2013 C7 Audi A6 DSR disable codes?
AudiBahncruiserA6
C?ID=411438
Could anyone guide me to disabling DSR (Driver steering recommendation) on my C7 A6 2013 without throwing the consequential fault codes? I changed the coding on System 44 steering assist from 101000010000 to 001000010000 and the car threw an engine code and an ABS code, as well as illuminating the TPMS warning inside the car. I will be including a health check from VCDS. If you could help me out and tell me if there's another module that needs different coding along with having DSR disabled, or another step that needs to be taken to not have these codes thrown, I'd appreciate it!
Address 01: Engine (J623-CTUA)       Labels: None
   Part No SW: 4G0 907 551 D    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0006
   Revision: --H07---
   Coding: 0A2A0032052601060000
   ASAM Dataset: EV_ECM30TFS0214G0907551D 001007
   ROD: EV_ECM30TFS0214G0907551D.rod
   VCID: 2A0D06A25C7F7AAB2DF-807E
6201 - Function Restriction due to Faults in Other Modules
          U1113 00 [101] - -
                    Mileage: 158548 km
                    Date: 2020.07.22
                    Time: 10:46:43
                    Engine speed: 1283.00 /min
                    Normed load value: 32.5 %
                    Coolant temperature: 24 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 10.866 V
                    Engine speed: actual: 1280 /min
                    MAF_ENVD: 272.35293 mg/stroke
                    Coolant temperature (unfiltered): 24.75 °C
                    Engine: operating status: IS
                    Engine load: 32.421875 %
                    Vehicle speed: actual: 0 km/h
Readiness: 1110 1101
   Part No SW: 4G1 927 158 A    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H16 1006
   Revision: --H16---
   Coding: 000002
   VCID: 2D070DBE6D916D93C8D-8078
   Coding: 44A78F0122E5F1805B00
   VCID: 363522D298C72E4BB97-8062
0788 - Control Module Incorrectly Coded
          U1014 00 [137] - -
          [VarECUDSRVariantCodingIncorrect]
                    Reset counter: 193
                    Mileage: 158548 km
                    Date: 2020.07.22
                    Time: 10:46:43
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 0F
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: AA
                    Uz: 96
   Part No SW: 4H0 907 064 DR    HW: 4H0 907 064 CR
   Component: BCM2 2.0      H32 0510
   Coding: 0DA82046000000000000
   Shop #: WSC 08138 001 1048576
   VCID: 7CA1F0FAE6EB341B0F3-8028
   Serial number: 2312000096364016
   Part No SW: 4G0 820 043 AH    HW: 4G0 820 043 AH
   Component: KLIMA 2 ZONEN H11 0070
   Serial number: 25051200110826
   Coding: 6601201849
   ASAM Dataset: EV_AirCondiBasisUDS 002040
   VCID: 6597B59E75E195D3C0D-8030
   Revision: 11012002    Serial number: 00000001301768
   Coding: 06002091063C9FE08100088380003908CF9CD208A6090221000004406000
   VCID: 6FBBD7B6A79D5F83BA1-803A
   Component: WWS57X 120428  H35 0080
   Serial number:         120503232016
   Coding: 0045F7
   Serial number: 20286388
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
   Component: E1 - LDS  H07 0044
   Serial number: 17 05 2012  00001799
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R1RB702
   Subsystem 5 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Serial number: 84088A26000000000001
   Part No SW: 4H0 919 475 AG    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0072
   Revision: 11001001    Serial number: 61061213800487
   Coding: A8C305
   ASAM Dataset: EV_EPHVA18AU57X0000 003008
   VCID: 77ABEFD6DF4D1743621-8022
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H32 0032
   Revision: --------    Serial number: 003D80023N3C
   Coding: 303234373131303030314A55304C34473053
   VCID: 33331BC68BB53B639E9-8066
   Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
   Component: BF-Gewichtss.  H11 0045
