A4 b8 Not starting
Runemnk
Norway
C?ID=217316
Hello.
My 2013 a4 b8.5 allroad 177hp wont start.
It stopped suddenly right outside my garage after work. No pre warning.
No dtc using full scan.
I just clicked on various modules and found i cant enter the immobilizer module. Is that normal? I could enter that on my older b6.
I get "no response from controller".
Runemnk
Norway
C?ID=217316
 Saturday,15,August,2020,14:57:34:52723
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4513.4
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 20 42 44 46 52 53 56 5F 62 69 6D
          72
VIN: WAUZZZ8K7EA044163   Mileage: 192550km-119645miles
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 KD    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H25 9977
   Revision: 45H25---
   Coding: 32194012243601080000
   Shop #: WSC 50080 002 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018KD 003004
   ROD: EV_ECM20TDI01103L906018JG.rod
   VCID: 76B5E014E84BE28B78F-8022
   Part No SW: 8K9 907 379 J    HW: 8K9 907 379 J
   Component: ESP8 quattro  H09 0050
   Coding: 06954401
   Shop #: WSC 06335 000 00000
   VCID: 49CF5BE8C9B5DD73C5D-801C
   Part No SW: 8K0 907 064 HG    HW: 8K0 907 064 GG
   Component: BCM2 2.0      H13 0641
   Coding: 03A24040000000000000
   VCID: 7CA1F23CD6E7B8DB0EB-8028
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0813000118394021
   Serial number: 0213000296073008
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 AJ    HW: 8K1 820 043 AJ
   Revision: C1000000    Serial number: 01270820131305
   Coding: 342002E000
   VCID: 70B9D60C8AAFCCBBA23-8024
   Revision: 08016001    Serial number: 00000671700701
   Coding: 2600C8118074AFC00081400300001D0D0F1C270826090201000008004400030100000020000000
   Shop #: WSC 06335 123 12345
   VCID: 78A9EE2CE2DF94FB6A3-802C
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA190713  H18 0461
   Serial number: 1307160707935
   Coding: 004577
   Serial number: 61885311
   Coding: 025028
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002008131229
   Serial number: 1F5881C6000000000001
   Serial number: 003KFDB1F2MG
   Coding: 30524435363030303030554A304C384B3053
   Shop #: WSC 60769 001 1048576
   VCID: 48C95EECD23F247BDA3-801C
   Serial number: 6334MSME7D1051066
   Serial number: 6344MSME7C704951J
   Serial number: 6352QSME42354C4AL
   Serial number: 6362QSME3C35374ET
   Serial number: 63732SME4A35326E3
   Serial number: 63832SME4A350658+
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20130830000638
   Coding: 000017
   VCID: 4FFB75F037D1F3439B9-801A
   Part No SW: 8K0 920 932     HW: 8K0 920 932
   Component: KOMBIINSTR.   H35 0563
   Revision: 00500000    Serial number: WWD6A3Y8E
   Coding: 038D290202010008010000
   VCID: 6C81C27CA687285B9EB-8038
   Component: GW-BEM 5CAN-M H11 0056
   Revision: 1Z110028    Serial number: 2841Z13812003F
   Coding: 80CF07FF00
   VCID: 4CC162FCC6C7C85BFEB-8018
   Serial number: 0975701103
   Serial number: 13239000783021200181
                    Reset counter: 184
                    Mileage: 192550 km
                    Date: 2020.08.14
                    Time: 17:53:02
                    Bin. Bits:    10111
                    Voltage: 12.70 V
                    Count: 6
   Revision: AA001002
   Coding: 02019164747464545425363E00
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000072580620
   Coding: 011C02204000410001
   Component: RCEPS         H38 0507
   Revision: 00001000    Serial number: 0024792797
   Coding: 100000000001
   Shop #: WSC 06334 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 34311A1CBEB7B09B86B-8060
   Revision: 00002001    Serial number: 0312880856
   Coding: 0100062820B930408120023680000047
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000072593593
   VCID: 4EC568F430DBFA4B90F-801A
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 30000000094551
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 392F2B2899D54DF355D-806C
   Part No SW: 4G0 035 056 H    HW: 4G0 035 056
   Component: Radio U STD   H60 0134
   Revision: AB001007    Serial number: 229H 0D7711075
   Coding: 010003020100000001
   VCID: 2615F05478EBD20B08F-8072
   Part No SW: 8R1 035 652 F    HW: 8R1 035 652
   Component: B-BN-EU       H62 0191
   Revision: --------    Serial number: 148H.0D7653330
   Coding: 01010001000681ED01802B4E000000030000
   VCID: 36352014A84BA28BB8F-8062
   Subsystem 1 - Part No SW: 8T0 919 604 A    HW: 8T0 919 604 A
   Component: DU6 Basic  H43 0098
   Serial number: 9465H/0D2667413
   Subsystem 2 - Part No SW: 8T0 919 611     HW: 8T0 919 611
   Component: E0380 Bedient  H01 0100
   Serial number: 00000001597288
                    Reset counter: 184
                    Mileage: 192550 km
                    Date: 2020.08.14
                    Time: 17:53:06
                    Voltage: 12.70 V
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000072215897
   Coding: 010C02204000210001
   VCID: 46D550D4D8AB320B28F-8012
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Revision: 1A001001    Serial number: 00000194125976
   Coding: 010D000000000000
   Shop #: WSC 25397 000 00000
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8K9827851A
   VCID: 3C21323C966778DB4EB-8068
   Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
   Component: J756  Slave  H52 0330
   Serial number: 8K9827852A
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000072215895
End----------(Elapsed Time: 01:32, VBatt start/end: 12.7V/12.7V)-----------
The energy management came now after trying to start, charging battery now.
Did you check battery connections and ground strap + alternator output?
Runemnk
Norway
C?ID=217316
It did not have the energy management code yesterday. It came today after trying to start many times.
I found in another forum that on the b8 the immo is in other modules. Not as a separate immo module
Runemnk
Norway
C?ID=217316
The immobilizer is built into the J393. So the immobilizer component responds on address 05 and the comfort/convenience component (BCM2) responds on address 46. Do you have a response on address 46? The fuses to the J393 are all in the right side of the cargo hold, in row 2, fuses 8, 10, and 11.
This is from audizine
Is this a mechanical issue and did you do basics like compression check or read RTFB yet?
Is your car modified?
Did you read your auto-scan?
Did you JPPSG yet?
