941 329 B
   Component: AFS-Modul links H02 0020
   Subsystem 2 - Part No: 4F0 941 329 B
   Component: AFS-Modul rechtsH02 0020
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 H
   Revision: 00000000    Serial number: 394EY067646219
   Revision: 00000000    Serial number: 00000000040273
   Component: von VA0  320910A192
   Coding: 344630393135313035442056413033323039313041313932
   Shop #: WSC 91520 999 85797
02272 - Quiescent Current Stage 1
            000 -  -  - Intermittent
                    Mileage: 116985 km
                    Date: 2015.02.21
                    Time: 10:53:45
                    Mileage: 116985 km
                    Date: 2015.02.21
                    Time: 11:00:11
02276 - Quiescent Current Stage 5
                    Mileage: 116985 km
                    Date: 2015.02.21
                    Time: 11:00:21
02274 - Quiescent Current Stage 3
                    Mileage: 116985 km
                    Date: 2015.02.21
                    Time: 11:00:31
                    Mileage: 116985 km
                    Date: 2015.02.21
                    Time: 11:00:41
   Coding: 0051754
   Component: SDS 3501 US     H45 0630
   Revision: 00000000    Serial number: 00000605160069
   Shop #: WSC 12336 024 394758
   VCID: 34672E4257A7F481BA8-8061
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Coding: 0051754
   Part No SW: 4F0 910 336 D    HW: 4E0 862 335
   Component: Handyvorb2      H13 0700
   Revision: 00000000    Serial number: 00000007530806
   Coding: 0010900
   VCID: 2447DE02E74764012A8-8071
End-------------------------(Elapsed Time: 02:45)--------------------------
LN-TAL
Norway
C?ID=13729
This might be a bit offset of your problem.
But 6 amps charger is NOTHING. I don't know how much juice your A6 needs from the battery. But I have a C-TEK MX25 charger which is able to switch to supply mode. The benefit of the supply mode compared to a charge mode is that the voltage is stable at 13,6V, as long as the charger can handle the current the car draws from the charger. On my audi A6 2012 with a lot of electrical systems, the car systems draws about 25-35 A from the battery when the ignition is on. What this means is that my charger which is able to supply 25A is actually a bit to small.
On my previous BMW 2006 5 series the current needed to supply the electrical systems with the ignition on was about the same, about 30 A. I don't know what audi says about power supply when updating control modules etc. But BMW says that you should connect a 70A (!) power supply. Thats probably (heavy) overkill, but that is what BMW officially says about this.
So I am sure that even with your 6A charger connected, the battery voltage will still drop after an hour or two. And I guess this update takes some time ? And as previously said, the charger will not supply a stable voltage to the system. The voltage can be anywhere between 10 and 15 volts.
I do not says that this is the problem, its probably not. But it is a reminder for all the people out there sitting in the car for hours (like myself) with the VCDS equipment and testing out long codings etc.
terrya6c6
Canada
C?ID=233251
Thanks, that is a good heads up. I will purchase a heavy duty charger. So far I have not had the need to sit for more than 20-30 minutes attempting an update or scan. I agree it does seem to be a heavy drain on the battery.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
VW official standpoint on chargers is pretty similar to BMW, for flashing VW requires at least a 70A charger. MMI updates do count as flashing. A regular Audi A6 (4F) pulls between 20-50A when the ignition is switched on depending on battery state and which control modules/systems are active. A 6A charger is indeed pretty much a joke at that point, better than nothing - sure - but nowhere near enough. The C-TEK MX25 wouldn't be my first choice either to be honest, I've done some checks using a decent oscilloscope and current clamps on those charges and most do not even reach the amounts claimed on their labels.
VW/Audi is sticking for example to Fronius chargers, yes they are expensive but they also deliver what they are supposed to. My older VAS 5900 (Fronius 25A) did reach it's limits on bigger models like the A6, the battery would slowly deplete - just while running standard diagnostics and demos on it. While their 70A solution is beyond reasonable - price wise - I ended up going with their 35A one and have been very happy with it.
That said, there is not straight forward guarantee that your issue was caused by an insufficient charger, the number of issues possibly related isn't exactly small. Using the wrong discs or reversing the order is the most common issue, after all - these are not updates a customer should even bother installing! Screw all the instructions you'll find in the forums, what you actually need is using is the instructions in TSB 2019334 but even then you wouldn't have even a fraction of the documents actually released by Audi on this subject.
