2003, Golf MK4 GTi. Random cutting out and refusing to start
Geelondon
London, UK
C?ID=396753
Hi all first off I hope I have the format for posting correct here.
I seem to have a car that will randomly cut out and refuse to start up. when attempting to start the car back up again its reluctant and requires gas pedal to the floor and continuous cranking.
the other issue I noticed was on some attempts there is just clicking and nothing more on trying to start it up. I have checked started motor etc and all is fine with there.
before I start swapping out the parts namely the N249 Valve or diverter valve is there any old hands that have experienced this issue and can shed light on any further tests.
many thanks in advance
VIN: WVWZZZ1JZ3W603278   Mileage: 272430km-169280mi
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
          76
VIN: WVWZZZ1JZ3W603278   Mileage: 272430km-169280miles
Address 01: Engine        Labels: 06A-906-032-AJQ.clb
   Part No: 06A 906 032 MJ
   Component: 1.8L R4/5VT     G   0003
   Coding: 11510
   VCID: 72A8FFE93CE999160D-5160
   WVWZZZ1JZ3W603278     VWZ7Z0C7509285
17608 - Boost Pressure Control Valve (N249)
            P1200 - 35-10 - Mechanical Malfunction - Intermittent
16502 - Engine Coolant Temp. Sensor (G62)
            P0118 - 35-00 - Signal too High
Readiness: 0000 1000
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 M
   Coding: 0019970
   Shop #: WSC 01271 785 00200
   VCID: 342439F1567DD726DF-5160
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 01271
   VCID: 210AC0A5A98F528E24-5184
00792 - A/C Pressure Switch (F129)
            35-00 - -
            37-00 - Faulty
   Part No: 1C0 909 605 A
   Component: 27 AIRBAG VW51 01   0008
   Coding: 12855
   Shop #: WSC 01271
   VCID: 2208CFA9AC8949963D-513C
Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
   Part No: 1J0 907 487 B
   Component: Lenkradelektronik   0002
   Coding: 00008
   Shop #: WSC 01271
   VCID: 302C35E1F265EB06BB-5160
   Part No: 1J0 920 946 A
   Component: KOMBI+WEGFAHRSP VDO V13
   Coding: 21414
   VCID: 2A182789D4B991D675-513C
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 01271
   VCID: 70ACF5E132E5AB06FB-513C
   Part No: 1C0 959 799 B
   Component: 1X Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 01271
   VCID: 362003F91001C536E1-4B1E
   Subsystem 1 - Part No: 1C2959802A
   Component: 1X Tõrsteuer.FS KLO 0009
   Subsystem 2 - Part No: 1C2959801A
   Component: 1X Tõrsteuer.BF KLO 0009
   Component: 1X Tõrsteuer.HL KLO 0009
   Component: 1X Tõrsteuer.HR KLO 0009
            27-00 - Implausible Signal
End----------(Elapsed Time: 04:47, VBatt start/end: 12.3V/12.3V)-----------
TFSI
Maryland, USA
C?ID=66650
I can see G62 fault logged in your diagnosis...your problem sounds like over-enrichment or falsified air/fuel ratio caused by false engine temperature reported. If possible disconnect the G62 sender and retry or replace it, clear fault memory and recheck start-ability or post fresh scan.
Jef
HQ
If the starter isn't trying to engage, are you sure there is nothing wrong with it? How is the cable to comes off the battery to the starter? How is the Terminal 50 path for the starter (wiring rot, ignition switch melting)?
Also make sure ground points are good. Cable that bolts to top of transmission good. Ground points under battery tray. Ground point in plenum chamber. Odds are there is a ground point at the steering column and also ground points at the base of the A-pillars.
Geelondon
London, UK
C?ID=396753
I do have a temp switch on order so will give this a try .
what are your thoughts on N249 by pass ?
Geelondon
London, UK
C?ID=396753
I have checked all earth points the gear box one was in poor state in fact just about holding on this has been replaced already but the problem still persists. will check the other points you mention thank you
ai_Ingo
Germany (Auto-Intern)
C?ID=56975
There may be 2 failures or a cause with 2 effects. Like Jef said, it can be a bad ground. I think the screw connection is under the battery and on the gearbox.
Take a jump start cable, connect it to battery minus and the motor housing. So you can quickly make a diagnosis. Is the engine turning now? Second, there is the G62 temperature sensor, as described by TFSI. If the measured value deviates significantly from the actual value, the mixture is too rich, so that the engine only starts with gas and stutters, usually with a clearly black smoke. or on the other hand so lean that it doesn't start.
Remove the connector from the sensor, the control unit should use a substitute value.
Fred's Imports
Vermont, USA
C?ID=16454
ECM defaults to -35C when the coolant temp sensor G62 goes open, just replace it. You can check the ECM freeze frame for this.
Check for bad battery as when voltage drops below 10 or so while cranking the starter relay can drop out causing your problem. A starter that draws too much amperage will also cause the primary circuit to drop out.
ai_Ingo
C?ID=56975
Basically I agree with you, I've already seen -35 degrees. But this is a Bosch MED 7.5 system and I'm pretty sure that there is a substitute value for the temperature. Please have a look here: https://vwts.ru/forum/attachments/75039/
Page 67, there the strategy is described. But please, it's just my opinion, I can be wrong about that too.