   Serial number: 6940000Y120000E4C707
   Serial number: 3575HRB405P1BBH490QG
   Serial number: 3585HRB405J1D5MS3GBV
   Serial number: 3515JRB405F197FG18T9
   Serial number: 3525JRB4057197FGJGFE
   Serial number: 3554VRB400I4UE20A253
   Serial number: 3564VRB400I4UE20QHUH
   Revision: 00000000    Serial number: 20120524000347
   Coding: 000014
   VCID: 303914CA7A23007BE3B-8064
   Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
   Component: E221 - MFL  H09 0009
   Part No SW: 4G8 920 983 E    HW: 4G8 920 983 E
   Component: TBenUsa       H79 0515
   Revision: 28460207    Serial number: 658220512596000
   Coding: 0BE609040B41D705020000
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU57.rod
   VCID: 372B2FD69FCDD743A21-8062
   Part No SW: 4G0 907 468 AB    HW: 4G0 907 468 AA
   Component: J533--Gateway H10 0028
   Revision: --------    Serial number: 00000000532195
   Coding: 00CD073000
   ASAM Dataset: EV_GatewPkoUDS 001013
   VCID: 70B9D4CABA23407BA3B-8024
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790906776
   Voltage stabilizer:
   Serial number: 070212000000000006E5
   Revision: AA000000    Serial number: 00000029950718
   VCID: 77ABEFD6DFCD1743621-8022
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0009
   Revision: --------    Serial number: EJ1BPA42050WC60
   ASAM Dataset: EV_SARA 009017
   ROD: EV_SARA_009.rod
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH01 0040
   Revision: 00H01000    Serial number: 6PZ 010 287-03
   VCID: 303914CA7623007BE3B-8064
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H01 0040
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F23.05.1200H010003CF27241ÿ
   Subsystem 4 - Serial number: F27241ÿ
   Component: TSG FA        H03 0506
   Coding: 011F17005E00628002000012
   VCID: 47CB5F16EFADA7C3D21-8012
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0016586405
   Coding: 001000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D1EC274AF326B95F-8066
   Revision: 00002001    Serial number: 0177096776
   Coding: 0106023A00FA418580B00804020503070000000000000000000000000000
   Shop #: WSC 26158 444 109201
   Component: GTO BF  H01 0080
   Serial number: 00000000000000086895
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO16614967
   Coding: 101F00
   Revision: CJ007001    Serial number: 00000000055255
   VCID: 1D67DD7E1DB19D1358D-8048
   Component: TSG BF        H03 0506
   Coding: 011F17005E00628002000002
   VCID: 46D55212E8A7BECB297-8012
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000351943
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B0303A6538563A3D69-807E
   Serial number: 120522-0001-006
   Coding: 1221A6101002A500
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2C0100BA568B649BDF3-8078
   Part No SW: 4G0 035 082 D    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0112
   Revision: AB001007    Serial number: 156E50C7598176
   Coding: 020007010000000001
   VCID: 211FE18E21C9B9F37C5-8074
   Part No SW: 4G0 035 746 B    HW: 4G0 035 746 B
   Component: H-BNT-NA      H49 0549
   Revision: --------    Serial number: 194EY0C7500753
   Coding: 050200000003E0EF55128B3E00000003100001000000000000
   VCID: 2615F29248E75ECB097-8072
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Serial number: AUZ8ZDC9401MLSD
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Serial number: 90349LEO001CM
   Subsystem 4 - Part No: 8R0 060 961 D
   Component: CD-Database  4353
   Component: TSG HL        H03 0506
   VCID: 49CF592EF9B951B3C45-801C
   Revision: --H06---    Serial number: 525 PA8J24G5IW
   Coding: 1080004
   VCID: 2615F29244E75ECB097-8072
   Component: TSG HR        H03 0506
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: 313F11CE71A90973EC5-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
End----(Elapsed Time: 02:15, VBatt start/end: 12.1V/11.9V. VIgn 11.9V)-----