- In order to look into this further, do you happen to have an auto-scan from the time prior to your attempt?
- What are the specific part numbers of the update CDs you have been using?
- A screenshot/photo of the exact error messages you're getting won't hurt either.
terrya6c6
Canada
C?ID=233251
The update files are 4F0998961_cd1 and 4F00998961_cd2
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Please answer all the questions.
Did you purchase these through Audi or did you download them somewhere and burn 'em on a disc?
terrya6c6
Canada
C?ID=233251
Hi Sebastian
I did purchase them online, they are not Audi discs, they are burnt copies. I compared them from files downloaded online they match.
The scan attached is before I attempted the update. I was able to run CD2 successfully, I just updated the CD changer to an AMI unit a couple of days ago. I still have the CD changer if I need to attempt flashing from CD1. My iphone does work in the car, I have to pair it each time I get in and the contacts import feature does not work. As for the screen image I will have to install the changer again to get one. From memory the screen would read error 152 from device. or sometimes error 156 from device or error 160 from device.
Thanks for the help.
Thursday,25,December,2014,13:53:39:40091
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
Mileage: 108930km-67685mi   Repair Order:
VIN: WAUEV74F17N007807   Mileage: 108930km-67685miles
   VCID: 2149D716F8557129405-8074
053248 - No Communication with Comfort System Control Module (J393)
               U1000 - 002 -  - Intermittent
                    Mileage: 107295 km
                    Temperature: 24.0°C
                    Temperature: 26.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
   VCID: 2A5B303A8563B27111F-807F
   Coding: 0020840
   VCID: 66C3840A51FB5611F57-8033
Address 05: Acc/Start Auth.        Labels: None
   VCID: 55A1B3C6BC9DCD896CD-FFFF
No Faults Found
   Part No SW: 4F0 910 731 F    HW: 4E0 035 729
   Component: Interfacebox    H43 2740
   Coding: 0000003
   VCID: 2541C306EC7D9D093CD-8070
                    Fault Frequency: 19
                    Reset counter: 155
                    Mileage: 107288 km
                    Date: 2014.10.17
                    Time: 14:48:04
00658 - Control Head
                    Reset counter: 155
                    Mileage: 107295 km
                    Date: 2014.12.04
                    Time: 16:07:58
                    Bin. Bits:      001
   Coding: 0524328
   VCID: 5BB5A5FE9AB91BF95A9-800E
   Coding: 0113114
   VCID: 306F2252A3BFC8A1DFB-8065
   Coding: 00064784
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
   VCID: 1C37E6E2DF375CC1933-8049
   Coding: 0013876
   Coding: 0012141
   Coding: 2113363
   VCID: 2345DD1EE2496339529-8076
   VCID: 275DC90E96718F190E1-8072
   Coding: 0082954
   VCID: 61C99716B8D53129005-8034
   VCID: 387F1A724BCF10E197B-806D
   Coding: 0051947
   VCID: 2C5736228F97AC41E33-8079
   Coding: 4618269
   VCID: 2E533C2AB98BDE51CD7-807B
01503 - Bulb for 3rd Brake Light (M25)
                    Fault Status: 00101001
                    Fault Frequency: 15
                    Reset counter: 140
                    Mileage: 106958 km
                    Date: 2014.07.15
                    Time: 17:29:27
   Part No SW: 4F0 910 223 F    HW: 4F0 035 223 F
   Component: DSP-High C6     H09 0190
   Coding: 0000026
   Coding: 0012014
   VCID: 5EB3ACEA89AB0ED13D7-800B
   Coding: 0051947
   Revision: --H04---
   Coding: 0007022
   VCID: 1F4DD1EECE2147D9761-804A
   Coding: 0000016
   VCID: 2959CF368065B969185-807C
                    Reset counter: 138
                    Mileage: 106952 km
                    Date: 2014.07.15
                    Time: 17:47:53
   Part No SW: 4E0 910 541 M    HW: 4F0 035 541 H
   Component: TUNER EU/US/RDW H42 0570
                    Fault Frequency: 48
                    Mileage: 107288 km
                    Date: 2014.09.29
                    Time: 18:09:06
                    Fault Frequency: 33
                    Mileage: 107288 km
                    Date: 2014.10.02
                    Time: 14:14:18
                    Fault Frequency: 26
                    Mileage: 107288 km
                    Date: 2014.10.16
                    Time: 13:32:04
                    Fault Frequency: 26
