2014 Audi S4 MMI issue
brosa2064
C?ID=404843
I started my car one day with no prior issues whatsoever and had no MMI. Screen was black from the start didn't come on and then turn off, no buttons on the control panel had lights. Tried the 3 button reset and i can hear the MMI head unit make a sound but nothing. The back up camera sensor still works as i will hear beeping when backing and getting close to something. At first i thought it was a energy management issue cutting power to non vital devices and also thought i had a parasitic drain. I bought a new battery coded it and i no longer get the energy management active code or any of the voltage codes i used to get. I bought a used MMI head unit thinking that was it but put it in and didn't turn on. When i plug in the big plug on the MMI I can hear it turn on. When i was having an issue 5F could not be reached, sound system could not be reached, radio could not be reached, and had a CAN gateway error with an open optical circuit. Right after installing the new unit i cleared codes and ran a scan and got no codes that i wouldn't have expected( i took out the acoustic fuse so i have that error). So i thought i was making progress, i ran an optical bus scan and I've gotten mixed results. Sometimes ok sometimes not. I've also hooked up an optical loop in the trunk to the amp and whatever is next to the amp with no change. One thing i have noticed when unplugging the optical on any component is that when i wake up the car the red light blinks for about 10 seconds then i see no lights at all. Doesn't matter even if the car is running the lights stop blinking after a bit, not sure if that is normal?? After the unit had been installed a while i ran a scan and the the same codes came back in, MMI components could not be reached. Not sure if the control panel is a potential issue, but i know how much it can cost just trying to diag a problem like this. I put the old unit back in and also heard it wake up when i plugged it in. I also got similar code results. When i first plugged it in and ran a scan it didn't produce any unknown errors. But after a while the codes came back on the old unit as well. I will add the scans below.
VIN: WAUBGAFLXEA134413   License Plate:
Mileage: 142240km-88383mi   Repair Order:
Gateway Installation List:  8R0 907 468 P
A9-Struct. Borne Sound -- Status: Cannot be reached 1100
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 36 3C 42 44 46 47 52 53 56
          5F 62 6C 72 A9
VIN: WAUBGAFLXEA134413   Mileage: 142240km-88383miles
5F-Information Electr. -- Status: Cannot be reached 1100
Address 01: Engine (J623-CTUB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 G    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0007
   Revision: --H07---
   Coding: 0A250034052600060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551G 001007
   ROD: EV_ECM30TFS021_AU48.rod
   VCID: 3A2D37BDCCD8BD1B5DF-806E
Readiness: 1110 1101
   Part No SW: 8K5 927 156 D    HW: 0B5 927 156 K
   Component: 0B5 30TFSINAR H02 0005
   Revision: --H02---
   Coding: 000001
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001025
   ROD: EV_TCMDL501021.rod
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 291D1A01
   VCID: 094F9871D93E6683045-805C
   Part No SW: 8K0 907 064 JM    HW: 8K0 907 064 JM
   Component: BCM2 2.0      H14 0650
   Coding: 0D814040000000000000
   VCID: 04518945FE1C3BEB773-8050
   Serial number: 0214000044179002
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01140320140465
   Coding: 6600228000
   VCID: 392F28B1C95EB603545-806C
   Revision: 08016001    Serial number: 00000774300801
   Coding: 26000011863CAFE0210048C300003D0D0F9CD308A2090221000008004000030100000030000000
   Shop #: WSC 06325 123 12345
   VCID: 78A9EDB5B2D46F0B6BB-802C
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA170214  H18 0461
   Serial number: 1402140705554
   Coding: 004577
   Serial number: 22368802
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000803140989
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555RA94W03
   Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: A6A9C917000000000001
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003KJDC02ANG
   Coding: 303844354730303030304A55304C384B3053
   Shop #: WSC 59013 001 1048576
   VCID: 4ACD677D9C382D9BCDF-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R140000HZ69
   Serial number: 6334MSME450A4101+
   Serial number: 6344MSME450A223EE
   Serial number: 6352QSME634032465
   Serial number: 6362QSME2B405174C
   Serial number: 63732SME613D1F7AC
   Serial number: 63832SME76402F540
   Revision: --------    Serial number: 90372NCC0005M
   Coding: 000036
   VCID: 44D14945BE9CFBEB373-8010
   Part No SW: 8K0 920 983     HW: 8K0 920 983
   Component: KOMBIINSTR.   H35 0564
   Revision: 00100000    Serial number: ZAI55RC3F
   Coding: 8BB709008301D705020000
   VCID: 72BDDF9DD4A8055B55F-8026
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z1430403F9
   Coding: 80C303FF00
   VCID: 4CC1616596CC33ABFF3-8018
   Serial number: 5179422703
03619 - Control Module for Structural Accoustics
                    Reset counter: 179
                    Mileage: 142240 km
                    Date: 2020.07.30