                    Mileage: 107288 km
                    Date: 2014.10.16
                    Time: 13:32:15
                    Fault Frequency: 26
                    Mileage: 107288 km
                    Date: 2014.10.16
                    Time: 13:32:25
   Coding: 0051754
   VCID: 34672E4257A7F481BB3-8061
   Coding: 0051754
   Coding: 0010900
   VCID: 2447DE02E74764012B3-8071
End-------------------------(Elapsed Time: 03:42)--------------------------
Thursday,25,December,2014,14:10:41:40091
VIN: WAUEV74F17N007807   License Plate: BPJ7391
                    Mileage: 107295 km
                    Temperature: 24.0°C
                    Temperature: 26.0°C
                    Voltage: 0.000 V
   Coding: 0020840
   Coding: 0000015
   VCID: 63C59D1EA2C92339129-8036
                    Reset counter: 100
                    Mileage: 106965 km
   Coding: 0000003
                    Fault Frequency: 19
                    Reset counter: 155
                    Mileage: 107288 km
                    Date: 2014.10.17
                    Time: 14:48:04
                    Reset counter: 155
                    Mileage: 107295 km
                    Date: 2014.12.04
                    Time: 16:07:58
                    Bin. Bits:      001
   Coding: 0524328
   Coding: 0113114
   Coding: 00064784
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
   Coding: 0013876
   Coding: 0012141
   Coding: 2113363
   Coding: 0082954
   Coding: 0051947
   Coding: 4618269
                    Fault Frequency: 15
                    Reset counter: 140
                    Mileage: 106958 km
                    Date: 2014.07.15
                    Time: 17:29:27
   Coding: 0000026
   Coding: 0012014
   Coding: 0051947
   Revision: --H04---
   Coding: 0007022
   Coding: 0000016
                    Reset counter: 138
                    Mileage: 106952 km
                    Date: 2014.07.15
                    Time: 17:47:53
                    Fault Frequency: 48
                    Mileage: 107288 km
                    Date: 2014.09.29
                    Time: 18:09:06
                    Fault Frequency: 33
                    Mileage: 107288 km
                    Date: 2014.10.02
                    Time: 14:14:18
                    Fault Frequency: 26
                    Mileage: 107288 km
                    Date: 2014.10.16
                    Time: 13:32:04
                    Fault Frequency: 26
                    Mileage: 107288 km
                    Date: 2014.10.16
                    Time: 13:32:15
                    Fault Frequency: 26
                    Mileage: 107288 km
                    Date: 2014.10.16
                    Time: 13:32:25
   Coding: 0051754
   Coding: 0051754
   Coding: 0010900
End-------------------------(Elapsed Time: 02:44)--------------------------
Zenerdiode
Newcastle, England
C?ID=24330
...they are not Audi discs, they are burnt copies.
I was waiting for this question. Thing is, if the burner that authored your discs has a wobbly laser, your PC's drive may be able to follow the wobble better than the drive in the car. That's why the two binaries check OK.
I know it's hindsight, but even in 'rip off Britain' the update discs from the dealer are only £6.12...! I had a 45A SMPS connected when I did mine, vacuumed the slot before putting the disc in and was wearing gloves to prevent fingerprints. :rolleyes:
If people are making money off these discs on t'internet, I'm in the wrong job again...
terrya6c6
Canada
C?ID=233251
Thanks I will contact a dealer and try and purchase a copy. It is worth having the phone system work properly if that is causing my issue.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Step #1 get a real charger, step #2 get real cds, step #3 follow the instructions in the TSB!
FWIW, the TSB states that Disc #1 needs to run TWICE before even attempting Disc #2. Something you seem not to have done either...
terrya6c6
Canada
C?ID=233251
I tried running Disc 1 many times following the instructions I had been sent with the files. I had read on one forum a person had similar issues running disc 1. He ran disc 2 successfully and was then able to run disc 1. I was able to install disc 2 as per the instruction but not disc1. I was not so lucky.
Sebastian, I do get your message. If following this to the letter works I will post. Thanks.