                    Time: 22:58:09
                    Bin. Bits:    10111
                    Voltage: 12.20 V
                    Count: 6
                    Bin. Bits:    00000
                    Time: 16.30 s
                    Reset counter: 179
                    Mileage: 142240 km
                    Date: 2020.07.30
                    Time: 22:59:04
                    Bin. Bits:    10111
                    Voltage: 12.20 V
                    Count: 6
                    Bin. Bits:    00000
01304 - Radio
                    Reset counter: 179
                    Mileage: 142240 km
                    Date: 2020.07.30
                    Time: 22:59:04
                    Bin. Bits:    10111
                    Voltage: 12.20 V
                    Count: 6
                    Bin. Bits:    00000
03158 - Control Module for Information Electronics 1 (J794)
                    Reset counter: 179
                    Mileage: 142240 km
                    Date: 2020.07.30
                    Time: 22:59:04
                    Bin. Bits:    10111
                    Voltage: 12.20 V
                    Count: 6
                    Bin. Bits:    00000
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H14 0100
   Serial number: 000103140001973
   ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
   VCID: 2F3B16E9079A68B3FA1-807A
   Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
   Component: MEM-FS        H06 0077
   Revision: AA000000    Serial number: 00000093975974
   Coding: 00581B00000000000000
   VCID: 3B2332B9C3628413469-806E
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Component: SWA Master    H05 0071
   Serial number: 0328261936
   Coding: 010211
   Shop #: WSC 06324 000 00000
   VCID: 3FDB46A9D7FA98336A1-806A
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0328830499
   Coding: 010211
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 011C13204E00410001
   VCID: 56F5830D5800797B597-8002
   Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
   Component: RCEPS         H40 0508
   Revision: 00001000    Serial number: 0008374499
   Coding: 100000010001
   ASAM Dataset: EV_RCEPSAU48X 008015
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 35372481E5C65263B0D-8060
   Revision: 00002001    Serial number: 0329456385
   Coding: 0106023A00FA400580B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000810842
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
Address 47: Sound System
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   VCID: 55F784014506726350D-8000
   Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
   Component: EPB-4         H01 0005
   Revision: --------    Serial number: 20000000418149
   ROD: EV_ParkiBrake_AU48.rod
Address 56: Radio
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0305
   Coding: 010C13204000210001
   VCID: 59EF8831291E5603745-800C
   Revision: --H09---    Serial number: 525PA8-J4292BH
   Coding: 1000006
   VCID: 38292DB5FE54AF0BABB-806C
   Component: TSG HR        H07 0305
Address A9: Struct. Borne Sound
End----------(Elapsed Time: 01:38, VBatt start/end: 12.3V/12.3V)-----------
This is my typical scan
Mileage: 140400km-87240mi   Repair Order:
          5F 62 6C 72 A9
VIN: WAUBGAFLXEA134413   Mileage: 140400km-87240miles
   Revision: --H07---
Readiness: 0010 0001
   Revision: --H02---
   Coding: 000001
   Coding: 291D1A01
02214 - Tire Pressure Warning
                    Reset counter: 66
                    Mileage: 138634 km
                    Date: 2020.04.13
                    Time: 08:43:47
                    Hex Value: 0x4000
                    Hex Value: 0x4006
                    Hex Value: 0x1221
                    Hex Value: 0x1CB3
                    Hex Value: 0x0000
   Coding: 6600228000
   Coding: 26000091863CAFE0210048C300003D0D0F9CD308A2090221000008004000030100000030000000
   Coding: 004577
   Coding: 02005D
   Coding: 000036
   Coding: 80C303FF00
                    Reset counter: 241
                    Mileage: 139154 km
                    Date: 2020.05.18
                    Time: 01:20:14
                    Bin. Bits:    10111
                    Voltage: 11.80 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
00384 - Optical Databus
                    Reset counter: 6
                    Mileage: 139412 km
                    Date: 2020.05.31
                    Time: 02:52:02
                    Bin. Bits:    10000
                    Voltage: 12.00 V
                    Count: 9
                    Bin. Bits:    00000
   Coding: 010211
   Coding: 010211
131840 - Switch for Electric Parking Brake
          C100C 13 [008] - Open Circuit
Address 56: Radio
   Coding: 1000006
and different optical scans
Mileage: 142040km-88259mi   Repair Order:
Control Module Part Number: 8R0 907 468 P
  Component and/or Version: GW-BEM 5CAN-M H11 0060
Optical Bus Diagnostic : Standard
Controller          	Electrical          	Optical
19-CAN Gateway      	OK                  	OK
5F-Information Electr.(High/D3)	OK                  	OK
47-Sound System     	OK                  	OK
56-Radio            	OK                  	OK
Standard optical shows the same but in the past i have gotten errors on the optical scan....
